Eros
Last activity: 19 Jul 2023 2:48 EDT
Pega Personal Edition 8.7 installation failed
Here is the error which I'm getting while installing
BUILD FAILED C:\Users\thepr\OneDrive\Desktop\117149_PEga_8.7(2)\pegaGuiInstallerTemp\build.xml:305: exec returned: 1
Total time: 13 minutes 30 seconds org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:91) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81) ... 2 more --- Nested Exception --- org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:81) at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:88) at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398) Output logs : -
Targets:Initialization,Database Server Installation,Data Load,Configuration,PRPC Launching Buildfile: C:\Users\thepr\OneDrive\Desktop\117149_PEga_8.7(2)\.\pegaGuiInstallerTemp\build.xml
Initialization: [echo] Beginning installation of Pega Platform 8.7.0 Personal Edition -- this process should take about 5-10 minutes ... [mkdir] Created dir: C:\PRPCPersonalEdition [mkdir] Created dir: C:\PRPCPersonalEdition\temp [unzip] Expanding: C:\Users\thepr\OneDrive\Desktop\117149_PEga_8.7(2)\pegaGuiInstallerTemp\PersonalEdition.zip into C:\PRPCPersonalEdition [echo] Configuring Tomcat (Setting Java Home and Catalina Home)... [replace] Replaced 0 occurrences in 0 files. [replace] Replaced 1 occurrences in 1 files. [replace] Replaced 2 occurrences in 1 files. [replace] Replaced 1 occurrences in 1 files.
Database Server Installation: [exec] The files belonging to this database system will be owned by user "thepr". [exec] This user must also own the server process. [exec] [exec] The database cluster will be initialized with locale "English_India.1252". [exec] The default text search configuration will be set to "english". [exec] [exec] Data page checksums are disabled. [exec] [exec] creating directory C:/PRPCPersonalEdition/pgsql/data ... ok [exec] creating subdirectories ... ok [exec] selecting default max_connections ... 100 [exec] selecting default shared_buffers ... 128MB [exec] selecting default timezone ... Asia/Calcutta [exec] selecting dynamic shared memory implementation ... windows [exec] creating configuration files ... ok [exec] running bootstrap script ... ok [exec] performing post-bootstrap initialization ... ok [exec] syncing data to disk ... ok [exec] [exec] Success. You can now start the database server using: [exec] [exec] C:/PRPCPersonalEdition/pgsql/bin/pg_ctl -D ^"C^:^\PRPCPersonalEdition^/pgsql^\data^" -l logfile start [exec] [exec] [exec] WARNING: enabling "trust" authentication for local connections [exec] You can change this by editing pg_hba.conf or using the option -A, or [exec] --auth-local and --auth-host, the next time you run initdb. [echo] [echo] Waiting for Postgres to start... [echo] Connected to Database. [exec] ALTER ROLE [exec] ALTER ROLE [exec] CREATE SCHEMApsql:C:/PRPCPersonalEdition/scripts/installPLJava.sql:6: WARNING: Java virtual machine not yet loaded [exec] [exec] GRANT [exec] CREATE FUNCTION [exec] DETAIL: The specified module could not be found.CREATE LANGUAGE [exec] [exec] [exec] CREATE FUNCTION [exec] CREATE LANGUAGE [exec] HINT: SET pljava.libjvm_location TO the correct path to the jvm library (libjvm.so or jvm.dll, etc.) [exec] CREATE TABLE [exec] GRANT [exec] CREATE TABLE [exec] GRANT [exec] CREATE TABLE [exec] GRANT [exec] CREATE TABLE [exec] GRANT [exec] CREATE TABLE [exec] GRANT [exec] CREATE FUNCTION [exec] CREATE FUNCTION [exec] CREATE FUNCTION [exec] CREATE FUNCTION [exec] CREATE FUNCTION [exec] CREATE FUNCTION [exec] CREATE FUNCTION [exec] CREATE FUNCTION [exec] CREATE FUNCTION
Data Load: [echo] [echo] Waiting for Postgres to restart... [echo] Connected to Database. [echo] [echo] Loading database with Pega Platform... [exec] pg_restore: connecting to database for restore [exec] pg_restore: implied data-only restore [exec] pg_restore: processing item 4655 ENCODING ENCODING [exec] pg_restore: processing item 4656 STDSTRINGS STDSTRINGS [exec] pg_restore: processing item 4657 SEARCHPATH SEARCHPATH [exec] pg_restore: processing item 4658 DATABASE postgres [exec] pg_restore: processing item 4660 DATABASE PROPERTIES postgres [exec] pg_restore: entering main parallel loop [exec] pg_restore: launching item 4521 TABLE DATA jar_repository [exec] pg_restore: launching item 4524 TABLE DATA classpath_entry [exec] pg_restore: launching item 4522 TABLE DATA jar_entry [exec] pg_restore: launching item 4523 TABLE DATA jar_descriptor [exec] pg_restore: disabling triggers for jar_entry [exec] pg_restore: processing data for table "sqlj.jar_entry" [exec] pg_restore: disabling triggers for jar_repository [exec] pg_restore: processing data for table "sqlj.jar_repository" [exec] pg_restore: enabling triggers for jar_repository [exec] pg_restore: finished item 4521 TABLE DATA jar_repository [exec] pg_restore: launching item 4525 TABLE DATA typemap_entry [exec] pg_restore: disabling triggers for typemap_entry [exec] pg_restore: processing data for table "sqlj.typemap_entry" [exec] pg_restore: enabling triggers for typemap_entry [exec] pg_restore: finished item 4525 TABLE DATA typemap_entry [exec] pg_restore: disabling triggers for classpath_entry [exec] pg_restore: processing data for table "sqlj.classpath_entry" [exec] pg_restore: enabling triggers for classpath_entry [exec] pg_restore: finished item 4524 TABLE DATA classpath_entry [exec] pg_restore: enabling triggers for jar_entry [exec] pg_restore: finished item 4522 TABLE DATA jar_entry [exec] pg_restore: disabling triggers for jar_descriptor [exec] pg_restore: processing data for table "sqlj.jar_descriptor" [exec] pg_restore: enabling triggers for jar_descriptor [exec] pg_restore: finished item 4523 TABLE DATA jar_descriptor [exec] pg_restore: finished main parallel loop [exec] pg_restore: connecting to database for restore [exec] pg_restore: processing item 6763 ENCODING ENCODING [exec] pg_restore: processing item 6764 STDSTRINGS STDSTRINGS [exec] pg_restore: processing item 6765 SEARCHPATH SEARCHPATH [exec] pg_restore: processing item 6766 DATABASE postgres [exec] pg_restore: processing item 6767 COMMENT DATABASE postgres [exec] pg_restore: processing item 6768 DATABASE PROPERTIES postgres [exec] pg_restore: processing item 11 SCHEMA data [exec] pg_restore: creating SCHEMA "data" [exec] pg_restore: processing item 12 SCHEMA rules [exec] pg_restore: creating SCHEMA "rules" [exec] pg_restore: processing item 755 FUNCTION pr_compare_value_lists(character varying, text, character varying, integer, integer) [exec] pg_restore: creating FUNCTION "data.pr_compare_value_lists(character varying, text, character varying, integer, integer)" [exec] pg_restore: processing item 756 FUNCTION pr_compare_value_lists_allof(character varying, text) [exec] pg_restore: creating FUNCTION "data.pr_compare_value_lists_allof(character varying, text)" [exec] pg_restore: processing item 757 FUNCTION pr_compare_value_lists_anyof(character varying, text) [exec] pg_restore: creating FUNCTION "data.pr_compare_value_lists_anyof(character varying, text)" [exec] pg_restore: processing item 772 FUNCTION pr_read_decimal_from_stream(character varying, character varying, bytea) [exec] pg_restore: creating FUNCTION "data.pr_read_decimal_from_stream(character varying, character varying, bytea)" [exec] pg_restore: processing item 771 FUNCTION pr_read_from_stream(character varying, character varying, bytea) [exec] pg_restore: creating FUNCTION "data.pr_read_from_stream(character varying, character varying, bytea)" [exec] pg_restore: processing item 773 FUNCTION pr_read_int_from_stream(character varying, character varying, bytea) [exec] pg_restore: creating FUNCTION "data.pr_read_int_from_stream(character varying, character varying, bytea)" [exec] pg_restore: processing item 759 FUNCTION sppc_data_uniqueid_withouttran(character varying, character varying, character varying) [exec] pg_restore: creating FUNCTION "data.sppc_data_uniqueid_withouttran(character varying, character varying, character varying)" [exec] pg_restore: processing item 760 FUNCTION sppr_aggregate_usage() [exec] pg_restore: creating FUNCTION "data.sppr_aggregate_usage()" [exec] pg_restore: processing item 766 FUNCTION sppr_defragment_table(character varying, character varying) [exec] pg_restore: creating FUNCTION "data.sppr_defragment_table(character varying, character varying)" [exec] pg_restore: processing item 758 FUNCTION sppr_purge_table(character varying, character varying, integer) [exec] pg_restore: creating FUNCTION "data.sppr_purge_table(character varying, character varying, integer)" [exec] pg_restore: processing item 761 FUNCTION sppr_sys_getindextime(character varying) [exec] pg_restore: creating FUNCTION "data.sppr_sys_getindextime(character varying)" [exec] pg_restore: processing item 762 FUNCTION sppr_sys_reservequeueitem_b(character varying, character varying, character varying, character varying, character varying, character varying, timestamp without time zone, character varying, character varying) [exec] pg_restore: creating FUNCTION "data.sppr_sys_reservequeueitem_b(character varying, character varying, character varying, character varying, character varying, character varying, timestamp without time zone, character varying, character varying)" [exec] pg_restore: processing item 763 FUNCTION sppr_sys_statusnodes_set(character varying, character varying, character varying, character varying, character varying, character varying) [exec] pg_restore: creating FUNCTION "data.sppr_sys_statusnodes_set(character varying, character varying, character varying, character varying, character varying, character varying)" [exec] pg_restore: processing item 764 FUNCTION sppr_sys_updatescache_flush(integer) [exec] pg_restore: creating FUNCTION "data.sppr_sys_updatescache_flush(integer)" [exec] pg_restore: processing item 765 FUNCTION sppr_sys_updatescache_gettime(character varying) [exec] pg_restore: creating FUNCTION "data.sppr_sys_updatescache_gettime(character varying)" [exec] pg_restore: processing item 767 FUNCTION pr_compare_value_lists(character varying, text, character varying, integer, integer) [exec] pg_restore: creating FUNCTION "rules.pr_compare_value_lists(character varying, text, character varying, integer, integer)" [exec] pg_restore: processing item 768 FUNCTION pr_compare_value_lists_allof(character varying, text) [exec] pg_restore: creating FUNCTION "rules.pr_compare_value_lists_allof(character varying, text)" [exec] pg_restore: processing item 769 FUNCTION pr_compare_value_lists_anyof(character varying, text) [exec] pg_restore: creating FUNCTION "rules.pr_compare_value_lists_anyof(character varying, text)" [exec] pg_restore: processing item 775 FUNCTION pr_read_decimal_from_stream(character varying, character varying, bytea) [exec] pg_restore: creating FUNCTION "rules.pr_read_decimal_from_stream(character varying, character varying, bytea)" [exec] pg_restore: processing item 774 FUNCTION pr_read_from_stream(character varying, character varying, bytea) [exec] pg_restore: creating FUNCTION "rules.pr_read_from_stream(character varying, character varying, bytea)" [exec] pg_restore: processing item 776 FUNCTION pr_read_int_from_stream(character varying, character varying, bytea) [exec] pg_restore: creating FUNCTION "rules.pr_read_int_from_stream(character varying, character varying, bytea)" [exec] pg_restore: processing item 770 FUNCTION sppr_rebuild_indexes(character varying) [exec] pg_restore: creating FUNCTION "rules.sppr_rebuild_indexes(character varying)" [exec] pg_restore: processing item 432 TABLE p_address [exec] pg_restore: creating TABLE "data.p_address" [exec] pg_restore: processing item 433 TABLE p_contact [exec] pg_restore: creating TABLE "data.p_contact" [exec] pg_restore: processing item 428 TABLE p_contactcontactrel [exec] pg_restore: creating TABLE "data.p_contactcontactrel" [exec] pg_restore: processing item 429 TABLE p_contactorgrel [exec] pg_restore: creating TABLE "data.p_contactorgrel" [exec] pg_restore: processing item 434 TABLE p_organization [exec] pg_restore: creating TABLE "data.p_organization" [exec] pg_restore: processing item 430 TABLE p_orgorgrel [exec] pg_restore: creating TABLE "data.p_orgorgrel" [exec] pg_restore: processing item 431 TABLE p_role [exec] pg_restore: creating TABLE "data.p_role" [exec] pg_restore: processing item 361 TABLE pc_apn_token [exec] pg_restore: creating TABLE "data.pc_apn_token" [exec] pg_restore: processing item 255 TABLE pc_assign_workbasket [exec] pg_restore: creating TABLE "data.pc_assign_workbasket" [exec] pg_restore: processing item 256 TABLE pc_assign_worklist [exec] pg_restore: creating TABLE "data.pc_assign_worklist" [exec] pg_restore: processing item 318 TABLE pc_cep_actions_repository [exec] pg_restore: creating TABLE "data.pc_cep_actions_repository" [exec] pg_restore: processing item 319 TABLE pc_cep_events_repository [exec] pg_restore: creating TABLE "data.pc_cep_events_repository" [exec] pg_restore: processing item 466 TABLE pc_clientdata_restriction [exec] pg_restore: creating TABLE "data.pc_clientdata_restriction" [exec] pg_restore: processing item 232 TABLE pc_data_adm_seccorspol [exec] pg_restore: creating TABLE "data.pc_data_adm_seccorspol" [exec] pg_restore: processing item 233 TABLE pc_data_adm_seckeyid [exec] pg_restore: creating TABLE "data.pc_data_adm_seckeyid" [exec] pg_restore: processing item 491 TABLE pc_data_file_temp [exec] pg_restore: creating TABLE "data.pc_data_file_temp" [exec] pg_restore: processing item 236 TABLE pc_data_notiftn_param [exec] pg_restore: creating TABLE "data.pc_data_notiftn_param" [exec] pg_restore: processing item 257 TABLE pc_data_uniqueid [exec] pg_restore: creating TABLE "data.pc_data_uniqueid" [exec] pg_restore: processing item 258 TABLE pc_data_workattach [exec] pg_restore: creating TABLE "data.pc_data_workattach" [exec] pg_restore: processing item 265 TABLE pc_events [exec] pg_restore: creating TABLE "data.pc_events" [exec] pg_restore: processing item 482 TABLE pc_flaudit [exec] pg_restore: creating TABLE "data.pc_flaudit" [exec] pg_restore: processing item 362 TABLE pc_gcm_token [exec] pg_restore: creating TABLE "data.pc_gcm_token" [exec] pg_restore: processing item 379 TABLE pc_history_data_dms_work [exec] pg_restore: creating TABLE "data.pc_history_data_dms_work" [exec] pg_restore: processing item 477 TABLE pc_history_document [exec] pg_restore: creating TABLE "data.pc_history_document" [exec] pg_restore: processing item 449 TABLE pc_history_group [exec] pg_restore: creating TABLE "data.pc_history_group" [exec] pg_restore: processing item 259 TABLE pc_history_work [exec] pg_restore: creating TABLE "data.pc_history_work" [exec] pg_restore: processing item 469 TABLE pc_history_work_cover_task [exec] pg_restore: creating TABLE "data.pc_history_work_cover_task" [exec] pg_restore: processing item 253 TABLE pc_index_accel [exec] pg_restore: creating TABLE "data.pc_index_accel" [exec] pg_restore: processing item 385 TABLE pc_index_location [exec] pg_restore: creating TABLE "data.pc_index_location" [exec] pg_restore: processing item 260 TABLE pc_index_workparty [exec] pg_restore: creating TABLE "data.pc_index_workparty" [exec] pg_restore: processing item 406 TABLE pc_link_association [exec] pg_restore: creating TABLE "data.pc_link_association" [exec] pg_restore: processing item 484 TABLE pc_link_association_channel [exec] pg_restore: creating TABLE "data.pc_link_association_channel" [exec] pg_restore: processing item 422 TABLE pc_link_association_doc [exec] pg_restore: creating TABLE "data.pc_link_association_doc" [exec] pg_restore: processing item 450 TABLE pc_link_association_member [exec] pg_restore: creating TABLE "data.pc_link_association_member" [exec] pg_restore: processing item 463 TABLE pc_link_association_pin [exec] pg_restore: creating TABLE "data.pc_link_association_pin" [exec] pg_restore: processing item 480 TABLE pc_link_association_rrcategory [exec] pg_restore: creating TABLE "data.pc_link_association_rrcategory" [exec] pg_restore: processing item 467 TABLE pc_link_association_space [exec] pg_restore: creating TABLE "data.pc_link_association_space" [exec] pg_restore: processing item 261 TABLE pc_link_attachment [exec] pg_restore: creating TABLE "data.pc_link_attachment" [exec] pg_restore: processing item 447 TABLE pc_link_category [exec] pg_restore: creating TABLE "data.pc_link_category" [exec] pg_restore: processing item 262 TABLE pc_link_folder [exec] pg_restore: creating TABLE "data.pc_link_folder" [exec] pg_restore: processing item 288 TABLE pc_link_topcase [exec] pg_restore: creating TABLE "data.pc_link_topcase" [exec] pg_restore: processing item 356 TABLE pc_pegatask [exec] pg_restore: creating TABLE "data.pc_pegatask" [exec] pg_restore: processing item 264 TABLE pc_schedule_task [exec] pg_restore: creating TABLE "data.pc_schedule_task" [exec] pg_restore: processing item 266 TABLE pc_work [exec] pg_restore: creating TABLE "data.pc_work" [exec] pg_restore: processing item 263 TABLE pc_work_accel [exec] pg_restore: creating TABLE "data.pc_work_accel" [exec] pg_restore: processing item 405 TABLE pc_work_agile [exec] pg_restore: creating TABLE "data.pc_work_agile" [exec] pg_restore: processing item 453 TABLE pc_work_clientdata [exec] pg_restore: creating TABLE "data.pc_work_clientdata" [exec] pg_restore: processing item 468 TABLE pc_work_cover_task [exec] pg_restore: creating TABLE "data.pc_work_cover_task" [exec] pg_restore: processing item 378 TABLE pc_work_dms [exec] pg_restore: creating TABLE "data.pc_work_dms" [exec] pg_restore: processing item 421 TABLE pc_work_document [exec] pg_restore: creating TABLE "data.pc_work_document" [exec] pg_restore: processing item 268 TABLE pc_work_dsm_batch [exec] pg_restore: creating TABLE "data.pc_work_dsm_batch" [exec] pg_restore: processing item 499 TABLE pc_work_dsm_simulation [exec] pg_restore: creating TABLE "data.pc_work_dsm_simulation" [exec] pg_restore: processing item 448 TABLE pc_work_group [exec] pg_restore: creating TABLE "data.pc_work_group" [exec] pg_restore: processing item 407 TABLE pc_work_guide [exec] pg_restore: creating TABLE "data.pc_work_guide" [exec] pg_restore: processing item 402 TABLE pc_work_notification [exec] pg_restore: creating TABLE "data.pc_work_notification" [exec] pg_restore: processing item 495 TABLE pc_work_prediction [exec] pg_restore: creating TABLE "data.pc_work_prediction" [exec] pg_restore: processing item 267 TABLE pc_work_processemail [exec] pg_restore: creating TABLE "data.pc_work_processemail" [exec] pg_restore: processing item 338 TABLE pc_work_social [exec] pg_restore: creating TABLE "data.pc_work_social" [exec] pg_restore: processing item 493 TABLE pc_work_triage [exec] pg_restore: creating TABLE "data.pc_work_triage" [exec] pg_restore: processing item 273 TABLE pr_data_admin [exec] pg_restore: creating TABLE "data.pr_data_admin" [exec] pg_restore: processing item 521 VIEW pcv4_assignment_summary [exec] pg_restore: creating VIEW "data.pcv4_assignment_summary" [exec] pg_restore: processing item 522 VIEW pcv4_assignmentwb_summary [exec] pg_restore: creating VIEW "data.pcv4_assignmentwb_summary" [exec] pg_restore: processing item 523 VIEW pcv4_work_history [exec] pg_restore: creating VIEW "data.pcv4_work_history" [exec] pg_restore: processing item 269 TABLE pi_data_connect [exec] pg_restore: creating TABLE "data.pi_data_connect" [exec] pg_restore: processing item 284 TABLE pr4_history_rule [exec] pg_restore: creating TABLE "data.pr4_history_rule" [exec] pg_restore: processing item 321 TABLE pr4_log_rule_usage [exec] pg_restore: creating TABLE "data.pr4_log_rule_usage" [exec] pg_restore: processing item 322 TABLE pr4_log_rule_usage_details [exec] pg_restore: creating TABLE "data.pr4_log_rule_usage_details" [exec] pg_restore: processing item 507 TABLE pr_archival_class_dependency [exec] pg_restore: creating TABLE "data.pr_archival_class_dependency" [exec] pg_restore: processing item 514 TABLE pr_archival_excluded_case [exec] pg_restore: creating TABLE "data.pr_archival_excluded_case" [exec] pg_restore: processing item 270 TABLE pr_assign [exec] pg_restore: creating TABLE "data.pr_assign" [exec] pg_restore: processing item 315 TABLE pr_cep_events_queue [exec] pg_restore: creating TABLE "data.pr_cep_events_queue" [exec] pg_restore: processing item 316 TABLE pr_cep_eventslookup [exec] pg_restore: creating TABLE "data.pr_cep_eventslookup" [exec] pg_restore: processing item 317 TABLE pr_cep_user_subscriptions [exec] pg_restore: creating TABLE "data.pr_cep_user_subscriptions" [exec] pg_restore: processing item 328 TABLE pr_daily_usage [exec] pg_restore: creating TABLE "data.pr_daily_usage" [exec] pg_restore: processing item 272 TABLE pr_data [exec] pg_restore: creating TABLE "data.pr_data" [exec] pg_restore: processing item 398 TABLE pr_data_adm_configuration [exec] pg_restore: creating TABLE "data.pr_data_adm_configuration" [exec] pg_restore: processing item 399 TABLE pr_data_adm_factory [exec] pg_restore: creating TABLE "data.pr_data_adm_factory" [exec] pg_restore: processing item 451 TABLE pr_data_admin_auth_code [exec] pg_restore: creating TABLE "data.pr_data_admin_auth_code" [exec] pg_restore: processing item 498 TABLE pr_data_admin_dds_table [exec] pg_restore: creating TABLE "data.pr_data_admin_dds_table" [exec] pg_restore: processing item 471 TABLE pr_data_admin_sec_cert [exec] pg_restore: creating TABLE "data.pr_data_admin_sec_cert" [exec] pg_restore: processing item 408 TABLE pr_data_admin_sec_de_cdk [exec] pg_restore: creating TABLE "data.pr_data_admin_sec_de_cdk" [exec] pg_restore: processing item 409 TABLE pr_data_admin_sec_de_key [exec] pg_restore: creating TABLE "data.pr_data_admin_sec_de_key" [exec] pg_restore: processing item 441 TABLE pr_data_admin_sec_sde_cdk [exec] pg_restore: creating TABLE "data.pr_data_admin_sec_sde_cdk" [exec] pg_restore: processing item 274 TABLE pr_data_admin_tenant [exec] pg_restore: creating TABLE "data.pr_data_admin_tenant" [exec] pg_restore: processing item 250 TABLE pr_data_analysis_specification [exec] pg_restore: creating TABLE "data.pr_data_analysis_specification" [exec] pg_restore: processing item 490 TABLE pr_data_app_oauth2client [exec] pg_restore: creating TABLE "data.pr_data_app_oauth2client" [exec] pg_restore: processing item 497 TABLE pr_data_appalias_authservice [exec] pg_restore: creating TABLE "data.pr_data_appalias_authservice" [exec] pg_restore: processing item 462 TABLE pr_data_application_quality [exec] pg_restore: creating TABLE "data.pr_data_application_quality" [exec] pg_restore: processing item 419 TABLE pr_data_applicationpreference [exec] pg_restore: creating TABLE "data.pr_data_applicationpreference" [exec] pg_restore: processing item 519 TABLE pr_data_archivalmigration [exec] pg_restore: creating TABLE "data.pr_data_archivalmigration" [exec] pg_restore: processing item 254 TABLE pr_data_autotest [exec] pg_restore: creating TABLE "data.pr_data_autotest" [exec] pg_restore: processing item 446 TABLE pr_data_category [exec] pg_restore: creating TABLE "data.pr_data_category" [exec] pg_restore: processing item 481 TABLE pr_data_collaboration [exec] pg_restore: creating TABLE "data.pr_data_collaboration" [exec] pg_restore: processing item 506 TABLE pr_data_configuration_audit [exec] pg_restore: creating TABLE "data.pr_data_configuration_audit" [exec] pg_restore: processing item 501 TABLE pr_data_configuration_setting [exec] pg_restore: creating TABLE "data.pr_data_configuration_setting" [exec] pg_restore: processing item 513 TABLE pr_data_conversation_event [exec] pg_restore: creating TABLE "data.pr_data_conversation_event" [exec] pg_restore: processing item 512 TABLE pr_data_conversation_summary [exec] pg_restore: creating TABLE "data.pr_data_conversation_summary" [exec] pg_restore: processing item 235 TABLE pr_data_custm_date_fmt [exec] pg_restore: creating TABLE "data.pr_data_custm_date_fmt" [exec] pg_restore: processing item 520 TABLE pr_data_customer_interaction [exec] pg_restore: creating TABLE "data.pr_data_customer_interaction" [exec] pg_restore: processing item 483 TABLE pr_data_decision_biasresults [exec] pg_restore: creating TABLE "data.pr_data_decision_biasresults" [exec] pg_restore: processing item 381 TABLE pr_data_decision_ddf_error [exec] pg_restore: creating TABLE "data.pr_data_decision_ddf_error" [exec] pg_restore: processing item 437 TABLE pr_data_decision_ddf_run_opts [exec] pg_restore: creating TABLE "data.pr_data_decision_ddf_run_opts" [exec] pg_restore: processing item 240 TABLE pr_data_decision_ddf_runtime [exec] pg_restore: creating TABLE "data.pr_data_decision_ddf_runtime" [exec] pg_restore: processing item 239 TABLE pr_data_decision_df_met [exec] pg_restore: creating TABLE "data.pr_data_decision_df_met" [exec] pg_restore: processing item 238 TABLE pr_data_decision_df_part [exec] pg_restore: creating TABLE "data.pr_data_decision_df_part" [exec] pg_restore: processing item 411 TABLE pr_data_distinctvalueindex [exec] pg_restore: creating TABLE "data.pr_data_distinctvalueindex" [exec] pg_restore: processing item 342 TABLE pr_data_dm_admmart_mdl_fact [exec] pg_restore: creating TABLE "data.pr_data_dm_admmart_mdl_fact" [exec] pg_restore: processing item 341 TABLE pr_data_dm_admmart_model [exec] pg_restore: creating TABLE "data.pr_data_dm_admmart_model" [exec] pg_restore: processing item 229 TABLE pr_data_dm_admmart_pred [exec] pg_restore: creating TABLE "data.pr_data_dm_admmart_pred" [exec] pg_restore: processing item 456 TABLE pr_data_dm_binarydistribution [exec] pg_restore: creating TABLE "data.pr_data_dm_binarydistribution" [exec] pg_restore: processing item 459 TABLE pr_data_dm_contingencytable [exec] pg_restore: creating TABLE "data.pr_data_dm_contingencytable" [exec] pg_restore: processing item 517 TABLE pr_data_dm_distribution [exec] pg_restore: creating TABLE "data.pr_data_dm_distribution" [exec] pg_restore: processing item 457 TABLE pr_data_dm_histogram [exec] pg_restore: creating TABLE "data.pr_data_dm_histogram" [exec] pg_restore: processing item 474 TABLE pr_data_dm_notification [exec] pg_restore: creating TABLE "data.pr_data_dm_notification" [exec] pg_restore: processing item 458 TABLE pr_data_dm_snapshot [exec] pg_restore: creating TABLE "data.pr_data_dm_snapshot" [exec] pg_restore: processing item 518 TABLE pr_data_dm_summary [exec] pg_restore: creating TABLE "data.pr_data_dm_summary" [exec] pg_restore: processing item 454 TABLE pr_data_dmorg_dmsample_circle [exec] pg_restore: creating TABLE "data.pr_data_dmorg_dmsample_circle" [exec] pg_restore: processing item 370 TABLE pr_data_dms_customer_data [exec] pg_restore: creating TABLE "data.pr_data_dms_customer_data" [exec] pg_restore: processing item 371 TABLE pr_data_dms_device [exec] pg_restore: creating TABLE "data.pr_data_dms_device" [exec] pg_restore: processing item 374 TABLE pr_data_dms_droppedcallevents [exec] pg_restore: creating TABLE "data.pr_data_dms_droppedcallevents" [exec] pg_restore: processing item 375 TABLE pr_data_dms_global [exec] pg_restore: creating TABLE "data.pr_data_dms_global" [exec] pg_restore: processing item 372 TABLE pr_data_dms_purchase [exec] pg_restore: creating TABLE "data.pr_data_dms_purchase" [exec] pg_restore: processing item 373 TABLE pr_data_dms_subscription [exec] pg_restore: creating TABLE "data.pr_data_dms_subscription" [exec] pg_restore: processing item 397 TABLE pr_data_dms_survey_data [exec] pg_restore: creating TABLE "data.pr_data_dms_survey_data" [exec] pg_restore: processing item 470 TABLE pr_data_explain_simulation [exec] pg_restore: creating TABLE "data.pr_data_explain_simulation" [exec] pg_restore: processing item 400 TABLE pr_data_features [exec] pg_restore: creating TABLE "data.pr_data_features" [exec] pg_restore: processing item 248 TABLE pr_data_file [exec] pg_restore: creating TABLE "data.pr_data_file" [exec] pg_restore: processing item 472 TABLE pr_data_full_sync_stats [exec] pg_restore: creating TABLE "data.pr_data_full_sync_stats" [exec] pg_restore: processing item 249 TABLE pr_data_guardrails [exec] pg_restore: creating TABLE "data.pr_data_guardrails" [exec] pg_restore: processing item 485 TABLE pr_data_guardrails_evaluation [exec] pg_restore: creating TABLE "data.pr_data_guardrails_evaluation" [exec] pg_restore: processing item 486 TABLE pr_data_guardrails_runstatus [exec] pg_restore: creating TABLE "data.pr_data_guardrails_runstatus" [exec] pg_restore: processing item 460 TABLE pr_data_healthcheck [exec] pg_restore: creating TABLE "data.pr_data_healthcheck" [exec] pg_restore: processing item 355 TABLE pr_data_ih_association [exec] pg_restore: creating TABLE "data.pr_data_ih_association" [exec] pg_restore: processing item 346 TABLE pr_data_ih_dim_action [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_action" [exec] pg_restore: processing item 351 TABLE pr_data_ih_dim_application [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_application" [exec] pg_restore: processing item 352 TABLE pr_data_ih_dim_channel [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_channel" [exec] pg_restore: processing item 350 TABLE pr_data_ih_dim_context [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_context" [exec] pg_restore: processing item 347 TABLE pr_data_ih_dim_customer [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_customer" [exec] pg_restore: processing item 410 TABLE pr_data_ih_dim_journey [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_journey" [exec] pg_restore: processing item 348 TABLE pr_data_ih_dim_location [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_location" [exec] pg_restore: processing item 349 TABLE pr_data_ih_dim_operator [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_operator" [exec] pg_restore: processing item 353 TABLE pr_data_ih_dim_outcome [exec] pg_restore: creating TABLE "data.pr_data_ih_dim_outcome" [exec] pg_restore: processing item 354 TABLE pr_data_ih_fact [exec] pg_restore: creating TABLE "data.pr_data_ih_fact" [exec] pg_restore: processing item 461 TABLE pr_data_integrationsystem [exec] pg_restore: creating TABLE "data.pr_data_integrationsystem" [exec] pg_restore: processing item 237 TABLE pr_data_mobile_app_pf_asset [exec] pg_restore: creating TABLE "data.pr_data_mobile_app_pf_asset" [exec] pg_restore: processing item 360 TABLE pr_data_mobile_appinfo [exec] pg_restore: creating TABLE "data.pr_data_mobile_appinfo" [exec] pg_restore: processing item 358 TABLE pr_data_mobile_asset [exec] pg_restore: creating TABLE "data.pr_data_mobile_asset" [exec] pg_restore: processing item 357 TABLE pr_data_mobile_build [exec] pg_restore: creating TABLE "data.pr_data_mobile_build" [exec] pg_restore: processing item 359 TABLE pr_data_mobile_certificate [exec] pg_restore: creating TABLE "data.pr_data_mobile_certificate" [exec] pg_restore: processing item 390 TABLE pr_data_mobile_device [exec] pg_restore: creating TABLE "data.pr_data_mobile_device" [exec] pg_restore: processing item 424 TABLE pr_data_mobile_map_track [exec] pg_restore: creating TABLE "data.pr_data_mobile_map_track" [exec] pg_restore: processing item 425 TABLE pr_data_mobile_map_user [exec] pg_restore: creating TABLE "data.pr_data_mobile_map_user" [exec] pg_restore: processing item 516 TABLE pr_data_nlp_deployprediction [exec] pg_restore: creating TABLE "data.pr_data_nlp_deployprediction" [exec] pg_restore: processing item 383 TABLE pr_data_nlp_details [exec] pg_restore: creating TABLE "data.pr_data_nlp_details" [exec] pg_restore: processing item 412 TABLE pr_data_nlp_model_training [exec] pg_restore: creating TABLE "data.pr_data_nlp_model_training" [exec] pg_restore: processing item 503 TABLE pr_data_nlp_reporting [exec] pg_restore: creating TABLE "data.pr_data_nlp_reporting" [exec] pg_restore: processing item 510 TABLE pr_data_nlp_simulationinput [exec] pg_restore: creating TABLE "data.pr_data_nlp_simulationinput" [exec] pg_restore: processing item 509 TABLE pr_data_nlp_simulationresult [exec] pg_restore: creating TABLE "data.pr_data_nlp_simulationresult" [exec] pg_restore: processing item 502 TABLE pr_data_nlp_snapshot [exec] pg_restore: creating TABLE "data.pr_data_nlp_snapshot" [exec] pg_restore: processing item 496 TABLE pr_data_nlp_status [exec] pg_restore: creating TABLE "data.pr_data_nlp_status" [exec] pg_restore: processing item 382 TABLE pr_data_nlp_summary [exec] pg_restore: creating TABLE "data.pr_data_nlp_summary" [exec] pg_restore: processing item 403 TABLE pr_data_notification_recipient [exec] pg_restore: creating TABLE "data.pr_data_notification_recipient" [exec] pg_restore: processing item 420 TABLE pr_data_offline_sync [exec] pg_restore: creating TABLE "data.pr_data_offline_sync" [exec] pg_restore: processing item 488 TABLE pr_data_op_session [exec] pg_restore: creating TABLE "data.pr_data_op_session" [exec] pg_restore: processing item 384 TABLE pr_data_pegasample_product [exec] pg_restore: creating TABLE "data.pr_data_pegasample_product" [exec] pg_restore: processing item 335 TABLE pr_data_pmf_worklist [exec] pg_restore: creating TABLE "data.pr_data_pmf_worklist" [exec] pg_restore: processing item 473 TABLE pr_data_qp_run_partition [exec] pg_restore: creating TABLE "data.pr_data_qp_run_partition" [exec] pg_restore: processing item 345 TABLE pr_data_recents [exec] pg_restore: creating TABLE "data.pr_data_recents" [exec] pg_restore: processing item 275 TABLE pr_data_reportcategory [exec] pg_restore: creating TABLE "data.pr_data_reportcategory" [exec] pg_restore: processing item 276 TABLE pr_data_reportshortcut [exec] pg_restore: creating TABLE "data.pr_data_reportshortcut" [exec] pg_restore: processing item 440 TABLE pr_data_repositories [exec] pg_restore: creating TABLE "data.pr_data_repositories" [exec] pg_restore: processing item 442 TABLE pr_data_retention_policy [exec] pg_restore: creating TABLE "data.pr_data_retention_policy" [exec] pg_restore: processing item 478 TABLE pr_data_rrcategories [exec] pg_restore: creating TABLE "data.pr_data_rrcategories" [exec] pg_restore: processing item 418 TABLE pr_data_rulecoverage_results [exec] pg_restore: creating TABLE "data.pr_data_rulecoverage_results" [exec] pg_restore: processing item 393 TABLE pr_data_saml_authreqcontext [exec] pg_restore: creating TABLE "data.pr_data_saml_authreqcontext" [exec] pg_restore: processing item 392 TABLE pr_data_saml_logininfo [exec] pg_restore: creating TABLE "data.pr_data_saml_logininfo" [exec] pg_restore: processing item 395 TABLE pr_data_saml_logoutreqinfo [exec] pg_restore: creating TABLE "data.pr_data_saml_logoutreqinfo" [exec] pg_restore: processing item 391 TABLE pr_data_saml_replaycache [exec] pg_restore: creating TABLE "data.pr_data_saml_replaycache" [exec] pg_restore: processing item 396 TABLE pr_data_saml_requestorinfo [exec] pg_restore: creating TABLE "data.pr_data_saml_requestorinfo" [exec] pg_restore: processing item 394 TABLE pr_data_saml_sessioninfo [exec] pg_restore: creating TABLE "data.pr_data_saml_sessioninfo" [exec] pg_restore: processing item 344 TABLE pr_data_sample_shoppingcart [exec] pg_restore: creating TABLE "data.pr_data_sample_shoppingcart" [exec] pg_restore: processing item 277 TABLE pr_data_sample_uidetails [exec] pg_restore: creating TABLE "data.pr_data_sample_uidetails" [exec] pg_restore: processing item 278 TABLE pr_data_samplesrcustomer [exec] pg_restore: creating TABLE "data.pr_data_samplesrcustomer" [exec] pg_restore: processing item 279 TABLE pr_data_samplesrproduct [exec] pg_restore: creating TABLE "data.pr_data_samplesrproduct" [exec] pg_restore: processing item 280 TABLE pr_data_samplesrpurchase [exec] pg_restore: creating TABLE "data.pr_data_samplesrpurchase" [exec] pg_restore: processing item 494 TABLE pr_data_sizeestimator_config [exec] pg_restore: creating TABLE "data.pr_data_sizeestimator_config" [exec] pg_restore: processing item 435 TABLE pr_data_smsaccount [exec] pg_restore: creating TABLE "data.pr_data_smsaccount" [exec] pg_restore: processing item 340 TABLE pr_data_social_reference [exec] pg_restore: creating TABLE "data.pr_data_social_reference" [exec] pg_restore: processing item 416 TABLE pr_data_stream_node_updates [exec] pg_restore: creating TABLE "data.pr_data_stream_node_updates" [exec] pg_restore: processing item 415 TABLE pr_data_stream_nodes [exec] pg_restore: creating TABLE "data.pr_data_stream_nodes" [exec] pg_restore: processing item 414 TABLE pr_data_stream_sessions [exec] pg_restore: creating TABLE "data.pr_data_stream_sessions" [exec] pg_restore: processing item 230 TABLE pr_data_svcinvhist [exec] pg_restore: creating TABLE "data.pr_data_svcinvhist" [exec] pg_restore: processing item 330 TABLE pr_data_tag [exec] pg_restore: creating TABLE "data.pr_data_tag" [exec] pg_restore: processing item 387 TABLE pr_data_tag_oplink [exec] pg_restore: creating TABLE "data.pr_data_tag_oplink" [exec] pg_restore: processing item 388 TABLE pr_data_tag_relevantrecord [exec] pg_restore: creating TABLE "data.pr_data_tag_relevantrecord" [exec] pg_restore: processing item 281 TABLE pr_data_template_metadata [exec] pg_restore: creating TABLE "data.pr_data_template_metadata" [exec] pg_restore: processing item 366 TABLE pr_data_testcaseresults [exec] pg_restore: creating TABLE "data.pr_data_testcaseresults" [exec] pg_restore: processing item 404 TABLE pr_data_testsuiteresults [exec] pg_restore: creating TABLE "data.pr_data_testsuiteresults" [exec] pg_restore: processing item 401 TABLE pr_data_toggle [exec] pg_restore: creating TABLE "data.pr_data_toggle" [exec] pg_restore: processing item 367 TABLE pr_data_token [exec] pg_restore: creating TABLE "data.pr_data_token" [exec] pg_restore: processing item 489 TABLE pr_data_token_blacklisted_jti [exec] pg_restore: creating TABLE "data.pr_data_token_blacklisted_jti" [exec] pg_restore: processing item 505 TABLE pr_data_user_activity [exec] pg_restore: creating TABLE "data.pr_data_user_activity" [exec] pg_restore: processing item 389 TABLE pr_database_info_table [exec] pg_restore: creating TABLE "data.pr_database_info_table" [exec] pg_restore: processing item 511 TABLE pr_datapage_cache [exec] pg_restore: creating TABLE "data.pr_datapage_cache" [exec] pg_restore: processing item 271 TABLE pr_dm_proposition [exec] pg_restore: creating TABLE "data.pr_dm_proposition" [exec] pg_restore: processing item 231 TABLE pr_extract_time [exec] pg_restore: creating TABLE "data.pr_extract_time" [exec] pg_restore: processing item 323 TABLE pr_file_store [exec] pg_restore: creating TABLE "data.pr_file_store" [exec] pg_restore: processing item 324 TABLE pr_file_upload [exec] pg_restore: creating TABLE "data.pr_file_upload" [exec] pg_restore: processing item 325 TABLE pr_file_upload_fallback [exec] pg_restore: creating TABLE "data.pr_file_upload_fallback" [exec] pg_restore: processing item 282 TABLE pr_history [exec] pg_restore: creating TABLE "data.pr_history" [exec] pg_restore: processing item 283 TABLE pr_history_data [exec] pg_restore: creating TABLE "data.pr_history_data" [exec] pg_restore: processing item 376 TABLE pr_history_data_dms_customer [exec] pg_restore: creating TABLE "data.pr_history_data_dms_customer" [exec] pg_restore: processing item 377 TABLE pr_history_data_dms_glbl [exec] pg_restore: creating TABLE "data.pr_history_data_dms_glbl" [exec] pg_restore: processing item 327 TABLE pr_hourly_usage [exec] pg_restore: creating TABLE "data.pr_hourly_usage" [exec] pg_restore: processing item 285 TABLE pr_index [exec] pg_restore: creating TABLE "data.pr_index" [exec] pg_restore: processing item 244 TABLE pr_index_accessgrouproles [exec] pg_restore: creating TABLE "data.pr_index_accessgrouproles" [exec] pg_restore: processing item 245 TABLE pr_index_accessgroupwkpools [exec] pg_restore: creating TABLE "data.pr_index_accessgroupwkpools" [exec] pg_restore: processing item 242 TABLE pr_index_appfeatures [exec] pg_restore: creating TABLE "data.pr_index_appfeatures" [exec] pg_restore: processing item 333 TABLE pr_index_assignmentdeps [exec] pg_restore: creating TABLE "data.pr_index_assignmentdeps" [exec] pg_restore: processing item 293 TABLE pr_index_assignmentskills [exec] pg_restore: creating TABLE "data.pr_index_assignmentskills" [exec] pg_restore: processing item 365 TABLE pr_index_data_agents [exec] pg_restore: creating TABLE "data.pr_index_data_agents" [exec] pg_restore: processing item 413 TABLE pr_index_distinctvalues [exec] pg_restore: creating TABLE "data.pr_index_distinctvalues" [exec] pg_restore: processing item 247 TABLE pr_index_email [exec] pg_restore: creating TABLE "data.pr_index_email" [exec] pg_restore: processing item 343 TABLE pr_index_operator_workgroups [exec] pg_restore: creating TABLE "data.pr_index_operator_workgroups" [exec] pg_restore: processing item 292 TABLE pr_index_operators [exec] pg_restore: creating TABLE "data.pr_index_operators" [exec] pg_restore: processing item 294 TABLE pr_index_operatorskills [exec] pg_restore: creating TABLE "data.pr_index_operatorskills" [exec] pg_restore: processing item 386 TABLE pr_index_pref_notify [exec] pg_restore: creating TABLE "data.pr_index_pref_notify" [exec] pg_restore: processing item 286 TABLE pr_index_scheduledtask [exec] pg_restore: creating TABLE "data.pr_index_scheduledtask" [exec] pg_restore: processing item 339 TABLE pr_index_trackstatus [exec] pg_restore: creating TABLE "data.pr_index_trackstatus" [exec] pg_restore: processing item 492 TABLE pr_index_tracktriageactions [exec] pg_restore: creating TABLE "data.pr_index_tracktriageactions" [exec] pg_restore: processing item 246 TABLE pr_index_workgroups [exec] pg_restore: creating TABLE "data.pr_index_workgroups" [exec] pg_restore: processing item 443 TABLE pr_indexmetadata [exec] pg_restore: creating TABLE "data.pr_indexmetadata" [exec] pg_restore: processing item 439 TABLE pr_jobscheduler_override [exec] pg_restore: creating TABLE "data.pr_jobscheduler_override" [exec] pg_restore: processing item 326 TABLE pr_license_parameters [exec] pg_restore: creating TABLE "data.pr_license_parameters" [exec] pg_restore: processing item 287 TABLE pr_link [exec] pg_restore: creating TABLE "data.pr_link" [exec] pg_restore: processing item 332 TABLE pr_link_dco_pmf [exec] pg_restore: creating TABLE "data.pr_link_dco_pmf" [exec] pg_restore: processing item 336 TABLE pr_link_pmf_rulechanges [exec] pg_restore: creating TABLE "data.pr_link_pmf_rulechanges" [exec] pg_restore: processing item 331 TABLE pr_link_work_tag [exec] pg_restore: creating TABLE "data.pr_link_work_tag" [exec] pg_restore: processing item 289 TABLE pr_log [exec] pg_restore: creating TABLE "data.pr_log" [exec] pg_restore: processing item 500 TABLE pr_log_archivalsummary [exec] pg_restore: creating TABLE "data.pr_log_archivalsummary" [exec] pg_restore: processing item 455 TABLE pr_log_archivepurgeresults [exec] pg_restore: creating TABLE "data.pr_log_archivepurgeresults" [exec] pg_restore: processing item 508 TABLE pr_log_batchid_generation [exec] pg_restore: creating TABLE "data.pr_log_batchid_generation" [exec] pg_restore: processing item 337 TABLE pr_log_batchstats [exec] pg_restore: creating TABLE "data.pr_log_batchstats" [exec] pg_restore: processing item 368 TABLE pr_log_cluster [exec] pg_restore: creating TABLE "data.pr_log_cluster" [exec] pg_restore: processing item 438 TABLE pr_log_collaboration [exec] pg_restore: creating TABLE "data.pr_log_collaboration" [exec] pg_restore: processing item 251 TABLE pr_log_dataaccessaudit [exec] pg_restore: creating TABLE "data.pr_log_dataaccessaudit" [exec] pg_restore: processing item 436 TABLE pr_log_dataflow_events [exec] pg_restore: creating TABLE "data.pr_log_dataflow_events" [exec] pg_restore: processing item 504 TABLE pr_log_expungedcases [exec] pg_restore: creating TABLE "data.pr_log_expungedcases" [exec] pg_restore: processing item 475 TABLE pr_log_indexing_progress [exec] pg_restore: creating TABLE "data.pr_log_indexing_progress" [exec] pg_restore: processing item 417 TABLE pr_log_jobs_scheduler [exec] pg_restore: creating TABLE "data.pr_log_jobs_scheduler" [exec] pg_restore: processing item 380 TABLE pr_log_progress [exec] pg_restore: creating TABLE "data.pr_log_progress" [exec] pg_restore: processing item 243 TABLE pr_log_reportstats [exec] pg_restore: creating TABLE "data.pr_log_reportstats" [exec] pg_restore: processing item 334 TABLE pr_log_securityaudit [exec] pg_restore: creating TABLE "data.pr_log_securityaudit" [exec] pg_restore: processing item 479 TABLE pr_log_service_email [exec] pg_restore: creating TABLE "data.pr_log_service_email" [exec] pg_restore: processing item 369 TABLE pr_log_systemstate [exec] pg_restore: creating TABLE "data.pr_log_systemstate" [exec] pg_restore: processing item 444 TABLE pr_metadata [exec] pg_restore: creating TABLE "data.pr_metadata" [exec] pg_restore: processing item 241 TABLE pr_notification_channels [exec] pg_restore: creating TABLE "data.pr_notification_channels" [exec] pg_restore: processing item 515 TABLE pr_oauth2_session_index [exec] pg_restore: creating TABLE "data.pr_oauth2_session_index" [exec] pg_restore: processing item 427 TABLE pr_offline_attachment_mapping [exec] pg_restore: creating TABLE "data.pr_offline_attachment_mapping" [exec] pg_restore: processing item 426 TABLE pr_offline_attachment_stub [exec] pg_restore: creating TABLE "data.pr_offline_attachment_stub" [exec] pg_restore: processing item 298 TABLE pr_offline_pack [exec] pg_restore: creating TABLE "data.pr_offline_pack" [exec] pg_restore: processing item 464 TABLE pr_offline_sync_requests [exec] pg_restore: creating TABLE "data.pr_offline_sync_requests" [exec] pg_restore: processing item 465 TABLE pr_offline_sync_requests_info [exec] pg_restore: creating TABLE "data.pr_offline_sync_requests_info" [exec] pg_restore: processing item 291 TABLE pr_operator_prefs [exec] pg_restore: creating TABLE "data.pr_operator_prefs" [exec] pg_restore: processing item 290 TABLE pr_operators [exec] pg_restore: creating TABLE "data.pr_operators" [exec] pg_restore: processing item 295 TABLE pr_other [exec] pg_restore: creating TABLE "data.pr_other" [exec] pg_restore: processing item 297 TABLE pr_page_store [exec] pg_restore: creating TABLE "data.pr_page_store" [exec] pg_restore: processing item 320 TABLE pr_perf_stats [exec] pg_restore: creating TABLE "data.pr_perf_stats" [exec] pg_restore: processing item 296 TABLE pr_portal_state [exec] pg_restore: creating TABLE "data.pr_portal_state" [exec] pg_restore: processing item 476 TABLE pr_sys_bi_publisheddatamodel [exec] pg_restore: creating TABLE "data.pr_sys_bi_publisheddatamodel" [exec] pg_restore: processing item 299 TABLE pr_sys_context [exec] pg_restore: creating TABLE "data.pr_sys_context" [exec] pg_restore: processing item 452 TABLE pr_sys_delayed_queue [exec] pg_restore: creating TABLE "data.pr_sys_delayed_queue" [exec] pg_restore: processing item 300 TABLE pr_sys_locks [exec] pg_restore: creating TABLE "data.pr_sys_locks" [exec] pg_restore: processing item 445 TABLE pr_sys_msg_qp_brokenitems [exec] pg_restore: creating TABLE "data.pr_sys_msg_qp_brokenitems" [exec] pg_restore: processing item 307 TABLE pr_sys_queue_autotest [exec] pg_restore: creating TABLE "data.pr_sys_queue_autotest" [exec] pg_restore: processing item 313 TABLE pr_sys_queue_col_pop [exec] pg_restore: creating TABLE "data.pr_sys_queue_col_pop" [exec] pg_restore: processing item 314 TABLE pr_sys_queue_count [exec] pg_restore: creating TABLE "data.pr_sys_queue_count" [exec] pg_restore: processing item 311 TABLE pr_sys_queue_execreq_conn [exec] pg_restore: creating TABLE "data.pr_sys_queue_execreq_conn" [exec] pg_restore: processing item 310 TABLE pr_sys_queue_execreq_svc [exec] pg_restore: creating TABLE "data.pr_sys_queue_execreq_svc" [exec] pg_restore: processing item 423 TABLE pr_sys_queue_ftsconflict [exec] pg_restore: creating TABLE "data.pr_sys_queue_ftsconflict" [exec] pg_restore: processing item 364 TABLE pr_sys_queue_ftsindexer [exec] pg_restore: creating TABLE "data.pr_sys_queue_ftsindexer" [exec] pg_restore: processing item 309 TABLE pr_sys_queue_sla [exec] pg_restore: creating TABLE "data.pr_sys_queue_sla" [exec] pg_restore: processing item 312 TABLE pr_sys_queue_startflows [exec] pg_restore: creating TABLE "data.pr_sys_queue_startflows" [exec] pg_restore: processing item 306 TABLE pr_sys_queues [exec] pg_restore: creating TABLE "data.pr_sys_queues" [exec] pg_restore: processing item 301 TABLE pr_sys_serviceregistry [exec] pg_restore: creating TABLE "data.pr_sys_serviceregistry" [exec] pg_restore: processing item 302 TABLE pr_sys_serviceregistry_kvs [exec] pg_restore: creating TABLE "data.pr_sys_serviceregistry_kvs" [exec] pg_restore: processing item 363 TABLE pr_sys_statusdetails [exec] pg_restore: creating TABLE "data.pr_sys_statusdetails" [exec] pg_restore: processing item 303 TABLE pr_sys_statusnodes [exec] pg_restore: creating TABLE "data.pr_sys_statusnodes" [exec] pg_restore: processing item 304 TABLE pr_sys_updatescache [exec] pg_restore: creating TABLE "data.pr_sys_updatescache" [exec] pg_restore: processing item 305 TABLE pr_sys_user [exec] pg_restore: creating TABLE "data.pr_sys_user" [exec] pg_restore: processing item 487 TABLE pr_sys_user_grid [exec] pg_restore: creating TABLE "data.pr_sys_user_grid" [exec] pg_restore: processing item 308 TABLE pr_sys_workindexer_queue [exec] pg_restore: creating TABLE "data.pr_sys_workindexer_queue" [exec] pg_restore: processing item 252 TABLE pr_sysjobs [exec] pg_restore: creating TABLE "data.pr_sysjobs" [exec] pg_restore: processing item 329 TABLE pr_usage_summary [exec] pg_restore: creating TABLE "data.pr_usage_summary" [exec] pg_restore: processing item 234 TABLE prpc_ignite_server_addr [exec] pg_restore: creating TABLE "data.prpc_ignite_server_addr" [exec] pg_restore: processing item 534 TABLE pc_index_flowref [exec] pg_restore: creating TABLE "rules.pc_index_flowref" [exec] pg_restore: processing item 537 TABLE pr4_base [exec] pg_restore: creating TABLE "rules.pr4_base" [exec] pg_restore: processing item 539 TABLE pr4_fieldvalue [exec] pg_restore: creating TABLE "rules.pr4_fieldvalue" [exec] pg_restore: processing item 544 TABLE pr4_rule [exec] pg_restore: creating TABLE "rules.pr4_rule" [exec] pg_restore: processing item 592 TABLE pr4_rule_appconfiguration [exec] pg_restore: creating TABLE "rules.pr4_rule_appconfiguration" [exec] pg_restore: processing item 527 TABLE pr4_rule_application [exec] pg_restore: creating TABLE "rules.pr4_rule_application" [exec] pg_restore: processing item 546 TABLE pr4_rule_autotest [exec] pg_restore: creating TABLE "rules.pr4_rule_autotest" [exec] pg_restore: processing item 603 TABLE pr4_rule_bi_dashboard [exec] pg_restore: creating TABLE "rules.pr4_rule_bi_dashboard" [exec] pg_restore: processing item 607 TABLE pr4_rule_bi_insight [exec] pg_restore: creating TABLE "rules.pr4_rule_bi_insight" [exec] pg_restore: processing item 602 TABLE pr4_rule_bi_queryphrase [exec] pg_restore: creating TABLE "rules.pr4_rule_bi_queryphrase" [exec] pg_restore: processing item 601 TABLE pr4_rule_bi_theme [exec] pg_restore: creating TABLE "rules.pr4_rule_bi_theme" [exec] pg_restore: processing item 596 TABLE pr4_rule_clientdata [exec] pg_restore: creating TABLE "rules.pr4_rule_clientdata" [exec] pg_restore: processing item 595 TABLE pr4_rule_connect [exec] pg_restore: creating TABLE "rules.pr4_rule_connect" [exec] pg_restore: processing item 598 TABLE pr4_rule_connect_robot [exec] pg_restore: creating TABLE "rules.pr4_rule_connect_robot" [exec] pg_restore: processing item 609 TABLE pr4_rule_dataobject [exec] pg_restore: creating TABLE "rules.pr4_rule_dataobject" [exec] pg_restore: processing item 605 TABLE pr4_rule_declare_expression [exec] pg_restore: creating TABLE "rules.pr4_rule_declare_expression" [exec] pg_restore: processing item 554 TABLE pr4_rule_declarepages [exec] pg_restore: creating TABLE "rules.pr4_rule_declarepages" [exec] pg_restore: processing item 583 TABLE pr4_rule_delegationconfig [exec] pg_restore: creating TABLE "rules.pr4_rule_delegationconfig" [exec] pg_restore: processing item 553 TABLE pr4_rule_file [exec] pg_restore: creating TABLE "rules.pr4_rule_file" [exec] pg_restore: processing item 555 TABLE pr4_rule_file_binary [exec] pg_restore: creating TABLE "rules.pr4_rule_file_binary" [exec] pg_restore: processing item 549 TABLE pr4_rule_flow [exec] pg_restore: creating TABLE "rules.pr4_rule_flow" [exec] pg_restore: processing item 525 TABLE pr4_rule_guide [exec] pg_restore: creating TABLE "rules.pr4_rule_guide" [exec] pg_restore: processing item 526 TABLE pr4_rule_html_property [exec] pg_restore: creating TABLE "rules.pr4_rule_html_property" [exec] pg_restore: processing item 582 TABLE pr4_rule_library [exec] pg_restore: creating TABLE "rules.pr4_rule_library" [exec] pg_restore: processing item 610 TABLE pr4_rule_localization [exec] pg_restore: creating TABLE "rules.pr4_rule_localization" [exec] pg_restore: processing item 580 TABLE pr4_rule_message [exec] pg_restore: creating TABLE "rules.pr4_rule_message" [exec] pg_restore: processing item 608 TABLE pr4_rule_persona [exec] pg_restore: creating TABLE "rules.pr4_rule_persona" [exec] pg_restore: processing item 593 TABLE pr4_rule_presentation [exec] pg_restore: creating TABLE "rules.pr4_rule_presentation" [exec] pg_restore: processing item 550 TABLE pr4_rule_property [exec] pg_restore: creating TABLE "rules.pr4_rule_property" [exec] pg_restore: processing item 594 TABLE pr4_rule_reports [exec] pg_restore: creating TABLE "rules.pr4_rule_reports" [exec] pg_restore: processing item 563 TABLE pr4_rule_requirement [exec] pg_restore: creating TABLE "rules.pr4_rule_requirement" [exec] pg_restore: processing item 551 TABLE pr4_rule_ruleset [exec] pg_restore: creating TABLE "rules.pr4_rule_ruleset" [exec] pg_restore: processing item 545 TABLE pr4_rule_section [exec] pg_restore: creating TABLE "rules.pr4_rule_section" [exec] pg_restore: processing item 587 TABLE pr4_rule_securitypolicies [exec] pg_restore: creating TABLE "rules.pr4_rule_securitypolicies" [exec] pg_restore: processing item 524 TABLE pr4_rule_service_rest [exec] pg_restore: creating TABLE "rules.pr4_rule_service_rest" [exec] pg_restore: processing item 547 TABLE pr4_rule_shortcut [exec] pg_restore: creating TABLE "rules.pr4_rule_shortcut" [exec] pg_restore: processing item 552 TABLE pr4_rule_sysgen [exec] pg_restore: creating TABLE "rules.pr4_rule_sysgen" [exec] pg_restore: processing item 584 TABLE pr4_rule_testcase [exec] pg_restore: creating TABLE "rules.pr4_rule_testcase" [exec] pg_restore: processing item 590 TABLE pr4_rule_testsuite [exec] pg_restore: creating TABLE "rules.pr4_rule_testsuite" [exec] pg_restore: processing item 564 TABLE pr4_rule_usecase [exec] pg_restore: creating TABLE "rules.pr4_rule_usecase" [exec] pg_restore: processing item 606 TABLE pr4_rule_view [exec] pg_restore: creating TABLE "rules.pr4_rule_view" [exec] pg_restore: processing item 548 TABLE pr4_rule_vw [exec] pg_restore: creating TABLE "rules.pr4_rule_vw" [exec] pg_restore: processing item 561 TABLE pr_app_branch_idx [exec] pg_restore: creating TABLE "rules.pr_app_branch_idx" [exec] pg_restore: processing item 559 TABLE pr_assembledclasses [exec] pg_restore: creating TABLE "rules.pr_assembledclasses" [exec] pg_restore: processing item 532 TABLE pr_changelog [exec] pg_restore: creating TABLE "rules.pr_changelog" [exec] pg_restore: processing item 575 TABLE pr_data_admin_product [exec] pg_restore: creating TABLE "rules.pr_data_admin_product" [exec] pg_restore: processing item 538 TABLE pr_data_admin_restore [exec] pg_restore: creating TABLE "rules.pr_data_admin_restore" [exec] pg_restore: processing item 585 TABLE pr_data_customproperties [exec] pg_restore: creating TABLE "rules.pr_data_customproperties" [exec] pg_restore: processing item 571 TABLE pr_data_map_entries [exec] pg_restore: creating TABLE "rules.pr_data_map_entries" [exec] pg_restore: processing item 565 TABLE pr_data_products [exec] pg_restore: creating TABLE "rules.pr_data_products" [exec] pg_restore: processing item 566 TABLE pr_data_restore [exec] pg_restore: creating TABLE "rules.pr_data_restore" [exec] pg_restore: processing item 573 TABLE pr_data_rule_appmetadata [exec] pg_restore: creating TABLE "rules.pr_data_rule_appmetadata" [exec] pg_restore: processing item 578 TABLE pr_data_scanner [exec] pg_restore: creating TABLE "rules.pr_data_scanner" [exec] pg_restore: processing item 558 TABLE pr_engineclasses [exec] pg_restore: creating TABLE "rules.pr_engineclasses" [exec] pg_restore: processing item 586 TABLE pr_index_applicationbuilton [exec] pg_restore: creating TABLE "rules.pr_index_applicationbuilton" [exec] pg_restore: processing item 604 TABLE pr_index_bi_permission [exec] pg_restore: creating TABLE "rules.pr_index_bi_permission" [exec] pg_restore: processing item 536 TABLE pr_index_circumstance_def [exec] pg_restore: creating TABLE "rules.pr_index_circumstance_def" [exec] pg_restore: processing item 540 TABLE pr_index_css [exec] pg_restore: creating TABLE "rules.pr_index_css" [exec] pg_restore: processing item 541 TABLE pr_index_customfields [exec] pg_restore: creating TABLE "rules.pr_index_customfields" [exec] pg_restore: processing item 591 TABLE pr_index_datasaveoptions [exec] pg_restore: creating TABLE "rules.pr_index_datasaveoptions" [exec] pg_restore: processing item 562 TABLE pr_index_datasources [exec] pg_restore: creating TABLE "rules.pr_index_datasources" [exec] pg_restore: processing item 611 TABLE pr_index_dpparameter [exec] pg_restore: creating TABLE "rules.pr_index_dpparameter" [exec] pg_restore: processing item 588 TABLE pr_index_policyconditions [exec] pg_restore: creating TABLE "rules.pr_index_policyconditions" [exec] pg_restore: processing item 577 TABLE pr_index_privilege [exec] pg_restore: creating TABLE "rules.pr_index_privilege" [exec] pg_restore: processing item 543 TABLE pr_index_reference [exec] pg_restore: creating TABLE "rules.pr_index_reference" [exec] pg_restore: processing item 579 TABLE pr_index_rule_agents [exec] pg_restore: creating TABLE "rules.pr_index_rule_agents" [exec] pg_restore: processing item 542 TABLE pr_index_warnings [exec] pg_restore: creating TABLE "rules.pr_index_warnings" [exec] pg_restore: processing item 589 TABLE pr_link_feature [exec] pg_restore: creating TABLE "rules.pr_link_feature" [exec] pg_restore: processing item 535 TABLE pr_link_usecase [exec] pg_restore: creating TABLE "rules.pr_link_usecase" [exec] pg_restore: processing item 599 TABLE pr_migration_point [exec] pg_restore: creating TABLE "rules.pr_migration_point" [exec] pg_restore: processing item 574 TABLE pr_reference_page [exec] pg_restore: creating TABLE "rules.pr_reference_page" [exec] pg_restore: processing item 533 TABLE pr_selectquerylog [exec] pg_restore: creating TABLE "rules.pr_selectquerylog" [exec] pg_restore: processing item 568 TABLE pr_sys_app_hierarchy_flat [exec] pg_restore: creating TABLE "rules.pr_sys_app_hierarchy_flat" [exec] pg_restore: processing item 560 TABLE pr_sys_app_ruleset_index [exec] pg_restore: creating TABLE "rules.pr_sys_app_ruleset_index" [exec] pg_restore: processing item 569 TABLE pr_sys_appcache_dep [exec] pg_restore: creating TABLE "rules.pr_sys_appcache_dep" [exec] pg_restore: processing item 567 TABLE pr_sys_appcache_entry [exec] pg_restore: creating TABLE "rules.pr_sys_appcache_entry" [exec] pg_restore: processing item 570 TABLE pr_sys_appcache_shortcut [exec] pg_restore: creating TABLE "rules.pr_sys_appcache_shortcut" [exec] pg_restore: processing item 529 TABLE pr_sys_cache_dep [exec] pg_restore: creating TABLE "rules.pr_sys_cache_dep" [exec] pg_restore: processing item 528 TABLE pr_sys_cache_entry [exec] pg_restore: creating TABLE "rules.pr_sys_cache_entry" [exec] pg_restore: processing item 530 TABLE pr_sys_cache_impl [exec] pg_restore: creating TABLE "rules.pr_sys_cache_impl" [exec] pg_restore: processing item 531 TABLE pr_sys_class_ancestors [exec] pg_restore: creating TABLE "rules.pr_sys_class_ancestors" [exec] pg_restore: processing item 557 TABLE pr_sys_decchg [exec] pg_restore: creating TABLE "rules.pr_sys_decchg" [exec] pg_restore: processing item 581 TABLE pr_sys_hotfix_events [exec] pg_restore: creating TABLE "rules.pr_sys_hotfix_events" [exec] pg_restore: processing item 597 TABLE pr_sys_import_queue [exec] pg_restore: creating TABLE "rules.pr_sys_import_queue" [exec] pg_restore: processing item 572 TABLE pr_sys_rule_impl [exec] pg_restore: creating TABLE "rules.pr_sys_rule_impl" [exec] pg_restore: processing item 556 TABLE pr_sys_ruleset_index [exec] pg_restore: creating TABLE "rules.pr_sys_ruleset_index" [exec] pg_restore: processing item 600 TABLE pr_sys_runtime_context [exec] pg_restore: creating TABLE "rules.pr_sys_runtime_context" [exec] pg_restore: processing item 576 TABLE pr_sysgen_static_content [exec] pg_restore: creating TABLE "rules.pr_sysgen_static_content" [exec] pg_restore: processing item 615 TABLE prpc_install_log [exec] pg_restore: creating TABLE "rules.prpc_install_log" [exec] pg_restore: processing item 612 VIEW pwbv4_circumstance_duplicates [exec] pg_restore: creating VIEW "rules.pwbv4_circumstance_duplicates" [exec] pg_restore: processing item 613 VIEW pwbv4_rule_locking [exec] pg_restore: creating VIEW "rules.pwbv4_rule_locking" [exec] pg_restore: processing item 614 VIEW pwbv4_rule_overrides [exec] pg_restore: creating VIEW "rules.pwbv4_rule_overrides" [exec] pg_restore: entering main parallel loop [exec] pg_restore: launching item 6583 TABLE DATA p_address [exec] pg_restore: launching item 6584 TABLE DATA p_contact [exec] pg_restore: launching item 6579 TABLE DATA p_contactcontactrel [exec] pg_restore: launching item 6580 TABLE DATA p_contactorgrel [exec] pg_restore: processing data for table "data.p_contactcontactrel" [exec] pg_restore: finished item 6579 TABLE DATA p_contactcontactrel [exec] pg_restore: launching item 6585 TABLE DATA p_organization [exec] pg_restore: processing data for table "data.p_organization" [exec] pg_restore: finished item 6585 TABLE DATA p_organization [exec] pg_restore: launching item 6581 TABLE DATA p_orgorgrel [exec] pg_restore: processing data for table "data.p_orgorgrel" [exec] pg_restore: finished item 6581 TABLE DATA p_orgorgrel [exec] pg_restore: launching item 6582 TABLE DATA p_role [exec] pg_restore: processing data for table "data.p_role" [exec] pg_restore: processing data for table "data.p_contactorgrel" [exec] pg_restore: finished item 6582 TABLE DATA p_role [exec] pg_restore: launching item 6512 TABLE DATA pc_apn_token [exec] pg_restore: processing data for table "data.pc_apn_token" [exec] pg_restore: finished item 6580 TABLE DATA p_contactorgrel [exec] pg_restore: launching item 6406 TABLE DATA pc_assign_workbasket [exec] pg_restore: processing data for table "data.pc_assign_workbasket" [exec] pg_restore: finished item 6512 TABLE DATA pc_apn_token [exec] pg_restore: launching item 6407 TABLE DATA pc_assign_worklist [exec] pg_restore: processing data for table "data.pc_assign_worklist" [exec] pg_restore: finished item 6407 TABLE DATA pc_assign_worklist [exec] pg_restore: launching item 6469 TABLE DATA pc_cep_actions_repository [exec] pg_restore: processing data for table "data.pc_cep_actions_repository" [exec] pg_restore: finished item 6469 TABLE DATA pc_cep_actions_repository [exec] pg_restore: launching item 6470 TABLE DATA pc_cep_events_repository [exec] pg_restore: processing data for table "data.pc_cep_events_repository" [exec] pg_restore: processing data for table "data.p_contact" [exec] pg_restore: finished item 6406 TABLE DATA pc_assign_workbasket [exec] pg_restore: launching item 6617 TABLE DATA pc_clientdata_restriction [exec] pg_restore: processing data for table "data.pc_clientdata_restriction" [exec] pg_restore: finished item 6584 TABLE DATA p_contact [exec] pg_restore: launching item 6383 TABLE DATA pc_data_adm_seccorspol [exec] pg_restore: processing data for table "data.pc_data_adm_seccorspol" [exec] pg_restore: processing data for table "data.p_address" [exec] pg_restore: finished item 6470 TABLE DATA pc_cep_events_repository [exec] pg_restore: launching item 6384 TABLE DATA pc_data_adm_seckeyid [exec] pg_restore: processing data for table "data.pc_data_adm_seckeyid" [exec] pg_restore: finished item 6617 TABLE DATA pc_clientdata_restriction [exec] pg_restore: launching item 6642 TABLE DATA pc_data_file_temp [exec] pg_restore: processing data for table "data.pc_data_file_temp" [exec] pg_restore: finished item 6583 TABLE DATA p_address [exec] pg_restore: launching item 6387 TABLE DATA pc_data_notiftn_param [exec] pg_restore: processing data for table "data.pc_data_notiftn_param" [exec] pg_restore: finished item 6383 TABLE DATA pc_data_adm_seccorspol [exec] pg_restore: launching item 6408 TABLE DATA pc_data_uniqueid [exec] pg_restore: finished item 6642 TABLE DATA pc_data_file_temp [exec] pg_restore: launching item 6409 TABLE DATA pc_data_workattach [exec] pg_restore: processing data for table "data.pc_data_uniqueid" [exec] pg_restore: processing data for table "data.pc_data_workattach" [exec] pg_restore: finished item 6384 TABLE DATA pc_data_adm_seckeyid [exec] pg_restore: launching item 6416 TABLE DATA pc_events [exec] pg_restore: processing data for table "data.pc_events" [exec] pg_restore: finished item 6387 TABLE DATA pc_data_notiftn_param [exec] pg_restore: launching item 6633 TABLE DATA pc_flaudit [exec] pg_restore: processing data for table "data.pc_flaudit" [exec] pg_restore: finished item 6408 TABLE DATA pc_data_uniqueid [exec] pg_restore: launching item 6513 TABLE DATA pc_gcm_token [exec] pg_restore: processing data for table "data.pc_gcm_token" [exec] pg_restore: finished item 6409 TABLE DATA pc_data_workattach [exec] pg_restore: launching item 6530 TABLE DATA pc_history_data_dms_work [exec] pg_restore: processing data for table "data.pc_history_data_dms_work" [exec] pg_restore: finished item 6513 TABLE DATA pc_gcm_token [exec] pg_restore: launching item 6628 TABLE DATA pc_history_document [exec] pg_restore: processing data for table "data.pc_history_document" [exec] pg_restore: finished item 6416 TABLE DATA pc_events [exec] pg_restore: launching item 6600 TABLE DATA pc_history_group [exec] pg_restore: processing data for table "data.pc_history_group" [exec] pg_restore: finished item 6633 TABLE DATA pc_flaudit [exec] pg_restore: launching item 6410 TABLE DATA pc_history_work [exec] pg_restore: processing data for table "data.pc_history_work" [exec] pg_restore: finished item 6628 TABLE DATA pc_history_document [exec] pg_restore: launching item 6620 TABLE DATA pc_history_work_cover_task [exec] pg_restore: processing data for table "data.pc_history_work_cover_task" [exec] pg_restore: finished item 6530 TABLE DATA pc_history_data_dms_work [exec] pg_restore: launching item 6404 TABLE DATA pc_index_accel [exec] pg_restore: processing data for table "data.pc_index_accel" [exec] pg_restore: finished item 6620 TABLE DATA pc_history_work_cover_task [exec] pg_restore: launching item 6536 TABLE DATA pc_index_location [exec] pg_restore: processing data for table "data.pc_index_location" [exec] pg_restore: finished item 6600 TABLE DATA pc_history_group [exec] pg_restore: launching item 6411 TABLE DATA pc_index_workparty [exec] pg_restore: processing data for table "data.pc_index_workparty" [exec] pg_restore: finished item 6536 TABLE DATA pc_index_location [exec] pg_restore: launching item 6557 TABLE DATA pc_link_association [exec] pg_restore: processing data for table "data.pc_link_association" [exec] pg_restore: finished item 6557 TABLE DATA pc_link_association [exec] pg_restore: launching item 6635 TABLE DATA pc_link_association_channel [exec] pg_restore: processing data for table "data.pc_link_association_channel" [exec] pg_restore: finished item 6635 TABLE DATA pc_link_association_channel [exec] pg_restore: launching item 6573 TABLE DATA pc_link_association_doc [exec] pg_restore: processing data for table "data.pc_link_association_doc" [exec] pg_restore: finished item 6573 TABLE DATA pc_link_association_doc [exec] pg_restore: launching item 6601 TABLE DATA pc_link_association_member [exec] pg_restore: processing data for table "data.pc_link_association_member" [exec] pg_restore: finished item 6601 TABLE DATA pc_link_association_member [exec] pg_restore: launching item 6614 TABLE DATA pc_link_association_pin [exec] pg_restore: processing data for table "data.pc_link_association_pin" [exec] pg_restore: finished item 6614 TABLE DATA pc_link_association_pin [exec] pg_restore: launching item 6631 TABLE DATA pc_link_association_rrcategory [exec] pg_restore: processing data for table "data.pc_link_association_rrcategory" [exec] pg_restore: finished item 6631 TABLE DATA pc_link_association_rrcategory [exec] pg_restore: launching item 6618 TABLE DATA pc_link_association_space [exec] pg_restore: processing data for table "data.pc_link_association_space" [exec] pg_restore: finished item 6618 TABLE DATA pc_link_association_space [exec] pg_restore: launching item 6412 TABLE DATA pc_link_attachment [exec] pg_restore: processing data for table "data.pc_link_attachment" [exec] pg_restore: finished item 6412 TABLE DATA pc_link_attachment [exec] pg_restore: launching item 6598 TABLE DATA pc_link_category [exec] pg_restore: processing data for table "data.pc_link_category" [exec] pg_restore: finished item 6598 TABLE DATA pc_link_category [exec] pg_restore: launching item 6413 TABLE DATA pc_link_folder [exec] pg_restore: processing data for table "data.pc_link_folder" [exec] pg_restore: finished item 6404 TABLE DATA pc_index_accel [exec] pg_restore: launching item 6439 TABLE DATA pc_link_topcase [exec] pg_restore: processing data for table "data.pc_link_topcase" [exec] pg_restore: finished item 6413 TABLE DATA pc_link_folder [exec] pg_restore: launching item 6507 TABLE DATA pc_pegatask [exec] pg_restore: processing data for table "data.pc_pegatask" [exec] pg_restore: finished item 6410 TABLE DATA pc_history_work [exec] pg_restore: launching item 6415 TABLE DATA pc_schedule_task [exec] pg_restore: processing data for table "data.pc_schedule_task" [exec] pg_restore: finished item 6507 TABLE DATA pc_pegatask [exec] pg_restore: launching item 6417 TABLE DATA pc_work [exec] pg_restore: processing data for table "data.pc_work" [exec] pg_restore: finished item 6415 TABLE DATA pc_schedule_task [exec] pg_restore: launching item 6414 TABLE DATA pc_work_accel [exec] pg_restore: processing data for table "data.pc_work_accel" [exec] pg_restore: finished item 6417 TABLE DATA pc_work [exec] pg_restore: launching item 6556 TABLE DATA pc_work_agile [exec] pg_restore: processing data for table "data.pc_work_agile" [exec] pg_restore: finished item 6411 TABLE DATA pc_index_workparty [exec] pg_restore: launching item 6604 TABLE DATA pc_work_clientdata [exec] pg_restore: processing data for table "data.pc_work_clientdata" [exec] pg_restore: finished item 6414 TABLE DATA pc_work_accel [exec] pg_restore: launching item 6619 TABLE DATA pc_work_cover_task [exec] pg_restore: processing data for table "data.pc_work_cover_task" [exec] pg_restore: finished item 6604 TABLE DATA pc_work_clientdata [exec] pg_restore: launching item 6529 TABLE DATA pc_work_dms [exec] pg_restore: processing data for table "data.pc_work_dms" [exec] pg_restore: finished item 6556 TABLE DATA pc_work_agile [exec] pg_restore: launching item 6572 TABLE DATA pc_work_document [exec] pg_restore: processing data for table "data.pc_work_document" [exec] pg_restore: finished item 6529 TABLE DATA pc_work_dms [exec] pg_restore: launching item 6419 TABLE DATA pc_work_dsm_batch [exec] pg_restore: processing data for table "data.pc_work_dsm_batch" [exec] pg_restore: finished item 6619 TABLE DATA pc_work_cover_task [exec] pg_restore: launching