Accenture
Accenture
Accenture
Posted: Dec 13, 2023
Last activity: Feb 1, 2024
Last activity: 1 Feb 2024 1:10 EST
ABAC property Encryption
We are trying to implement ABAC on a few existing properties using property encrypt whereby Key will be saved in AWS KMS.
We have a few tables in the system which are commonly used by the application as well as external technologies (ETL/AWS Glue) for both read and write operations.
- If an external system is writing into a common table (unencrypted value), and application assign the value to one of the encrypted properties, will the value be encrypted once viewed from clipboard/tracer/logs?
- Is there any way that the external technology can implement the decrypt function from Pega while reading from the db during processing data from the table/generating reports.
***Edited by Moderator Rupashree to add Capability tags***
