Tata Consultancy Services
Last activity: 22 Dec 2023 7:23 EST
Get the list of agents and its status
Could anyone please explain how to design the report definition which will give the list of agents, its status and at which node its is running.
Nirmala J
Accenture
@NirmalaJ2240 Index-Agents class holds the information you have asked. Please write a RD on this.
Thanks for your reply.
Could you please help with the property name which hold the status of the Agent.
Accenture
@NirmalaJ2240 Attached properties with this chat.
Hi, Here I couldn't see any property holding the status.
Am I missing something here or should we use class join or something, COuld you please elaborate.
Nirmala J
Lventur
You could make use of D_pzAgentsInCluster pega OOTB data page, to get all agent status inside cluster information.
Updated: 3 Aug 2023 3:09 EDT
Is this DPage from @baseclass, couldn'd find in Dpage-->(Records-->Data Model-->DPage)
Note: Pega version: 7.1.9
Lventur
In Operator -> Preference tab please make sure Diagnostics option is enabled and then search the rule
Vinay Kumar Lingammagari
Updated: 3 Aug 2023 9:53 EDT
Accenture
SG
Can you try to run and check D_pzAgentManagement if you don't find D_pzAgentsInCluster.
Note: In V7.1/7.2 we don't have Diagnostics option on operator preferences so search with old:D_pzAgentsInCluster / old: D_pzAgentManagement
Gunasekaran Baskaran Nirmala Jaganathan
CNO
@VinayKumarL16594575 In the results of D_pzAgentManagement,the property .pyAgentStatus displaying only the status 'stopped' for all the agents.can you help with the alternative