item 6650 TABLE DATA pc_work_dsm_simulation [exec] pg_restore: processing data for table "data.pc_work_dsm_simulation" [exec] pg_restore: finished item 6572 TABLE DATA pc_work_document [exec] pg_restore: launching item 6599 TABLE DATA pc_work_group [exec] pg_restore: processing data for table "data.pc_work_group" [exec] pg_restore: finished item 6419 TABLE DATA pc_work_dsm_batch [exec] pg_restore: launching item 6558 TABLE DATA pc_work_guide [exec] pg_restore: processing data for table "data.pc_work_guide" [exec] pg_restore: finished item 6599 TABLE DATA pc_work_group [exec] pg_restore: launching item 6553 TABLE DATA pc_work_notification [exec] pg_restore: processing data for table "data.pc_work_notification" [exec] pg_restore: finished item 6650 TABLE DATA pc_work_dsm_simulation [exec] pg_restore: launching item 6646 TABLE DATA pc_work_prediction [exec] pg_restore: processing data for table "data.pc_work_prediction" [exec] pg_restore: finished item 6439 TABLE DATA pc_link_topcase [exec] pg_restore: launching item 6418 TABLE DATA pc_work_processemail [exec] pg_restore: processing data for table "data.pc_work_processemail" [exec] pg_restore: finished item 6558 TABLE DATA pc_work_guide [exec] pg_restore: launching item 6489 TABLE DATA pc_work_social [exec] pg_restore: processing data for table "data.pc_work_social" [exec] pg_restore: finished item 6418 TABLE DATA pc_work_processemail [exec] pg_restore: launching item 6644 TABLE DATA pc_work_triage [exec] pg_restore: processing data for table "data.pc_work_triage" [exec] pg_restore: finished item 6553 TABLE DATA pc_work_notification [exec] pg_restore: launching item 6420 TABLE DATA pi_data_connect [exec] pg_restore: processing data for table "data.pi_data_connect" [exec] pg_restore: finished item 6644 TABLE DATA pc_work_triage [exec] pg_restore: launching item 6435 TABLE DATA pr4_history_rule [exec] pg_restore: processing data for table "data.pr4_history_rule" [exec] pg_restore: finished item 6420 TABLE DATA pi_data_connect [exec] pg_restore: launching item 6472 TABLE DATA pr4_log_rule_usage [exec] pg_restore: processing data for table "data.pr4_log_rule_usage" [exec] pg_restore: finished item 6435 TABLE DATA pr4_history_rule [exec] pg_restore: launching item 6473 TABLE DATA pr4_log_rule_usage_details [exec] pg_restore: processing data for table "data.pr4_log_rule_usage_details" [exec] pg_restore: finished item 6473 TABLE DATA pr4_log_rule_usage_details [exec] pg_restore: launching item 6658 TABLE DATA pr_archival_class_dependency [exec] pg_restore: processing data for table "data.pr_archival_class_dependency" [exec] pg_restore: finished item 6489 TABLE DATA pc_work_social [exec] pg_restore: launching item 6665 TABLE DATA pr_archival_excluded_case [exec] pg_restore: processing data for table "data.pr_archival_excluded_case" [exec] pg_restore: finished item 6658 TABLE DATA pr_archival_class_dependency [exec] pg_restore: launching item 6421 TABLE DATA pr_assign [exec] pg_restore: processing data for table "data.pr_assign" [exec] pg_restore: finished item 6665 TABLE DATA pr_archival_excluded_case [exec] pg_restore: launching item 6466 TABLE DATA pr_cep_events_queue [exec] pg_restore: processing data for table "data.pr_cep_events_queue" [exec] pg_restore: finished item 6421 TABLE DATA pr_assign [exec] pg_restore: launching item 6467 TABLE DATA pr_cep_eventslookup [exec] pg_restore: processing data for table "data.pr_cep_eventslookup" [exec] pg_restore: finished item 6466 TABLE DATA pr_cep_events_queue [exec] pg_restore: launching item 6468 TABLE DATA pr_cep_user_subscriptions [exec] pg_restore: processing data for table "data.pr_cep_user_subscriptions" [exec] pg_restore: finished item 6467 TABLE DATA pr_cep_eventslookup [exec] pg_restore: launching item 6479 TABLE DATA pr_daily_usage [exec] pg_restore: processing data for table "data.pr_daily_usage" [exec] pg_restore: finished item 6479 TABLE DATA pr_daily_usage [exec] pg_restore: launching item 6423 TABLE DATA pr_data [exec] pg_restore: processing data for table "data.pr_data" [exec] pg_restore: finished item 6468 TABLE DATA pr_cep_user_subscriptions [exec] pg_restore: launching item 6549 TABLE DATA pr_data_adm_configuration [exec] pg_restore: processing data for table "data.pr_data_adm_configuration" [exec] pg_restore: finished item 6549 TABLE DATA pr_data_adm_configuration [exec] pg_restore: launching item 6550 TABLE DATA pr_data_adm_factory [exec] pg_restore: processing data for table "data.pr_data_adm_factory" [exec] pg_restore: finished item 6550 TABLE DATA pr_data_adm_factory [exec] pg_restore: launching item 6424 TABLE DATA pr_data_admin [exec] pg_restore: processing data for table "data.pr_data_admin" [exec] pg_restore: finished item 6472 TABLE DATA pr4_log_rule_usage [exec] pg_restore: launching item 6602 TABLE DATA pr_data_admin_auth_code [exec] pg_restore: processing data for table "data.pr_data_admin_auth_code" [exec] pg_restore: finished item 6646 TABLE DATA pc_work_prediction [exec] pg_restore: launching item 6649 TABLE DATA pr_data_admin_dds_table [exec] pg_restore: processing data for table "data.pr_data_admin_dds_table" [exec] pg_restore: finished item 6602 TABLE DATA pr_data_admin_auth_code [exec] pg_restore: launching item 6622 TABLE DATA pr_data_admin_sec_cert [exec] pg_restore: processing data for table "data.pr_data_admin_sec_cert" [exec] pg_restore: finished item 6424 TABLE DATA pr_data_admin [exec] pg_restore: launching item 6559 TABLE DATA pr_data_admin_sec_de_cdk [exec] pg_restore: processing data for table "data.pr_data_admin_sec_de_cdk" [exec] pg_restore: finished item 6423 TABLE DATA pr_data [exec] pg_restore: launching item 6560 TABLE DATA pr_data_admin_sec_de_key [exec] pg_restore: processing data for table "data.pr_data_admin_sec_de_key" [exec] pg_restore: finished item 6649 TABLE DATA pr_data_admin_dds_table [exec] pg_restore: launching item 6592 TABLE DATA pr_data_admin_sec_sde_cdk [exec] pg_restore: processing data for table "data.pr_data_admin_sec_sde_cdk" [exec] pg_restore: finished item 6559 TABLE DATA pr_data_admin_sec_de_cdk [exec] pg_restore: launching item 6425 TABLE DATA pr_data_admin_tenant [exec] pg_restore: processing data for table "data.pr_data_admin_tenant" [exec] pg_restore: finished item 6560 TABLE DATA pr_data_admin_sec_de_key [exec] pg_restore: launching item 6401 TABLE DATA pr_data_analysis_specification [exec] pg_restore: processing data for table "data.pr_data_analysis_specification" [exec] pg_restore: finished item 6622 TABLE DATA pr_data_admin_sec_cert [exec] pg_restore: launching item 6641 TABLE DATA pr_data_app_oauth2client [exec] pg_restore: pg_restore: processing data for table "data.pr_data_app_oauth2client" [exec] finished item 6592 TABLE DATA pr_data_admin_sec_sde_cdk [exec] pg_restore: launching item 6648 TABLE DATA pr_data_appalias_authservice [exec] pg_restore: processing data for table "data.pr_data_appalias_authservice" [exec] pg_restore: finished item 6425 TABLE DATA pr_data_admin_tenant [exec] pg_restore: launching item 6613 TABLE DATA pr_data_application_quality [exec] pg_restore: processing data for table "data.pr_data_application_quality" [exec] pg_restore: finished item 6401 TABLE DATA pr_data_analysis_specification [exec] pg_restore: launching item 6570 TABLE DATA pr_data_applicationpreference [exec] pg_restore: processing data for table "data.pr_data_applicationpreference" [exec] pg_restore: finished item 6648 TABLE DATA pr_data_appalias_authservice [exec] pg_restore: launching item 6670 TABLE DATA pr_data_archivalmigration [exec] pg_restore: processing data for table "data.pr_data_archivalmigration" [exec] pg_restore: finished item 6641 TABLE DATA pr_data_app_oauth2client [exec] pg_restore: launching item 6405 TABLE DATA pr_data_autotest [exec] pg_restore: processing data for table "data.pr_data_autotest" [exec] pg_restore: finished item 6613 TABLE DATA pr_data_application_quality [exec] pg_restore: launching item 6597 TABLE DATA pr_data_category [exec] pg_restore: processing data for table "data.pr_data_category" [exec] pg_restore: finished item 6570 TABLE DATA pr_data_applicationpreference [exec] pg_restore: launching item 6632 TABLE DATA pr_data_collaboration [exec] pg_restore: processing data for table "data.pr_data_collaboration" [exec] pg_restore: finished item 6632 TABLE DATA pr_data_collaboration [exec] pg_restore: launching item 6657 TABLE DATA pr_data_configuration_audit [exec] pg_restore: processing data for table "data.pr_data_configuration_audit" [exec] pg_restore: finished item 6657 TABLE DATA pr_data_configuration_audit [exec] pg_restore: launching item 6652 TABLE DATA pr_data_configuration_setting [exec] pg_restore: processing data for table "data.pr_data_configuration_setting" [exec] pg_restore: finished item 6652 TABLE DATA pr_data_configuration_setting [exec] pg_restore: launching item 6664 TABLE DATA pr_data_conversation_event [exec] pg_restore: processing data for table "data.pr_data_conversation_event" [exec] pg_restore: finished item 6405 TABLE DATA pr_data_autotest [exec] pg_restore: launching item 6663 TABLE DATA pr_data_conversation_summary [exec] pg_restore: processing data for table "data.pr_data_conversation_summary" [exec] pg_restore: finished item 6664 TABLE DATA pr_data_conversation_event [exec] pg_restore: launching item 6386 TABLE DATA pr_data_custm_date_fmt [exec] pg_restore: processing data for table "data.pr_data_custm_date_fmt" [exec] pg_restore: finished item 6670 TABLE DATA pr_data_archivalmigration [exec] pg_restore: launching item 6671 TABLE DATA pr_data_customer_interaction [exec] pg_restore: processing data for table "data.pr_data_customer_interaction" [exec] pg_restore: finished item 6597 TABLE DATA pr_data_category [exec] pg_restore: launching item 6634 TABLE DATA pr_data_decision_biasresults [exec] pg_restore: processing data for table "data.pr_data_decision_biasresults" [exec] pg_restore: finished item 6386 TABLE DATA pr_data_custm_date_fmt [exec] pg_restore: launching item 6532 TABLE DATA pr_data_decision_ddf_error [exec] pg_restore: processing data for table "data.pr_data_decision_ddf_error" [exec] pg_restore: finished item 6663 TABLE DATA pr_data_conversation_summary [exec] pg_restore: launching item 6588 TABLE DATA pr_data_decision_ddf_run_opts [exec] pg_restore: processing data for table "data.pr_data_decision_ddf_run_opts" [exec] pg_restore: finished item 6634 TABLE DATA pr_data_decision_biasresults [exec] pg_restore: launching item 6391 TABLE DATA pr_data_decision_ddf_runtime [exec] pg_restore: processing data for table "data.pr_data_decision_ddf_runtime" [exec] pg_restore: finished item 6671 TABLE DATA pr_data_customer_interaction [exec] pg_restore: launching item 6390 TABLE DATA pr_data_decision_df_met [exec] pg_restore: processing data for table "data.pr_data_decision_df_met" [exec] pg_restore: finished item 6532 TABLE DATA pr_data_decision_ddf_error [exec] pg_restore: launching item 6389 TABLE DATA pr_data_decision_df_part [exec] pg_restore: processing data for table "data.pr_data_decision_df_part" [exec] pg_restore: finished item 6391 TABLE DATA pr_data_decision_ddf_runtime [exec] pg_restore: launching item 6562 TABLE DATA pr_data_distinctvalueindex [exec] pg_restore: processing data for table "data.pr_data_distinctvalueindex" [exec] pg_restore: finished item 6588 TABLE DATA pr_data_decision_ddf_run_opts [exec] pg_restore: launching item 6493 TABLE DATA pr_data_dm_admmart_mdl_fact [exec] pg_restore: processing data for table "data.pr_data_dm_admmart_mdl_fact" [exec] pg_restore: finished item 6390 TABLE DATA pr_data_decision_df_met [exec] pg_restore: launching item 6492 TABLE DATA pr_data_dm_admmart_model [exec] pg_restore: processing data for table "data.pr_data_dm_admmart_model" [exec] pg_restore: finished item 6389 TABLE DATA pr_data_decision_df_part [exec] pg_restore: launching item 6380 TABLE DATA pr_data_dm_admmart_pred [exec] pg_restore: processing data for table "data.pr_data_dm_admmart_pred" [exec] pg_restore: finished item 6562 TABLE DATA pr_data_distinctvalueindex [exec] pg_restore: launching item 6607 TABLE DATA pr_data_dm_binarydistribution [exec] pg_restore: processing data for table "data.pr_data_dm_binarydistribution" [exec] pg_restore: finished item 6493 TABLE DATA pr_data_dm_admmart_mdl_fact [exec] pg_restore: launching item 6610 TABLE DATA pr_data_dm_contingencytable [exec] pg_restore: processing data for table "data.pr_data_dm_contingencytable" [exec] pg_restore: finished item 6492 TABLE DATA pr_data_dm_admmart_model [exec] pg_restore: launching item 6668 TABLE DATA pr_data_dm_distribution [exec] pg_restore: processing data for table "data.pr_data_dm_distribution" [exec] pg_restore: finished item 6607 TABLE DATA pr_data_dm_binarydistribution [exec] pg_restore: launching item 6608 TABLE DATA pr_data_dm_histogram [exec] pg_restore: processing data for table "data.pr_data_dm_histogram" [exec] pg_restore: finished item 6380 TABLE DATA pr_data_dm_admmart_pred [exec] pg_restore: launching item 6625 TABLE DATA pr_data_dm_notification [exec] pg_restore: processing data for table "data.pr_data_dm_notification" [exec] pg_restore: finished item 6608 TABLE DATA pr_data_dm_histogram [exec] pg_restore: launching item 6609 TABLE DATA pr_data_dm_snapshot [exec] pg_restore: processing data for table "data.pr_data_dm_snapshot" [exec] pg_restore: finished item 6668 TABLE DATA pr_data_dm_distribution [exec] pg_restore: launching item 6669 TABLE DATA pr_data_dm_summary [exec] pg_restore: processing data for table "data.pr_data_dm_summary" [exec] pg_restore: finished item 6625 TABLE DATA pr_data_dm_notification [exec] pg_restore: launching item 6605 TABLE DATA pr_data_dmorg_dmsample_circle [exec] pg_restore: processing data for table "data.pr_data_dmorg_dmsample_circle" [exec] pg_restore: finished item 6610 TABLE DATA pr_data_dm_contingencytable [exec] pg_restore: launching item 6521 TABLE DATA pr_data_dms_customer_data [exec] pg_restore: processing data for table "data.pr_data_dms_customer_data" [exec] pg_restore: finished item 6605 TABLE DATA pr_data_dmorg_dmsample_circle [exec] pg_restore: launching item 6522 TABLE DATA pr_data_dms_device [exec] pg_restore: processing data for table "data.pr_data_dms_device" [exec] pg_restore: finished item 6521 TABLE DATA pr_data_dms_customer_data [exec] pg_restore: launching item 6525 TABLE DATA pr_data_dms_droppedcallevents [exec] pg_restore: processing data for table "data.pr_data_dms_droppedcallevents" [exec] pg_restore: finished item 6609 TABLE DATA pr_data_dm_snapshot [exec] pg_restore: launching item 6526 TABLE DATA pr_data_dms_global [exec] pg_restore: processing data for table "data.pr_data_dms_global" [exec] pg_restore: finished item 6525 TABLE DATA pr_data_dms_droppedcallevents [exec] pg_restore: launching item 6523 TABLE DATA pr_data_dms_purchase [exec] pg_restore: processing data for table "data.pr_data_dms_purchase" [exec] pg_restore: finished item 6522 TABLE DATA pr_data_dms_device [exec] pg_restore: launching item 6524 TABLE DATA pr_data_dms_subscription [exec] pg_restore: processing data for table "data.pr_data_dms_subscription" [exec] pg_restore: finished item 6669 TABLE DATA pr_data_dm_summary [exec] pg_restore: launching item 6548 TABLE DATA pr_data_dms_survey_data [exec] pg_restore: processing data for table "data.pr_data_dms_survey_data" [exec] pg_restore: finished item 6548 TABLE DATA pr_data_dms_survey_data [exec] pg_restore: launching item 6621 TABLE DATA pr_data_explain_simulation [exec] pg_restore: processing data for table "data.pr_data_explain_simulation" [exec] pg_restore: finished item 6523 TABLE DATA pr_data_dms_purchase [exec] pg_restore: launching item 6551 TABLE DATA pr_data_features [exec] pg_restore: processing data for table "data.pr_data_features" [exec] pg_restore: finished item 6526 TABLE DATA pr_data_dms_global [exec] pg_restore: launching item 6399 TABLE DATA pr_data_file [exec] pg_restore: processing data for table "data.pr_data_file" [exec] pg_restore: finished item 6524 TABLE DATA pr_data_dms_subscription [exec] pg_restore: launching item 6623 TABLE DATA pr_data_full_sync_stats [exec] pg_restore: processing data for table "data.pr_data_full_sync_stats" [exec] pg_restore: finished item 6623 TABLE DATA pr_data_full_sync_stats [exec] pg_restore: launching item 6400 TABLE DATA pr_data_guardrails [exec] pg_restore: processing data for table "data.pr_data_guardrails" [exec] pg_restore: finished item 6621 TABLE DATA pr_data_explain_simulation [exec] pg_restore: launching item 6636 TABLE DATA pr_data_guardrails_evaluation [exec] pg_restore: processing data for table "data.pr_data_guardrails_evaluation" [exec] pg_restore: finished item 6399 TABLE DATA pr_data_file [exec] pg_restore: launching item 6637 TABLE DATA pr_data_guardrails_runstatus [exec] pg_restore: processing data for table "data.pr_data_guardrails_runstatus" [exec] pg_restore: finished item 6400 TABLE DATA pr_data_guardrails [exec] pg_restore: launching item 6611 TABLE DATA pr_data_healthcheck [exec] pg_restore: processing data for table "data.pr_data_healthcheck" [exec] pg_restore: finished item 6636 TABLE DATA pr_data_guardrails_evaluation [exec] pg_restore: launching item 6506 TABLE DATA pr_data_ih_association [exec] pg_restore: processing data for table "data.pr_data_ih_association" [exec] pg_restore: finished item 6551 TABLE DATA pr_data_features [exec] pg_restore: launching item 6497 TABLE DATA pr_data_ih_dim_action [exec] pg_restore: processing data for table "data.pr_data_ih_dim_action" [exec] pg_restore: finished item 6611 TABLE DATA pr_data_healthcheck [exec] pg_restore: launching item 6502 TABLE DATA pr_data_ih_dim_application [exec] pg_restore: processing data for table "data.pr_data_ih_dim_application" [exec] pg_restore: finished item 6637 TABLE DATA pr_data_guardrails_runstatus [exec] pg_restore: launching item 6503 TABLE DATA pr_data_ih_dim_channel [exec] pg_restore: processing data for table "data.pr_data_ih_dim_channel" [exec] pg_restore: finished item 6506 TABLE DATA pr_data_ih_association [exec] pg_restore: launching item 6501 TABLE DATA pr_data_ih_dim_context [exec] pg_restore: processing data for table "data.pr_data_ih_dim_context" [exec] pg_restore: finished item 6502 TABLE DATA pr_data_ih_dim_application [exec] pg_restore: launching item 6498 TABLE DATA pr_data_ih_dim_customer [exec] pg_restore: processing data for table "data.pr_data_ih_dim_customer" [exec] pg_restore: finished item 6501 TABLE DATA pr_data_ih_dim_context [exec] pg_restore: launching item 6561 TABLE DATA pr_data_ih_dim_journey [exec] pg_restore: processing data for table "data.pr_data_ih_dim_journey" [exec] pg_restore: finished item 6503 TABLE DATA pr_data_ih_dim_channel [exec] pg_restore: launching item 6499 TABLE DATA pr_data_ih_dim_location [exec] pg_restore: processing data for table "data.pr_data_ih_dim_location" [exec] pg_restore: finished item 6499 TABLE DATA pr_data_ih_dim_location [exec] pg_restore: launching item 6500 TABLE DATA pr_data_ih_dim_operator [exec] pg_restore: processing data for table "data.pr_data_ih_dim_operator" [exec] pg_restore: finished item 6561 TABLE DATA pr_data_ih_dim_journey [exec] pg_restore: launching item 6504 TABLE DATA pr_data_ih_dim_outcome [exec] pg_restore: processing data for table "data.pr_data_ih_dim_outcome" [exec] pg_restore: finished item 6504 TABLE DATA pr_data_ih_dim_outcome [exec] pg_restore: launching item 6505 TABLE DATA pr_data_ih_fact [exec] pg_restore: processing data for table "data.pr_data_ih_fact" [exec] pg_restore: finished item 6500 TABLE DATA pr_data_ih_dim_operator [exec] pg_restore: launching item 6612 TABLE DATA pr_data_integrationsystem [exec] pg_restore: processing data for table "data.pr_data_integrationsystem" [exec] pg_restore: finished item 6497 TABLE DATA pr_data_ih_dim_action [exec] pg_restore: launching item 6388 TABLE DATA pr_data_mobile_app_pf_asset [exec] pg_restore: processing data for table "data.pr_data_mobile_app_pf_asset" [exec] pg_restore: finished item 6612 TABLE DATA pr_data_integrationsystem [exec] pg_restore: launching item 6511 TABLE DATA pr_data_mobile_appinfo [exec] pg_restore: processing data for table "data.pr_data_mobile_appinfo" [exec] pg_restore: finished item 6505 TABLE DATA pr_data_ih_fact [exec] pg_restore: launching item 6509 TABLE DATA pr_data_mobile_asset [exec] pg_restore: processing data for table "data.pr_data_mobile_asset" [exec] pg_restore: finished item 6388 TABLE DATA pr_data_mobile_app_pf_asset [exec] pg_restore: launching item 6508 TABLE DATA pr_data_mobile_build [exec] pg_restore: processing data for table "data.pr_data_mobile_build" [exec] pg_restore: finished item 6511 TABLE DATA pr_data_mobile_appinfo [exec] pg_restore: launching item 6510 TABLE DATA pr_data_mobile_certificate [exec] pg_restore: processing data for table "data.pr_data_mobile_certificate" [exec] pg_restore: finished item 6509 TABLE DATA pr_data_mobile_asset [exec] pg_restore: launching item 6541 TABLE DATA pr_data_mobile_device [exec] pg_restore: processing data for table "data.pr_data_mobile_device" [exec] pg_restore: finished item 6508 TABLE DATA pr_data_mobile_build [exec] pg_restore: launching item 6575 TABLE DATA pr_data_mobile_map_track [exec] pg_restore: processing data for table "data.pr_data_mobile_map_track" [exec] pg_restore: finished item 6510 TABLE DATA pr_data_mobile_certificate [exec] pg_restore: launching item 6576 TABLE DATA pr_data_mobile_map_user [exec] pg_restore: processing data for table "data.pr_data_mobile_map_user" [exec] pg_restore: finished item 6498 TABLE DATA pr_data_ih_dim_customer [exec] pg_restore: launching item 6667 TABLE DATA pr_data_nlp_deployprediction [exec] pg_restore: processing data for table "data.pr_data_nlp_deployprediction" [exec] pg_restore: finished item 6575 TABLE DATA pr_data_mobile_map_track [exec] pg_restore: launching item 6534 TABLE DATA pr_data_nlp_details [exec] pg_restore: processing data for table "data.pr_data_nlp_details" [exec] pg_restore: finished item 6541 TABLE DATA pr_data_mobile_device [exec] pg_restore: launching item 6563 TABLE DATA pr_data_nlp_model_training [exec] pg_restore: processing data for table "data.pr_data_nlp_model_training" [exec] pg_restore: finished item 6534 TABLE DATA pr_data_nlp_details [exec] pg_restore: launching item 6654 TABLE DATA pr_data_nlp_reporting [exec] pg_restore: processing data for table "data.pr_data_nlp_reporting" [exec] pg_restore: finished item 6667 TABLE DATA pr_data_nlp_deployprediction [exec] pg_restore: launching item 6661 TABLE DATA pr_data_nlp_simulationinput [exec] pg_restore: processing data for table "data.pr_data_nlp_simulationinput" [exec] pg_restore: finished item 6563 TABLE DATA pr_data_nlp_model_training [exec] pg_restore: launching item 6660 TABLE DATA pr_data_nlp_simulationresult [exec] pg_restore: processing data for table "data.pr_data_nlp_simulationresult" [exec] pg_restore: finished item 6654 TABLE DATA pr_data_nlp_reporting [exec] pg_restore: launching item 6653 TABLE DATA pr_data_nlp_snapshot [exec] pg_restore: processing data for table "data.pr_data_nlp_snapshot" [exec] pg_restore: finished item 6576 TABLE DATA pr_data_mobile_map_user [exec] pg_restore: launching item 6647 TABLE DATA pr_data_nlp_status [exec] pg_restore: processing data for table "data.pr_data_nlp_status" [exec] pg_restore: finished item 6660 TABLE DATA pr_data_nlp_simulationresult [exec] pg_restore: launching item 6533 TABLE DATA pr_data_nlp_summary [exec] pg_restore: pg_restore: finished item 6653 TABLE DATA pr_data_nlp_snapshot [exec] processing data for table "data.pr_data_nlp_summary" [exec] pg_restore: launching item 6554 TABLE DATA pr_data_notification_recipient [exec] pg_restore: processing data for table "data.pr_data_notification_recipient" [exec] pg_restore: finished item 6554 TABLE DATA pr_data_notification_recipient [exec] pg_restore: launching item 6571 TABLE DATA pr_data_offline_sync [exec] pg_restore: processing data for table "data.pr_data_offline_sync" [exec] pg_restore: finished item 6533 TABLE DATA pr_data_nlp_summary [exec] pg_restore: launching item 6639 TABLE DATA pr_data_op_session [exec] pg_restore: processing data for table "data.pr_data_op_session" [exec] pg_restore: finished item 6571 TABLE DATA pr_data_offline_sync [exec] pg_restore: launching item 6535 TABLE DATA pr_data_pegasample_product [exec] pg_restore: processing data for table "data.pr_data_pegasample_product" [exec] pg_restore: finished item 6639 TABLE DATA pr_data_op_session [exec] pg_restore: launching item 6486 TABLE DATA pr_data_pmf_worklist [exec] pg_restore: processing data for table "data.pr_data_pmf_worklist" [exec] pg_restore: finished item 6661 TABLE DATA pr_data_nlp_simulationinput [exec] pg_restore: launching item 6624 TABLE DATA pr_data_qp_run_partition [exec] pg_restore: processing data for table "data.pr_data_qp_run_partition" [exec] pg_restore: finished item 6535 TABLE DATA pr_data_pegasample_product [exec] pg_restore: launching item 6496 TABLE DATA pr_data_recents [exec] pg_restore: processing data for table "data.pr_data_recents" [exec] pg_restore: finished item 6647 TABLE DATA pr_data_nlp_status [exec] pg_restore: launching item 6426 TABLE DATA pr_data_reportcategory [exec] pg_restore: processing data for table "data.pr_data_reportcategory" [exec] pg_restore: finished item 6496 TABLE DATA pr_data_recents [exec] pg_restore: launching item 6427 TABLE DATA pr_data_reportshortcut [exec] pg_restore: processing data for table "data.pr_data_reportshortcut" [exec] pg_restore: finished item 6427 TABLE DATA pr_data_reportshortcut [exec] pg_restore: launching item 6591 TABLE DATA pr_data_repositories [exec] pg_restore: processing data for table "data.pr_data_repositories" [exec] pg_restore: finished item 6624 TABLE DATA pr_data_qp_run_partition [exec] pg_restore: launching item 6593 TABLE DATA pr_data_retention_policy [exec] pg_restore: processing data for table "data.pr_data_retention_policy" [exec] pg_restore: finished item 6591 TABLE DATA pr_data_repositories [exec] pg_restore: launching item 6629 TABLE DATA pr_data_rrcategories [exec] pg_restore: processing data for table "data.pr_data_rrcategories" [exec] pg_restore: finished item 6486 TABLE DATA pr_data_pmf_worklist [exec] pg_restore: launching item 6569 TABLE DATA pr_data_rulecoverage_results [exec] pg_restore: processing data for table "data.pr_data_rulecoverage_results" [exec] pg_restore: finished item 6593 TABLE DATA pr_data_retention_policy [exec] pg_restore: launching item 6544 TABLE DATA pr_data_saml_authreqcontext [exec] pg_restore: processing data for table "data.pr_data_saml_authreqcontext" [exec] pg_restore: finished item 6629 TABLE DATA pr_data_rrcategories [exec] pg_restore: launching item 6543 TABLE DATA pr_data_saml_logininfo [exec] pg_restore: processing data for table "data.pr_data_saml_logininfo" [exec] pg_restore: finished item 6544 TABLE DATA pr_data_saml_authreqcontext [exec] pg_restore: launching item 6546 TABLE DATA pr_data_saml_logoutreqinfo [exec] pg_restore: processing data for table "data.pr_data_saml_logoutreqinfo" [exec] pg_restore: finished item 6543 TABLE DATA pr_data_saml_logininfo [exec] pg_restore: launching item 6542 TABLE DATA pr_data_saml_replaycache [exec] pg_restore: processing data for table "data.pr_data_saml_replaycache" [exec] pg_restore: finished item 6546 TABLE DATA pr_data_saml_logoutreqinfo [exec] pg_restore: launching item 6547 TABLE DATA pr_data_saml_requestorinfo [exec] pg_restore: processing data for table "data.pr_data_saml_requestorinfo" [exec] pg_restore: finished item 6426 TABLE DATA pr_data_reportcategory [exec] pg_restore: launching item 6545 TABLE DATA pr_data_saml_sessioninfo [exec] pg_restore: processing data for table "data.pr_data_saml_sessioninfo" [exec] pg_restore: finished item 6569 TABLE DATA pr_data_rulecoverage_results [exec] pg_restore: launching item 6495 TABLE DATA pr_data_sample_shoppingcart [exec] pg_restore: processing data for table "data.pr_data_sample_shoppingcart" [exec] pg_restore: finished item 6542 TABLE DATA pr_data_saml_replaycache [exec] pg_restore: launching item 6428 TABLE DATA pr_data_sample_uidetails [exec] pg_restore: processing data for table "data.pr_data_sample_uidetails" [exec] pg_restore: finished item 6547 TABLE DATA pr_data_saml_requestorinfo [exec] pg_restore: launching item 6429 TABLE DATA pr_data_samplesrcustomer [exec] pg_restore: processing data for table "data.pr_data_samplesrcustomer" [exec] pg_restore: finished item 6495 TABLE DATA pr_data_sample_shoppingcart [exec] pg_restore: launching item 6430 TABLE DATA pr_data_samplesrproduct [exec] pg_restore: processing data for table "data.pr_data_samplesrproduct" [exec] pg_restore: finished item 6429 TABLE DATA pr_data_samplesrcustomer [exec] pg_restore: launching item 6431 TABLE DATA pr_data_samplesrpurchase [exec] pg_restore: processing data for table "data.pr_data_samplesrpurchase" [exec] pg_restore: finished item 6428 TABLE DATA pr_data_sample_uidetails [exec] pg_restore: launching item 6645 TABLE DATA pr_data_sizeestimator_config [exec] pg_restore: processing data for table "data.pr_data_sizeestimator_config" [exec] pg_restore: finished item 6430 TABLE DATA pr_data_samplesrproduct [exec] pg_restore: launching item 6586 TABLE DATA pr_data_smsaccount [exec] pg_restore: processing data for table "data.pr_data_smsaccount" [exec] pg_restore: finished item 6645 TABLE DATA pr_data_sizeestimator_config [exec] pg_restore: launching item 6491 TABLE DATA pr_data_social_reference [exec] pg_restore: processing data for table "data.pr_data_social_reference" [exec] pg_restore: finished item 6586 TABLE DATA pr_data_smsaccount [exec] pg_restore: launching item 6567 TABLE DATA pr_data_stream_node_updates [exec] pg_restore: processing data for table "data.pr_data_stream_node_updates" [exec] pg_restore: finished item 6491 TABLE DATA pr_data_social_reference [exec] pg_restore: launching item 6566 TABLE DATA pr_data_stream_nodes [exec] pg_restore: processing data for table "data.pr_data_stream_nodes" [exec] pg_restore: finished item 6567 TABLE DATA pr_data_stream_node_updates [exec] pg_restore: launching item 6565 TABLE DATA pr_data_stream_sessions [exec] pg_restore: processing data for table "data.pr_data_stream_sessions" [exec] pg_restore: finished item 6545 TABLE DATA pr_data_saml_sessioninfo [exec] pg_restore: launching item 6381 TABLE DATA pr_data_svcinvhist [exec] pg_restore: processing data for table "data.pr_data_svcinvhist" [exec] pg_restore: finished item 6565 TABLE DATA pr_data_stream_sessions [exec] pg_restore: launching item 6481 TABLE DATA pr_data_tag [exec] pg_restore: processing data for table "data.pr_data_tag" [exec] pg_restore: finished item 6566 TABLE DATA pr_data_stream_nodes [exec] pg_restore: launching item 6538 TABLE DATA pr_data_tag_oplink [exec] pg_restore: processing data for table "data.pr_data_tag_oplink" [exec] pg_restore: finished item 6381 TABLE DATA pr_data_svcinvhist [exec] pg_restore: launching item 6539 TABLE DATA pr_data_tag_relevantrecord [exec] pg_restore: processing data for table "data.pr_data_tag_relevantrecord" [exec] pg_restore: finished item 6481 TABLE DATA pr_data_tag [exec] pg_restore: launching item 6432 TABLE DATA pr_data_template_metadata [exec] pg_restore: processing data for table "data.pr_data_template_metadata" [exec] pg_restore: finished item 6538 TABLE DATA pr_data_tag_oplink [exec] pg_restore: launching item 6517 TABLE DATA pr_data_testcaseresults [exec] pg_restore: processing data for table "data.pr_data_testcaseresults" [exec] pg_restore: finished item 6432 TABLE DATA pr_data_template_metadata [exec] pg_restore: launching item 6555 TABLE DATA pr_data_testsuiteresults [exec] pg_restore: processing data for table "data.pr_data_testsuiteresults" [exec] pg_restore: finished item 6517 TABLE DATA pr_data_testcaseresults [exec] pg_restore: launching item 6552 TABLE DATA pr_data_toggle [exec] pg_restore: processing data for table "data.pr_data_toggle" [exec] pg_restore: finished item 6555 TABLE DATA pr_data_testsuiteresults [exec] pg_restore: launching item 6518 TABLE DATA pr_data_token [exec] pg_restore: processing data for table "data.pr_data_token" [exec] pg_restore: finished item 6552 TABLE DATA pr_data_toggle [exec] pg_restore: launching item 6640 TABLE DATA pr_data_token_blacklisted_jti [exec] pg_restore: processing data for table "data.pr_data_token_blacklisted_jti" [exec] pg_restore: finished item 6518 TABLE DATA pr_data_token [exec] pg_restore: launching item 6656 TABLE DATA pr_data_user_activity [exec] pg_restore: processing data for table "data.pr_data_user_activity" [exec] pg_restore: finished item 6539 TABLE DATA pr_data_tag_relevantrecord [exec] pg_restore: launching item 6540 TABLE DATA pr_database_info_table [exec] pg_restore: processing data for table "data.pr_database_info_table" [exec] pg_restore: finished item 6656 TABLE DATA pr_data_user_activity [exec] pg_restore: launching item 6662 TABLE DATA pr_datapage_cache [exec] pg_restore: processing data for table "data.pr_datapage_cache" [exec] pg_restore: finished item 6540 TABLE DATA pr_database_info_table [exec] pg_restore: launching item 6422 TABLE DATA pr_dm_proposition [exec] pg_restore: processing data for table "data.pr_dm_proposition" [exec] pg_restore: finished item 6431 TABLE DATA pr_data_samplesrpurchase [exec] pg_restore: launching item 6382 TABLE DATA pr_extract_time [exec] pg_restore: processing data for table "data.pr_extract_time" [exec] pg_restore: finished item 6662 TABLE DATA pr_datapage_cache [exec] pg_restore: launching item 6474 TABLE DATA pr_file_store [exec] pg_restore: processing data for table "data.pr_file_store" [exec] pg_restore: finished item 6382 TABLE DATA pr_extract_time [exec] pg_restore: launching item 6475 TABLE DATA pr_file_upload [exec] pg_restore: processing data for table "data.pr_file_upload" [exec] pg_restore: finished item 6422 TABLE DATA pr_dm_proposition [exec] pg_restore: launching item 6476 TABLE DATA pr_file_upload_fallback [exec] pg_restore: processing data for table "data.pr_file_upload_fallback" [exec] pg_restore: finished item 6476 TABLE DATA pr_file_upload_fallback [exec] pg_restore: launching item 6433 TABLE DATA pr_history [exec] pg_restore: processing data for table "data.pr_history" [exec] pg_restore: finished item 6474 TABLE DATA pr_file_store [exec] pg_restore: launching item 6434 TABLE DATA pr_history_data [exec] pg_restore: processing data for table "data.pr_history_data" [exec] pg_restore: finished item 6433 TABLE DATA pr_history [exec] pg_restore: launching item 6527 TABLE DATA pr_history_data_dms_customer [exec] pg_restore: processing data for table "data.pr_history_data_dms_customer" [exec] pg_restore: finished item 6434 TABLE DATA pr_history_data [exec] pg_restore: launching item 6528 TABLE DATA pr_history_data_dms_glbl [exec] pg_restore: processing data for table "data.pr_history_data_dms_glbl" [exec] pg_restore: finished item 6527 TABLE DATA pr_history_data_dms_customer [exec] pg_restore: launching item 6478 TABLE DATA pr_hourly_usage [exec] pg_restore: processing data for table "data.pr_hourly_usage" [exec] pg_restore: finished item 6528 TABLE DATA pr_history_data_dms_glbl [exec] pg_restore: launching item 6436 TABLE DATA pr_index [exec] pg_restore: processing data for table "data.pr_index" [exec] pg_restore: finished item 6478 TABLE DATA pr_hourly_usage [exec] pg_restore: launching item 6395 TABLE DATA pr_index_accessgrouproles [exec] pg_restore: processing data for table "data.pr_index_accessgrouproles" [exec] pg_restore: finished item 6640 TABLE DATA pr_data_token_blacklisted_jti [exec] pg_restore: launching item 6396 TABLE DATA pr_index_accessgroupwkpools [exec] pg_restore: processing data for table "data.pr_index_accessgroupwkpools" [exec] pg_restore: finished item 6475 TABLE DATA