Patient advocate foundation
Last activity: 8 Mar 2024 9:16 EST
How to convert Pega rules LOG to JSON format ?
I have done a POC regarding Log management using ELK Stack.
I have converted pegarule.log to pegarules.JSON.log using JSONAppender in the server itself
I am using pega version 8.6
In the server we have prlog4j2.xml i have added the given appender below pegarules.log
<RollingRandomAccessFile name="JSONAppender" fileName="${sys:pega.logdir}/PegaRULES.json.log" filePattern="${sys:pega.logdir}/PegaRULES-%d{MM-dd-yyyy}-%i.json.log.gz"> <LogStashJSONLayoutPega/> <Filters> <!--Deny message logged under ALERT log level--> <ThresholdFilter level="ALERT" onMatch="DENY" onMismatch="NEUTRAL"/> </Filters> <Policies> <TimeBasedTriggeringPolicy /> <SizeBasedTriggeringPolicy size="250 MB"/> </Policies> <DefaultRolloverStrategy max="20"/> </RollingRandomAccessFile>
Instead of using Logstash to process the logs i directly converted the logs to JSON (which is more readable) and stored in Elastic search.
Ajay Raghul.S
