Cognizant
Last activity: 21 Mar 2024 8:15 EDT
Send Email is not sending email to my email ID.
Hi,I have a requirement to send email after completion of a case to the customer.However even after using Send Email step I am not receiving emails to my email ID.
Attached screenshot of the configuration.
Maantic Inc
Do you have any custom Email account set? If yes, can you share the details?
Maantic Inc
Are you on Pega Cloud? Can you check if your organization's firewall is filtering those emails out? Do you see errors coming in tracer?
Bits in Glass
@TanyaS58 you need to create an email account instance with your work pool name to send outbound email. Please create an email account and check if email is being sent.
Tanya Singh
Cognizant
@Anoop Krishna by default pega has a default email account created Proprietary information hidden and I want to send an email to my outlook email account from this account so i will have to create an email account for my outlook then?
@TanyaS58 The default (Email account rule) will not be working you can check that by performing test connectivity it will show result as fail You need to configure a working email account rule in your platform for sending correspondence or Email using a send E-mail step (please make sure the test connectivity is success) please find the below document that helps you configuring a working Email Account rule in your platform Thank you !
Cognizant
@Manojkumar_ J I have created one email account but i want to know how to override this with the default email.
@TanyaS58using Send email step will not help here please use a activity step in the flow action (utility shape) and in the step "Call SendEmailNotification" and specify the parameters in the dropdown of the step( you can specify the email account that you are going to use in the pyNotifyAccountName ) property and also specify the 1.To address (to make it dynamic specify the property through which you are getting the receivers email ID ) 2.Subject 3.Message 4.Password(sender) 5.SMTP host (from the email account rule-sender) 6. SMTP port (from the email account rule-sender) This will help you send email the email using the account that you configured Thank you !
S MANOJ KUMAR REDDY
Cognizant
@Manojkumar_ J i will try this approach once as I was not passing the entire parameters in this activity
Cognizant
@Manojkumar_ J I tried this approach however the activity is failing since I am using outlook so SMTP host and SMTP port are not required however ,even in the To email if I enter the my outlook mail ID its not working.Even running the activity stndalone is not working.
Pls refer the below screenshots:
Cognizant
@Manojkumar_ J I did that as well but I feel its having Status as Fail(on test connectivity) so its not working.
Cognizant
@Manojkumar_ J and apart from this even the To parameter is mandatory so there also its not accepting my outlook mailid.
@TanyaS58And also any specific reason for using MS graph as a service can you use the SMTP for the sender IMAP for the receiver please find the below images that i used to configure it and it ran successfully for me
Cognizant
@Manojkumar_ J I am using MS Graph as my official mail id is Outlook and for that i need Graph API
@TanyaS58 I have tested the above scenario with a outlook mail only and used SMTP as my server can you also try that the host and port will be set default by pega
Tanya Singh
Cognizant
@Manojkumar_ J for outlook how to get the user ID and password
@TanyaS58The User ID will be same as your outlook email ID and the password will be your outlook account password in the receiver side please select "use senders ID and password" this will fill the receiver details as well and perform test connectivity Thank you !
Cognizant
@Manojkumar_ J Thanku I iwll follow this approach
Cognizant
@Manojkumar_ J Unfortunately when I tested the connectivity for receivers end I got failure status and as well while sending email using the activity in a utility I got an exception in tracer as well.Attaching the screenshot.Kindly suggest what change do i need to make.
@TanyaS58 I suggested you to configure the sender with SMTP host but from the attachment i am still seeing you are using the MS graph API can you please use SMTP instead for the sender and IMAP for the receiver
follow the step in the document and let me know if the account connectivity is good Thank you !
Updated: 21 Mar 2024 0:38 EDT
Cognizant
@Manojkumar_ J I am using SMTP and IMAP i feel the old screenshot i have attached.
Plz find the correct attachment.
@TanyaS58 Any issue in the test connectivity if yes, please attach the error message both in the sender and the receiver section Thank you !
Cognizant
@Manojkumar_ J only in the receiver end we have error.
@TanyaS58I think that is because of the DSS mentioned in the SS you attached can you please set the "DisableStartTLS" to false, I Think that is blocking the TLS connection from the receiver please let me know if you able to get successful in the test connectivity at the receiver section ! Thank you !
Did you perform a Test Connection for both Send/Receive to ensure the email account is successfully connected to the exchange server?
If yes, please test during the case workflow and check Pega logs for more information to understand the root cause.
Cognizant
@Manojkumar_ J How did you get the user ID and password details?
Updated: 15 Mar 2024 5:42 EDT
Evoke Technologies
@TanyaS58Could you cross-verify the status of the Pega Default email if you are using that to send an external email, if the status displays failure then you will have to configure a new email account using the wizard and select Microsoft Office 365 as the provider for sending a correspondence or Email template using the send E-mail step.
Cognizant
@RoshanRajAK yes the default email is failing however I have created an email account but i need to know where can we change the configuration so that by default mails are being send from my email account and not the default one.
Evoke Technologies
@TanyaS58 What is the type of email you are using for the configuration? Is it a Gmail Mail address or an Outlook Mail Address?
Cognizant
@RoshanRajAK outlook
Evoke Technologies
@TanyaS58 If the config is for your company's outlook mail , do check with your IT team since microsoft outlook has few blockers installed and you need to register a new set of credentials for the connection status to be successful. Also what port are you currently using for your configuration?
Cognizant
@RoshanRajAK even my configured email account is showing status connectivity as Fail
Maantic Inc
It is possible that your organization's firewall is preventing it.
Bits in Glass
@TanyaS58 you need to have an actual email id to send email from pega and with that email id you need to create an email account instance in pega application. This email id and email account is to send email from pega, meaning pega requires an email id to send email.
You will be receiving email from this email id which you have used to create email account in pega.
Marije Schillern
Vodafone Group
@TanyaS58 Go through the following contents from Pega Academy to send email from cases:
https://academy.pega.com/topic/sending-automatic-emails-cases/v1
@TanyaS58 i implement send email use case a lot in client projects.
* Normally i would check that an Email Account is set up and tested connectivity successfully.
* Ensure that the agent/JS responsible for sending email is running.
* You could just run OOTB SendEmailNotification activity with parameters to unit test. Trace and see if any error. I have an article that uses the activity (https://support.pega.com/discussion/attach-excel-file-email). I believe SendSimpleEmail activity can be also used to quickly test.
Tanya Singh