pr_file_upload [exec] pg_restore: launching item 6393 TABLE DATA pr_index_appfeatures [exec] pg_restore: processing data for table "data.pr_index_appfeatures" [exec] pg_restore: finished item 6393 TABLE DATA pr_index_appfeatures [exec] pg_restore: launching item 6484 TABLE DATA pr_index_assignmentdeps [exec] pg_restore: processing data for table "data.pr_index_assignmentdeps" [exec] pg_restore: finished item 6484 TABLE DATA pr_index_assignmentdeps [exec] pg_restore: launching item 6444 TABLE DATA pr_index_assignmentskills [exec] pg_restore: processing data for table "data.pr_index_assignmentskills" [exec] pg_restore: finished item 6395 TABLE DATA pr_index_accessgrouproles [exec] pg_restore: launching item 6516 TABLE DATA pr_index_data_agents [exec] pg_restore: processing data for table "data.pr_index_data_agents" [exec] pg_restore: finished item 6444 TABLE DATA pr_index_assignmentskills [exec] pg_restore: launching item 6564 TABLE DATA pr_index_distinctvalues [exec] pg_restore: processing data for table "data.pr_index_distinctvalues" [exec] pg_restore: finished item 6516 TABLE DATA pr_index_data_agents [exec] pg_restore: launching item 6398 TABLE DATA pr_index_email [exec] pg_restore: processing data for table "data.pr_index_email" [exec] pg_restore: finished item 6564 TABLE DATA pr_index_distinctvalues [exec] pg_restore: launching item 6494 TABLE DATA pr_index_operator_workgroups [exec] pg_restore: processing data for table "data.pr_index_operator_workgroups" [exec] pg_restore: finished item 6436 TABLE DATA pr_index [exec] pg_restore: launching item 6443 TABLE DATA pr_index_operators [exec] pg_restore: processing data for table "data.pr_index_operators" [exec] pg_restore: finished item 6494 TABLE DATA pr_index_operator_workgroups [exec] pg_restore: launching item 6445 TABLE DATA pr_index_operatorskills [exec] pg_restore: processing data for table "data.pr_index_operatorskills" [exec] pg_restore: finished item 6443 TABLE DATA pr_index_operators [exec] pg_restore: launching item 6537 TABLE DATA pr_index_pref_notify [exec] pg_restore: processing data for table "data.pr_index_pref_notify" [exec] pg_restore: finished item 6445 TABLE DATA pr_index_operatorskills [exec] pg_restore: launching item 6437 TABLE DATA pr_index_scheduledtask [exec] pg_restore: processing data for table "data.pr_index_scheduledtask" [exec] pg_restore: finished item 6437 TABLE DATA pr_index_scheduledtask [exec] pg_restore: launching item 6490 TABLE DATA pr_index_trackstatus [exec] pg_restore: processing data for table "data.pr_index_trackstatus" [exec] pg_restore: finished item 6490 TABLE DATA pr_index_trackstatus [exec] pg_restore: launching item 6643 TABLE DATA pr_index_tracktriageactions [exec] pg_restore: processing data for table "data.pr_index_tracktriageactions" [exec] pg_restore: finished item 6643 TABLE DATA pr_index_tracktriageactions [exec] pg_restore: launching item 6397 TABLE DATA pr_index_workgroups [exec] pg_restore: processing data for table "data.pr_index_workgroups" [exec] pg_restore: finished item 6397 TABLE DATA pr_index_workgroups [exec] pg_restore: launching item 6594 TABLE DATA pr_indexmetadata [exec] pg_restore: processing data for table "data.pr_indexmetadata" [exec] pg_restore: finished item 6594 TABLE DATA pr_indexmetadata [exec] pg_restore: launching item 6590 TABLE DATA pr_jobscheduler_override [exec] pg_restore: processing data for table "data.pr_jobscheduler_override" [exec] pg_restore: finished item 6590 TABLE DATA pr_jobscheduler_override [exec] pg_restore: launching item 6477 TABLE DATA pr_license_parameters [exec] pg_restore: processing data for table "data.pr_license_parameters" [exec] pg_restore: finished item 6477 TABLE DATA pr_license_parameters [exec] pg_restore: launching item 6438 TABLE DATA pr_link [exec] pg_restore: processing data for table "data.pr_link" [exec] pg_restore: finished item 6438 TABLE DATA pr_link [exec] pg_restore: launching item 6483 TABLE DATA pr_link_dco_pmf [exec] pg_restore: finished item 6396 TABLE DATA pr_index_accessgroupwkpools [exec] pg_restore: launching item 6487 TABLE DATA pr_link_pmf_rulechanges [exec] pg_restore: processing data for table "data.pr_link_dco_pmf" [exec] pg_restore: processing data for table "data.pr_link_pmf_rulechanges" [exec] pg_restore: finished item 6483 TABLE DATA pr_link_dco_pmf [exec] pg_restore: launching item 6482 TABLE DATA pr_link_work_tag [exec] pg_restore: processing data for table "data.pr_link_work_tag" [exec] pg_restore: finished item 6487 TABLE DATA pr_link_pmf_rulechanges [exec] pg_restore: launching item 6440 TABLE DATA pr_log [exec] pg_restore: processing data for table "data.pr_log" [exec] pg_restore: finished item 6482 TABLE DATA pr_link_work_tag [exec] pg_restore: launching item 6651 TABLE DATA pr_log_archivalsummary [exec] pg_restore: processing data for table "data.pr_log_archivalsummary" [exec] pg_restore: finished item 6440 TABLE DATA pr_log [exec] pg_restore: launching item 6606 TABLE DATA pr_log_archivepurgeresults [exec] pg_restore: processing data for table "data.pr_log_archivepurgeresults" [exec] pg_restore: finished item 6651 TABLE DATA pr_log_archivalsummary [exec] pg_restore: launching item 6659 TABLE DATA pr_log_batchid_generation [exec] pg_restore: processing data for table "data.pr_log_batchid_generation" [exec] pg_restore: finished item 6606 TABLE DATA pr_log_archivepurgeresults [exec] pg_restore: launching item 6488 TABLE DATA pr_log_batchstats [exec] pg_restore: processing data for table "data.pr_log_batchstats" [exec] pg_restore: finished item 6398 TABLE DATA pr_index_email [exec] pg_restore: launching item 6519 TABLE DATA pr_log_cluster [exec] pg_restore: processing data for table "data.pr_log_cluster" [exec] pg_restore: finished item 6659 TABLE DATA pr_log_batchid_generation [exec] pg_restore: launching item 6589 TABLE DATA pr_log_collaboration [exec] pg_restore: processing data for table "data.pr_log_collaboration" [exec] pg_restore: finished item 6519 TABLE DATA pr_log_cluster [exec] pg_restore: launching item 6402 TABLE DATA pr_log_dataaccessaudit [exec] pg_restore: processing data for table "data.pr_log_dataaccessaudit" [exec] pg_restore: finished item 6589 TABLE DATA pr_log_collaboration [exec] pg_restore: launching item 6587 TABLE DATA pr_log_dataflow_events [exec] pg_restore: processing data for table "data.pr_log_dataflow_events" [exec] pg_restore: finished item 6402 TABLE DATA pr_log_dataaccessaudit [exec] pg_restore: launching item 6655 TABLE DATA pr_log_expungedcases [exec] pg_restore: processing data for table "data.pr_log_expungedcases" [exec] pg_restore: finished item 6587 TABLE DATA pr_log_dataflow_events [exec] pg_restore: launching item 6626 TABLE DATA pr_log_indexing_progress [exec] pg_restore: processing data for table "data.pr_log_indexing_progress" [exec] pg_restore: finished item 6655 TABLE DATA pr_log_expungedcases [exec] pg_restore: launching item 6568 TABLE DATA pr_log_jobs_scheduler [exec] pg_restore: processing data for table "data.pr_log_jobs_scheduler" [exec] pg_restore: finished item 6626 TABLE DATA pr_log_indexing_progress [exec] pg_restore: launching item 6531 TABLE DATA pr_log_progress [exec] pg_restore: processing data for table "data.pr_log_progress" [exec] pg_restore: finished item 6568 TABLE DATA pr_log_jobs_scheduler [exec] pg_restore: launching item 6394 TABLE DATA pr_log_reportstats [exec] pg_restore: processing data for table "data.pr_log_reportstats" [exec] pg_restore: finished item 6531 TABLE DATA pr_log_progress [exec] pg_restore: launching item 6485 TABLE DATA pr_log_securityaudit [exec] pg_restore: processing data for table "data.pr_log_securityaudit" [exec] pg_restore: finished item 6394 TABLE DATA pr_log_reportstats [exec] pg_restore: launching item 6630 TABLE DATA pr_log_service_email [exec] pg_restore: processing data for table "data.pr_log_service_email" [exec] pg_restore: finished item 6485 TABLE DATA pr_log_securityaudit [exec] pg_restore: launching item 6520 TABLE DATA pr_log_systemstate [exec] pg_restore: processing data for table "data.pr_log_systemstate" [exec] pg_restore: finished item 6630 TABLE DATA pr_log_service_email [exec] pg_restore: launching item 6595 TABLE DATA pr_metadata [exec] pg_restore: processing data for table "data.pr_metadata" [exec] pg_restore: finished item 6595 TABLE DATA pr_metadata [exec] pg_restore: launching item 6392 TABLE DATA pr_notification_channels [exec] pg_restore: processing data for table "data.pr_notification_channels" [exec] pg_restore: finished item 6392 TABLE DATA pr_notification_channels [exec] pg_restore: launching item 6666 TABLE DATA pr_oauth2_session_index [exec] pg_restore: processing data for table "data.pr_oauth2_session_index" [exec] pg_restore: finished item 6520 TABLE DATA pr_log_systemstate [exec] pg_restore: launching item 6578 TABLE DATA pr_offline_attachment_mapping [exec] pg_restore: processing data for table "data.pr_offline_attachment_mapping" [exec] pg_restore: finished item 6578 TABLE DATA pr_offline_attachment_mapping [exec] pg_restore: launching item 6577 TABLE DATA pr_offline_attachment_stub [exec] pg_restore: processing data for table "data.pr_offline_attachment_stub" [exec] pg_restore: finished item 6666 TABLE DATA pr_oauth2_session_index [exec] pg_restore: launching item 6449 TABLE DATA pr_offline_pack [exec] pg_restore: processing data for table "data.pr_offline_pack" [exec] pg_restore: finished item 6577 TABLE DATA pr_offline_attachment_stub [exec] pg_restore: launching item 6615 TABLE DATA pr_offline_sync_requests [exec] pg_restore: processing data for table "data.pr_offline_sync_requests" [exec] pg_restore: finished item 6449 TABLE DATA pr_offline_pack [exec] pg_restore: launching item 6616 TABLE DATA pr_offline_sync_requests_info [exec] pg_restore: processing data for table "data.pr_offline_sync_requests_info" [exec] pg_restore: finished item 6616 TABLE DATA pr_offline_sync_requests_info [exec] pg_restore: launching item 6442 TABLE DATA pr_operator_prefs [exec] pg_restore: processing data for table "data.pr_operator_prefs" [exec] pg_restore: finished item 6442 TABLE DATA pr_operator_prefs [exec] pg_restore: launching item 6441 TABLE DATA pr_operators [exec] pg_restore: processing data for table "data.pr_operators" [exec] pg_restore: finished item 6441 TABLE DATA pr_operators [exec] pg_restore: launching item 6446 TABLE DATA pr_other [exec] pg_restore: processing data for table "data.pr_other" [exec] pg_restore: finished item 6446 TABLE DATA pr_other [exec] pg_restore: launching item 6448 TABLE DATA pr_page_store [exec] pg_restore: processing data for table "data.pr_page_store" [exec] pg_restore: finished item 6448 TABLE DATA pr_page_store [exec] pg_restore: launching item 6471 TABLE DATA pr_perf_stats [exec] pg_restore: processing data for table "data.pr_perf_stats" [exec] pg_restore: finished item 6471 TABLE DATA pr_perf_stats [exec] pg_restore: launching item 6447 TABLE DATA pr_portal_state [exec] pg_restore: processing data for table "data.pr_portal_state" [exec] pg_restore: finished item 6447 TABLE DATA pr_portal_state [exec] pg_restore: launching item 6627 TABLE DATA pr_sys_bi_publisheddatamodel [exec] pg_restore: processing data for table "data.pr_sys_bi_publisheddatamodel" [exec] pg_restore: finished item 6627 TABLE DATA pr_sys_bi_publisheddatamodel [exec] pg_restore: launching item 6450 TABLE DATA pr_sys_context [exec] pg_restore: processing data for table "data.pr_sys_context" [exec] pg_restore: finished item 6450 TABLE DATA pr_sys_context [exec] pg_restore: launching item 6603 TABLE DATA pr_sys_delayed_queue [exec] pg_restore: processing data for table "data.pr_sys_delayed_queue" [exec] pg_restore: finished item 6615 TABLE DATA pr_offline_sync_requests [exec] pg_restore: launching item 6451 TABLE DATA pr_sys_locks [exec] pg_restore: processing data for table "data.pr_sys_locks" [exec] pg_restore: finished item 6603 TABLE DATA pr_sys_delayed_queue [exec] pg_restore: launching item 6596 TABLE DATA pr_sys_msg_qp_brokenitems [exec] pg_restore: processing data for table "data.pr_sys_msg_qp_brokenitems" [exec] pg_restore: finished item 6451 TABLE DATA pr_sys_locks [exec] pg_restore: launching item 6458 TABLE DATA pr_sys_queue_autotest [exec] pg_restore: processing data for table "data.pr_sys_queue_autotest" [exec] pg_restore: finished item 6596 TABLE DATA pr_sys_msg_qp_brokenitems [exec] pg_restore: launching item 6464 TABLE DATA pr_sys_queue_col_pop [exec] pg_restore: processing data for table "data.pr_sys_queue_col_pop" [exec] pg_restore: finished item 6458 TABLE DATA pr_sys_queue_autotest [exec] pg_restore: launching item 6465 TABLE DATA pr_sys_queue_count [exec] pg_restore: processing data for table "data.pr_sys_queue_count" [exec] pg_restore: finished item 6464 TABLE DATA pr_sys_queue_col_pop [exec] pg_restore: launching item 6462 TABLE DATA pr_sys_queue_execreq_conn [exec] pg_restore: processing data for table "data.pr_sys_queue_execreq_conn" [exec] pg_restore: finished item 6465 TABLE DATA pr_sys_queue_count [exec] pg_restore: launching item 6461 TABLE DATA pr_sys_queue_execreq_svc [exec] pg_restore: processing data for table "data.pr_sys_queue_execreq_svc" [exec] pg_restore: finished item 6462 TABLE DATA pr_sys_queue_execreq_conn [exec] pg_restore: launching item 6574 TABLE DATA pr_sys_queue_ftsconflict [exec] pg_restore: processing data for table "data.pr_sys_queue_ftsconflict" [exec] pg_restore: finished item 6461 TABLE DATA pr_sys_queue_execreq_svc [exec] pg_restore: launching item 6515 TABLE DATA pr_sys_queue_ftsindexer [exec] pg_restore: processing data for table "data.pr_sys_queue_ftsindexer" [exec] pg_restore: finished item 6574 TABLE DATA pr_sys_queue_ftsconflict [exec] pg_restore: launching item 6460 TABLE DATA pr_sys_queue_sla [exec] pg_restore: processing data for table "data.pr_sys_queue_sla" [exec] pg_restore: finished item 6515 TABLE DATA pr_sys_queue_ftsindexer [exec] pg_restore: launching item 6463 TABLE DATA pr_sys_queue_startflows [exec] pg_restore: processing data for table "data.pr_sys_queue_startflows" [exec] pg_restore: finished item 6460 TABLE DATA pr_sys_queue_sla [exec] pg_restore: launching item 6457 TABLE DATA pr_sys_queues [exec] pg_restore: processing data for table "data.pr_sys_queues" [exec] pg_restore: finished item 6537 TABLE DATA pr_index_pref_notify [exec] pg_restore: launching item 6452 TABLE DATA pr_sys_serviceregistry [exec] pg_restore: finished item 6463 TABLE DATA pr_sys_queue_startflows [exec] pg_restore: launching item 6453 TABLE DATA pr_sys_serviceregistry_kvs [exec] pg_restore: processing data for table "data.pr_sys_serviceregistry" [exec] pg_restore: processing data for table "data.pr_sys_serviceregistry_kvs" [exec] pg_restore: finished item 6457 TABLE DATA pr_sys_queues [exec] pg_restore: launching item 6514 TABLE DATA pr_sys_statusdetails [exec] pg_restore: processing data for table "data.pr_sys_statusdetails" [exec] pg_restore: finished item 6514 TABLE DATA pr_sys_statusdetails [exec] pg_restore: launching item 6454 TABLE DATA pr_sys_statusnodes [exec] pg_restore: processing data for table "data.pr_sys_statusnodes" [exec] pg_restore: finished item 6452 TABLE DATA pr_sys_serviceregistry [exec] pg_restore: launching item 6455 TABLE DATA pr_sys_updatescache [exec] pg_restore: processing data for table "data.pr_sys_updatescache" [exec] pg_restore: finished item 6488 TABLE DATA pr_log_batchstats [exec] pg_restore: launching item 6456 TABLE DATA pr_sys_user [exec] pg_restore: processing data for table "data.pr_sys_user" [exec] pg_restore: finished item 6455 TABLE DATA pr_sys_updatescache [exec] pg_restore: launching item 6638 TABLE DATA pr_sys_user_grid [exec] pg_restore: processing data for table "data.pr_sys_user_grid" [exec] pg_restore: finished item 6454 TABLE DATA pr_sys_statusnodes [exec] pg_restore: launching item 6459 TABLE DATA pr_sys_workindexer_queue [exec] pg_restore: processing data for table "data.pr_sys_workindexer_queue" [exec] pg_restore: finished item 6456 TABLE DATA pr_sys_user [exec] pg_restore: launching item 6403 TABLE DATA pr_sysjobs [exec] pg_restore: processing data for table "data.pr_sysjobs" [exec] pg_restore: finished item 6638 TABLE DATA pr_sys_user_grid [exec] pg_restore: launching item 6480 TABLE DATA pr_usage_summary [exec] pg_restore: processing data for table "data.pr_usage_summary" [exec] pg_restore: finished item 6480 TABLE DATA pr_usage_summary [exec] pg_restore: launching item 6385 TABLE DATA prpc_ignite_server_addr [exec] pg_restore: processing data for table "data.prpc_ignite_server_addr" [exec] pg_restore: finished item 6385 TABLE DATA prpc_ignite_server_addr [exec] pg_restore: launching item 6682 TABLE DATA pc_index_flowref [exec] pg_restore: processing data for table "rules.pc_index_flowref" [exec] pg_restore: finished item 6682 TABLE DATA pc_index_flowref [exec] pg_restore: launching item 6685 TABLE DATA pr4_base [exec] pg_restore: processing data for table "rules.pr4_base" [exec] pg_restore: finished item 6453 TABLE DATA pr_sys_serviceregistry_kvs [exec] pg_restore: launching item 6687 TABLE DATA pr4_fieldvalue [exec] pg_restore: processing data for table "rules.pr4_fieldvalue" [exec] pg_restore: finished item 6459 TABLE DATA pr_sys_workindexer_queue [exec] pg_restore: launching item 6692 TABLE DATA pr4_rule [exec] pg_restore: processing data for table "rules.pr4_rule" [exec] pg_restore: finished item 6403 TABLE DATA pr_sysjobs [exec] pg_restore: launching item 6740 TABLE DATA pr4_rule_appconfiguration [exec] pg_restore: processing data for table "rules.pr4_rule_appconfiguration" [exec] pg_restore: finished item 6740 TABLE DATA pr4_rule_appconfiguration [exec] pg_restore: launching item 6675 TABLE DATA pr4_rule_application [exec] pg_restore: processing data for table "rules.pr4_rule_application" [exec] pg_restore: finished item 6675 TABLE DATA pr4_rule_application [exec] pg_restore: launching item 6694 TABLE DATA pr4_rule_autotest [exec] pg_restore: processing data for table "rules.pr4_rule_autotest" [exec] pg_restore: finished item 6694 TABLE DATA pr4_rule_autotest [exec] pg_restore: launching item 6751 TABLE DATA pr4_rule_bi_dashboard [exec] pg_restore: processing data for table "rules.pr4_rule_bi_dashboard" [exec] pg_restore: finished item 6751 TABLE DATA pr4_rule_bi_dashboard [exec] pg_restore: launching item 6755 TABLE DATA pr4_rule_bi_insight [exec] pg_restore: processing data for table "rules.pr4_rule_bi_insight" [exec] pg_restore: finished item 6755 TABLE DATA pr4_rule_bi_insight [exec] pg_restore: launching item 6750 TABLE DATA pr4_rule_bi_queryphrase [exec] pg_restore: processing data for table "rules.pr4_rule_bi_queryphrase" [exec] pg_restore: finished item 6750 TABLE DATA pr4_rule_bi_queryphrase [exec] pg_restore: launching item 6749 TABLE DATA pr4_rule_bi_theme [exec] pg_restore: processing data for table "rules.pr4_rule_bi_theme" [exec] pg_restore: finished item 6749 TABLE DATA pr4_rule_bi_theme [exec] pg_restore: launching item 6744 TABLE DATA pr4_rule_clientdata [exec] pg_restore: processing data for table "rules.pr4_rule_clientdata" [exec] pg_restore: finished item 6744 TABLE DATA pr4_rule_clientdata [exec] pg_restore: launching item 6743 TABLE DATA pr4_rule_connect [exec] pg_restore: processing data for table "rules.pr4_rule_connect" [exec] pg_restore: finished item 6743 TABLE DATA pr4_rule_connect [exec] pg_restore: launching item 6746 TABLE DATA pr4_rule_connect_robot [exec] pg_restore: processing data for table "rules.pr4_rule_connect_robot" [exec] pg_restore: finished item 6746 TABLE DATA pr4_rule_connect_robot [exec] pg_restore: launching item 6757 TABLE DATA pr4_rule_dataobject [exec] pg_restore: processing data for table "rules.pr4_rule_dataobject" [exec] pg_restore: finished item 6757 TABLE DATA pr4_rule_dataobject [exec] pg_restore: launching item 6753 TABLE DATA pr4_rule_declare_expression [exec] pg_restore: processing data for table "rules.pr4_rule_declare_expression" [exec] pg_restore: finished item 6753 TABLE DATA pr4_rule_declare_expression [exec] pg_restore: launching item 6702 TABLE DATA pr4_rule_declarepages [exec] pg_restore: processing data for table "rules.pr4_rule_declarepages" [exec] pg_restore: finished item 6702 TABLE DATA pr4_rule_declarepages [exec] pg_restore: launching item 6731 TABLE DATA pr4_rule_delegationconfig [exec] pg_restore: processing data for table "rules.pr4_rule_delegationconfig" [exec] pg_restore: finished item 6731 TABLE DATA pr4_rule_delegationconfig [exec] pg_restore: launching item 6701 TABLE DATA pr4_rule_file [exec] pg_restore: processing data for table "rules.pr4_rule_file" [exec] pg_restore: finished item 6685 TABLE DATA pr4_base [exec] pg_restore: launching item 6703 TABLE DATA pr4_rule_file_binary [exec] pg_restore: processing data for table "rules.pr4_rule_file_binary" [exec] pg_restore: finished item 6687 TABLE DATA pr4_fieldvalue [exec] pg_restore: launching item 6697 TABLE DATA pr4_rule_flow [exec] pg_restore: processing data for table "rules.pr4_rule_flow" [exec] pg_restore: finished item 6701 TABLE DATA pr4_rule_file [exec] pg_restore: launching item 6673 TABLE DATA pr4_rule_guide [exec] pg_restore: processing data for table "rules.pr4_rule_guide" [exec] pg_restore: finished item 6673 TABLE DATA pr4_rule_guide [exec] pg_restore: launching item 6674 TABLE DATA pr4_rule_html_property [exec] pg_restore: processing data for table "rules.pr4_rule_html_property" [exec] pg_restore: finished item 6697 TABLE DATA pr4_rule_flow [exec] pg_restore: launching item 6730 TABLE DATA pr4_rule_library [exec] pg_restore: processing data for table "rules.pr4_rule_library" [exec] pg_restore: finished item 6674 TABLE DATA pr4_rule_html_property [exec] pg_restore: launching item 6758 TABLE DATA pr4_rule_localization [exec] pg_restore: processing data for table "rules.pr4_rule_localization" [exec] pg_restore: finished item 6758 TABLE DATA pr4_rule_localization [exec] pg_restore: launching item 6728 TABLE DATA pr4_rule_message [exec] pg_restore: processing data for table "rules.pr4_rule_message" [exec] pg_restore: finished item 6728 TABLE DATA pr4_rule_message [exec] pg_restore: launching item 6756 TABLE DATA pr4_rule_persona [exec] pg_restore: processing data for table "rules.pr4_rule_persona" [exec] pg_restore: finished item 6756 TABLE DATA pr4_rule_persona [exec] pg_restore: launching item 6741 TABLE DATA pr4_rule_presentation [exec] pg_restore: processing data for table "rules.pr4_rule_presentation" [exec] pg_restore: finished item 6741 TABLE DATA pr4_rule_presentation [exec] pg_restore: launching item 6698 TABLE DATA pr4_rule_property [exec] pg_restore: processing data for table "rules.pr4_rule_property" [exec] pg_restore: finished item 6730 TABLE DATA pr4_rule_library [exec] pg_restore: launching item 6742 TABLE DATA pr4_rule_reports [exec] pg_restore: processing data for table "rules.pr4_rule_reports" [exec] pg_restore: finished item 6742 TABLE DATA pr4_rule_reports [exec] pg_restore: launching item 6711 TABLE DATA pr4_rule_requirement [exec] pg_restore: processing data for table "rules.pr4_rule_requirement" [exec] pg_restore: finished item 6711 TABLE DATA pr4_rule_requirement [exec] pg_restore: launching item 6699 TABLE DATA pr4_rule_ruleset [exec] pg_restore: processing data for table "rules.pr4_rule_ruleset" [exec] pg_restore: finished item 6699 TABLE DATA pr4_rule_ruleset [exec] pg_restore: launching item 6693 TABLE DATA pr4_rule_section [exec] pg_restore: processing data for table "rules.pr4_rule_section" [exec] pg_restore: finished item 6698 TABLE DATA pr4_rule_property [exec] pg_restore: launching item 6735 TABLE DATA pr4_rule_securitypolicies [exec] pg_restore: processing data for table "rules.pr4_rule_securitypolicies" [exec] pg_restore: finished item 6735 TABLE DATA pr4_rule_securitypolicies [exec] pg_restore: launching item 6672 TABLE DATA pr4_rule_service_rest [exec] pg_restore: processing data for table "rules.pr4_rule_service_rest" [exec] pg_restore: finished item 6672 TABLE DATA pr4_rule_service_rest [exec] pg_restore: launching item 6695 TABLE DATA pr4_rule_shortcut [exec] pg_restore: processing data for table "rules.pr4_rule_shortcut" [exec] pg_restore: finished item 6695 TABLE DATA pr4_rule_shortcut [exec] pg_restore: launching item 6700 TABLE DATA pr4_rule_sysgen [exec] pg_restore: processing data for table "rules.pr4_rule_sysgen" [exec] pg_restore: finished item 6700 TABLE DATA pr4_rule_sysgen [exec] pg_restore: launching item 6732 TABLE DATA pr4_rule_testcase [exec] pg_restore: processing data for table "rules.pr4_rule_testcase" [exec] pg_restore: finished item 6732 TABLE DATA pr4_rule_testcase [exec] pg_restore: launching item 6738 TABLE DATA pr4_rule_testsuite [exec] pg_restore: processing data for table "rules.pr4_rule_testsuite" [exec] pg_restore: finished item 6738 TABLE DATA pr4_rule_testsuite [exec] pg_restore: launching item 6712 TABLE DATA pr4_rule_usecase [exec] pg_restore: processing data for table "rules.pr4_rule_usecase" [exec] pg_restore: finished item 6712 TABLE DATA pr4_rule_usecase [exec] pg_restore: launching item 6754 TABLE DATA pr4_rule_view [exec] pg_restore: processing data for table "rules.pr4_rule_view" [exec] pg_restore: finished item 6754 TABLE DATA pr4_rule_view [exec] pg_restore: launching item 6696 TABLE DATA pr4_rule_vw [exec] pg_restore: processing data for table "rules.pr4_rule_vw" [exec] pg_restore: finished item 6703 TABLE DATA pr4_rule_file_binary [exec] pg_restore: launching item 6709 TABLE DATA pr_app_branch_idx [exec] pg_restore: processing data for table "rules.pr_app_branch_idx" [exec] pg_restore: finished item 6709 TABLE DATA pr_app_branch_idx [exec] pg_restore: launching item 6707 TABLE DATA pr_assembledclasses [exec] pg_restore: processing data for table "rules.pr_assembledclasses" [exec] pg_restore: finished item 6696 TABLE DATA pr4_rule_vw [exec] pg_restore: launching item 6680 TABLE DATA pr_changelog [exec] pg_restore: processing data for table "rules.pr_changelog" [exec] pg_restore: finished item 6680 TABLE DATA pr_changelog [exec] pg_restore: launching item 6723 TABLE DATA pr_data_admin_product [exec] pg_restore: processing data for table "rules.pr_data_admin_product" [exec] pg_restore: finished item 6723 TABLE DATA pr_data_admin_product [exec] pg_restore: launching item 6686 TABLE DATA pr_data_admin_restore [exec] pg_restore: processing data for table "rules.pr_data_admin_restore" [exec] pg_restore: finished item 6686 TABLE DATA pr_data_admin_restore [exec] pg_restore: launching item 6733 TABLE DATA pr_data_customproperties [exec] pg_restore: processing data for table "rules.pr_data_customproperties" [exec] pg_restore: finished item 6733 TABLE DATA pr_data_customproperties [exec] pg_restore: launching item 6719 TABLE DATA pr_data_map_entries [exec] pg_restore: processing data for table "rules.pr_data_map_entries" [exec] pg_restore: finished item 6719 TABLE DATA pr_data_map_entries [exec] pg_restore: launching item 6713 TABLE DATA pr_data_products [exec] pg_restore: processing data for table "rules.pr_data_products" [exec] pg_restore: finished item 6713 TABLE DATA pr_data_products [exec] pg_restore: launching item 6714 TABLE DATA pr_data_restore [exec] pg_restore: processing data for table "rules.pr_data_restore" [exec] pg_restore: finished item 6714 TABLE DATA pr_data_restore [exec] pg_restore: launching item 6721 TABLE DATA pr_data_rule_appmetadata [exec] pg_restore: processing data for table "rules.pr_data_rule_appmetadata" [exec] pg_restore: finished item 6721 TABLE DATA pr_data_rule_appmetadata [exec] pg_restore: launching item 6726 TABLE DATA pr_data_scanner [exec] pg_restore: processing data for table "rules.pr_data_scanner" [exec] pg_restore: finished item 6726 TABLE DATA pr_data_scanner [exec] pg_restore: launching item 6706 TABLE DATA pr_engineclasses [exec] pg_restore: processing data for table "rules.pr_engineclasses" [exec] pg_restore: finished item 6692 TABLE DATA pr4_rule [exec] pg_restore: launching item 6734 TABLE DATA pr_index_applicationbuilton [exec] pg_restore: processing data for table "rules.pr_index_applicationbuilton" [exec] pg_restore: finished item 6734 TABLE DATA pr_index_applicationbuilton [exec] pg_restore: launching item 6752 TABLE DATA pr_index_bi_permission [exec] pg_restore: processing data for table "rules.pr_index_bi_permission" [exec] pg_restore: finished item 6752 TABLE DATA pr_index_bi_permission [exec] pg_restore: launching item 6684 TABLE DATA pr_index_circumstance_def [exec] pg_restore: processing data for table "rules.pr_index_circumstance_def" [exec] pg_restore: finished item 6684 TABLE DATA pr_index_circumstance_def [exec] pg_restore: launching item 6688 TABLE DATA pr_index_css [exec] pg_restore: processing data for table "rules.pr_index_css" [exec] pg_restore: finished item 6693 TABLE DATA pr4_rule_section [exec] pg_restore: launching item 6689 TABLE DATA pr_index_customfields [exec] pg_restore: processing data for table "rules.pr_index_customfields" [exec] pg_restore: finished item 6689 TABLE DATA pr_index_customfields [exec] pg_restore: launching item 6739 TABLE DATA pr_index_datasaveoptions [exec] pg_restore: processing data for table "rules.pr_index_datasaveoptions" [exec] pg_restore: finished item 6739 TABLE DATA pr_index_datasaveoptions [exec] pg_restore: launching item 6710 TABLE DATA pr_index_datasources [exec] pg_restore: processing data for table "rules.pr_index_datasources" [exec] pg_restore: finished item 6710 TABLE DATA pr_index_datasources [exec] pg_restore: launching item 6759 TABLE DATA pr_index_dpparameter [exec] pg_restore: processing data for table "rules.pr_index_dpparameter" [exec] pg_restore: finished item 6759 TABLE DATA pr_index_dpparameter [exec] pg_restore: launching item 6736 TABLE DATA pr_index_policyconditions [exec] pg_restore: processing data for table "rules.pr_index_policyconditions" [exec] pg_restore: finished item 6736 TABLE DATA pr_index_policyconditions [exec] pg_restore: launching item 6725 TABLE DATA pr_index_privilege [exec] pg_restore: processing data for table "rules.pr_index_privilege" [exec] pg_restore: finished item 6725 TABLE DATA pr_index_privilege [exec] pg_restore: launching item 6691 TABLE DATA pr_index_reference [exec] pg_restore: processing data for table "rules.pr_index_reference" [exec] pg_restore: finished item 6688 TABLE DATA pr_index_css [exec] pg_restore: launching item 6727 TABLE DATA pr_index_rule_agents [exec] pg_restore: processing data for table "rules.pr_index_rule_agents" [exec] pg_restore: finished item 6727 TABLE DATA pr_index_rule_agents [exec] pg_restore: launching item 6690 TABLE DATA pr_index_warnings [exec] pg_restore: processing data for table "rules.pr_index_warnings" [exec] pg_restore: finished item 6690 TABLE DATA pr_index_warnings [exec] pg_restore: launching item 6737 TABLE DATA pr_link_feature [exec] pg_restore: processing data for table "rules.pr_link_feature" [exec] pg_restore: finished item 6737 TABLE DATA pr_link_feature [exec] pg_restore: launching item 6683 TABLE DATA pr_link_usecase [exec] pg_restore: processing data for table "rules.pr_link_usecase" [exec] pg_restore: finished item 6683 TABLE DATA pr_link_usecase [exec] pg_restore: launching item 6747 TABLE DATA pr_migration_point [exec] pg_restore: processing data for table "rules.pr_migration_point" [exec] pg_restore: finished item 6747 TABLE DATA pr_migration_point [exec] pg_restore: launching item 6722 TABLE DATA pr_reference_page [exec] pg_restore: processing data for table "rules.pr_reference_page" [exec] pg_restore: finished item 6707 TABLE DATA pr_assembledclasses [exec] pg_restore: launching item 6681 TABLE DATA pr_selectquerylog [exec] pg_restore: processing data for table "rules.pr_selectquerylog" [exec] pg_restore: finished item 6681 TABLE DATA pr_selectquerylog [exec] pg_restore: launching item 6716 TABLE DATA pr_sys_app_hierarchy_flat [exec] pg_restore: processing data for table "rules.pr_sys_app_hierarchy_flat" [exec] pg_restore: finished item 6716 TABLE DATA pr_sys_app_hierarchy_flat [exec] pg_restore: launching item 6708 TABLE DATA pr_sys_app_ruleset_index [exec] pg_restore: processing data for table "rules.pr_sys_app_ruleset_index" [exec] pg_restore: finished item 6708 TABLE DATA pr_sys_app_ruleset_index [exec] pg_restore: launching item 6717 TABLE DATA pr_sys_appcache_dep [exec] pg_restore: processing data for table "rules.pr_sys_appcache_dep" [exec] pg_restore: finished item 6717 TABLE DATA pr_sys_appcache_dep [exec] pg_restore: launching item 6715 TABLE DATA pr_sys_appcache_entry [exec] pg_restore: processing data for table "rules.pr_sys_appcache_entry" [exec] pg_restore: finished item 6715 TABLE DATA pr_sys_appcache_entry [exec] pg_restore: launching item 6718 TABLE DATA pr_sys_appcache_shortcut [exec] pg_restore: processing data for table "rules.pr_sys_appcache_shortcut" [exec] pg_restore: finished item 6718 TABLE DATA pr_sys_appcache_shortcut [exec] pg_restore: launching item 6677 TABLE DATA pr_sys_cache_dep [exec] pg_restore: processing data for table "rules.pr_sys_cache_dep" [exec] pg_restore: finished item 6677 TABLE DATA pr_sys_cache_dep [exec] pg_restore: launching item 6676 TABLE DATA pr_sys_cache_entry [exec] pg_restore: processing data for table "rules.pr_sys_cache_entry" [exec] pg_restore: finished item 6676 TABLE DATA pr_sys_cache_entry [exec] pg_restore: launching item 6678 TABLE DATA pr_sys_cache_impl [exec] pg_restore: processing data for table "rules.pr_sys_cache_impl" [exec] pg_restore: finished item 6678 TABLE DATA pr_sys_cache_impl [exec] pg_restore: launching item 6679 TABLE DATA pr_sys_class_ancestors [exec] pg_restore: processing data for table "rules.pr_sys_class_ancestors" [exec] pg_restore: finished item 6722 TABLE DATA pr_reference_page [exec] pg_restore: launching item 6705 TABLE DATA pr_sys_decchg [exec] pg_restore: processing data for table "rules.pr_sys_decchg" [exec] pg_restore: finished item 6705 TABLE DATA pr_sys_decchg [exec] pg_restore: launching item 6729 TABLE DATA pr_sys_hotfix_events [exec] pg_restore: processing data for table "rules.pr_sys_hotfix_events" [exec] pg_restore: finished item 6729 TABLE DATA pr_sys_hotfix_events [exec] pg_restore: launching item 6745 TABLE DATA pr_sys_import_queue [exec] pg_restore: processing data for table "rules.pr_sys_import_queue" [exec] pg_restore: finished item 6745 TABLE DATA pr_sys_import_queue [exec] pg_restore: launching item 6720 TABLE DATA pr_sys_rule_impl [exec] pg_restore: processing data for table "rules.pr_sys_rule_impl" [exec] pg_restore: finished item 6679 TABLE DATA pr_sys_class_ancestors [exec] pg_restore: launching item 6704 TABLE DATA pr_sys_ruleset_index [exec] pg_restore: processing data for table "rules.pr_sys_ruleset_index" [exec] pg_restore: finished item 6704 TABLE DATA pr_sys_ruleset_index [exec] pg_restore: launching item 6748 TABLE DATA pr_sys_runtime_context [exec] pg_restore: processing data for table "rules.pr_sys_runtime_context" [exec] pg_restore: finished item 6748 TABLE DATA pr_sys_runtime_context [exec] pg_restore: launching item 6724 TABLE DATA pr_sysgen_static_content [exec] pg_restore: processing data for table "rules.pr_sysgen_static_content" [exec] pg_restore: finished item 6724 TABLE DATA pr_sysgen_static_content [exec] pg_restore: launching item 6760 TABLE DATA prpc_install_log [exec] pg_restore: processing data for table "rules.prpc_install_log" [exec] pg_restore: finished item 6760 TABLE DATA prpc_install_log [exec] pg_restore: launching item 5516 CONSTRAINT p_contactcontactrel p_contactcontactrel_v2_pk [exec] pg_restore: creating CONSTRAINT "data.p_contactcontactrel p_contactcontactrel_v2_pk" [exec] pg_restore: finished item 5516 CONSTRAINT p_contactcontactrel p_contactcontactrel_v2_pk [exec] pg_restore: launching item 5549 CONSTRAINT p_organization p_organization_v2_pk [exec] pg_restore: creating CONSTRAINT "data.p_organization p_organization_v2_pk" [exec] pg_restore: finished item 5549 CONSTRAINT p_organization p_organization_v2_pk [exec] pg_restore: launching item 5543 INDEX idx_active_orgn_v2 [exec] pg_restore: creating INDEX "data.idx_active_orgn_v2" [exec] pg_restore: finished item 5543 INDEX idx_active_orgn_v2 [exec] pg_restore: launching item 5544 INDEX idx_industry_v2 [exec] pg_restore: creating INDEX "data.idx_industry_v2" [exec] pg_restore: finished item 5544 INDEX idx_industry_v2 [exec] pg_restore: launching item 5545 INDEX idx_organizationname_v2 [exec] pg_restore: creating INDEX "data.idx_organizationname_v2" [exec] pg_restore: finished item 5545 INDEX idx_organizationname_v2 [exec] pg_restore: launching item 5546 INDEX idx_organizationtype_v2 [exec] pg_restore: creating INDEX "data.idx_organizationtype_v2" [exec] pg_restore: finished item 6720 TABLE DATA pr_sys_rule_impl [exec] pg_restore: launching item 5547 INDEX idx_revenue_v2 [exec] pg_restore: creating INDEX "data.idx_revenue_v2" [exec] pg_restore: finished item 5546 INDEX idx_organizationtype_v2 [exec] pg_restore: launching item 5520 CONSTRAINT p_orgorgrel p_orgorgrel_v2_pk [exec] pg_restore: creating CONSTRAINT "data.p_orgorgrel p_orgorgrel_v2_pk" [exec] pg_restore: finished item 5547 INDEX idx_revenue_v2 [exec] pg_restore: launching item 5522 CONSTRAINT p_role p_role_v2_pk [exec] pg_restore: creating CONSTRAINT "data.p_role p_role_v2_pk" [exec] pg_restore: finished item 5520 CONSTRAINT p_orgorgrel p_orgorgrel_v2_pk [exec] pg_restore: launching item 5518 CONSTRAINT p_contactorgrel p_contactorgrel_v2_pk [exec] pg_restore: creating CONSTRAINT "data.p_contactorgrel p_contactorgrel_v2_pk" [exec] pg_restore: finished item 5518 CONSTRAINT p_contactorgrel p_contactorgrel_v2_pk [exec] pg_restore: launching item 5318 CONSTRAINT pc_apn_token pc_apn_token_pk [exec] pg_restore: creating CONSTRAINT "data.pc_apn_token pc_apn_token_pk" [exec] pg_restore: finished item 5522 CONSTRAINT p_role p_role_v2_pk [exec] pg_restore: launching item 4991 CONSTRAINT pc_assign_worklist pc_assign_worklist_pk [exec] pg_restore: creating CONSTRAINT "data.pc_assign_worklist pc_assign_worklist_pk" [exec] pg_restore: finished item 5318 CONSTRAINT pc_apn_token pc_apn_token_pk [exec] pg_restore: launching item 5200 CONSTRAINT pc_cep_actions_repository pc_cep_actions_repository_pk [exec] pg_restore: creating CONSTRAINT "data.pc_cep_actions_repository pc_cep_actions_repository_pk" [exec] pg_restore: finished item 4991 CONSTRAINT pc_assign_worklist pc_assign_worklist_pk [exec] pg_restore: launching item 4988 INDEX bulkprocessfromlist [exec] pg_restore: creating INDEX "data.bulkprocessfromlist" [exec] pg_restore: finished item 5200 CONSTRAINT pc_cep_actions_repository pc_cep_actions_repository_pk [exec] pg_restore: launching item 4989 INDEX getnextworkfromlist [exec] pg_restore: creating INDEX "data.getnextworkfromlist" [exec] pg_restore: finished item 4988 INDEX bulkprocessfromlist [exec] pg_restore: launching item 4992 INDEX refobjectworklist [exec] pg_restore: creating INDEX "data.refobjectworklist" [exec] pg_restore: finished item 4992 INDEX refobjectworklist [exec] pg_restore: launching item 4986 CONSTRAINT pc_assign_workbasket pc_assign_workbasket_pk [exec] pg_restore: creating CONSTRAINT "data.pc_assign_workbasket pc_assign_workbasket_pk" [exec] pg_restore: finished item 4989 INDEX getnextworkfromlist [exec] pg_restore: launching item 5542 CONSTRAINT p_contact p_contact_v2_pk [exec] pg_restore: creating CONSTRAINT "data.p_contact p_contact_v2_pk" [exec] pg_restore: finished item 4986 CONSTRAINT pc_assign_workbasket pc_assign_workbasket_pk [exec] pg_restore: launching item 4983 INDEX bulkprocessfrombasket [exec] pg_restore: creating INDEX "data.bulkprocessfrombasket" [exec] pg_restore: finished item 5542 CONSTRAINT p_contact p_contact_v2_pk [exec] pg_restore: launching item 4984 INDEX pc_assign_workbasket_idx1 [exec] pg_restore: creating INDEX "data.pc_assign_workbasket_idx1" [exec] pg_restore: finished item 4983 INDEX bulkprocessfrombasket [exec] pg_restore: launching item 4987 INDEX refobjectworkbasket [exec] pg_restore: creating INDEX "data.refobjectworkbasket" [exec] pg_restore: finished item 4984 INDEX pc_assign_workbasket_idx1 [exec] pg_restore: launching item 5535 INDEX idx_lastname_v2 [exec] pg_restore: creating INDEX "data.idx_lastname_v2" [exec] pg_restore: finished item 4987 INDEX refobjectworkbasket [exec] pg_restore: launching item 5536 INDEX idx_primaryemail_v2 [exec] pg_restore: creating INDEX "data.idx_primaryemail_v2" [exec] pg_restore: finished item 5535 INDEX idx_lastname_v2 [exec] pg_restore: launching item 5537 INDEX idx_primaryphone_v2 [exec] pg_restore: creating INDEX "data.idx_primaryphone_v2" [exec] pg_restore: finished item 5536 INDEX idx_primaryemail_v2 [exec] pg_restore: launching item 5538 INDEX idx_secondaryemail_v2 [exec] pg_restore: creating INDEX "data.idx_secondaryemail_v2" [exec] pg_restore: finished item 5537 INDEX idx_primaryphone_v2 [exec] pg_restore: launching item 5539 INDEX idx_secondaryphone_v2 [exec] pg_restore: creating INDEX "data.idx_secondaryphone_v2" [exec] pg_restore: finished item 5538 INDEX idx_secondaryemail_v2 [exec] pg_restore: launching item 5540 INDEX idx_tertiaryphone_v2 [exec] pg_restore: creating INDEX "data.idx_tertiaryphone_v2" [exec] pg_restore: finished item 5539 INDEX idx_secondaryphone_v2 [exec] pg_restore: launching item 5202 CONSTRAINT pc_cep_events_repository pc_cep_events_repository_pk [exec] pg_restore: creating CONSTRAINT "data.pc_cep_events_repository pc_cep_events_repository_pk" [exec] pg_restore: finished item 5540 INDEX idx_tertiaryphone_v2 [exec] pg_restore: launching item 5661 CONSTRAINT pc_clientdata_restriction pc_clientdata_restri_1208_pk [exec] pg_restore: creating CONSTRAINT "data.pc_clientdata_restriction pc_clientdata_restri_1208_pk" [exec] pg_restore: finished item 5661 CONSTRAINT pc_clientdata_restriction pc_clientdata_restri_1208_pk [exec] pg_restore: launching item 5659 INDEX pc_clientdata_restri_1208_idx1 [exec] pg_restore: creating INDEX "data.pc_clientdata_restri_1208_idx1" [exec] pg_restore: finished item 5202 CONSTRAINT pc_cep_events_repository pc_cep_events_repository_pk [exec] pg_restore: launching item 5534 CONSTRAINT p_address p_address_v2_pk [exec] pg_restore: creating CONSTRAINT "data.p_address p_address_v2_pk" [exec] pg_restore: finished item 5659 INDEX pc_clientdata_restri_1208_idx1 [exec] pg_restore: launching item 4914 CONSTRAINT pc_data_adm_seccorspol pc_data_adm_seccorspol_pk [exec] pg_restore: creating CONSTRAINT "data.pc_data_adm_seccorspol pc_data_adm_seccorspol_pk" [exec] pg_restore: finished item 5534 CONSTRAINT p_address p_address_v2_pk [exec] pg_restore: launching item 5523 INDEX idx_city_v2 [exec] pg_restore: creating INDEX "data.idx_city_v2" [exec] pg_restore: finished item 5523 INDEX idx_city_v2 [exec] pg_restore: launching item 5524 INDEX idx_postalcode_v2 [exec] pg_restore: creating INDEX "data.idx_postalcode_v2" [exec] pg_restore: finished item 4914 CONSTRAINT pc_data_adm_seccorspol pc_data_adm_seccorspol_pk [exec] pg_restore: launching item 5525 INDEX idx_primaryaddress_v2 [exec] pg_restore: creating INDEX "data.idx_primaryaddress_v2" [exec] pg_restore: finished item 5524 INDEX idx_postalcode_v2 [exec] pg_restore: launching item 5526 INDEX idx_province_v2 [exec] pg_restore: creating INDEX "data.idx_province_v2" [exec] pg_restore: finished item 5525 INDEX idx_primaryaddress_v2 [exec] pg_restore: launching item 5527 INDEX idx_region_v2 [exec] pg_restore: creating INDEX "data.idx_region_v2" [exec] pg_restore: finished item 5526 INDEX idx_province_v2 [exec] pg_restore: launching item 5528 INDEX idx_state_v2 [exec] pg_restore: creating INDEX "data.idx_state_v2" [exec] pg_restore: finished item 5527 INDEX idx_region_v2 [exec] pg_restore: launching item 5529 INDEX idx_subregion_v2 [exec] pg_restore: creating INDEX "data.idx_subregion_v2" [exec] pg_restore: finished item 5528 INDEX idx_state_v2 [exec] pg_restore: launching item 5530 INDEX p_address_v2_idx1 [exec] pg_restore: creating INDEX "data.p_address_v2_idx1" [exec] pg_restore: finished item 5529 INDEX idx_subregion_v2 [exec] pg_restore: launching item 5531 INDEX p_address_v2_idx2 [exec] pg_restore: creating INDEX "data.p_address_v2_idx2" [exec] pg_restore: finished item 5530 INDEX p_address_v2_idx1 [exec] pg_restore: launching item 5532 INDEX p_address_v2_idx3 [exec] pg_restore: creating INDEX "data.p_address_v2_idx3" [exec] pg_restore: finished item 5531 INDEX p_address_v2_idx2 [exec] pg_restore: launching item 4912 INDEX pc_data_adm_seccorspol_idx1 [exec] pg_restore: creating INDEX "data.pc_data_adm_seccorspol_idx1" [exec] pg_restore: finished item 5532 INDEX p_address_v2_idx3 [exec] pg_restore: launching item 5758 CONSTRAINT pc_data_file_temp pc_data_file_temp_pk [exec] pg_restore: creating CONSTRAINT "data.pc_data_file_temp pc_data_file_temp_pk" [exec] pg_restore: finished item 4912 INDEX pc_data_adm_seccorspol_idx1 [exec] pg_restore: launching item 4917 CONSTRAINT pc_data_adm_seckeyid pc_data_adm_seckeyid_pk [exec] pg_restore: creating CONSTRAINT "data.pc_data_adm_seckeyid pc_data_adm_seckeyid_pk" [exec] pg_restore: finished item 5758 CONSTRAINT pc_data_file_temp pc_data_file_temp_pk [exec] pg_restore: launching item 5754 INDEX pc_data_file_temp_idx1 [exec] pg_restore: creating INDEX "data.pc_data_file_temp_idx1" [exec] pg_restore: finished item 4917 CONSTRAINT pc_data_adm_seckeyid pc_data_adm_seckeyid_pk [exec] pg_restore: launching item 5755 INDEX pc_data_file_temp_idx2 [exec] pg_restore: creating INDEX "data.pc_data_file_temp_idx2" [exec] pg_restore: finished item 5754 INDEX pc_data_file_temp_idx1 [exec] pg_restore: launching item 5756 INDEX pc_data_file_temp_idx3 [exec] pg_restore: creating INDEX "data.pc_data_file_temp_idx3" [exec] pg_restore: finished item 5755 INDEX pc_data_file_temp_idx2 [exec] pg_restore: launching item 4915 INDEX pc_data_adm_seckeyid_idx1 [exec] pg_restore: creating INDEX "data.pc_data_adm_seckeyid_idx1" [exec] pg_restore: finished item 5756 INDEX pc_data_file_temp_idx3 [exec] pg_restore: launching item 4924 CONSTRAINT pc_data_notiftn_param pc_data_notiftn_param_pk [exec] pg_restore: creating CONSTRAINT "data.pc_data_notiftn_param pc_data_notiftn_param_pk" [exec] pg_restore: finished item 4915 INDEX pc_data_adm_seckeyid_idx1 [exec] pg_restore: launching item 4994 CONSTRAINT pc_data_uniqueid pc_data_uniqueid_pk [exec] pg_restore: creating CONSTRAINT "data.pc_data_uniqueid pc_data_uniqueid_pk" [exec] pg_restore: finished item 4924 CONSTRAINT pc_data_notiftn_param pc_data_notiftn_param_pk [exec] pg_restore: launching item 4922 INDEX pc_data_notiftn_param_idx1 [exec] pg_restore: creating INDEX "data.pc_data_notiftn_param_idx1" [exec] pg_restore: finished item 4922 INDEX pc_data_notiftn_param_idx1 [exec] pg_restore: launching item 4996 CONSTRAINT pc_data_workattach pc_data_workattach_pk [exec] pg_restore: pg_restore: finished item 4994 CONSTRAINT pc_data_uniqueid pc_data_uniqueid_pk [exec] pg_restore: creating CONSTRAINT "data.pc_data_workattach pc_data_workattach_pk" [exec] launching item 5320 CONSTRAINT pc_gcm_token pc_gcm_token_pk [exec] pg_restore: creating CONSTRAINT "data.pc_gcm_token pc_gcm_token_pk" [exec] pg_restore: finished item 5320 CONSTRAINT pc_gcm_token pc_gcm_token_pk [exec] pg_restore: launching item 5024 CONSTRAINT pc_events pc_events_pk [exec] pg_restore: creating CONSTRAINT "data.pc_events pc_events_pk" [exec] pg_restore: finished item 4996 CONSTRAINT pc_data_workattach pc_data_workattach_pk [exec] pg_restore: launching item 5722 CONSTRAINT pc_flaudit pc_flaudit_pk [exec] pg_restore: creating CONSTRAINT "data.pc_flaudit pc_flaudit_pk" [exec] pg_restore: finished item 5024 CONSTRAINT pc_events pc_events_pk [exec] pg_restore: launching item 5018 INDEX idx_events_ruleupdate [exec] pg_restore: creating INDEX "data.idx_events_ruleupdate" [exec] pg_restore: finished item 5722 CONSTRAINT pc_flaudit pc_flaudit_pk [exec] pg_restore: launching item 5019 INDEX pc_events_apprt [exec] pg_restore: creating INDEX "data.pc_events_apprt" [exec] pg_restore: finished item 5018 INDEX idx_events_ruleupdate [exec] pg_restore: launching item 5020 INDEX pc_events_idx1 [exec] pg_restore: creating INDEX "data.pc_events_idx1" [exec] pg_restore: finished item 5019 INDEX pc_events_apprt [exec] pg_restore: launching item 5021 INDEX pc_events_idx2 [exec] pg_restore: creating INDEX "data.pc_events_idx2" [exec] pg_restore: finished item 5020 INDEX pc_events_idx1 [exec] pg_restore: launching item 5022 INDEX pc_events_objclass [exec] pg_restore: creating INDEX "data.pc_events_objclass" [exec] pg_restore: finished item 5021 INDEX pc_events_idx2 [exec] pg_restore: launching item 5719 INDEX pc_flaudit_idx1 [exec] pg_restore: creating INDEX "data.pc_flaudit_idx1" [exec] pg_restore: finished item 5022 INDEX pc_events_objclass [exec] pg_restore: launching item 5720 INDEX pc_flaudit_idx2 [exec] pg_restore: pg_restore: creating INDEX "data.pc_flaudit_idx2" [exec] finished item 5719 INDEX pc_flaudit_idx1 [exec] pg_restore: launching item 5706 CONSTRAINT pc_history_document pc_history_document_pk [exec] pg_restore: creating CONSTRAINT "data.pc_history_document pc_history_document_pk" [exec] pg_restore: finished item 5720 INDEX pc_flaudit_idx2 [exec] pg_restore: launching item 5368 CONSTRAINT pc_history_data_dms_work pc_his_data_dms_work_pk [exec] pg_restore: creating CONSTRAINT "data.pc_history_data_dms_work pc_his_data_dms_work_pk" [exec] pg_restore: finished item 5706 CONSTRAINT pc_history_document pc_history_document_pk [exec] pg_restore: launching item 5704 INDEX pc_history_document_idx1 [exec] pg_restore: creating INDEX "data.pc_history_document_idx1" [exec] pg_restore: finished item 5704 INDEX pc_history_document_idx1 [exec] pg_restore: launching item 5676 CONSTRAINT pc_history_work_cover_task pc_history_work_cove_2353_pk [exec] pg_restore: creating CONSTRAINT "data.pc_history_work_cover_task pc_history_work_cove_2353_pk" [exec] pg_restore: finished item 5368 CONSTRAINT pc_history_data_dms_work pc_his_data_dms_work_pk [exec] pg_restore: launching item 5606 CONSTRAINT pc_history_group pc_history_group_pk [exec] pg_restore: creating CONSTRAINT "data.pc_history_group pc_history_group_pk" [exec] pg_restore: finished item 5676 CONSTRAINT pc_history_work_cover_task pc_history_work_cove_2353_pk [exec] pg_restore: launching item 5671 INDEX pc_history_work_cove_2353_idx1 [exec] pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx1" [exec] pg_restore: finished item 5671 INDEX pc_history_work_cove_2353_idx1 [exec] pg_restore: launching item 5672 INDEX pc_history_work_cove_2353_idx2 [exec] pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx2" [exec] pg_restore: finished item 5606 CONSTRAINT pc_history_group pc_history_group_pk [exec] pg_restore: launching item 5673 INDEX pc_history_work_cove_2353_idx3 [exec] pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx3" [exec] pg_restore: finished item 5672 INDEX pc_history_work_cove_2353_idx2 [exec] pg_restore: launching item 5674 INDEX pc_history_work_cove_2353_idx4 [exec] pg_restore: creating INDEX "data.pc_history_work_cove_2353_idx4" [exec] pg_restore: finished item 5673 INDEX pc_history_work_cove_2353_idx3 [exec] pg_restore: launching item 5603 INDEX pc_history_group_idx1 [exec] pg_restore: creating INDEX "data.pc_history_group_idx1" [exec] pg_restore: finished item 5674 INDEX pc_history_work_cove_2353_idx4 [exec] pg_restore: launching item 5604 INDEX pc_history_group_idx2 [exec] pg_restore: creating INDEX "data.pc_history_group_idx2" [exec] pg_restore: finished item 5603 INDEX pc_history_group_idx1 [exec] pg_restore: launching item 5386 CONSTRAINT pc_index_location pc_index_location_pk [exec] pg_restore: creating CONSTRAINT "data.pc_index_location pc_index_location_pk" [exec] pg_restore: finished item 5604 INDEX pc_history_group_idx2 [exec] pg_restore: launching item 5448 CONSTRAINT pc_link_association pc_link_association_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_association pc_link_association_pk" [exec] pg_restore: finished item 5386 CONSTRAINT pc_index_location pc_index_location_pk [exec] pg_restore: launching item 5384 INDEX keypurpose_pc_idx_location [exec] pg_restore: creating INDEX "data.keypurpose_pc_idx_location" [exec] pg_restore: finished item 5448 CONSTRAINT pc_link_association pc_link_association_pk [exec] pg_restore: launching item 5445 INDEX pc_link_association_idx1 [exec] pg_restore: creating INDEX "data.pc_link_association_idx1" [exec] pg_restore: finished item 5384 INDEX keypurpose_pc_idx_location [exec] pg_restore: launching item 5446 INDEX pc_link_association_idx2 [exec] pg_restore: creating INDEX "data.pc_link_association_idx2" [exec] pg_restore: finished item 5445 INDEX pc_link_association_idx1 [exec] pg_restore: launching item 5729 CONSTRAINT pc_link_association_channel pc_link_asso_channel_1128_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_association_channel pc_link_asso_channel_1128_pk" [exec] pg_restore: finished item 5446 INDEX pc_link_association_idx2 [exec] pg_restore: launching item 5498 CONSTRAINT pc_link_association_doc pc_link_association_doc_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_association_doc pc_link_association_doc_pk" [exec] pg_restore: finished item 5729 CONSTRAINT pc_link_association_channel pc_link_asso_channel_1128_pk [exec] pg_restore: launching item 5726 INDEX pc_link_asso_channel_1128_idx1 [exec] pg_restore: creating INDEX "data.pc_link_asso_channel_1128_idx1" [exec] pg_restore: finished item 5726 INDEX pc_link_asso_channel_1128_idx1 [exec] pg_restore: launching item 5727 INDEX pc_link_asso_channel_1128_idx2 [exec] pg_restore: creating INDEX "data.pc_link_asso_channel_1128_idx2" [exec] pg_restore: finished item 5727 INDEX pc_link_asso_channel_1128_idx2 [exec] pg_restore: launching item 5610 CONSTRAINT pc_link_association_member pc_link_am_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_association_member pc_link_am_pk" [exec] pg_restore: finished item 5610 CONSTRAINT pc_link_association_member pc_link_am_pk [exec] pg_restore: launching item 5607 INDEX pc_link_am_idx1 [exec] pg_restore: creating INDEX "data.pc_link_am_idx1" [exec] pg_restore: finished item 5607 INDEX pc_link_am_idx1 [exec] pg_restore: launching item 5608 INDEX pc_link_am_idx2 [exec] pg_restore: creating INDEX "data.pc_link_am_idx2" [exec] pg_restore: finished item 5608 INDEX pc_link_am_idx2 [exec] pg_restore: launching item 5654 CONSTRAINT pc_link_association_pin pc_link_association_pin_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_association_pin pc_link_association_pin_pk" [exec] pg_restore: finished item 5654 CONSTRAINT pc_link_association_pin pc_link_association_pin_pk [exec] pg_restore: launching item 5651 INDEX pc_link_association_pin_idx1 [exec] pg_restore: creating INDEX "data.pc_link_association_pin_idx1" [exec] pg_restore: finished item 5651 INDEX pc_link_association_pin_idx1 [exec] pg_restore: launching item 5652 INDEX pc_link_association_pin_idx2 [exec] pg_restore: creating INDEX "data.pc_link_association_pin_idx2" [exec] pg_restore: finished item 5652 INDEX pc_link_association_pin_idx2 [exec] pg_restore: launching item 5715 CONSTRAINT pc_link_association_rrcategory pc_link_association_1128_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_association_rrcategory pc_link_association_1128_pk" [exec] pg_restore: finished item 5498 CONSTRAINT pc_link_association_doc pc_link_association_doc_pk [exec] pg_restore: launching item 5495 INDEX pc_link_association_doc_idx1 [exec] pg_restore: creating INDEX "data.pc_link_association_doc_idx1" [exec] pg_restore: finished item 5495 INDEX pc_link_association_doc_idx1 [exec] pg_restore: launching item 5496 INDEX pc_link_association_doc_idx2 [exec] pg_restore: creating INDEX "data.pc_link_association_doc_idx2" [exec] pg_restore: finished item 5715 CONSTRAINT pc_link_association_rrcategory pc_link_association_1128_pk [exec] pg_restore: launching item 5713 INDEX pc_link_asso_1128_idx1 [exec] pg_restore: creating INDEX "data.pc_link_asso_1128_idx1" [exec] pg_restore: finished item 5496 INDEX pc_link_association_doc_idx2 [exec] pg_restore: launching item 5663 CONSTRAINT pc_link_association_space pc_link_association_space_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_association_space pc_link_association_space_pk" [exec] pg_restore: finished item 5713 INDEX pc_link_asso_1128_idx1 [exec] pg_restore: launching item 5009 CONSTRAINT pc_link_attachment pc_link_attachment_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_attachment pc_link_attachment_pk" [exec] pg_restore: finished item 5663 CONSTRAINT pc_link_association_space pc_link_association_space_pk [exec] pg_restore: launching item 5664 INDEX pr_link_ass_space_idx1 [exec] pg_restore: creating INDEX "data.pr_link_ass_space_idx1" [exec] pg_restore: finished item 5009 CONSTRAINT pc_link_attachment pc_link_attachment_pk [exec] pg_restore: launching item 5665 INDEX pr_link_ass_space_idx2 [exec] pg_restore: creating INDEX "data.pr_link_ass_space_idx2" [exec] pg_restore: finished item 5664 INDEX pr_link_ass_space_idx1 [exec] pg_restore: launching item 5005 INDEX attach_ref_from [exec] pg_restore: creating INDEX "data.attach_ref_from" [exec] pg_restore: finished item 5005 INDEX attach_ref_from [exec] pg_restore: launching item 5006 INDEX link_insname [exec] pg_restore: creating INDEX "data.link_insname" [exec] pg_restore: finished item 5006 INDEX link_insname [exec] pg_restore: launching item 5007 INDEX pc_link_attachment_idx1 [exec] pg_restore: creating INDEX "data.pc_link_attachment_idx1" [exec] pg_restore: finished item 5007 INDEX pc_link_attachment_idx1 [exec] pg_restore: launching item 5598 CONSTRAINT pc_link_category pc_link_category_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_category pc_link_category_pk" [exec] pg_restore: finished item 5598 CONSTRAINT pc_link_category pc_link_category_pk [exec] pg_restore: launching item 5595 INDEX pc_link_category_idx1 [exec] pg_restore: creating INDEX "data.pc_link_category_idx1" [exec] pg_restore: finished item 5595 INDEX pc_link_category_idx1 [exec] pg_restore: launching item 5596 INDEX pc_link_category_idx2 [exec] pg_restore: creating INDEX "data.pc_link_category_idx2" [exec] pg_restore: finished item 5596 INDEX pc_link_category_idx2 [exec] pg_restore: launching item 4977 CONSTRAINT pc_index_accel pc_index_accel_pk [exec] pg_restore: creating CONSTRAINT "data.pc_index_accel pc_index_accel_pk" [exec] pg_restore: finished item 4977 CONSTRAINT pc_index_accel pc_index_accel_pk [exec] pg_restore: launching item 5012 CONSTRAINT pc_link_folder pc_link_folder_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_folder pc_link_folder_pk" [exec] pg_restore: finished item 5665 INDEX pr_link_ass_space_idx2 [exec] pg_restore: launching item 4999 CONSTRAINT pc_history_work pc_history_work_pk [exec] pg_restore: creating CONSTRAINT "data.pc_history_work pc_history_work_pk" [exec] pg_restore: finished item 5012 CONSTRAINT pc_link_folder pc_link_folder_pk [exec] pg_restore: launching item 5010 INDEX folder_insname [exec] pg_restore: creating INDEX "data.folder_insname" [exec] pg_restore: finished item 4999 CONSTRAINT pc_history_work pc_history_work_pk [exec] pg_restore: launching item 4997 INDEX hist_insname [exec] pg_restore: creating INDEX "data.hist_insname" [exec] pg_restore: finished item 5010 INDEX folder_insname [exec] pg_restore: launching item 5000 INDEX pxhistoryforre [exec] pg_restore: creating INDEX "data.pxhistoryforre" [exec] pg_restore: finished item 5000 INDEX pxhistoryforre [exec] pg_restore: launching item 5308 CONSTRAINT pc_pegatask pc_pegatask_pk [exec] pg_restore: creating CONSTRAINT "data.pc_pegatask pc_pegatask_pk" [exec] pg_restore: finished item 4997 INDEX hist_insname [exec] pg_restore: launching item 5017 CONSTRAINT pc_schedule_task pc_schedule_task_pk [exec] pg_restore: creating CONSTRAINT "data.pc_schedule_task pc_schedule_task_pk" [exec] pg_restore: finished item 5308 CONSTRAINT pc_pegatask pc_pegatask_pk [exec] pg_restore: launching item 5306 INDEX pc_pegatask_idx1 [exec] pg_restore: creating INDEX "data.pc_pegatask_idx1" [exec] pg_restore: finished item 5017 CONSTRAINT pc_schedule_task pc_schedule_task_pk [exec] pg_restore: launching item 5015 INDEX pc_schedule_task_idx1 [exec] pg_restore: creating INDEX "data.pc_schedule_task_idx1" [exec] pg_restore: finished item 5306 INDEX pc_pegatask_idx1 [exec] pg_restore: launching item 5028 CONSTRAINT pc_work pc_work_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work pc_work_pk" [exec] pg_restore: finished item 5015 INDEX pc_schedule_task_idx1 [exec] pg_restore: launching item 5004 CONSTRAINT pc_index_workparty pc_index_workparty_pk [exec] pg_restore: creating CONSTRAINT "data.pc_index_workparty pc_index_workparty_pk" [exec] pg_restore: finished item 5028 CONSTRAINT pc_work pc_work_pk [exec] pg_restore: launching item 5025 INDEX pc_work_idx1 [exec] pg_restore: creating INDEX "data.pc_work_idx1" [exec] pg_restore: finished item 5025 INDEX pc_work_idx1 [exec] pg_restore: launching item 5026 INDEX pc_work_idx2 [exec] pg_restore: creating INDEX "data.pc_work_idx2" [exec] pg_restore: finished item 5004 CONSTRAINT pc_index_workparty pc_index_workparty_pk [exec] pg_restore: launching item 5001 INDEX index_key_purp [exec] pg_restore: creating INDEX "data.index_key_purp" [exec] pg_restore: finished item 5001 INDEX index_key_purp [exec] pg_restore: launching item 5002 INDEX pc_index_workparty_idx1 [exec] pg_restore: creating INDEX "data.pc_index_workparty_idx1" [exec] pg_restore: finished item 5002 INDEX pc_index_workparty_idx1 [exec] pg_restore: launching item 5014 CONSTRAINT pc_work_accel pc_work_accel_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_accel pc_work_accel_pk" [exec] pg_restore: finished item 5026 INDEX pc_work_idx2 [exec] pg_restore: launching item 5620 CONSTRAINT pc_work_clientdata pc_work_clientdata_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_clientdata pc_work_clientdata_pk" [exec] pg_restore: finished item 5014 CONSTRAINT pc_work_accel pc_work_accel_pk [exec] pg_restore: launching item 5444 CONSTRAINT pc_work_agile pc_work_agile_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_agile pc_work_agile_pk" [exec] pg_restore: finished item 5620 CONSTRAINT pc_work_clientdata pc_work_clientdata_pk [exec] pg_restore: launching item 5618 INDEX pc_work_clientdata_idx1 [exec] pg_restore: creating INDEX "data.pc_work_clientdata_idx1" [exec] pg_restore: finished item 5444 CONSTRAINT pc_work_agile pc_work_agile_pk [exec] pg_restore: launching item 5442 INDEX pc_work_agile_idx1 [exec] pg_restore: creating INDEX "data.pc_work_agile_idx1" [exec] pg_restore: finished item 5442 INDEX pc_work_agile_idx1 [exec] pg_restore: launching item 5366 CONSTRAINT pc_work_dms pc_work_dms_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_dms pc_work_dms_pk" [exec] pg_restore: finished item 5366 CONSTRAINT pc_work_dms pc_work_dms_pk [exec] pg_restore: launching item 5670 CONSTRAINT pc_work_cover_task pc_work_cover_task_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_cover_task pc_work_cover_task_pk" [exec] pg_restore: finished item 5670 CONSTRAINT pc_work_cover_task pc_work_cover_task_pk [exec] pg_restore: launching item 5666 INDEX pc_work_cover_task_idx1 [exec] pg_restore: creating INDEX "data.pc_work_cover_task_idx1" [exec] pg_restore: finished item 5666 INDEX pc_work_cover_task_idx1 [exec] pg_restore: launching item 5667 INDEX pc_work_cover_task_idx2 [exec] pg_restore: creating INDEX "data.pc_work_cover_task_idx2" [exec] pg_restore: finished item 5667 INDEX pc_work_cover_task_idx2 [exec] pg_restore: launching item 5668 INDEX pc_work_cover_task_idx3 [exec] pg_restore: creating INDEX "data.pc_work_cover_task_idx3" [exec] pg_restore: finished item 5668 INDEX pc_work_cover_task_idx3 [exec] pg_restore: launching item 5494 CONSTRAINT pc_work_document pc_work_document_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_document pc_work_document_pk" [exec] pg_restore: finished item 5494 CONSTRAINT pc_work_document pc_work_document_pk [exec] pg_restore: launching item 5491 INDEX pc_work_document_idx1 [exec] pg_restore: creating INDEX "data.pc_work_document_idx1" [exec] pg_restore: finished item 5491 INDEX pc_work_document_idx1 [exec] pg_restore: launching item 5492 INDEX pc_work_document_idx2 [exec] pg_restore: creating INDEX "data.pc_work_document_idx2" [exec] pg_restore: finished item 5618 INDEX pc_work_clientdata_idx1 [exec] pg_restore: launching item 5035 CONSTRAINT pc_work_dsm_batch pc_work_dsm_batch_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_dsm_batch pc_work_dsm_batch_pk" [exec] pg_restore: finished item 5492 INDEX pc_work_document_idx2 [exec] pg_restore: launching item 5602 CONSTRAINT pc_work_group pc_work_group_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_group pc_work_group_pk" [exec] pg_restore: finished item 5035 CONSTRAINT pc_work_dsm_batch pc_work_dsm_batch_pk [exec] pg_restore: launching item 5033 INDEX pc_work_dsm_batch_idx1 [exec] pg_restore: creating INDEX "data.pc_work_dsm_batch_idx1" [exec] pg_restore: finished item 5602 CONSTRAINT pc_work_group pc_work_group_pk [exec] pg_restore: launching item 5036 INDEX work_stratname [exec] pg_restore: creating INDEX "data.work_stratname" [exec] pg_restore: finished item 5033 INDEX pc_work_dsm_batch_idx1 [exec] pg_restore: launching item 5599 INDEX pc_work_group_idx1 [exec] pg_restore: creating INDEX "data.pc_work_group_idx1" [exec] pg_restore: finished item 5036 INDEX work_stratname [exec] pg_restore: launching item 5600 INDEX pc_work_group_idx2 [exec] pg_restore: creating INDEX "data.pc_work_group_idx2" [exec] pg_restore: finished item 5599 INDEX pc_work_group_idx1 [exec] pg_restore: launching item 5782 CONSTRAINT pc_work_dsm_simulation pc_work_dsm_simulation_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_dsm_simulation pc_work_dsm_simulation_pk" [exec] pg_restore: finished item 5600 INDEX pc_work_group_idx2 [exec] pg_restore: launching item 5097 CONSTRAINT pc_link_topcase pc_link_topcase_pk [exec] pg_restore: creating CONSTRAINT "data.pc_link_topcase pc_link_topcase_pk" [exec] pg_restore: finished item 5782 CONSTRAINT pc_work_dsm_simulation pc_work_dsm_simulation_pk [exec] pg_restore: launching item 5780 INDEX pc_work_dsm_simulation_idx1 [exec] pg_restore: creating INDEX "data.pc_work_dsm_simulation_idx1" [exec] pg_restore: finished item 5097 CONSTRAINT pc_link_topcase pc_link_topcase_pk [exec] pg_restore: launching item 5098 INDEX topcase_refto [exec] pg_restore: creating INDEX "data.topcase_refto" [exec] pg_restore: finished item 5780 INDEX pc_work_dsm_simulation_idx1 [exec] pg_restore: launching item 5451 CONSTRAINT pc_work_guide pc_work_guide_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_guide pc_work_guide_pk" [exec] pg_restore: finished item 5451 CONSTRAINT pc_work_guide pc_work_guide_pk [exec] pg_restore: launching item 5449 INDEX pc_work_guide_idx1 [exec] pg_restore: creating INDEX "data.pc_work_guide_idx1" [exec] pg_restore: finished item 5449 INDEX pc_work_guide_idx1 [exec] pg_restore: launching item 5030 CONSTRAINT pc_work_processemail pc_work_processemail_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_processemail pc_work_processemail_pk" [exec] pg_restore: finished item 5030 CONSTRAINT pc_work_processemail pc_work_processemail_pk [exec] pg_restore: launching item 5031 INDEX processemail_assignmentcdt [exec] pg_restore: creating INDEX "data.processemail_assignmentcdt" [exec] pg_restore: finished item 5031 INDEX processemail_assignmentcdt [exec] pg_restore: launching item 5032 INDEX processemail_itemid [exec] pg_restore: creating INDEX "data.processemail_itemid" [exec] pg_restore: finished item 5032 INDEX processemail_itemid [exec] pg_restore: launching item 5434 CONSTRAINT pc_work_notification pc_work_notification_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_notification pc_work_notification_pk" [exec] pg_restore: finished item 5434 CONSTRAINT pc_work_notification pc_work_notification_pk [exec] pg_restore: launching item 5431 INDEX pc_work_notification_idx1 [exec] pg_restore: creating INDEX "data.pc_work_notification_idx1" [exec] pg_restore: finished item 5431 INDEX pc_work_notification_idx1 [exec] pg_restore: launching item 5432 INDEX pc_work_notification_idx2 [exec] pg_restore: creating INDEX "data.pc_work_notification_idx2" [exec] pg_restore: finished item 5432 INDEX pc_work_notification_idx2 [exec] pg_restore: launching item 5762 CONSTRAINT pc_work_triage pc_work_triage_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_triage pc_work_triage_pk" [exec] pg_restore: finished item 5098 INDEX topcase_refto [exec] pg_restore: launching item 5040 CONSTRAINT pi_data_connect pi_data_connect_pk [exec] pg_restore: creating CONSTRAINT "data.pi_data_connect pi_data_connect_pk" [exec] pg_restore: finished item 5762 CONSTRAINT pc_work_triage pc_work_triage_pk [exec] pg_restore: launching item 5082 CONSTRAINT pr4_history_rule pr4_history_rule_pk [exec] pg_restore: creating CONSTRAINT "data.pr4_history_rule pr4_history_rule_pk" [exec] pg_restore: finished item 5040 CONSTRAINT pi_data_connect pi_data_connect_pk [exec] pg_restore: launching item 5037 INDEX connect_insname [exec] pg_restore: creating INDEX "data.connect_insname" [exec] pg_restore: finished item 5082 CONSTRAINT pr4_history_rule pr4_history_rule_pk [exec] pg_restore: launching item 5038 INDEX connect_objclass [exec] pg_restore: creating INDEX "data.connect_objclass" [exec] pg_restore: finished item 5037 INDEX connect_insname [exec] pg_restore: launching item 5083 INDEX rule_historyforre [exec] pg_restore: creating INDEX "data.rule_historyforre" [exec] pg_restore: finished item 5038 INDEX connect_objclass [exec] pg_restore: launching item 5084 INDEX rule_historytc [exec] pg_restore: creating INDEX "data.rule_historytc" [exec] pg_restore: finished item 5083 INDEX rule_historyforre [exec] pg_restore: launching item 5212 CONSTRAINT pr4_log_rule_usage_details pr4_log_rule_usage_details_pk [exec] pg_restore: creating CONSTRAINT "data.pr4_log_rule_usage_details pr4_log_rule_usage_details_pk" [exec] pg_restore: finished item 5084 INDEX rule_historytc [exec] pg_restore: launching item 5259 CONSTRAINT pc_work_social pc_work_social_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_social pc_work_social_pk" [exec] pg_restore: finished item 5212 CONSTRAINT pr4_log_rule_usage_details pr4_log_rule_usage_details_pk [exec] pg_restore: launching item 5210 INDEX pr4_log_detail_idx1 [exec] pg_restore: creating INDEX "data.pr4_log_detail_idx1" [exec] pg_restore: finished item 5259 CONSTRAINT pc_work_social pc_work_social_pk [exec] pg_restore: launching item 5213 INDEX pr_log_detail_cacheusage [exec] pg_restore: creating INDEX "data.pr_log_detail_cacheusage" [exec] pg_restore: finished item 5210 INDEX pr4_log_detail_idx1 [exec] pg_restore: launching item 5252 INDEX pc_work_social_idx4 [exec] pg_restore: creating INDEX "data.pc_work_social_idx4" [exec] pg_restore: finished item 5213 INDEX pr_log_detail_cacheusage [exec] pg_restore: launching item 5253 INDEX pc_work_social_idx_replyto [exec] pg_restore: creating INDEX "data.pc_work_social_idx_replyto" [exec] pg_restore: finished item 5252 INDEX pc_work_social_idx4 [exec] pg_restore: launching item 5254 INDEX pc_work_social_index1 [exec] pg_restore: creating INDEX "data.pc_work_social_index1" [exec] pg_restore: finished item 5253 INDEX pc_work_social_idx_replyto [exec] pg_restore: launching item 5255 INDEX pc_work_social_index2 [exec] pg_restore: creating INDEX "data.pc_work_social_index2" [exec] pg_restore: finished item 5254 INDEX pc_work_social_index1 [exec] pg_restore: launching item 5256 INDEX pc_work_social_index3 [exec] pg_restore: