CI
Last activity: 4 Jan 2024 7:43 EST
In Navigation Rule i used page list , Facing Same issue.
Hi Guys,
In Navigation rule i used item list for page list. But when I call any action on that item list, back end it's not run. In tracer also blank. Please help me how to resolve and how to configure.
Thank in Advance!
Updated: 4 Jan 2024 7:43 EST
NCS Pte. Ltd
SG
Hi @kirti: I think this is a context issue for you. Can you try adding the run Data transform action in the actions followed by refresh section?
Thanks.
NCS Pte. Ltd
SG
Hi @kirti: Hope you are able to see the navigation items in the runtime. If so, can you please help to share what is the action you defined in the navigation rule?
Also are you able to check the logs to see if there are any exceptions?
Thanks.
CI
In navigation rule Items action i able to see. But when I used item list action like "refresh the section",i can put set value or run active or run data transform. whatever I put in action it's not run in back end.
Item list tab I gave page list name and property name.
Activitylist item onliclick one actvity will run.
- Operation itemList
contact item
Amount item
If we have 2 operations
That item list shows like below
operation 1
contact
amount
Operation 2
contact
amount
Here i am facing issue every thing set in pyworkpage not in pagelist page .
NCS Pte. Ltd
SG
Thanks.
CI
CI
NCS Pte. Ltd
SG
Hi @kirti: Thanks for the info. In this configuration, what is the expectation when you click on the Operation Name and what is the expectation when you click on Contact and amount?
Can help to share the action configuration of each?
Thanks.
Accenture
CI
On ActivityList Label we have to run one activity.
Based up on that activity we have analyze how many operations in that case. that stores in one page list page.
on operation name we used item list called above page list .
contact and amount also under page list only.
I am facing issue here is everything will be set in PowerPage not in page list
