Vodafone
GR
Last activity: 19 Jul 2023 13:17 EDT
Cannot discard a private edit on a Decision Data
I have an issue with Pega for a while now. I've checked similar posts, but can't really say I can find any solution there. At some point I made a private edit on a Decision Data. After a while and after I tested some stuff, I tried to discard my private edit and here's where the odd thing happens.
To me it looks like it always returns to the same page with the rule in private edit mode and the discard button available to click. From other users' accounts, they cannot see my private edit and looks like it is discarded!
However, this is very annoying cause if the same rule gets updated under the same ruleset I cannot private edit that one, cause Pega says that I already have a version checked out.
If I try to check in I get the following error "Error—
CheckIn was unsuccessful. Original Instance does not contain Lock Information. Original Instance Handle : RULE-DECISION-DECISIONPARAMETERS AOM-SR-PRODUCTS-TARIFFPLAN TARIFFPLAN #20230206T131138.579 GMT"
Can you please assist?
Thank you