creating INDEX "data.pc_work_social_index3" [exec] pg_restore: finished item 5255 INDEX pc_work_social_index2 [exec] pg_restore: launching item 5257 INDEX pc_work_social_index4 [exec] pg_restore: creating INDEX "data.pc_work_social_index4" [exec] pg_restore: finished item 5256 INDEX pc_work_social_index3 [exec] pg_restore: launching item 5807 CONSTRAINT pr_archival_class_dependency pr_archival_class_de_1812_pk [exec] pg_restore: creating CONSTRAINT "data.pr_archival_class_dependency pr_archival_class_de_1812_pk" [exec] pg_restore: finished item 5257 INDEX pc_work_social_index4 [exec] pg_restore: launching item 5831 CONSTRAINT pr_archival_excluded_case pr_archival_excluded_case_pk [exec] pg_restore: creating CONSTRAINT "data.pr_archival_excluded_case pr_archival_excluded_case_pk" [exec] pg_restore: finished item 5807 CONSTRAINT pr_archival_class_dependency pr_archival_class_de_1812_pk [exec] pg_restore: launching item 5805 INDEX pr_archival_class_de_1812_idx1 [exec] pg_restore: creating INDEX "data.pr_archival_class_de_1812_idx1" [exec] pg_restore: finished item 5805 INDEX pr_archival_class_de_1812_idx1 [exec] pg_restore: launching item 5044 CONSTRAINT pr_assign pr_assign_pk [exec] pg_restore: creating CONSTRAINT "data.pr_assign pr_assign_pk" [exec] pg_restore: finished item 5831 CONSTRAINT pr_archival_excluded_case pr_archival_excluded_case_pk [exec] pg_restore: launching item 5832 INDEX pr_archival_excluded_idx1 [exec] pg_restore: creating INDEX "data.pr_archival_excluded_idx1" [exec] pg_restore: finished item 5832 INDEX pr_archival_excluded_idx1 [exec] pg_restore: launching item 5833 INDEX pr_archival_excluded_idx2 [exec] pg_restore: creating INDEX "data.pr_archival_excluded_idx2" [exec] pg_restore: finished item 5833 INDEX pr_archival_excluded_idx2 [exec] pg_restore: launching item 5834 INDEX pr_archival_excluded_idx3 [exec] pg_restore: creating INDEX "data.pr_archival_excluded_idx3" [exec] pg_restore: finished item 5834 INDEX pr_archival_excluded_idx3 [exec] pg_restore: launching item 5835 INDEX pr_archival_excluded_idx4 [exec] pg_restore: creating INDEX "data.pr_archival_excluded_idx4" [exec] pg_restore: finished item 5835 INDEX pr_archival_excluded_idx4 [exec] pg_restore: launching item 5191 CONSTRAINT pr_cep_events_queue pr_cep_events_queue_pk [exec] pg_restore: creating CONSTRAINT "data.pr_cep_events_queue pr_cep_events_queue_pk" [exec] pg_restore: finished item 5044 CONSTRAINT pr_assign pr_assign_pk [exec] pg_restore: launching item 5041 INDEX bulkprocesscleanup [exec] pg_restore: creating INDEX "data.bulkprocesscleanup" [exec] pg_restore: finished item 5191 CONSTRAINT pr_cep_events_queue pr_cep_events_queue_pk [exec] pg_restore: launching item 5042 INDEX bulkprocesscollate [exec] pg_restore: creating INDEX "data.bulkprocesscollate" [exec] pg_restore: finished item 5041 INDEX bulkprocesscleanup [exec] pg_restore: launching item 5192 INDEX pr_cep_queue_idx1 [exec] pg_restore: creating INDEX "data.pr_cep_queue_idx1" [exec] pg_restore: finished item 5042 INDEX bulkprocesscollate [exec] pg_restore: launching item 5193 INDEX pr_cep_queue_idx2 [exec] pg_restore: creating INDEX "data.pr_cep_queue_idx2" [exec] pg_restore: finished item 5192 INDEX pr_cep_queue_idx1 [exec] pg_restore: launching item 5195 CONSTRAINT pr_cep_eventslookup pr_cep_eventslookup_pk [exec] pg_restore: creating CONSTRAINT "data.pr_cep_eventslookup pr_cep_eventslookup_pk" [exec] pg_restore: finished item 5193 INDEX pr_cep_queue_idx2 [exec] pg_restore: launching item 5230 CONSTRAINT pr_daily_usage pr_daily_usage_pk [exec] pg_restore: creating CONSTRAINT "data.pr_daily_usage pr_daily_usage_pk" [exec] pg_restore: finished item 5195 CONSTRAINT pr_cep_eventslookup pr_cep_eventslookup_pk [exec] pg_restore: launching item 5197 CONSTRAINT pr_cep_user_subscriptions pr_cep_user_subscriptions_pk [exec] pg_restore: creating CONSTRAINT "data.pr_cep_user_subscriptions pr_cep_user_subscriptions_pk" [exec] pg_restore: finished item 5230 CONSTRAINT pr_daily_usage pr_daily_usage_pk [exec] pg_restore: launching item 5423 CONSTRAINT pr_data_adm_configuration pr_data_adm_config_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_adm_configuration pr_data_adm_config_pk" [exec] pg_restore: finished item 5197 CONSTRAINT pr_cep_user_subscriptions pr_cep_user_subscriptions_pk [exec] pg_restore: launching item 5198 INDEX pr_cep_usersub_index [exec] pg_restore: creating INDEX "data.pr_cep_usersub_index" [exec] pg_restore: finished item 5423 CONSTRAINT pr_data_adm_configuration pr_data_adm_config_pk [exec] pg_restore: launching item 5425 CONSTRAINT pr_data_adm_factory pr_data_adm_factory_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_adm_factory pr_data_adm_factory_pk" [exec] pg_restore: finished item 5198 INDEX pr_cep_usersub_index [exec] pg_restore: launching item 5208 CONSTRAINT pr4_log_rule_usage pr4_log_rule_usage_pk [exec] pg_restore: creating CONSTRAINT "data.pr4_log_rule_usage pr4_log_rule_usage_pk" [exec] pg_restore: finished item 5425 CONSTRAINT pr_data_adm_factory pr_data_adm_factory_pk [exec] pg_restore: launching item 5768 CONSTRAINT pc_work_prediction pc_work_prediction_pk [exec] pg_restore: creating CONSTRAINT "data.pc_work_prediction pc_work_prediction_pk" [exec] pg_restore: finished item 5208 CONSTRAINT pr4_log_rule_usage pr4_log_rule_usage_pk [exec] pg_restore: launching item 5209 INDEX pr_log_rule_node [exec] pg_restore: creating INDEX "data.pr_log_rule_node" [exec] pg_restore: finished item 5768 CONSTRAINT pc_work_prediction pc_work_prediction_pk [exec] pg_restore: launching item 5765 INDEX pc_work_prediction_idx1 [exec] pg_restore: creating INDEX "data.pc_work_prediction_idx1" [exec] pg_restore: finished item 5209 INDEX pr_log_rule_node [exec] pg_restore: launching item 5766 INDEX pc_work_prediction_idx2 [exec] pg_restore: creating INDEX "data.pc_work_prediction_idx2" [exec] pg_restore: finished item 5765 INDEX pc_work_prediction_idx1 [exec] pg_restore: launching item 5613 CONSTRAINT pr_data_admin_auth_code pr_data_admin_auth_code_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_auth_code pr_data_admin_auth_code_pk" [exec] pg_restore: finished item 5766 INDEX pc_work_prediction_idx2 [exec] pg_restore: launching item 5056 CONSTRAINT pr_data_admin pr_data_admin_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin pr_data_admin_pk" [exec] pg_restore: finished item 5613 CONSTRAINT pr_data_admin_auth_code pr_data_admin_auth_code_pk [exec] pg_restore: launching item 5611 INDEX pr_data_admin_auth_code_idx1 [exec] pg_restore: creating INDEX "data.pr_data_admin_auth_code_idx1" [exec] pg_restore: finished item 5611 INDEX pr_data_admin_auth_code_idx1 [exec] pg_restore: launching item 5049 CONSTRAINT pr_data pr_data_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data pr_data_pk" [exec] pg_restore: finished item 5056 CONSTRAINT pr_data_admin pr_data_admin_pk [exec] pg_restore: launching item 5050 INDEX cleardataadminstartflowsbywp [exec] pg_restore: creating INDEX "data.cleardataadminstartflowsbywp" [exec] pg_restore: finished item 5049 CONSTRAINT pr_data pr_data_pk [exec] pg_restore: launching item 5051 INDEX cleardataadminstartflowsforag [exec] pg_restore: creating INDEX "data.cleardataadminstartflowsforag" [exec] pg_restore: finished item 5050 INDEX cleardataadminstartflowsbywp [exec] pg_restore: launching item 5052 INDEX clearstartflowsbyapp [exec] pg_restore: creating INDEX "data.clearstartflowsbyapp" [exec] pg_restore: finished item 5051 INDEX cleardataadminstartflowsforag [exec] pg_restore: launching item 5053 INDEX pr_data_admin_idx1 [exec] pg_restore: creating INDEX "data.pr_data_admin_idx1" [exec] pg_restore: finished item 5052 INDEX clearstartflowsbyapp [exec] pg_restore: launching item 5054 INDEX pr_data_admin_idx2 [exec] pg_restore: creating INDEX "data.pr_data_admin_idx2" [exec] pg_restore: finished item 5053 INDEX pr_data_admin_idx1 [exec] pg_restore: launching item 5047 INDEX assoc_data [exec] pg_restore: creating INDEX "data.assoc_data" [exec] pg_restore: finished item 5054 INDEX pr_data_admin_idx2 [exec] pg_restore: launching item 5779 CONSTRAINT pr_data_admin_dds_table pr_data_admin_dds_table_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_dds_table pr_data_admin_dds_table_pk" [exec] pg_restore: finished item 5047 INDEX assoc_data [exec] pg_restore: launching item 5455 CONSTRAINT pr_data_admin_sec_de_cdk pr_data_admin_sec_de_cdk_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_sec_de_cdk pr_data_admin_sec_de_cdk_pk" [exec] pg_restore: finished item 5779 CONSTRAINT pr_data_admin_dds_table pr_data_admin_dds_table_pk [exec] pg_restore: launching item 5777 INDEX pr_data_admin_dds_table_idx1 [exec] pg_restore: creating INDEX "data.pr_data_admin_dds_table_idx1" [exec] pg_restore: finished item 5455 CONSTRAINT pr_data_admin_sec_de_cdk pr_data_admin_sec_de_cdk_pk [exec] pg_restore: launching item 5452 INDEX pr_ata_admin_sec_cdk_idx1 [exec] pg_restore: creating INDEX "data.pr_ata_admin_sec_cdk_idx1" [exec] pg_restore: finished item 5777 INDEX pr_data_admin_dds_table_idx1 [exec] pg_restore: launching item 5453 INDEX pr_ata_admin_sec_cdk_idx2 [exec] pg_restore: creating INDEX "data.pr_ata_admin_sec_cdk_idx2" [exec] pg_restore: finished item 5452 INDEX pr_ata_admin_sec_cdk_idx1 [exec] pg_restore: launching item 5457 CONSTRAINT pr_data_admin_sec_de_key pr_data_admin_sec_key_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_sec_de_key pr_data_admin_sec_key_pk" [exec] pg_restore: finished item 5453 INDEX pr_ata_admin_sec_cdk_idx2 [exec] pg_restore: launching item 5681 CONSTRAINT pr_data_admin_sec_cert pr_data_admin_sec_cert_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_sec_cert pr_data_admin_sec_cert_pk" [exec] pg_restore: finished item 5457 CONSTRAINT pr_data_admin_sec_de_key pr_data_admin_sec_key_pk [exec] pg_restore: launching item 5574 CONSTRAINT pr_data_admin_sec_sde_cdk pr_data_admin_sec_sde_cdk_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_sec_sde_cdk pr_data_admin_sec_sde_cdk_pk" [exec] pg_restore: finished item 5681 CONSTRAINT pr_data_admin_sec_cert pr_data_admin_sec_cert_pk [exec] pg_restore: launching item 5682 INDEX pr_data_admin_sec_idx1 [exec] pg_restore: creating INDEX "data.pr_data_admin_sec_idx1" [exec] pg_restore: finished item 5574 CONSTRAINT pr_data_admin_sec_sde_cdk pr_data_admin_sec_sde_cdk_pk [exec] pg_restore: launching item 5058 CONSTRAINT pr_data_admin_tenant pr_data_admin_tenant_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_admin_tenant pr_data_admin_tenant_pk" [exec] pg_restore: finished item 5682 INDEX pr_data_admin_sec_idx1 [exec] pg_restore: launching item 4970 CONSTRAINT pr_data_analysis_specification pr_data_analysis_spec_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_analysis_specification pr_data_analysis_spec_pk" [exec] pg_restore: finished item 5058 CONSTRAINT pr_data_admin_tenant pr_data_admin_tenant_pk [exec] pg_restore: launching item 5776 CONSTRAINT pr_data_appalias_authservice pr_data_appalias_aut_1610_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_appalias_authservice pr_data_appalias_aut_1610_pk" [exec] pg_restore: finished item 4970 CONSTRAINT pr_data_analysis_specification pr_data_analysis_spec_pk [exec] pg_restore: launching item 4971 INDEX pr_data_analysis_spec_product [exec] pg_restore: creating INDEX "data.pr_data_analysis_spec_product" [exec] pg_restore: finished item 5776 CONSTRAINT pr_data_appalias_authservice pr_data_appalias_aut_1610_pk [exec] pg_restore: launching item 5774 INDEX pr_data_appalias_aut_1610_idx1 [exec] pg_restore: creating INDEX "data.pr_data_appalias_aut_1610_idx1" [exec] pg_restore: finished item 4971 INDEX pr_data_analysis_spec_product [exec] pg_restore: launching item 5753 CONSTRAINT pr_data_app_oauth2client pr_data_app_oauth2client_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_app_oauth2client pr_data_app_oauth2client_pk" [exec] pg_restore: finished item 5774 INDEX pr_data_appalias_aut_1610_idx1 [exec] pg_restore: launching item 5650 CONSTRAINT pr_data_application_quality pr_data_application_5304_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_application_quality pr_data_application_5304_pk" [exec] pg_restore: finished item 5753 CONSTRAINT pr_data_app_oauth2client pr_data_app_oauth2client_pk [exec] pg_restore: launching item 5751 INDEX pr_data_app_oauth2client_idx1 [exec] pg_restore: creating INDEX "data.pr_data_app_oauth2client_idx1" [exec] pg_restore: finished item 5650 CONSTRAINT pr_data_application_quality pr_data_application_5304_pk [exec] pg_restore: launching item 5648 INDEX pr_data_application_5304_idx1 [exec] pg_restore: creating INDEX "data.pr_data_application_5304_idx1" [exec] pg_restore: finished item 5751 INDEX pr_data_app_oauth2client_idx1 [exec] pg_restore: launching item 5487 CONSTRAINT pr_data_applicationpreference pr_data_apppref_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_applicationpreference pr_data_apppref_pk" [exec] pg_restore: finished item 5648 INDEX pr_data_application_5304_idx1 [exec] pg_restore: launching item 5718 CONSTRAINT pr_data_collaboration pr_data_collaboration_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_collaboration pr_data_collaboration_pk" [exec] pg_restore: finished item 5487 CONSTRAINT pr_data_applicationpreference pr_data_apppref_pk [exec] pg_restore: launching item 5485 INDEX pr_data_apppref_idx1 [exec] pg_restore: creating INDEX "data.pr_data_apppref_idx1" [exec] pg_restore: finished item 5718 CONSTRAINT pr_data_collaboration pr_data_collaboration_pk [exec] pg_restore: launching item 5716 INDEX pr_data_collaboration_idx1 [exec] pg_restore: creating INDEX "data.pr_data_collaboration_idx1" [exec] pg_restore: finished item 5485 INDEX pr_data_apppref_idx1 [exec] pg_restore: launching item 5804 CONSTRAINT pr_data_configuration_audit pr_data_config_audit_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_configuration_audit pr_data_config_audit_pk" [exec] pg_restore: finished item 5804 CONSTRAINT pr_data_configuration_audit pr_data_config_audit_pk [exec] pg_restore: launching item 5802 INDEX pr_data_config_audit_idx1 [exec] pg_restore: creating INDEX "data.pr_data_config_audit_idx1" [exec] pg_restore: finished item 5802 INDEX pr_data_config_audit_idx1 [exec] pg_restore: launching item 5788 CONSTRAINT pr_data_configuration_setting pr_data_configuratio_2969_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_configuration_setting pr_data_configuratio_2969_pk" [exec] pg_restore: finished item 5788 CONSTRAINT pr_data_configuration_setting pr_data_configuratio_2969_pk [exec] pg_restore: launching item 5786 INDEX pr_data_configuratio_2969_idx1 [exec] pg_restore: creating INDEX "data.pr_data_configuratio_2969_idx1" [exec] pg_restore: finished item 5786 INDEX pr_data_configuratio_2969_idx1 [exec] pg_restore: launching item 4982 CONSTRAINT pr_data_autotest pr_data_autotest_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_autotest pr_data_autotest_pk" [exec] pg_restore: finished item 4982 CONSTRAINT pr_data_autotest pr_data_autotest_pk [exec] pg_restore: launching item 4978 INDEX pr_data_at_exestat [exec] pg_restore: creating INDEX "data.pr_data_at_exestat" [exec] pg_restore: finished item 4978 INDEX pr_data_at_exestat [exec] pg_restore: launching item 4979 INDEX pr_data_at_obj [exec] pg_restore: creating INDEX "data.pr_data_at_obj" [exec] pg_restore: finished item 4979 INDEX pr_data_at_obj [exec] pg_restore: launching item 4980 INDEX pr_data_at_reqop [exec] pg_restore: creating INDEX "data.pr_data_at_reqop" [exec] pg_restore: finished item 4980 INDEX pr_data_at_reqop [exec] pg_restore: launching item 5829 CONSTRAINT pr_data_conversation_event pr_data_conv_event_7275_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_conversation_event pr_data_conv_event_7275_pk" [exec] pg_restore: finished item 5829 CONSTRAINT pr_data_conversation_event pr_data_conv_event_7275_pk [exec] pg_restore: launching item 5826 INDEX pr_data_conv_event_7275_idx1 [exec] pg_restore: creating INDEX "data.pr_data_conv_event_7275_idx1" [exec] pg_restore: finished item 5716 INDEX pr_data_collaboration_idx1 [exec] pg_restore: launching item 5827 INDEX pr_data_conv_event_7275_idx2 [exec] pg_restore: creating INDEX "data.pr_data_conv_event_7275_idx2" [exec] pg_restore: finished item 5826 INDEX pr_data_conv_event_7275_idx1 [exec] pg_restore: launching item 5854 CONSTRAINT pr_data_archivalmigration pr_data_archivalmigration_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_archivalmigration pr_data_archivalmigration_pk" [exec] finished item 5827 INDEX pr_data_conv_event_7275_idx2 [exec] pg_restore: launching item 5594 CONSTRAINT pr_data_category pr_data_category_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_category pr_data_category_pk" [exec] pg_restore: finished item 5854 CONSTRAINT pr_data_archivalmigration pr_data_archivalmigration_pk [exec] pg_restore: launching item 5851 INDEX pr_data_archivalmigration_idx1 [exec] pg_restore: creating INDEX "data.pr_data_archivalmigration_idx1" [exec] pg_restore: finished item 5594 CONSTRAINT pr_data_category pr_data_category_pk [exec] pg_restore: launching item 5852 INDEX pr_data_archivalmigration_idx2 [exec] pg_restore: creating INDEX "data.pr_data_archivalmigration_idx2" [exec] pg_restore: finished item 5851 INDEX pr_data_archivalmigration_idx1 [exec] pg_restore: launching item 5592 INDEX pr_data_category_idx1 [exec] pg_restore: pg_restore: creating INDEX "data.pr_data_category_idx1" [exec] finished item 5852 INDEX pr_data_archivalmigration_idx2 [exec] pg_restore: launching item 4921 CONSTRAINT pr_data_custm_date_fmt pr_data_custm_date_fmt_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_custm_date_fmt pr_data_custm_date_fmt_pk" [exec] pg_restore: finished item 4921 CONSTRAINT pr_data_custm_date_fmt pr_data_custm_date_fmt_pk [exec] pg_restore: launching item 5825 CONSTRAINT pr_data_conversation_summary pr_data_conv_sum_7275_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_conversation_summary pr_data_conv_sum_7275_pk" [exec] pg_restore: finished item 5592 INDEX pr_data_category_idx1 [exec] pg_restore: launching item 5725 CONSTRAINT pr_data_decision_biasresults pr_data_decision_br_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_biasresults pr_data_decision_br_pk" [exec] pg_restore: finished item 5825 CONSTRAINT pr_data_conversation_summary pr_data_conv_sum_7275_pk [exec] pg_restore: launching item 5822 INDEX pr_data_conv_sum_7275_idx1 [exec] pg_restore: pg_restore: creating INDEX "data.pr_data_conv_sum_7275_idx1" [exec] finished item 5725 CONSTRAINT pr_data_decision_biasresults pr_data_decision_br_pk [exec] pg_restore: launching item 5823 INDEX pr_data_conv_sum_7275_idx2 [exec] pg_restore: creating INDEX "data.pr_data_conv_sum_7275_idx2" [exec] pg_restore: finished item 5823 INDEX pr_data_conv_sum_7275_idx2 [exec] pg_restore: launching item 5723 INDEX pr_data_decision_br_idx1 [exec] pg_restore: creating INDEX "data.pr_data_decision_br_idx1" [exec] pg_restore: finished item 5822 INDEX pr_data_conv_sum_7275_idx1 [exec] pg_restore: launching item 5858 CONSTRAINT pr_data_customer_interaction pr_data_customer_int_5670_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_customer_interaction pr_data_customer_int_5670_pk" [exec] pg_restore: finished item 5723 INDEX pr_data_decision_br_idx1 [exec] pg_restore: launching item 5373 CONSTRAINT pr_data_decision_ddf_error pr_data_ddf_error_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_decision_ddf_error pr_data_ddf_error_pk" [exec] finished item 5858 CONSTRAINT pr_data_customer_interaction pr_data_customer_int_5670_pk [exec] pg_restore: launching item 5855 INDEX pr_data_customer_int_5670_idx1 [exec] pg_restore: creating INDEX "data.pr_data_customer_int_5670_idx1" [exec] pg_restore: finished item 5373 CONSTRAINT pr_data_decision_ddf_error pr_data_ddf_error_pk [exec] pg_restore: launching item 5856 INDEX pr_data_customer_int_5670_idx2 [exec] pg_restore: creating INDEX "data.pr_data_customer_int_5670_idx2" [exec] pg_restore: finished item 5855 INDEX pr_data_customer_int_5670_idx1 [exec] pg_restore: launching item 5371 INDEX pr_data_ddf_error_idx1 [exec] pg_restore: creating INDEX "data.pr_data_ddf_error_idx1" [exec] pg_restore: finished item 5371 INDEX pr_data_ddf_error_idx1 [exec] pg_restore: launching item 4940 CONSTRAINT pr_data_decision_ddf_runtime pr_data_decision_runtime_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_ddf_runtime pr_data_decision_runtime_pk" [exec] pg_restore: finished item 5856 INDEX pr_data_customer_int_5670_idx2 [exec] pg_restore: launching item 5563 CONSTRAINT pr_data_decision_ddf_run_opts pr_data_decision_ddf_opts_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_ddf_run_opts pr_data_decision_ddf_opts_pk" [exec] pg_restore: finished item 4940 CONSTRAINT pr_data_decision_ddf_runtime pr_data_decision_runtime_pk [exec] pg_restore: launching item 4937 INDEX pr_data_decision_runtime_idx1 [exec] pg_restore: creating INDEX "data.pr_data_decision_runtime_idx1" [exec] pg_restore: finished item 5563 CONSTRAINT pr_data_decision_ddf_run_opts pr_data_decision_ddf_opts_pk [exec] pg_restore: launching item 4938 INDEX pr_data_decision_runtime_idx2 [exec] pg_restore: creating INDEX "data.pr_data_decision_runtime_idx2" [exec] pg_restore: finished item 4937 INDEX pr_data_decision_runtime_idx1 [exec] pg_restore: launching item 5557 INDEX pr_data_decision_ddf_opts_idx1 [exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx1" [exec] pg_restore: finished item 4938 INDEX pr_data_decision_runtime_idx2 [exec] pg_restore: launching item 5558 INDEX pr_data_decision_ddf_opts_idx2 [exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx2" [exec] pg_restore: finished item 5557 INDEX pr_data_decision_ddf_opts_idx1 [exec] pg_restore: launching item 5559 INDEX pr_data_decision_ddf_opts_idx3 [exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx3" [exec] pg_restore: finished item 5558 INDEX pr_data_decision_ddf_opts_idx2 [exec] pg_restore: launching item 5560 INDEX pr_data_decision_ddf_opts_idx4 [exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx4" [exec] pg_restore: finished item 5559 INDEX pr_data_decision_ddf_opts_idx3 [exec] pg_restore: launching item 5561 INDEX pr_data_decision_ddf_opts_idx5 [exec] pg_restore: creating INDEX "data.pr_data_decision_ddf_opts_idx5" [exec] pg_restore: finished item 5560 INDEX pr_data_decision_ddf_opts_idx4 [exec] pg_restore: launching item 4936 CONSTRAINT pr_data_decision_df_met pr_data_decision_df_met_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_df_met pr_data_decision_df_met_pk" [exec] pg_restore: finished item 5561 INDEX pr_data_decision_ddf_opts_idx5 [exec] pg_restore: launching item 4932 CONSTRAINT pr_data_decision_df_part pr_data_decision_df_part_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_decision_df_part pr_data_decision_df_part_pk" [exec] pg_restore: finished item 4936 CONSTRAINT pr_data_decision_df_met pr_data_decision_df_met_pk [exec] pg_restore: launching item 4933 INDEX pr_data_decision_df_met_idx1 [exec] pg_restore: creating INDEX "data.pr_data_decision_df_met_idx1" [exec] pg_restore: finished item 4932 CONSTRAINT pr_data_decision_df_part pr_data_decision_df_part_pk [exec] pg_restore: launching item 4934 INDEX pr_data_decision_df_met_idx2 [exec] pg_restore: creating INDEX "data.pr_data_decision_df_met_idx2" [exec] pg_restore: finished item 4933 INDEX pr_data_decision_df_met_idx1 [exec] pg_restore: launching item 4927 INDEX pr_data_decision_df_part_idx1 [exec] pg_restore: creating INDEX "data.pr_data_decision_df_part_idx1" [exec] pg_restore: finished item 4934 INDEX pr_data_decision_df_met_idx2 [exec] pg_restore: launching item 4928 INDEX pr_data_decision_df_part_idx2 [exec] pg_restore: creating INDEX "data.pr_data_decision_df_part_idx2" [exec] pg_restore: finished item 4927 INDEX pr_data_decision_df_part_idx1 [exec] pg_restore: launching item 4929 INDEX pr_data_decision_df_part_idx3 [exec] pg_restore: creating INDEX "data.pr_data_decision_df_part_idx3" [exec] pg_restore: finished item 4928 INDEX pr_data_decision_df_part_idx2 [exec] pg_restore: launching item 4930 INDEX pr_data_decision_df_part_idx4 [exec] pg_restore: creating INDEX "data.pr_data_decision_df_part_idx4" [exec] pg_restore: finished item 4929 INDEX pr_data_decision_df_part_idx3 [exec] pg_restore: launching item 5462 CONSTRAINT pr_data_distinctvalueindex pr_data_distinctvalue_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_distinctvalueindex pr_data_distinctvalue_pk" [exec] pg_restore: finished item 4930 INDEX pr_data_decision_df_part_idx4 [exec] pg_restore: launching item 5270 CONSTRAINT pr_data_dm_admmart_mdl_fact pr_data_dm_admmart_mdl_fact_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_admmart_mdl_fact pr_data_dm_admmart_mdl_fact_pk" [exec] pg_restore: finished item 5462 CONSTRAINT pr_data_distinctvalueindex pr_data_distinctvalue_pk [exec] pg_restore: launching item 5460 INDEX pr_data_distinctvalue_oc [exec] pg_restore: creating INDEX "data.pr_data_distinctvalue_oc" [exec] pg_restore: finished item 5270 CONSTRAINT pr_data_dm_admmart_mdl_fact pr_data_dm_admmart_mdl_fact_pk [exec] pg_restore: launching item 5268 INDEX admmart_model_fact_idx [exec] pg_restore: creating INDEX "data.admmart_model_fact_idx" [exec] pg_restore: finished item 5460 INDEX pr_data_distinctvalue_oc [exec] pg_restore: launching item 5267 CONSTRAINT pr_data_dm_admmart_model pr_data_dm_admmart_model_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_admmart_model pr_data_dm_admmart_model_pk" [exec] pg_restore: finished item 5268 INDEX admmart_model_fact_idx [exec] pg_restore: launching item 5628 CONSTRAINT pr_data_dm_binarydistribution pr_data_dm_binarydist_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_binarydistribution pr_data_dm_binarydist_pk" [exec] pg_restore: finished item 5267 CONSTRAINT pr_data_dm_admmart_model pr_data_dm_admmart_model_pk [exec] pg_restore: launching item 5265 INDEX admmart_model_idx [exec] pg_restore: creating INDEX "data.admmart_model_idx" [exec] pg_restore: finished item 5628 CONSTRAINT pr_data_dm_binarydistribution pr_data_dm_binarydist_pk [exec] pg_restore: launching item 5625 INDEX pr_data_dm_binarydist_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_binarydist_idx1" [exec] pg_restore: finished item 5265 INDEX admmart_model_idx [exec] pg_restore: launching item 5626 INDEX pr_data_dm_binarydist_idx2 [exec] pg_restore: creating INDEX "data.pr_data_dm_binarydist_idx2" [exec] pg_restore: finished item 5626 INDEX pr_data_dm_binarydist_idx2 [exec] pg_restore: launching item 4905 CONSTRAINT pr_data_dm_admmart_pred pr_data_dm_admmart_pred_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_admmart_pred pr_data_dm_admmart_pred_pk" [exec] pg_restore: finished item 4905 CONSTRAINT pr_data_dm_admmart_pred pr_data_dm_admmart_pred_pk [exec] pg_restore: launching item 4903 INDEX pr_data_dm_admmart_pred_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_admmart_pred_idx1" [exec] pg_restore: finished item 4903 INDEX pr_data_dm_admmart_pred_idx1 [exec] pg_restore: launching item 5631 CONSTRAINT pr_data_dm_histogram pr_data_dm_histogram_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_histogram pr_data_dm_histogram_pk" [exec] pg_restore: finished item 5631 CONSTRAINT pr_data_dm_histogram pr_data_dm_histogram_pk [exec] pg_restore: launching item 5629 INDEX pr_data_dm_histogram_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_histogram_idx1" [exec] pg_restore: finished item 5629 INDEX pr_data_dm_histogram_idx1 [exec] pg_restore: launching item 5846 CONSTRAINT pr_data_dm_distribution pr_data_dm_distribution_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_distribution pr_data_dm_distribution_pk" [exec] pg_restore: finished item 5846 CONSTRAINT pr_data_dm_distribution pr_data_dm_distribution_pk [exec] pg_restore: launching item 5843 INDEX pr_data_dm_distribution_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_distribution_idx1" [exec] pg_restore: finished item 5625 INDEX pr_data_dm_binarydist_idx1 [exec] pg_restore: launching item 5844 INDEX pr_data_dm_distribution_idx2 [exec] pg_restore: creating INDEX "data.pr_data_dm_distribution_idx2" [exec] pg_restore: finished item 5843 INDEX pr_data_dm_distribution_idx1 [exec] pg_restore: launching item 5697 CONSTRAINT pr_data_dm_notification pr_data_dm_ntfctn_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_notification pr_data_dm_ntfctn_pk" [exec] pg_restore: finished item 5844 INDEX pr_data_dm_distribution_idx2 [exec] pg_restore: launching item 5638 CONSTRAINT pr_data_dm_contingencytable pr_data_dm_contingen_1844_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_contingencytable pr_data_dm_contingen_1844_pk" [exec] pg_restore: finished item 5697 CONSTRAINT pr_data_dm_notification pr_data_dm_ntfctn_pk [exec] pg_restore: launching item 5690 INDEX pr_data_dm_ntfctn_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx1" [exec] pg_restore: finished item 5638 CONSTRAINT pr_data_dm_contingencytable pr_data_dm_contingen_1844_pk [exec] pg_restore: launching item 5691 INDEX pr_data_dm_ntfctn_idx2 [exec] pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx2" [exec] pg_restore: finished item 5690 INDEX pr_data_dm_ntfctn_idx1 [exec] pg_restore: launching item 5692 INDEX pr_data_dm_ntfctn_idx3 [exec] pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx3" [exec] pg_restore: finished item 5691 INDEX pr_data_dm_ntfctn_idx2 [exec] pg_restore: launching item 5693 INDEX pr_data_dm_ntfctn_idx4 [exec] pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx4" [exec] pg_restore: finished item 5692 INDEX pr_data_dm_ntfctn_idx3 [exec] pg_restore: launching item 5694 INDEX pr_data_dm_ntfctn_idx5 [exec] pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx5" [exec] pg_restore: finished item 5693 INDEX pr_data_dm_ntfctn_idx4 [exec] pg_restore: launching item 5695 INDEX pr_data_dm_ntfctn_idx6 [exec] pg_restore: creating INDEX "data.pr_data_dm_ntfctn_idx6" [exec] pg_restore: finished item 5694 INDEX pr_data_dm_ntfctn_idx5 [exec] pg_restore: launching item 5639 INDEX pr_data_dm_contingency_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_contingency_idx1" [exec] pg_restore: finished item 5695 INDEX pr_data_dm_ntfctn_idx6 [exec] pg_restore: launching item 5622 CONSTRAINT pr_data_dmorg_dmsample_circle pr_data_dmorg_dmsample_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dmorg_dmsample_circle pr_data_dmorg_dmsample_pk" [exec] pg_restore: finished item 5639 INDEX pr_data_dm_contingency_idx1 [exec] pg_restore: launching item 5346 CONSTRAINT pr_data_dms_customer_data pr_data_dms_customer_data_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_customer_data pr_data_dms_customer_data_pk" [exec] pg_restore: finished item 5622 CONSTRAINT pr_data_dmorg_dmsample_circle pr_data_dmorg_dmsample_pk [exec] pg_restore: launching item 5636 CONSTRAINT pr_data_dm_snapshot pr_data_dm_snapshot_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_snapshot pr_data_dm_snapshot_pk" [exec] pg_restore: finished item 5346 CONSTRAINT pr_data_dms_customer_data pr_data_dms_customer_data_pk [exec] pg_restore: launching item 5344 INDEX pr_data_dms_customer_data_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dms_customer_data_idx1" [exec] pg_restore: finished item 5636 CONSTRAINT pr_data_dm_snapshot pr_data_dm_snapshot_pk [exec] pg_restore: launching item 5632 INDEX pr_data_dm_snapshot_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_snapshot_idx1" [exec] pg_restore: finished item 5344 INDEX pr_data_dms_customer_data_idx1 [exec] pg_restore: launching item 5633 INDEX pr_data_dm_snapshot_idx2 [exec] pg_restore: creating INDEX "data.pr_data_dm_snapshot_idx2" [exec] pg_restore: finished item 5632 INDEX pr_data_dm_snapshot_idx1 [exec] pg_restore: launching item 5634 INDEX pr_data_dm_snapshot_idx3 [exec] pg_restore: creating INDEX "data.pr_data_dm_snapshot_idx3" [exec] pg_restore: finished item 5633 INDEX pr_data_dm_snapshot_idx2 [exec] pg_restore: launching item 5357 CONSTRAINT pr_data_dms_droppedcallevents pr_data_dms_droppedcallev_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_droppedcallevents pr_data_dms_droppedcallev_pk" [exec] pg_restore: finished item 5634 INDEX pr_data_dm_snapshot_idx3 [exec] pg_restore: launching item 5349 CONSTRAINT pr_data_dms_device pr_data_dms_device_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_device pr_data_dms_device_pk" [exec] pg_restore: finished item 5357 CONSTRAINT pr_data_dms_droppedcallevents pr_data_dms_droppedcallev_pk [exec] pg_restore: launching item 5850 CONSTRAINT pr_data_dm_summary pr_data_dm_summary_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dm_summary pr_data_dm_summary_pk" [exec] pg_restore: finished item 5349 CONSTRAINT pr_data_dms_device pr_data_dms_device_pk [exec] pg_restore: launching item 5347 INDEX pr_data_dms_device_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dms_device_idx1" [exec] pg_restore: finished item 5850 CONSTRAINT pr_data_dm_summary pr_data_dm_summary_pk [exec] pg_restore: launching item 5847 INDEX pr_data_dm_summaries_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dm_summaries_idx1" [exec] pg_restore: finished item 5347 INDEX pr_data_dms_device_idx1 [exec] pg_restore: launching item 5848 INDEX pr_data_dm_summary_idx2 [exec] pg_restore: creating INDEX "data.pr_data_dm_summary_idx2" [exec] pg_restore: finished item 5847 INDEX pr_data_dm_summaries_idx1 [exec] pg_restore: launching item 5421 CONSTRAINT pr_data_dms_survey_data pr_data_dms_survey_data_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_survey_data pr_data_dms_survey_data_pk" [exec] pg_restore: finished item 5848 INDEX pr_data_dm_summary_idx2 [exec] pg_restore: launching item 5352 CONSTRAINT pr_data_dms_purchase pr_data_dms_purchase_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_purchase pr_data_dms_purchase_pk" [exec] pg_restore: finished item 5421 CONSTRAINT pr_data_dms_survey_data pr_data_dms_survey_data_pk [exec] pg_restore: launching item 5359 CONSTRAINT pr_data_dms_global pr_data_dms_global_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_global pr_data_dms_global_pk" [exec] pg_restore: finished item 5352 CONSTRAINT pr_data_dms_purchase pr_data_dms_purchase_pk [exec] pg_restore: launching item 5350 INDEX pr_data_dms_purchase_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dms_purchase_idx1" [exec] pg_restore: finished item 5359 CONSTRAINT pr_data_dms_global pr_data_dms_global_pk [exec] pg_restore: launching item 5355 CONSTRAINT pr_data_dms_subscription pr_data_dms_subscription_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_dms_subscription pr_data_dms_subscription_pk" [exec] pg_restore: finished item 5350 INDEX pr_data_dms_purchase_idx1 [exec] pg_restore: launching item 5686 CONSTRAINT pr_data_full_sync_stats pr_offline_fullsync_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_full_sync_stats pr_offline_fullsync_pk" [exec] pg_restore: finished item 5355 CONSTRAINT pr_data_dms_subscription pr_data_dms_subscription_pk [exec] pg_restore: launching item 5353 INDEX pr_data_dms_subscription_idx1 [exec] pg_restore: creating INDEX "data.pr_data_dms_subscription_idx1" [exec] pg_restore: finished item 5686 CONSTRAINT pr_data_full_sync_stats pr_offline_fullsync_pk [exec] pg_restore: launching item 5683 INDEX pr_offline_fullsync_idx1 [exec] pg_restore: creating INDEX "data.pr_offline_fullsync_idx1" [exec] pg_restore: finished item 5353 INDEX pr_data_dms_subscription_idx1 [exec] pg_restore: launching item 5684 INDEX pr_offline_fullsync_idx2 [exec] pg_restore: creating INDEX "data.pr_offline_fullsync_idx2" [exec] pg_restore: finished item 5683 INDEX pr_offline_fullsync_idx1 [exec] pg_restore: launching item 5679 CONSTRAINT pr_data_explain_simulation pr_data_explain_simu_1179_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_explain_simulation