Issue when using Header freezer in Table Layout
We are using a table layout in a section where we are freezing the header when we are scrolling down to see the records, But we are facing the issue where when there is a single record the table should resize itself but it is showing blank space below the record and the UI doesn't look good. Is there any Solution for this?
***Edited by Moderator Rupashree to add Capability tags***
