Unable to install Pega Platform
Hi Team
I am not able to install the Pega platform 8.23 edition and getting the following error message.
Engine Load Inner: [echo] Calling engine load utility... [java] Exception in thread "main" com.beust.jcommander.ParameterException: Only one main parameter allowed but found several: "install" and "PegaRules" [java] at com.beust.jcommander.JCommander$MainParameter.addValue(JCommander.java:104) [java] at com.beust.jcommander.JCommander.parseValues(JCommander.java:789) [java] at com.beust.jcommander.JCommander.parse(JCommander.java:363) [java] at com.beust.jcommander.JCommander.parse(JCommander.java:342) [java] at com.pega.codeloader.MainKt.main(Main.kt:43)
BUILD FAILED C:\New folder\117667_Pega_23.1.1\scripts\setupDatabase.xml:541: The following error occurred while executing this line: C:\New folder\117667_Pega_23.1.1\scripts\setupDatabase.xml:2608: The following error occurred while executing this line: C:\New folder\117667_Pega_23.1.1\scripts\setupDatabase.xml:231: Java returned: 1 How to fix this issue?