pr_data_explain_simu_1179_pk" [exec] pg_restore: finished item 5684 INDEX pr_offline_fullsync_idx2 [exec] pg_restore: launching item 4965 CONSTRAINT pr_data_file pr_data_file_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_file pr_data_file_pk" [exec] pg_restore: finished item 5679 CONSTRAINT pr_data_explain_simulation pr_data_explain_simu_1179_pk [exec] pg_restore: launching item 5677 INDEX pr_data_explain_simu_1179_idx1 [exec] pg_restore: creating INDEX "data.pr_data_explain_simu_1179_idx1" [exec] pg_restore: finished item 4965 CONSTRAINT pr_data_file pr_data_file_pk [exec] pg_restore: launching item 4963 INDEX datafile_pd [exec] pg_restore: creating INDEX "data.datafile_pd" [exec] pg_restore: finished item 5677 INDEX pr_data_explain_simu_1179_idx1 [exec] pg_restore: launching item 4967 CONSTRAINT pr_data_guardrails pr_data_guardrails_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_guardrails pr_data_guardrails_pk" [exec] pg_restore: finished item 4963 INDEX datafile_pd [exec] pg_restore: launching item 5733 CONSTRAINT pr_data_guardrails_evaluation pr_data_guardrails_e_8355_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_guardrails_evaluation pr_data_guardrails_e_8355_pk" [exec] pg_restore: finished item 5733 CONSTRAINT pr_data_guardrails_evaluation pr_data_guardrails_e_8355_pk [exec] pg_restore: launching item 5730 INDEX pr_data_guardrails_e_8355_idx1 [exec] pg_restore: creating INDEX "data.pr_data_guardrails_e_8355_idx1" [exec] pg_restore: finished item 4967 CONSTRAINT pr_data_guardrails pr_data_guardrails_pk [exec] pg_restore: launching item 4968 INDEX pr_data_guardrails_product [exec] pg_restore: creating INDEX "data.pr_data_guardrails_product" [exec] pg_restore: finished item 4968 INDEX pr_data_guardrails_product [exec] pg_restore: launching item 5731 INDEX pr_data_guardrails_e_8355_idx2 [exec] pg_restore: creating INDEX "data.pr_data_guardrails_e_8355_idx2" [exec] pg_restore: finished item 5730 INDEX pr_data_guardrails_e_8355_idx1 [exec] pg_restore: launching item 5428 CONSTRAINT pr_data_features pr_data_features_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_features pr_data_features_pk" [exec] pg_restore: finished item 5731 INDEX pr_data_guardrails_e_8355_idx2 [exec] pg_restore: launching item 5644 CONSTRAINT pr_data_healthcheck pr_data_healthcheck_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_healthcheck pr_data_healthcheck_pk" [exec] finished item 5428 CONSTRAINT pr_data_features pr_data_features_pk [exec] pg_restore: launching item 5426 INDEX pr_data_features_idx1 [exec] pg_restore: creating INDEX "data.pr_data_features_idx1" [exec] pg_restore: finished item 5426 INDEX pr_data_features_idx1 [exec] pg_restore: launching item 5735 CONSTRAINT pr_data_guardrails_runstatus pr_data_guardrails_r_8355_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_guardrails_runstatus pr_data_guardrails_r_8355_pk" [exec] pg_restore: finished item 5644 CONSTRAINT pr_data_healthcheck pr_data_healthcheck_pk [exec] pg_restore: launching item 5640 INDEX pr_data_healthcheck_idx1 [exec] pg_restore: creating INDEX "data.pr_data_healthcheck_idx1" [exec] pg_restore: finished item 5640 INDEX pr_data_healthcheck_idx1 [exec] pg_restore: launching item 5641 INDEX pr_data_healthcheck_idx2 [exec] pg_restore: creating INDEX "data.pr_data_healthcheck_idx2" [exec] pg_restore: finished item 5735 CONSTRAINT pr_data_guardrails_runstatus pr_data_guardrails_r_8355_pk [exec] pg_restore: launching item 5642 INDEX pr_data_healthcheck_idx3 [exec] pg_restore: creating INDEX "data.pr_data_healthcheck_idx3" [exec] pg_restore: finished item 5642 INDEX pr_data_healthcheck_idx3 [exec] pg_restore: launching item 5305 CONSTRAINT pr_data_ih_association pr_data_ih_association_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_ih_association pr_data_ih_association_pk" [exec] finished item 5641 INDEX pr_data_healthcheck_idx2 [exec] pg_restore: launching item 5292 CONSTRAINT pr_data_ih_dim_application pr_data_ih_dim_applicaiton_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_application pr_data_ih_dim_applicaiton_pk" [exec] pg_restore: finished item 5292 CONSTRAINT pr_data_ih_dim_application pr_data_ih_dim_applicaiton_pk [exec] pg_restore: launching item 5290 CONSTRAINT pr_data_ih_dim_context pr_data_ih_dim_context_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_context pr_data_ih_dim_context_pk" [exec] pg_restore: finished item 5305 CONSTRAINT pr_data_ih_association pr_data_ih_association_pk [exec] pg_restore: launching item 5303 INDEX pr_data_ih_association_idx1 [exec] pg_restore: creating INDEX "data.pr_data_ih_association_idx1" [exec] pg_restore: finished item 5290 CONSTRAINT pr_data_ih_dim_context pr_data_ih_dim_context_pk [exec] pg_restore: launching item 5294 CONSTRAINT pr_data_ih_dim_channel pr_data_ih_dim_channel_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_channel pr_data_ih_dim_channel_pk" [exec] finished item 5303 INDEX pr_data_ih_association_idx1 [exec] pg_restore: launching item 5286 CONSTRAINT pr_data_ih_dim_location pr_data_ih_dim_location_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_location pr_data_ih_dim_location_pk" [exec] pg_restore: finished item 5286 CONSTRAINT pr_data_ih_dim_location pr_data_ih_dim_location_pk [exec] pg_restore: launching item 5459 CONSTRAINT pr_data_ih_dim_journey pr_data_ih_dim_journey_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_journey pr_data_ih_dim_journey_pk" [exec] finished item 5294 CONSTRAINT pr_data_ih_dim_channel pr_data_ih_dim_channel_pk [exec] pg_restore: launching item 5296 CONSTRAINT pr_data_ih_dim_outcome pr_data_ih_dim_outcome_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_outcome pr_data_ih_dim_outcome_pk" [exec] pg_restore: finished item 5459 CONSTRAINT pr_data_ih_dim_journey pr_data_ih_dim_journey_pk [exec] pg_restore: launching item 5288 CONSTRAINT pr_data_ih_dim_operator pr_data_ih_dim_operator_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_operator pr_data_ih_dim_operator_pk" [exec] pg_restore: finished item 5296 CONSTRAINT pr_data_ih_dim_outcome pr_data_ih_dim_outcome_pk [exec] pg_restore: launching item 5282 CONSTRAINT pr_data_ih_dim_action pr_data_ih_dim_action_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_action pr_data_ih_dim_action_pk" [exec] pg_restore: finished item 5288 CONSTRAINT pr_data_ih_dim_operator pr_data_ih_dim_operator_pk [exec] pg_restore: launching item 5647 CONSTRAINT pr_data_integrationsystem pr_data_integrationsystem_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_integrationsystem pr_data_integrationsystem_pk" [exec] pg_restore: finished item 5282 CONSTRAINT pr_data_ih_dim_action pr_data_ih_dim_action_pk [exec] pg_restore: launching item 5302 CONSTRAINT pr_data_ih_fact pr_data_ih_fact_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_fact pr_data_ih_fact_pk" [exec] pg_restore: finished item 5647 CONSTRAINT pr_data_integrationsystem pr_data_integrationsystem_pk [exec] pg_restore: launching item 5645 INDEX pr_data_integrationsystem_idx1 [exec] pg_restore: creating INDEX "data.pr_data_integrationsystem_idx1" [exec] pg_restore: finished item 5302 CONSTRAINT pr_data_ih_fact pr_data_ih_fact_pk [exec] pg_restore: launching item 5297 INDEX pr_data_ih_fact_idx1 [exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx1" [exec] pg_restore: finished item 5645 INDEX pr_data_integrationsystem_idx1 [exec] pg_restore: launching item 5298 INDEX pr_data_ih_fact_idx2 [exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx2" [exec] pg_restore: finished item 5297 INDEX pr_data_ih_fact_idx1 [exec] pg_restore: launching item 5299 INDEX pr_data_ih_fact_idx3 [exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx3" [exec] pg_restore: finished item 5299 INDEX pr_data_ih_fact_idx3 [exec] pg_restore: launching item 5300 INDEX pr_data_ih_fact_idx4 [exec] pg_restore: creating INDEX "data.pr_data_ih_fact_idx4" [exec] pg_restore: finished item 5300 INDEX pr_data_ih_fact_idx4 [exec] pg_restore: launching item 4926 CONSTRAINT pr_data_mobile_app_pf_asset pr_data_mobile_app_pf_asset_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_mobile_app_pf_asset pr_data_mobile_app_pf_asset_pk" [exec] finished item 5298 INDEX pr_data_ih_fact_idx2 [exec] pg_restore: launching item 5316 CONSTRAINT pr_data_mobile_appinfo pr_data_mobile_appinfo_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_appinfo pr_data_mobile_appinfo_pk" [exec] pg_restore: finished item 5316 CONSTRAINT pr_data_mobile_appinfo pr_data_mobile_appinfo_pk [exec] pg_restore: launching item 5312 CONSTRAINT pr_data_mobile_asset pr_data_mobile_asset_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_asset pr_data_mobile_asset_pk" [exec] pg_restore: finished item 4926 CONSTRAINT pr_data_mobile_app_pf_asset pr_data_mobile_app_pf_asset_pk [exec] pg_restore: launching item 5310 CONSTRAINT pr_data_mobile_build pr_data_mobile_build_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_build pr_data_mobile_build_pk" [exec] pg_restore: finished item 5312 CONSTRAINT pr_data_mobile_asset pr_data_mobile_asset_pk [exec] pg_restore: launching item 5314 CONSTRAINT pr_data_mobile_certificate pr_data_mobile_certificate_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_certificate pr_data_mobile_certificate_pk" [exec] pg_restore: finished item 5310 CONSTRAINT pr_data_mobile_build pr_data_mobile_build_pk [exec] pg_restore: launching item 5284 CONSTRAINT pr_data_ih_dim_customer pr_data_ih_dim_customer_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_ih_dim_customer pr_data_ih_dim_customer_pk" [exec] pg_restore: finished item 5314 CONSTRAINT pr_data_mobile_certificate pr_data_mobile_certificate_pk [exec] pg_restore: launching item 5505 CONSTRAINT pr_data_mobile_map_track pr_data_mobile_map_track_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_map_track pr_data_mobile_map_track_pk" [exec] pg_restore: finished item 5284 CONSTRAINT pr_data_ih_dim_customer pr_data_ih_dim_customer_pk [exec] pg_restore: launching item 5400 CONSTRAINT pr_data_mobile_device pr_data_mobile_device_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_device pr_data_mobile_device_pk" [exec] pg_restore: finished item 5505 CONSTRAINT pr_data_mobile_map_track pr_data_mobile_map_track_pk [exec] pg_restore: launching item 5503 INDEX pr_data_mobile_map_idx1 [exec] pg_restore: creating INDEX "data.pr_data_mobile_map_idx1" [exec] pg_restore: finished item 5400 CONSTRAINT pr_data_mobile_device pr_data_mobile_device_pk [exec] pg_restore: launching item 5381 CONSTRAINT pr_data_nlp_details pr_data_nlp_result_d_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_details pr_data_nlp_result_d_pk" [exec] pg_restore: finished item 5503 INDEX pr_data_mobile_map_idx1 [exec] pg_restore: launching item 5842 CONSTRAINT pr_data_nlp_deployprediction pr_data_nlp_deploypr_4542_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_deployprediction pr_data_nlp_deploypr_4542_pk" [exec] pg_restore: finished item 5381 CONSTRAINT pr_data_nlp_details pr_data_nlp_result_d_pk [exec] pg_restore: launching item 5378 INDEX pr_data_nlp_d_pxdocid_idx [exec] pg_restore: creating INDEX "data.pr_data_nlp_d_pxdocid_idx" [exec] pg_restore: finished item 5842 CONSTRAINT pr_data_nlp_deployprediction pr_data_nlp_deploypr_4542_pk [exec] pg_restore: launching item 5379 INDEX pr_data_nlp_d_pytype_idx [exec] pg_restore: creating INDEX "data.pr_data_nlp_d_pytype_idx" [exec] pg_restore: finished item 5378 INDEX pr_data_nlp_d_pxdocid_idx [exec] pg_restore: launching item 5840 INDEX pr_data_nlp_deploypr_4542_idx1 [exec] pg_restore: creating INDEX "data.pr_data_nlp_deploypr_4542_idx1" [exec] pg_restore: finished item 5840 INDEX pr_data_nlp_deploypr_4542_idx1 [exec] pg_restore: launching item 5466 CONSTRAINT pr_data_nlp_model_training pr_data_nlp_model_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_nlp_model_training pr_data_nlp_model_pk" [exec] finished item 5379 INDEX pr_data_nlp_d_pytype_idx [exec] pg_restore: launching item 5796 CONSTRAINT pr_data_nlp_reporting pr_data_nlp_reporting_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_reporting pr_data_nlp_reporting_pk" [exec] pg_restore: finished item 5796 CONSTRAINT pr_data_nlp_reporting pr_data_nlp_reporting_pk [exec] pg_restore: launching item 5793 INDEX pr_data_nlp_reporting_idx1 [exec] pg_restore: creating INDEX "data.pr_data_nlp_reporting_idx1" [exec] pg_restore: finished item 5466 CONSTRAINT pr_data_nlp_model_training pr_data_nlp_model_pk [exec] pg_restore: launching item 5463 INDEX pr_data_nlp_model_idx1 [exec] pg_restore: creating INDEX "data.pr_data_nlp_model_idx1" [exec] pg_restore: finished item 5793 INDEX pr_data_nlp_reporting_idx1 [exec] pg_restore: launching item 5464 INDEX pr_data_nlp_model_idx2 [exec] pg_restore: creating INDEX "data.pr_data_nlp_model_idx2" [exec] pg_restore: finished item 5463 INDEX pr_data_nlp_model_idx1 [exec] pg_restore: launching item 5794 INDEX pr_data_nlp_reporting_idx2 [exec] pg_restore: creating INDEX "data.pr_data_nlp_reporting_idx2" [exec] pg_restore: finished item 5464 INDEX pr_data_nlp_model_idx2 [exec] pg_restore: launching item 5508 CONSTRAINT pr_data_mobile_map_user pr_data_mobile_map_user_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_mobile_map_user pr_data_mobile_map_user_pk" [exec] pg_restore: finished item 5794 INDEX pr_data_nlp_reporting_idx2 [exec] pg_restore: launching item 5814 CONSTRAINT pr_data_nlp_simulationresult pr_data_nlp_sim_rs_9045_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_simulationresult pr_data_nlp_sim_rs_9045_pk" [exec] pg_restore: finished item 5508 CONSTRAINT pr_data_mobile_map_user pr_data_mobile_map_user_pk [exec] pg_restore: launching item 5506 INDEX pr_data_mobile_map_user_idx1 [exec] pg_restore: creating INDEX "data.pr_data_mobile_map_user_idx1" [exec] pg_restore: finished item 5814 CONSTRAINT pr_data_nlp_simulationresult pr_data_nlp_sim_rs_9045_pk [exec] pg_restore: launching item 5811 INDEX pr_data_nlp_sim_rs_9045_idx1 [exec] pg_restore: pg_restore: creating INDEX "data.pr_data_nlp_sim_rs_9045_idx1" [exec] finished item 5506 INDEX pr_data_mobile_map_user_idx1 [exec] pg_restore: launching item 5812 INDEX pr_data_nlp_sim_rs_9045_idx2 [exec] pg_restore: creating INDEX "data.pr_data_nlp_sim_rs_9045_idx2" [exec] pg_restore: finished item 5811 INDEX pr_data_nlp_sim_rs_9045_idx1 [exec] pg_restore: launching item 5792 CONSTRAINT pr_data_nlp_snapshot pr_data_nlp_snapshot_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_snapshot pr_data_nlp_snapshot_pk" [exec] pg_restore: finished item 5812 INDEX pr_data_nlp_sim_rs_9045_idx2 [exec] pg_restore: launching item 5437 CONSTRAINT pr_data_notification_recipient pr_data_ntfctn_rcpnt_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_notification_recipient pr_data_ntfctn_rcpnt_pk" [exec] pg_restore: finished item 5792 CONSTRAINT pr_data_nlp_snapshot pr_data_nlp_snapshot_pk [exec] pg_restore: launching item 5789 INDEX pr_data_nlp_snapshot_idx1 [exec] pg_restore: creating INDEX "data.pr_data_nlp_snapshot_idx1" [exec] pg_restore: finished item 5437 CONSTRAINT pr_data_notification_recipient pr_data_ntfctn_rcpnt_pk [exec] pg_restore: launching item 5790 INDEX pr_data_nlp_snapshot_idx2 [exec] pg_restore: creating INDEX "data.pr_data_nlp_snapshot_idx2" [exec] pg_restore: finished item 5789 INDEX pr_data_nlp_snapshot_idx1 [exec] pg_restore: launching item 5435 INDEX pr_data_ntfctn_rcpnt_idx1 [exec] pg_restore: creating INDEX "data.pr_data_ntfctn_rcpnt_idx1" [exec] pg_restore: finished item 5435 INDEX pr_data_ntfctn_rcpnt_idx1 [exec] pg_restore: launching item 5375 CONSTRAINT pr_data_nlp_summary pr_data_nlp_result_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_summary pr_data_nlp_result_pk" [exec] pg_restore: finished item 5790 INDEX pr_data_nlp_snapshot_idx2 [exec] pg_restore: launching item 5490 CONSTRAINT pr_data_offline_sync pr_data_offline_sync_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_offline_sync pr_data_offline_sync_pk" [exec] pg_restore: finished item 5490 CONSTRAINT pr_data_offline_sync pr_data_offline_sync_pk [exec] pg_restore: launching item 5488 INDEX pr_data_offline_sync_idx1 [exec] pg_restore: creating INDEX "data.pr_data_offline_sync_idx1" [exec] pg_restore: finished item 5488 INDEX pr_data_offline_sync_idx1 [exec] pg_restore: launching item 5744 CONSTRAINT pr_data_op_session pr_data_op_session_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_op_session pr_data_op_session_pk" [exec] pg_restore: finished item 5375 CONSTRAINT pr_data_nlp_summary pr_data_nlp_result_pk [exec] pg_restore: launching item 5376 INDEX pr_data_nlp_s_pydatasetid_idx [exec] pg_restore: creating INDEX "data.pr_data_nlp_s_pydatasetid_idx" [exec] pg_restore: finished item 5744 CONSTRAINT pr_data_op_session pr_data_op_session_pk [exec] pg_restore: launching item 5377 INDEX pr_data_nlp_s_pysentiment_idx [exec] pg_restore: creating INDEX "data.pr_data_nlp_s_pysentiment_idx" [exec] pg_restore: finished item 5376 INDEX pr_data_nlp_s_pydatasetid_idx [exec] pg_restore: launching item 5739 INDEX pr_data_op_session_idx1 [exec] pg_restore: creating INDEX "data.pr_data_op_session_idx1" [exec] pg_restore: finished item 5739 INDEX pr_data_op_session_idx1 [exec] pg_restore: launching item 5740 INDEX pr_data_op_session_idx2 [exec] pg_restore: creating INDEX "data.pr_data_op_session_idx2" [exec] pg_restore: finished item 5377 INDEX pr_data_nlp_s_pysentiment_idx [exec] pg_restore: launching item 5741 INDEX pr_data_op_session_idx3 [exec] pg_restore: creating INDEX "data.pr_data_op_session_idx3" [exec] pg_restore: finished item 5740 INDEX pr_data_op_session_idx2 [exec] pg_restore: launching item 5742 INDEX pr_data_op_session_idx4 [exec] pg_restore: creating INDEX "data.pr_data_op_session_idx4" [exec] pg_restore: finished item 5741 INDEX pr_data_op_session_idx3 [exec] pg_restore: launching item 5818 CONSTRAINT pr_data_nlp_simulationinput pr_data_nlp_sim_in_9045_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_simulationinput pr_data_nlp_sim_in_9045_pk" [exec] pg_restore: finished item 5742 INDEX pr_data_op_session_idx4 [exec] pg_restore: launching item 5383 CONSTRAINT pr_data_pegasample_product pr_data_pegasample_product_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_pegasample_product pr_data_pegasample_product_pk" [exec] pg_restore: finished item 5818 CONSTRAINT pr_data_nlp_simulationinput pr_data_nlp_sim_in_9045_pk [exec] pg_restore: launching item 5815 INDEX pr_data_nlp_sim_in_9045_idx1 [exec] pg_restore: creating INDEX "data.pr_data_nlp_sim_in_9045_idx1" [exec] pg_restore: finished item 5383 CONSTRAINT pr_data_pegasample_product pr_data_pegasample_product_pk [exec] pg_restore: launching item 5816 INDEX pr_data_nlp_sim_in_9045_idx2 [exec] pg_restore: creating INDEX "data.pr_data_nlp_sim_in_9045_idx2" [exec] pg_restore: finished item 5815 INDEX pr_data_nlp_sim_in_9045_idx1 [exec] pg_restore: launching item 5773 CONSTRAINT pr_data_nlp_status pr_data_nlp_status_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_nlp_status pr_data_nlp_status_pk" [exec] pg_restore: finished item 5816 INDEX pr_data_nlp_sim_in_9045_idx2 [exec] pg_restore: launching item 5280 CONSTRAINT pr_data_recents pr_data_recents_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_recents pr_data_recents_pk" [exec] pg_restore: finished item 5773 CONSTRAINT pr_data_nlp_status pr_data_nlp_status_pk [exec] pg_restore: launching item 5769 INDEX pr_data_nlp_status_idx1 [exec] pg_restore: creating INDEX "data.pr_data_nlp_status_idx1" [exec] pg_restore: finished item 5280 CONSTRAINT pr_data_recents pr_data_recents_pk [exec] pg_restore: launching item 5770 INDEX pr_data_nlp_status_idx2 [exec] pg_restore: creating INDEX "data.pr_data_nlp_status_idx2" [exec] pg_restore: finished item 5769 INDEX pr_data_nlp_status_idx1 [exec] pg_restore: launching item 5771 INDEX pr_data_nlp_status_idx3 [exec] pg_restore: creating INDEX "data.pr_data_nlp_status_idx3" [exec] pg_restore: finished item 5770 INDEX pr_data_nlp_status_idx2 [exec] pg_restore: launching item 5278 INDEX pr_data_recents_idx1 [exec] pg_restore: creating INDEX "data.pr_data_recents_idx1" [exec] pg_restore: finished item 5771 INDEX pr_data_nlp_status_idx3 [exec] pg_restore: launching item 5062 CONSTRAINT pr_data_reportshortcut pr_data_reportshortcut_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_data_reportshortcut pr_data_reportshortcut_pk" [exec] finished item 5278 INDEX pr_data_recents_idx1 [exec] pg_restore: launching item 5689 CONSTRAINT pr_data_qp_run_partition pr_data_qp_run_partition_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_qp_run_partition pr_data_qp_run_partition_pk" [exec] pg_restore: finished item 5062 CONSTRAINT pr_data_reportshortcut pr_data_reportshortcut_pk [exec] pg_restore: launching item 5572 CONSTRAINT pr_data_repositories pr_data_repositories_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_repositories pr_data_repositories_pk" [exec] pg_restore: finished item 5689 CONSTRAINT pr_data_qp_run_partition pr_data_qp_run_partition_pk [exec] pg_restore: launching item 5687 INDEX pr_data_qp_run_partition_idx1 [exec] pg_restore: creating INDEX "data.pr_data_qp_run_partition_idx1" [exec] pg_restore: finished item 5687 INDEX pr_data_qp_run_partition_idx1 [exec] pg_restore: launching item 5247 CONSTRAINT pr_data_pmf_worklist pr_data_pmf_worklist_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_pmf_worklist pr_data_pmf_worklist_pk" [exec] pg_restore: finished item 5572 CONSTRAINT pr_data_repositories pr_data_repositories_pk [exec] pg_restore: launching item 5570 INDEX data_repositoryname [exec] pg_restore: creating INDEX "data.data_repositoryname" [exec] pg_restore: finished item 5570 INDEX data_repositoryname [exec] pg_restore: launching item 5578 CONSTRAINT pr_data_retention_policy pr_data_retention_policy_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_retention_policy pr_data_retention_policy_pk" [exec] pg_restore: finished item 5247 CONSTRAINT pr_data_pmf_worklist pr_data_pmf_worklist_pk [exec] pg_restore: launching item 5245 INDEX pmf_dev_integration_idx [exec] pg_restore: creating INDEX "data.pmf_dev_integration_idx" [exec] pg_restore: finished item 5245 INDEX pmf_dev_integration_idx [exec] pg_restore: launching item 5709 CONSTRAINT pr_data_rrcategories pr_data_rrcategories_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_rrcategories pr_data_rrcategories_pk" [exec] pg_restore: finished item 5578 CONSTRAINT pr_data_retention_policy pr_data_retention_policy_pk [exec] pg_restore: launching item 5575 INDEX pr_data_retention_policy_idx1 [exec] pg_restore: creating INDEX "data.pr_data_retention_policy_idx1" [exec] pg_restore: finished item 5709 CONSTRAINT pr_data_rrcategories pr_data_rrcategories_pk [exec] pg_restore: launching item 5576 INDEX pr_data_retention_policy_idx2 [exec] pg_restore: pg_restore: creating INDEX "data.pr_data_retention_policy_idx2" [exec] finished item 5575 INDEX pr_data_retention_policy_idx1 [exec] pg_restore: launching item 5707 INDEX pr_data_rrcategories_idx1 [exec] pg_restore: pg_restore: creating INDEX "data.pr_data_rrcategories_idx1" [exec] finished item 5576 INDEX pr_data_retention_policy_idx2 [exec] pg_restore: launching item 5409 CONSTRAINT pr_data_saml_authreqcontext pr_data_saml_arc_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_authreqcontext pr_data_saml_arc_pk" [exec] pg_restore: finished item 5707 INDEX pr_data_rrcategories_idx1 [exec] pg_restore: launching item 5406 CONSTRAINT pr_data_saml_logininfo pr_data_saml_logininfo_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_logininfo pr_data_saml_logininfo_pk" [exec] pg_restore: finished item 5409 CONSTRAINT pr_data_saml_authreqcontext pr_data_saml_arc_pk [exec] pg_restore: launching item 5407 INDEX pr_data_saml_arc_idx1 [exec] pg_restore: creating INDEX "data.pr_data_saml_arc_idx1" [exec] pg_restore: finished item 5406 CONSTRAINT pr_data_saml_logininfo pr_data_saml_logininfo_pk [exec] pg_restore: launching item 5404 INDEX pr_data_saml_logininfo_idx1 [exec] pg_restore: creating INDEX "data.pr_data_saml_logininfo_idx1" [exec] pg_restore: finished item 5407 INDEX pr_data_saml_arc_idx1 [exec] pg_restore: launching item 5415 CONSTRAINT pr_data_saml_logoutreqinfo pr_data_saml_logout_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_logoutreqinfo pr_data_saml_logout_pk" [exec] pg_restore: finished item 5404 INDEX pr_data_saml_logininfo_idx1 [exec] pg_restore: launching item 5060 CONSTRAINT pr_data_reportcategory pr_data_reportcategory_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_reportcategory pr_data_reportcategory_pk" [exec] pg_restore: finished item 5415 CONSTRAINT pr_data_saml_logoutreqinfo pr_data_saml_logout_pk [exec] pg_restore: launching item 5413 INDEX pr_data_saml_logout_idx1 [exec] pg_restore: creating INDEX "data.pr_data_saml_logout_idx1" [exec] pg_restore: finished item 5413 INDEX pr_data_saml_logout_idx1 [exec] pg_restore: launching item 5484 CONSTRAINT pr_data_rulecoverage_results pr_data_rcr_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_rulecoverage_results pr_data_rcr_pk" [exec] pg_restore: finished item 5060 CONSTRAINT pr_data_reportcategory pr_data_reportcategory_pk [exec] pg_restore: launching item 5403 CONSTRAINT pr_data_saml_replaycache pr_data_saml_rc_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_replaycache pr_data_saml_rc_pk" [exec] pg_restore: finished item 5484 CONSTRAINT pr_data_rulecoverage_results pr_data_rcr_pk [exec] pg_restore: launching item 5481 INDEX pr_data_rcr_idx1 [exec] pg_restore: creating INDEX "data.pr_data_rcr_idx1" [exec] pg_restore: finished item 5403 CONSTRAINT pr_data_saml_replaycache pr_data_saml_rc_pk [exec] pg_restore: launching item 5482 INDEX pr_data_rcr_idx2 [exec] pg_restore: creating INDEX "data.pr_data_rcr_idx2" [exec] pg_restore: finished item 5481 INDEX pr_data_rcr_idx1 [exec] pg_restore: launching item 5401 INDEX pr_data_saml_rc_idx1 [exec] pg_restore: creating INDEX "data.pr_data_saml_rc_idx1" [exec] pg_restore: finished item 5482 INDEX pr_data_rcr_idx2 [exec] pg_restore: launching item 5419 CONSTRAINT pr_data_saml_requestorinfo pr_data_saml_requestor_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_requestorinfo pr_data_saml_requestor_pk" [exec] pg_restore: finished item 5401 INDEX pr_data_saml_rc_idx1 [exec] pg_restore: launching item 5275 CONSTRAINT pr_data_sample_shoppingcart pr_data_sample_shoppingcart_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_sample_shoppingcart pr_data_sample_shoppingcart_pk" [exec] pg_restore: finished item 5419 CONSTRAINT pr_data_saml_requestorinfo pr_data_saml_requestor_pk [exec] pg_restore: launching item 5416 INDEX pr_data_saml_requestor_idx1 [exec] pg_restore: creating INDEX "data.pr_data_saml_requestor_idx1" [exec] pg_restore: finished item 5275 CONSTRAINT pr_data_sample_shoppingcart pr_data_sample_shoppingcart_pk [exec] pg_restore: launching item 5417 INDEX pr_data_saml_requestor_idx2 [exec] pg_restore: creating INDEX "data.pr_data_saml_requestor_idx2" [exec] pg_restore: finished item 5417 INDEX pr_data_saml_requestor_idx2 [exec] pg_restore: launching item 5276 INDEX shoppingcartdispname [exec] pg_restore: creating INDEX "data.shoppingcartdispname" [exec] pg_restore: finished item 5416 INDEX pr_data_saml_requestor_idx1 [exec] pg_restore: launching item 5277 INDEX shoppingcartproductkey [exec] pg_restore: creating INDEX "data.shoppingcartproductkey" [exec] pg_restore: finished item 5276 INDEX shoppingcartdispname [exec] pg_restore: launching item 5066 CONSTRAINT pr_data_samplesrcustomer pr_data_samplesrcustomer_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_samplesrcustomer pr_data_samplesrcustomer_pk" [exec] pg_restore: finished item 5277 INDEX shoppingcartproductkey [exec] pg_restore: launching item 5064 CONSTRAINT pr_data_sample_uidetails pr_data_sample_uidetails_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_sample_uidetails pr_data_sample_uidetails_pk" [exec] pg_restore: finished item 5066 CONSTRAINT pr_data_samplesrcustomer pr_data_samplesrcustomer_pk [exec] pg_restore: launching item 5068 CONSTRAINT pr_data_samplesrproduct pr_data_samplesrproduct_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_samplesrproduct pr_data_samplesrproduct_pk" [exec] pg_restore: finished item 5068 CONSTRAINT pr_data_samplesrproduct pr_data_samplesrproduct_pk [exec] pg_restore: launching item 5764 CONSTRAINT pr_data_sizeestimator_config pr_data_sizeestimato_1538_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_sizeestimator_config pr_data_sizeestimato_1538_pk" [exec] pg_restore: finished item 5064 CONSTRAINT pr_data_sample_uidetails pr_data_sample_uidetails_pk [exec] pg_restore: launching item 5551 CONSTRAINT pr_data_smsaccount pr_data_smsaccount_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_smsaccount pr_data_smsaccount_pk" [exec] pg_restore: finished item 5764 CONSTRAINT pr_data_sizeestimator_config pr_data_sizeestimato_1538_pk [exec] pg_restore: launching item 5264 CONSTRAINT pr_data_social_reference pr_data_social_reference_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_social_reference pr_data_social_reference_pk" [exec] pg_restore: finished item 5551 CONSTRAINT pr_data_smsaccount pr_data_smsaccount_pk [exec] pg_restore: launching item 5475 CONSTRAINT pr_data_stream_node_updates pr_data_strem_nodes_upd_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_stream_node_updates pr_data_strem_nodes_upd_pk" [exec] pg_restore: finished item 5264 CONSTRAINT pr_data_social_reference pr_data_social_reference_pk [exec] pg_restore: launching item 5262 INDEX pr_data_social_reference_idx1 [exec] pg_restore: creating INDEX "data.pr_data_social_reference_idx1" [exec] pg_restore: finished item 5475 CONSTRAINT pr_data_stream_node_updates pr_data_strem_nodes_upd_pk [exec] pg_restore: launching item 5412 CONSTRAINT pr_data_saml_sessioninfo pr_data_saml_session_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_saml_sessioninfo pr_data_saml_session_pk" [exec] pg_restore: finished item 5262 INDEX pr_data_social_reference_idx1 [exec] pg_restore: launching item 5471 CONSTRAINT pr_data_stream_sessions pr_data_stream_sessions_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_stream_sessions pr_data_stream_sessions_pk" [exec] pg_restore: finished item 5412 CONSTRAINT pr_data_saml_sessioninfo pr_data_saml_session_pk [exec] pg_restore: launching item 5410 INDEX pr_data_saml_session_idx1 [exec] pg_restore: creating INDEX "data.pr_data_saml_session_idx1" [exec] pg_restore: finished item 5410 INDEX pr_data_saml_session_idx1 [exec] pg_restore: launching item 5473 CONSTRAINT pr_data_stream_nodes pr_data_stream_nodes_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_stream_nodes pr_data_stream_nodes_pk" [exec] pg_restore: finished item 5471 CONSTRAINT pr_data_stream_sessions pr_data_stream_sessions_pk [exec] pg_restore: launching item 4909 CONSTRAINT pr_data_svcinvhist pr_data_svcinvhist_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_svcinvhist pr_data_svcinvhist_pk" [exec] pg_restore: finished item 5473 CONSTRAINT pr_data_stream_nodes pr_data_stream_nodes_pk [exec] pg_restore: launching item 5234 CONSTRAINT pr_data_tag pr_data_tag_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_tag pr_data_tag_pk" [exec] pg_restore: finished item 4909 CONSTRAINT pr_data_svcinvhist pr_data_svcinvhist_pk [exec] pg_restore: launching item 4906 INDEX pr_data_svcinvhist_idx1 [exec] pg_restore: creating INDEX "data.pr_data_svcinvhist_idx1" [exec] pg_restore: finished item 4906 INDEX pr_data_svcinvhist_idx1 [exec] pg_restore: launching item 4907 INDEX pr_data_svcinvhist_idx2 [exec] pg_restore: creating INDEX "data.pr_data_svcinvhist_idx2" [exec] pg_restore: finished item 5234 CONSTRAINT pr_data_tag pr_data_tag_pk [exec] pg_restore: launching item 5393 CONSTRAINT pr_data_tag_oplink pr_data_tag_oplink_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_tag_oplink pr_data_tag_oplink_pk" [exec] pg_restore: finished item 4907 INDEX pr_data_svcinvhist_idx2 [exec] pg_restore: launching item 5072 CONSTRAINT pr_data_template_metadata pr_data_template_metadata_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_template_metadata pr_data_template_metadata_pk" [exec] pg_restore: finished item 5393 CONSTRAINT pr_data_tag_oplink pr_data_tag_oplink_pk [exec] pg_restore: launching item 5391 INDEX pr_data_tag_oplink_ix1 [exec] pg_restore: creating INDEX "data.pr_data_tag_oplink_ix1" [exec] pg_restore: finished item 5391 INDEX pr_data_tag_oplink_ix1 [exec] pg_restore: launching item 5334 CONSTRAINT pr_data_testcaseresults pr_data_tcr_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_testcaseresults pr_data_tcr_pk" [exec] pg_restore: finished item 5334 CONSTRAINT pr_data_testcaseresults pr_data_tcr_pk [exec] pg_restore: launching item 5331 INDEX pr_data_tcr_idx1 [exec] pg_restore: creating INDEX "data.pr_data_tcr_idx1" [exec] pg_restore: finished item 5072 CONSTRAINT pr_data_template_metadata pr_data_template_metadata_pk [exec] pg_restore: launching item 5332 INDEX pr_data_tcr_idx2 [exec] pg_restore: creating INDEX "data.pr_data_tcr_idx2" [exec] pg_restore: finished item 5331 INDEX pr_data_tcr_idx1 [exec] pg_restore: launching item 5441 CONSTRAINT pr_data_testsuiteresults pr_data_tsr_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_testsuiteresults pr_data_tsr_pk" [exec] pg_restore: finished item 5332 INDEX pr_data_tcr_idx2 [exec] pg_restore: launching item 5430 CONSTRAINT pr_data_toggle pr_data_toggle_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_toggle pr_data_toggle_pk" [exec] pg_restore: finished item 5441 CONSTRAINT pr_data_testsuiteresults pr_data_tsr_pk [exec] pg_restore: launching item 5438 INDEX pr_data_tsr_idx1 [exec] pg_restore: creating INDEX "data.pr_data_tsr_idx1" [exec] pg_restore: finished item 5430 CONSTRAINT pr_data_toggle pr_data_toggle_pk [exec] pg_restore: launching item 5439 INDEX pr_data_tsr_idx2 [exec] pg_restore: creating INDEX "data.pr_data_tsr_idx2" [exec] pg_restore: finished item 5438 INDEX pr_data_tsr_idx1 [exec] pg_restore: launching item 5338 CONSTRAINT pr_data_token pr_data_token_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_token pr_data_token_pk" [exec] pg_restore: finished item 5439 INDEX pr_data_tsr_idx2 [exec] pg_restore: launching item 5395 CONSTRAINT pr_data_tag_relevantrecord pr_data_tag_relevantrecord_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_tag_relevantrecord pr_data_tag_relevantrecord_pk" [exec] pg_restore: finished item 5338 CONSTRAINT pr_data_token pr_data_token_pk [exec] pg_restore: launching item 5335 INDEX pr_data_token_idx1 [exec] pg_restore: creating INDEX "data.pr_data_token_idx1" [exec] pg_restore: finished item 5335 INDEX pr_data_token_idx1 [exec] pg_restore: launching item 5336 INDEX pr_data_token_idx3 [exec] pg_restore: creating INDEX "data.pr_data_token_idx3" [exec] pg_restore: finished item 5336 INDEX pr_data_token_idx3 [exec] pg_restore: launching item 5801 CONSTRAINT pr_data_user_activity pr_data_user_activity_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_user_activity pr_data_user_activity_pk" [exec] pg_restore: finished item 5395 CONSTRAINT pr_data_tag_relevantrecord pr_data_tag_relevantrecord_pk [exec] pg_restore: launching item 5396 INDEX pr_data_tag_rr_idx1 [exec] pg_restore: creating INDEX "data.pr_data_tag_rr_idx1" [exec] pg_restore: finished item 5801 CONSTRAINT pr_data_user_activity pr_data_user_activity_pk [exec] pg_restore: launching item 5799 INDEX pr_data_user_activity_idx1 [exec] pg_restore: creating INDEX "data.pr_data_user_activity_idx1" [exec] pg_restore: finished item 5799 INDEX pr_data_user_activity_idx1 [exec] pg_restore: launching item 5398 CONSTRAINT pr_database_info_table pr_database_info_table_pk [exec] pg_restore: creating CONSTRAINT "data.pr_database_info_table