Configuring Pega logs for ECS Formatting
We are migrating our Pega Application(V 8.6.1) which is currently running as a Weblogic on Oracle DB setup to Openshift Container(on same Oracle DB). We are trying to configure ECS formatting(https://www.elastic.co/guide/en/ecs-logging/java/current/setup.html) for logs. We added logback-ecs-encoder and ecs-logging-core jars to class path. Then updated EcsLayout to /pega/config/deploy/prlog4j2.xml. Just need to know where do we need to add the dependency. Can someone help with the same?
<dependency>
<groupId>co.elastic.logging</groupId>
<artifactId>log4j2-ecs-layout</artifactId>
<version>${ecs-logging-java.version}</version>
</dependency>
@Jey2705
We came across the note that jars would suffice and don't need of dependency. so we are attempting the same. Thanks!
If you are not using a dependency management tool, like maven, you have to manually add both
logback-ecs-encoderandecs-logging-corejars to the classpath. For example to the$CATALINA_HOME/libdirectory. Other than that, there are no required dependencies.
