Covert pega table data into XML and publish file into repository using file data set
Hi Team,
We have a requirement where we want to use the file data sets to generate a file and place it in repository.
However, the file data set supports JSON and CSV only. This is good for the systems which can able to consume the json or csv payload, but for other systems they need XML and CRD file types to be placed in repository.
They dont have any middleware systems which can convert into the type the consumer wants.
I am looking for an option where we can do anything on JAVA READ and WRITE classes which are the options provided in file data sets under "Enable Custom Stream Processing"
Any ideas will be helpful.
Thanks in advance.
