Endeavour Energy
Last activity: 11 Sep 2023 4:09 EDT
java.lang.NoClassDefFoundError: com/pega/apache/log4j/spi/ThrowableInformation at com.pega.apache.log4j.spi.LoggingEvent Error
Lately in production, we are seeing the issue where case integration is failing with below error:
java.lang.NoClassDefFoundError: com/pega/apache/log4j/spi/ThrowableInformation at com.pega.apache.log4j.spi.LoggingEvent.<init>(LoggingEvent.java:155) at com.pega.apache.log4j.Category.forcedLog(Category.java:391) at com.pega.apache.log4j.Category.error(Category.java:322) at com.pega.pegarules.priv.LogHelper.error(LogHelper.java:1351) at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3521) at com.pegarules.generated.activity.ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.step7_circum0(ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.java:1002) at
Cannot see anything wrong in logs as such, if we try to integrate the same case from other node, it is successful. We restarted the affected node and we havent seen that issue post that on the affected node.
But again, when restart of nodes happened, issue start to be appearing again