pr_database_info_table_pk" [exec] pg_restore: finished item 5398 CONSTRAINT pr_database_info_table pr_database_info_table_pk [exec] pg_restore: launching item 5070 CONSTRAINT pr_data_samplesrpurchase pr_data_samplesrpurchase_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_samplesrpurchase pr_data_samplesrpurchase_pk" [exec] pg_restore: finished item 5396 INDEX pr_data_tag_rr_idx1 [exec] pg_restore: launching item 5821 CONSTRAINT pr_datapage_cache pr_datapage_cache_pk [exec] pg_restore: creating CONSTRAINT "data.pr_datapage_cache pr_datapage_cache_pk" [exec] pg_restore: finished item 5070 CONSTRAINT pr_data_samplesrpurchase pr_data_samplesrpurchase_pk [exec] pg_restore: launching item 4911 CONSTRAINT pr_extract_time pr_extract_time_pk [exec] pg_restore: creating CONSTRAINT "data.pr_extract_time pr_extract_time_pk" [exec] pg_restore: finished item 5821 CONSTRAINT pr_datapage_cache pr_datapage_cache_pk [exec] pg_restore: launching item 5819 INDEX pr_datapage_cache_idx1 [exec] pg_restore: creating INDEX "data.pr_datapage_cache_idx1" [exec] pg_restore: finished item 5819 INDEX pr_datapage_cache_idx1 [exec] pg_restore: launching item 5046 CONSTRAINT pr_dm_proposition pr_dm_proposition_pk [exec] pg_restore: creating CONSTRAINT "data.pr_dm_proposition pr_dm_proposition_pk" [exec] pg_restore: finished item 4911 CONSTRAINT pr_extract_time pr_extract_time_pk [exec] pg_restore: launching item 5224 CONSTRAINT pr_file_upload_fallback pr_file_upl_fb_pk [exec] pg_restore: creating CONSTRAINT "data.pr_file_upload_fallback pr_file_upl_fb_pk" [exec] pg_restore: finished item 5046 CONSTRAINT pr_dm_proposition pr_dm_proposition_pk [exec] pg_restore: launching item 5216 CONSTRAINT pr_file_store pr_file_store_pk [exec] pg_restore: creating CONSTRAINT "data.pr_file_store pr_file_store_pk" [exec] pg_restore: finished item 5224 CONSTRAINT pr_file_upload_fallback pr_file_upl_fb_pk [exec] pg_restore: launching item 5221 INDEX pr_file_upl_fb_abs [exec] pg_restore: creating INDEX "data.pr_file_upl_fb_abs" [exec] pg_restore: finished item 5221 INDEX pr_file_upl_fb_abs [exec] pg_restore: launching item 5222 INDEX pr_file_upl_fb_path [exec] pg_restore: creating INDEX "data.pr_file_upl_fb_path" [exec] pg_restore: finished item 5216 CONSTRAINT pr_file_store pr_file_store_pk [exec] pg_restore: launching item 5214 INDEX pathinfo_index [exec] pg_restore: creating INDEX "data.pathinfo_index" [exec] pg_restore: finished item 5222 INDEX pr_file_upl_fb_path [exec] pg_restore: launching item 5075 CONSTRAINT pr_history pr_history_pk [exec] pg_restore: creating CONSTRAINT "data.pr_history pr_history_pk" [exec] pg_restore: finished item 5214 INDEX pathinfo_index [exec] pg_restore: launching item 5080 CONSTRAINT pr_history_data pr_history_data_pk [exec] pg_restore: creating CONSTRAINT "data.pr_history_data pr_history_data_pk" [exec] pg_restore: finished item 5075 CONSTRAINT pr_history pr_history_pk [exec] pg_restore: launching item 5073 INDEX pr_history_idx2 [exec] pg_restore: creating INDEX "data.pr_history_idx2" [exec] pg_restore: finished item 5080 CONSTRAINT pr_history_data pr_history_data_pk [exec] pg_restore: launching item 5076 INDEX workhistory_re [exec] pg_restore: creating INDEX "data.workhistory_re" [exec] pg_restore: finished item 5076 INDEX workhistory_re [exec] pg_restore: launching item 5077 INDEX pr_history_data_idx2 [exec] pg_restore: pg_restore: creating INDEX "data.pr_history_data_idx2" [exec] finished item 5073 INDEX pr_history_idx2 [exec] pg_restore: launching item 5078 INDEX pr_history_data_idx3 [exec] pg_restore: creating INDEX "data.pr_history_data_idx3" [exec] pg_restore: finished item 5078 INDEX pr_history_data_idx3 [exec] pg_restore: launching item 5361 CONSTRAINT pr_history_data_dms_customer pr_his_data_dms_customer_pk [exec] pg_restore: creating CONSTRAINT "data.pr_history_data_dms_customer pr_his_data_dms_customer_pk" [exec] pg_restore: finished item 5077 INDEX pr_history_data_idx2 [exec] pg_restore: launching item 5364 CONSTRAINT pr_history_data_dms_glbl pr_his_data_dms_glbl_pk [exec] pg_restore: creating CONSTRAINT "data.pr_history_data_dms_glbl pr_his_data_dms_glbl_pk" [exec] pg_restore: finished item 5364 CONSTRAINT pr_history_data_dms_glbl pr_his_data_dms_glbl_pk [exec] pg_restore: launching item 5362 INDEX pr_his_data_dms_glbl_idx1 [exec] pg_restore: creating INDEX "data.pr_his_data_dms_glbl_idx1" [exec] pg_restore: finished item 5361 CONSTRAINT pr_history_data_dms_customer pr_his_data_dms_customer_pk [exec] pg_restore: launching item 5228 CONSTRAINT pr_hourly_usage pr_hourly_usage_pk [exec] pg_restore: creating CONSTRAINT "data.pr_hourly_usage pr_hourly_usage_pk" [exec] pg_restore: finished item 5362 INDEX pr_his_data_dms_glbl_idx1 [exec] pg_restore: launching item 5750 CONSTRAINT pr_data_token_blacklisted_jti pr_data_token_blackl_1063_pk [exec] pg_restore: creating CONSTRAINT "data.pr_data_token_blacklisted_jti pr_data_token_blackl_1063_pk" [exec] pg_restore: finished item 5228 CONSTRAINT pr_hourly_usage pr_hourly_usage_pk [exec] pg_restore: launching item 5220 CONSTRAINT pr_file_upload pr_file_upload_pk [exec] pg_restore: creating CONSTRAINT "data.pr_file_upload pr_file_upload_pk" [exec] pg_restore: finished item 5750 CONSTRAINT pr_data_token_blacklisted_jti pr_data_token_blackl_1063_pk [exec] pg_restore: launching item 5745 INDEX pr_data_token_blackl_1063_idx1 [exec] pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx1" [exec] pg_restore: finished item 5220 CONSTRAINT pr_file_upload pr_file_upload_pk [exec] pg_restore: launching item 5746 INDEX pr_data_token_blackl_1063_idx2 [exec] pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx2" [exec] pg_restore: finished item 5745 INDEX pr_data_token_blackl_1063_idx1 [exec] pg_restore: launching item 5747 INDEX pr_data_token_blackl_1063_idx3 [exec] pg_restore: pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx3" [exec] finished item 5746 INDEX pr_data_token_blackl_1063_idx2 [exec] pg_restore: launching item 5748 INDEX pr_data_token_blackl_1063_idx4 [exec] pg_restore: creating INDEX "data.pr_data_token_blackl_1063_idx4" [exec] pg_restore: finished item 5748 INDEX pr_data_token_blackl_1063_idx4 [exec] pg_restore: launching item 5217 INDEX pr_file_upload_abs [exec] pg_restore: creating INDEX "data.pr_file_upload_abs" [exec] pg_restore: finished item 5747 INDEX pr_data_token_blackl_1063_idx3 [exec] pg_restore: launching item 5218 INDEX pr_file_upload_path [exec] pg_restore: creating INDEX "data.pr_file_upload_path" [exec] pg_restore: finished item 5217 INDEX pr_file_upload_abs [exec] pg_restore: launching item 4947 CONSTRAINT pr_index_appfeatures pr_index_appfeatures_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_appfeatures pr_index_appfeatures_pk" [exec] pg_restore: finished item 5218 INDEX pr_file_upload_path [exec] pg_restore: launching item 5241 CONSTRAINT pr_index_assignmentdeps pr_index_assignmentdeps_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_assignmentdeps pr_index_assignmentdeps_pk" [exec] pg_restore: finished item 4947 CONSTRAINT pr_index_appfeatures pr_index_appfeatures_pk [exec] pg_restore: launching item 4943 INDEX pr_index_appfeatures_idx1 [exec] pg_restore: creating INDEX "data.pr_index_appfeatures_idx1" [exec] pg_restore: finished item 5241 CONSTRAINT pr_index_assignmentdeps pr_index_assignmentdeps_pk [exec] pg_restore: launching item 4944 INDEX pr_index_appfeatures_idx2 [exec] pg_restore: creating INDEX "data.pr_index_appfeatures_idx2" [exec] pg_restore: finished item 4943 INDEX pr_index_appfeatures_idx1 [exec] pg_restore: launching item 4945 INDEX pr_index_appfeatures_idx3 [exec] pg_restore: creating INDEX "data.pr_index_appfeatures_idx3" [exec] pg_restore: finished item 4944 INDEX pr_index_appfeatures_idx2 [exec] pg_restore: launching item 5239 INDEX keypurposeidx_adeps [exec] pg_restore: creating INDEX "data.keypurposeidx_adeps" [exec] pg_restore: finished item 4945 INDEX pr_index_appfeatures_idx3 [exec] pg_restore: launching item 5242 INDEX pri_assigndeps [exec] pg_restore: creating INDEX "data.pri_assigndeps" [exec] pg_restore: finished item 5239 INDEX keypurposeidx_adeps [exec] pg_restore: launching item 4953 CONSTRAINT pr_index_accessgrouproles pr_index_accessgrouproles_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_accessgrouproles pr_index_accessgrouproles_pk" [exec] pg_restore: finished item 5242 INDEX pri_assigndeps [exec] pg_restore: launching item 5119 CONSTRAINT pr_index_assignmentskills pr_index_assignmentskills_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_assignmentskills pr_index_assignmentskills_pk" [exec] pg_restore: finished item 4953 CONSTRAINT pr_index_accessgrouproles pr_index_accessgrouproles_pk [exec] pg_restore: launching item 4951 INDEX keypurposeidx_agrproles [exec] pg_restore: creating INDEX "data.keypurposeidx_agrproles" [exec] pg_restore: finished item 5119 CONSTRAINT pr_index_assignmentskills pr_index_assignmentskills_pk [exec] pg_restore: launching item 5114 INDEX getnextwork2assignmentskills [exec] pg_restore: creating INDEX "data.getnextwork2assignmentskills" [exec] pg_restore: finished item 4951 INDEX keypurposeidx_agrproles [exec] pg_restore: launching item 5115 INDEX getnextworkassignmentskills [exec] pg_restore: creating INDEX "data.getnextworkassignmentskills" [exec] pg_restore: finished item 5114 INDEX getnextwork2assignmentskills [exec] pg_restore: launching item 5116 INDEX keypurposeidx_askills [exec] pg_restore: creating INDEX "data.keypurposeidx_askills" [exec] pg_restore: finished item 5115 INDEX getnextworkassignmentskills [exec] pg_restore: launching item 5117 INDEX pr_index_assignmentskills_idx1 [exec] pg_restore: creating INDEX "data.pr_index_assignmentskills_idx1" [exec] pg_restore: finished item 5116 INDEX keypurposeidx_askills [exec] pg_restore: launching item 5330 CONSTRAINT pr_index_data_agents pr_index_data_agents_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_data_agents pr_index_data_agents_pk" [exec] pg_restore: finished item 5117 INDEX pr_index_assignmentskills_idx1 [exec] pg_restore: launching item 5469 CONSTRAINT pr_index_distinctvalues pr_index_distinctvalues_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_distinctvalues pr_index_distinctvalues_pk" [exec] pg_restore: finished item 5330 CONSTRAINT pr_index_data_agents pr_index_data_agents_pk [exec] pg_restore: launching item 5328 INDEX pr_index_data_agents_idx1 [exec] pg_restore: creating INDEX "data.pr_index_data_agents_idx1" [exec] pg_restore: finished item 5469 CONSTRAINT pr_index_distinctvalues pr_index_distinctvalues_pk [exec] pg_restore: launching item 5467 INDEX pr_index_distinctvalues_ins [exec] pg_restore: creating INDEX "data.pr_index_distinctvalues_ins" [exec] pg_restore: finished item 5328 INDEX pr_index_data_agents_idx1 [exec] pg_restore: launching item 5088 CONSTRAINT pr_index pr_index_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index pr_index_pk" [exec] pg_restore: finished item 5467 INDEX pr_index_distinctvalues_ins [exec] pg_restore: launching item 5273 CONSTRAINT pr_index_operator_workgroups pr_index_operator_wg_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_operator_workgroups pr_index_operator_wg_pk" [exec] pg_restore: finished item 5088 CONSTRAINT pr_index pr_index_pk [exec] pg_restore: launching item 5085 INDEX insindexedkey [exec] pg_restore: creating INDEX "data.insindexedkey" [exec] pg_restore: finished item 5273 CONSTRAINT pr_index_operator_workgroups pr_index_operator_wg_pk [exec] pg_restore: launching item 5086 INDEX keypurposeidx [exec] pg_restore: creating INDEX "data.keypurposeidx" [exec] pg_restore: finished item 5085 INDEX insindexedkey [exec] pg_restore: launching item 5271 INDEX pr_index_operator_wg_idx1 [exec] pg_restore: creating INDEX "data.pr_index_operator_wg_idx1" [exec] pg_restore: finished item 5271 INDEX pr_index_operator_wg_idx1 [exec] pg_restore: launching item 5113 CONSTRAINT pr_index_operators pr_index_operators_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_operators pr_index_operators_pk" [exec] pg_restore: finished item 5086 INDEX keypurposeidx [exec] pg_restore: launching item 5123 CONSTRAINT pr_index_operatorskills pr_index_operatorskills_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_operatorskills pr_index_operatorskills_pk" [exec] pg_restore: finished item 5113 CONSTRAINT pr_index_operators pr_index_operators_pk [exec] pg_restore: launching item 5111 INDEX keypurposeidx_oper [exec] pg_restore: creating INDEX "data.keypurposeidx_oper" [exec] pg_restore: finished item 5123 CONSTRAINT pr_index_operatorskills pr_index_operatorskills_pk [exec] pg_restore: launching item 5120 INDEX keypurposeidx_oskills [exec] pg_restore: creating INDEX "data.keypurposeidx_oskills" [exec] pg_restore: finished item 5111 INDEX keypurposeidx_oper [exec] pg_restore: launching item 5121 INDEX pr_index_operatorskills_idx1 [exec] pg_restore: creating INDEX "data.pr_index_operatorskills_idx1" [exec] pg_restore: finished item 5120 INDEX keypurposeidx_oskills [exec] pg_restore: launching item 5092 CONSTRAINT pr_index_scheduledtask pr_index_scheduledtask_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_scheduledtask pr_index_scheduledtask_pk" [exec] pg_restore: finished item 5121 INDEX pr_index_operatorskills_idx1 [exec] pg_restore: launching item 5261 CONSTRAINT pr_index_trackstatus pr_index_trackstatus_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_trackstatus pr_index_trackstatus_pk" [exec] pg_restore: finished item 5092 CONSTRAINT pr_index_scheduledtask pr_index_scheduledtask_pk [exec] pg_restore: launching item 5089 INDEX insindexedschtaskkey [exec] pg_restore: creating INDEX "data.insindexedschtaskkey" [exec] pg_restore: finished item 5261 CONSTRAINT pr_index_trackstatus pr_index_trackstatus_pk [exec] pg_restore: launching item 5090 INDEX keypurposeidx_schedtask [exec] pg_restore: creating INDEX "data.keypurposeidx_schedtask" [exec] pg_restore: finished item 5089 INDEX insindexedschtaskkey [exec] pg_restore: launching item 5760 CONSTRAINT pr_index_tracktriageactions pr_index_tracktriage_1119_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_tracktriageactions pr_index_tracktriage_1119_pk" [exec] pg_restore: finished item 5090 INDEX keypurposeidx_schedtask [exec] pg_restore: launching item 4959 CONSTRAINT pr_index_workgroups pr_index_workgroups_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_workgroups pr_index_workgroups_pk" [exec] pg_restore: finished item 5760 CONSTRAINT pr_index_tracktriageactions pr_index_tracktriage_1119_pk [exec] pg_restore: launching item 5581 CONSTRAINT pr_indexmetadata pr_indexmetadata_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_indexmetadata pr_indexmetadata_pk" [exec] finished item 4959 CONSTRAINT pr_index_workgroups pr_index_workgroups_pk [exec] pg_restore: launching item 4957 INDEX pr_index_workgroups_idx1 [exec] pg_restore: creating INDEX "data.pr_index_workgroups_idx1" [exec] pg_restore: finished item 5581 CONSTRAINT pr_indexmetadata pr_indexmetadata_pk [exec] pg_restore: launching item 5579 INDEX pr_indexmetadata_idx1 [exec] pg_restore: creating INDEX "data.pr_indexmetadata_idx1" [exec] pg_restore: finished item 4957 INDEX pr_index_workgroups_idx1 [exec] pg_restore: launching item 5569 CONSTRAINT pr_jobscheduler_override pr_jobscheduler_override_pk [exec] pg_restore: creating CONSTRAINT "data.pr_jobscheduler_override pr_jobscheduler_override_pk" [exec] pg_restore: finished item 5579 INDEX pr_indexmetadata_idx1 [exec] pg_restore: launching item 5226 CONSTRAINT pr_license_parameters pr_lic_param_pk [exec] pg_restore: creating CONSTRAINT "data.pr_license_parameters pr_lic_param_pk" [exec] pg_restore: finished item 5569 CONSTRAINT pr_jobscheduler_override pr_jobscheduler_override_pk [exec] pg_restore: launching item 5567 INDEX pr_jobscheduler_override_idx1 [exec] pg_restore: creating INDEX "data.pr_jobscheduler_override_idx1" [exec] pg_restore: finished item 5567 INDEX pr_jobscheduler_override_idx1 [exec] pg_restore: launching item 5094 CONSTRAINT pr_link pr_link_pk [exec] pg_restore: creating CONSTRAINT "data.pr_link pr_link_pk" [exec] pg_restore: finished item 5226 CONSTRAINT pr_license_parameters pr_lic_param_pk [exec] pg_restore: launching item 4956 CONSTRAINT pr_index_accessgroupwkpools pr_index_accessgroupwkpools_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_accessgroupwkpools pr_index_accessgroupwkpools_pk" [exec] pg_restore: finished item 5094 CONSTRAINT pr_link pr_link_pk [exec] pg_restore: launching item 5095 INDEX pr_link_ref_idx [exec] pg_restore: creating INDEX "data.pr_link_ref_idx" [exec] pg_restore: finished item 4956 CONSTRAINT pr_index_accessgroupwkpools pr_index_accessgroupwkpools_pk [exec] pg_restore: launching item 4954 INDEX keypurposeidx_agrpwrk [exec] pg_restore: creating INDEX "data.keypurposeidx_agrpwrk" [exec] pg_restore: finished item 5095 INDEX pr_link_ref_idx [exec] pg_restore: launching item 5238 CONSTRAINT pr_link_dco_pmf pr_link_dco_pmf_pk [exec] pg_restore: creating CONSTRAINT "data.pr_link_dco_pmf pr_link_dco_pmf_pk" [exec] pg_restore: finished item 4954 INDEX keypurposeidx_agrpwrk [exec] pg_restore: launching item 5249 CONSTRAINT pr_link_pmf_rulechanges pr_link_pmf_rulechanges_pk [exec] pg_restore: creating CONSTRAINT "data.pr_link_pmf_rulechanges pr_link_pmf_rulechanges_pk" [exec] pg_restore: finished item 5238 CONSTRAINT pr_link_dco_pmf pr_link_dco_pmf_pk [exec] pg_restore: launching item 5236 CONSTRAINT pr_link_work_tag pr_link_work_tag_pk [exec] pg_restore: creating CONSTRAINT "data.pr_link_work_tag pr_link_work_tag_pk" [exec] pg_restore: finished item 5249 CONSTRAINT pr_link_pmf_rulechanges pr_link_pmf_rulechanges_pk [exec] pg_restore: launching item 5102 CONSTRAINT pr_log pr_log_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log pr_log_pk" [exec] pg_restore: finished item 5236 CONSTRAINT pr_link_work_tag pr_link_work_tag_pk [exec] pg_restore: launching item 5785 CONSTRAINT pr_log_archivalsummary pr_log_archivalsummary_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_archivalsummary pr_log_archivalsummary_pk" [exec] pg_restore: finished item 5785 CONSTRAINT pr_log_archivalsummary pr_log_archivalsummary_pk [exec] pg_restore: launching item 5783 INDEX pr_log_archivalsummary_idx1 [exec] pg_restore: creating INDEX "data.pr_log_archivalsummary_idx1" [exec] pg_restore: finished item 5783 INDEX pr_log_archivalsummary_idx1 [exec] pg_restore: launching item 5624 CONSTRAINT pr_log_archivepurgeresults pr_log_archivepurgeresults_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_archivepurgeresults pr_log_archivepurgeresults_pk" [exec] pg_restore: finished item 5624 CONSTRAINT pr_log_archivepurgeresults pr_log_archivepurgeresults_pk [exec] pg_restore: launching item 4962 CONSTRAINT pr_index_email pr_index_email_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_email pr_index_email_pk" [exec] pg_restore: finished item 4962 CONSTRAINT pr_index_email pr_index_email_pk [exec] pg_restore: launching item 4960 INDEX pr_index_email_keypurposeidx [exec] pg_restore: creating INDEX "data.pr_index_email_keypurposeidx" [exec] pg_restore: finished item 5102 CONSTRAINT pr_log pr_log_pk [exec] pg_restore: launching item 5099 INDEX pr_log_fn [exec] pg_restore: creating INDEX "data.pr_log_fn" [exec] pg_restore: finished item 4960 INDEX pr_index_email_keypurposeidx [exec] pg_restore: launching item 5100 INDEX pr_log_idx1 [exec] pg_restore: creating INDEX "data.pr_log_idx1" [exec] pg_restore: finished item 5099 INDEX pr_log_fn [exec] pg_restore: launching item 5810 CONSTRAINT pr_log_batchid_generation pr_log_batchid_gen_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_batchid_generation pr_log_batchid_gen_pk" [exec] pg_restore: finished item 5100 INDEX pr_log_idx1 [exec] pg_restore: launching item 5340 CONSTRAINT pr_log_cluster pr_log_cluster_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_cluster pr_log_cluster_pk" [exec] pg_restore: finished item 5810 CONSTRAINT pr_log_batchid_generation pr_log_batchid_gen_pk [exec] pg_restore: launching item 5808 INDEX pr_log_batchid_gen_idx1 [exec] pg_restore: creating INDEX "data.pr_log_batchid_gen_idx1" [exec] pg_restore: finished item 5340 CONSTRAINT pr_log_cluster pr_log_cluster_pk [exec] pg_restore: launching item 5341 INDEX pr_log_custer_idx1 [exec] pg_restore: creating INDEX "data.pr_log_custer_idx1" [exec] pg_restore: finished item 5808 INDEX pr_log_batchid_gen_idx1 [exec] pg_restore: launching item 5566 CONSTRAINT pr_log_collaboration pr_log_collaboration_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_collaboration pr_log_collaboration_pk" [exec] pg_restore: finished item 5341 INDEX pr_log_custer_idx1 [exec] pg_restore: launching item 4973 CONSTRAINT pr_log_dataaccessaudit pr_log_dataaccessaudit_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_dataaccessaudit pr_log_dataaccessaudit_pk" [exec] pg_restore: finished item 5566 CONSTRAINT pr_log_collaboration pr_log_collaboration_pk [exec] pg_restore: launching item 5564 INDEX pr_log_collaboration_idx1 [exec] pg_restore: creating INDEX "data.pr_log_collaboration_idx1" [exec] pg_restore: finished item 4973 CONSTRAINT pr_log_dataaccessaudit pr_log_dataaccessaudit_pk [exec] pg_restore: launching item 5556 CONSTRAINT pr_log_dataflow_events pr_log_dataflow_events_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_dataflow_events pr_log_dataflow_events_pk" [exec] pg_restore: finished item 5564 INDEX pr_log_collaboration_idx1 [exec] pg_restore: launching item 5798 CONSTRAINT pr_log_expungedcases pr_log_expungedcases_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_expungedcases pr_log_expungedcases_pk" [exec] pg_restore: finished item 5556 CONSTRAINT pr_log_dataflow_events pr_log_dataflow_events_pk [exec] pg_restore: launching item 5552 INDEX pr_log_dataflow_events_idx1 [exec] pg_restore: creating INDEX "data.pr_log_dataflow_events_idx1" [exec] pg_restore: finished item 5552 INDEX pr_log_dataflow_events_idx1 [exec] pg_restore: launching item 5553 INDEX pr_log_dataflow_events_idx2 [exec] pg_restore: creating INDEX "data.pr_log_dataflow_events_idx2" [exec] pg_restore: finished item 5798 CONSTRAINT pr_log_expungedcases pr_log_expungedcases_pk [exec] pg_restore: launching item 5554 INDEX pr_log_dataflow_events_idx3 [exec] pg_restore: creating INDEX "data.pr_log_dataflow_events_idx3" [exec] pg_restore: finished item 5553 INDEX pr_log_dataflow_events_idx2 [exec] pg_restore: launching item 5700 CONSTRAINT pr_log_indexing_progress pr_log_indexing_progress_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_indexing_progress pr_log_indexing_progress_pk" [exec] pg_restore: finished item 5554 INDEX pr_log_dataflow_events_idx3 [exec] pg_restore: launching item 5480 CONSTRAINT pr_log_jobs_scheduler pr_log_jobs_scheduler_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_jobs_scheduler pr_log_jobs_scheduler_pk" [exec] pg_restore: finished item 5700 CONSTRAINT pr_log_indexing_progress pr_log_indexing_progress_pk [exec] pg_restore: launching item 5698 INDEX pr_log_indexing_progress_idx1 [exec] pg_restore: creating INDEX "data.pr_log_indexing_progress_idx1" [exec] pg_restore: finished item 5698 INDEX pr_log_indexing_progress_idx1 [exec] pg_restore: launching item 5370 CONSTRAINT pr_log_progress pr_log_progress_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "data.pr_log_progress pr_log_progress_pk" [exec] finished item 5480 CONSTRAINT pr_log_jobs_scheduler pr_log_jobs_scheduler_pk [exec] pg_restore: launching item 5476 INDEX pr_log_jobs_scheduler_idx1 [exec] pg_restore: creating INDEX "data.pr_log_jobs_scheduler_idx1" [exec] pg_restore: finished item 5370 CONSTRAINT pr_log_progress pr_log_progress_pk [exec] pg_restore: launching item 5477 INDEX pr_log_jobs_scheduler_idx2 [exec] pg_restore: pg_restore: creating INDEX "data.pr_log_jobs_scheduler_idx2" [exec] finished item 5476 INDEX pr_log_jobs_scheduler_idx1 [exec] pg_restore: launching item 5478 INDEX pr_log_jobs_scheduler_idx3 [exec] pg_restore: creating INDEX "data.pr_log_jobs_scheduler_idx3" [exec] pg_restore: finished item 5477 INDEX pr_log_jobs_scheduler_idx2 [exec] pg_restore: launching item 4950 CONSTRAINT pr_log_reportstats pr_log_reportstats_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_reportstats pr_log_reportstats_pk" [exec] pg_restore: finished item 5478 INDEX pr_log_jobs_scheduler_idx3 [exec] pg_restore: launching item 5244 CONSTRAINT pr_log_securityaudit pr_log_securityaudit_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_securityaudit pr_log_securityaudit_pk" [exec] pg_restore: finished item 4950 CONSTRAINT pr_log_reportstats pr_log_reportstats_pk [exec] pg_restore: launching item 4948 INDEX pr_log_reportstats_idx1 [exec] pg_restore: creating INDEX "data.pr_log_reportstats_idx1" [exec] pg_restore: finished item 5244 CONSTRAINT pr_log_securityaudit pr_log_securityaudit_pk [exec] pg_restore: launching item 5712 CONSTRAINT pr_log_service_email pr_log_service_email_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_service_email pr_log_service_email_pk" [exec] pg_restore: finished item 4948 INDEX pr_log_reportstats_idx1 [exec] pg_restore: launching item 5587 CONSTRAINT pr_metadata pr_metadata_pk [exec] pg_restore: creating CONSTRAINT "data.pr_metadata pr_metadata_pk" [exec] pg_restore: finished item 5712 CONSTRAINT pr_log_service_email pr_log_service_email_pk [exec] pg_restore: launching item 5710 INDEX pr_log_service_email_idx1 [exec] pg_restore: creating INDEX "data.pr_log_service_email_idx1" [exec] pg_restore: finished item 5587 CONSTRAINT pr_metadata pr_metadata_pk [exec] pg_restore: launching item 5582 INDEX pr_metadata_idx1 [exec] pg_restore: creating INDEX "data.pr_metadata_idx1" [exec] pg_restore: finished item 5710 INDEX pr_log_service_email_idx1 [exec] pg_restore: launching item 5583 INDEX pr_metadata_idx2 [exec] pg_restore: creating INDEX "data.pr_metadata_idx2" [exec] pg_restore: finished item 5582 INDEX pr_metadata_idx1 [exec] pg_restore: launching item 5584 INDEX pr_metadata_idx3 [exec] pg_restore: creating INDEX "data.pr_metadata_idx3" [exec] pg_restore: finished item 5583 INDEX pr_metadata_idx2 [exec] pg_restore: launching item 5585 INDEX pr_metadata_idx4 [exec] pg_restore: creating INDEX "data.pr_metadata_idx4" [exec] pg_restore: finished item 5584 INDEX pr_metadata_idx3 [exec] pg_restore: launching item 4942 CONSTRAINT pr_notification_channels pr_notification_channels_pk [exec] pg_restore: creating CONSTRAINT "data.pr_notification_channels pr_notification_channels_pk" [exec] pg_restore: finished item 5585 INDEX pr_metadata_idx4 [exec] pg_restore: launching item 5343 CONSTRAINT pr_log_systemstate pr_log_systemstate_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_systemstate pr_log_systemstate_pk" [exec] pg_restore: finished item 4942 CONSTRAINT pr_notification_channels pr_notification_channels_pk [exec] pg_restore: launching item 5514 CONSTRAINT pr_offline_attachment_mapping pr_off_att_map_pk [exec] pg_restore: creating CONSTRAINT "data.pr_offline_attachment_mapping pr_off_att_map_pk" [exec] pg_restore: finished item 5343 CONSTRAINT pr_log_systemstate pr_log_systemstate_pk [exec] pg_restore: launching item 5839 CONSTRAINT pr_oauth2_session_index pr_oauth2_session_index_pk [exec] pg_restore: creating CONSTRAINT "data.pr_oauth2_session_index pr_oauth2_session_index_pk" [exec] pg_restore: finished item 5514 CONSTRAINT pr_offline_attachment_mapping pr_off_att_map_pk [exec] pg_restore: launching item 5512 INDEX pr_off_att_map_idx1 [exec] pg_restore: creating INDEX "data.pr_off_att_map_idx1" [exec] pg_restore: finished item 5839 CONSTRAINT pr_oauth2_session_index pr_oauth2_session_index_pk [exec] pg_restore: launching item 5836 INDEX pr_oauth2_session_index_idx1 [exec] pg_restore: pg_restore: creating INDEX "data.pr_oauth2_session_index_idx1" [exec] finished item 5512 INDEX pr_off_att_map_idx1 [exec] pg_restore: launching item 5837 INDEX pr_oauth2_session_index_idx2 [exec] pg_restore: creating INDEX "data.pr_oauth2_session_index_idx2" [exec] pg_restore: finished item 5836 INDEX pr_oauth2_session_index_idx1 [exec] pg_restore: launching item 5511 CONSTRAINT pr_offline_attachment_stub pr_off_att_stub_pk [exec] pg_restore: creating CONSTRAINT "data.pr_offline_attachment_stub pr_off_att_stub_pk" [exec] pg_restore: finished item 5837 INDEX pr_oauth2_session_index_idx2 [exec] pg_restore: launching item 5133 CONSTRAINT pr_offline_pack pr_offline_pack_pk [exec] pg_restore: creating CONSTRAINT "data.pr_offline_pack pr_offline_pack_pk" [exec] pg_restore: finished item 5511 CONSTRAINT pr_offline_attachment_stub pr_off_att_stub_pk [exec] pg_restore: launching item 5509 INDEX pr_off_att_stub_idx1 [exec] pg_restore: creating INDEX "data.pr_off_att_stub_idx1" [exec] pg_restore: finished item 5133 CONSTRAINT pr_offline_pack pr_offline_pack_pk [exec] pg_restore: launching item 5658 CONSTRAINT pr_offline_sync_requests_info pr_offline_sync_requ_1956_pk [exec] pg_restore: creating CONSTRAINT "data.pr_offline_sync_requests_info pr_offline_sync_requ_1956_pk" [exec] pg_restore: finished item 5509 INDEX pr_off_att_stub_idx1 [exec] pg_restore: launching item 5109 CONSTRAINT pr_operator_prefs pr_operator_prefs_pk [exec] pg_restore: creating CONSTRAINT "data.pr_operator_prefs pr_operator_prefs_pk" [exec] pg_restore: finished item 5658 CONSTRAINT pr_offline_sync_requests_info pr_offline_sync_requ_1956_pk [exec] pg_restore: launching item 5107 CONSTRAINT pr_operators pr_operators_pk [exec] pg_restore: creating CONSTRAINT "data.pr_operators pr_operators_pk" [exec] pg_restore: finished item 5109 CONSTRAINT pr_operator_prefs pr_operator_prefs_pk [exec] pg_restore: launching item 5110 INDEX prefs_uid [exec] pg_restore: creating INDEX "data.prefs_uid" [exec] pg_restore: finished item 5107 CONSTRAINT pr_operators pr_operators_pk [exec] pg_restore: launching item 5103 INDEX operators_oc_wg [exec] pg_restore: creating INDEX "data.operators_oc_wg" [exec] pg_restore: finished item 5110 INDEX prefs_uid [exec] pg_restore: launching item 5104 INDEX ops_extension [exec] pg_restore: creating INDEX "data.ops_extension" [exec] pg_restore: finished item 5103 INDEX operators_oc_wg [exec] pg_restore: launching item 5105 INDEX pr_operators_idx1 [exec] pg_restore: creating INDEX "data.pr_operators_idx1" [exec] pg_restore: finished item 5104 INDEX ops_extension [exec] pg_restore: launching item 5125 CONSTRAINT pr_other pr_other_pk [exec] pg_restore: creating CONSTRAINT "data.pr_other pr_other_pk" [exec] pg_restore: finished item 5105 INDEX pr_operators_idx1 [exec] pg_restore: launching item 5129 CONSTRAINT pr_page_store pr_page_store_pk [exec] pg_restore: creating CONSTRAINT "data.pr_page_store pr_page_store_pk" [exec] pg_restore: finished item 5125 CONSTRAINT pr_other pr_other_pk [exec] pg_restore: launching item 5206 CONSTRAINT pr_perf_stats pr_perf_stats_pk [exec] pg_restore: creating CONSTRAINT "data.pr_perf_stats pr_perf_stats_pk" [exec] pg_restore: finished item 5129 CONSTRAINT pr_page_store pr_page_store_pk [exec] pg_restore: launching item 5130 INDEX pr_pagestore_create [exec] pg_restore: creating INDEX "data.pr_pagestore_create" [exec] pg_restore: finished item 5130 INDEX pr_pagestore_create [exec] pg_restore: launching item 5131 INDEX pr_pagestore_req [exec] pg_restore: creating INDEX "data.pr_pagestore_req" [exec] pg_restore: finished item 5206 CONSTRAINT pr_perf_stats pr_perf_stats_pk [exec] pg_restore: launching item 5203 INDEX pr_perf_snap [exec] pg_restore: creating INDEX "data.pr_perf_snap" [exec] pg_restore: finished item 5131 INDEX pr_pagestore_req [exec] pg_restore: launching item 5204 INDEX pr_perf_snaptime [exec] pg_restore: creating INDEX "data.pr_perf_snaptime" [exec] pg_restore: finished item 5203 INDEX pr_perf_snap [exec] pg_restore: launching item 5127 CONSTRAINT pr_portal_state pr_portal_state_pk [exec] pg_restore: creating CONSTRAINT "data.pr_portal_state pr_portal_state_pk" [exec] pg_restore: finished item 5204 INDEX pr_perf_snaptime [exec] pg_restore: launching item 5703 CONSTRAINT pr_sys_bi_publisheddatamodel pr_sys_bi_publishedd_2895_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_bi_publisheddatamodel pr_sys_bi_publishedd_2895_pk" [exec] pg_restore: finished item 5127 CONSTRAINT pr_portal_state pr_portal_state_pk [exec] pg_restore: launching item 5135 CONSTRAINT pr_sys_context pr_sys_context_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_context pr_sys_context_pk" [exec] pg_restore: finished item 5703 CONSTRAINT pr_sys_bi_publisheddatamodel pr_sys_bi_publishedd_2895_pk [exec] pg_restore: launching item 5701 INDEX pr_sys_bi_publishedd_2895_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_bi_publishedd_2895_idx1" [exec] pg_restore: finished item 5135 CONSTRAINT pr_sys_context pr_sys_context_pk [exec] pg_restore: launching item 5136 INDEX pr_syscontext_create [exec] pg_restore: creating INDEX "data.pr_syscontext_create" [exec] pg_restore: finished item 5701 INDEX pr_sys_bi_publishedd_2895_idx1 [exec] pg_restore: launching item 5137 INDEX pr_syscontext_req [exec] pg_restore: pg_restore: finished item 5136 INDEX pr_syscontext_create [exec] pg_restore: launching item 5656 CONSTRAINT pr_offline_sync_requests pr_offline_sync_requests_pk [exec] creating INDEX "data.pr_syscontext_req" [exec] pg_restore: creating CONSTRAINT "data.pr_offline_sync_requests pr_offline_sync_requests_pk" [exec] pg_restore: finished item 5656 CONSTRAINT pr_offline_sync_requests pr_offline_sync_requests_pk [exec] pg_restore: launching item 5617 CONSTRAINT pr_sys_delayed_queue pr_sys_delayed_queue_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_delayed_queue pr_sys_delayed_queue_pk" [exec] pg_restore: finished item 5617 CONSTRAINT pr_sys_delayed_queue pr_sys_delayed_queue_pk [exec] pg_restore: launching item 5614 INDEX pr_sys_delayed_queue_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_delayed_queue_idx1" [exec] pg_restore: finished item 5614 INDEX pr_sys_delayed_queue_idx1 [exec] pg_restore: launching item 5615 INDEX pr_sys_delayed_queue_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_delayed_queue_idx2" [exec] pg_restore: finished item 5615 INDEX pr_sys_delayed_queue_idx2 [exec] pg_restore: launching item 5139 CONSTRAINT pr_sys_locks pr_sys_locks_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_locks pr_sys_locks_pk" [exec] pg_restore: finished item 5137 INDEX pr_syscontext_req [exec] pg_restore: launching item 5591 CONSTRAINT pr_sys_msg_qp_brokenitems pr_sys_msg_qp_bi_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_msg_qp_brokenitems pr_sys_msg_qp_bi_pk" [exec] pg_restore: finished item 5139 CONSTRAINT pr_sys_locks pr_sys_locks_pk [exec] pg_restore: launching item 5140 INDEX syslocks [exec] pg_restore: creating INDEX "data.syslocks" [exec] pg_restore: finished item 5140 INDEX syslocks [exec] pg_restore: launching item 5163 CONSTRAINT pr_sys_queue_autotest pr_sys_queue_autotest_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_autotest pr_sys_queue_autotest_pk" [exec] pg_restore: finished item 5591 CONSTRAINT pr_sys_msg_qp_brokenitems pr_sys_msg_qp_bi_pk [exec] pg_restore: launching item 5588 INDEX pr_sys_msg_qp_bi_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_msg_qp_bi_idx1" [exec] pg_restore: finished item 5163 CONSTRAINT pr_sys_queue_autotest pr_sys_queue_autotest_pk [exec] pg_restore: launching item 5589 INDEX pr_sys_msg_qp_bi_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_msg_qp_bi_idx2" [exec] pg_restore: finished item 5588 INDEX pr_sys_msg_qp_bi_idx1 [exec] pg_restore: launching item 5160 INDEX pr_sys_queue_autotest1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_autotest1" [exec] pg_restore: finished item 5589 INDEX pr_sys_msg_qp_bi_idx2 [exec] pg_restore: launching item 5161 INDEX pr_sys_queue_autotest2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_autotest2" [exec] pg_restore: finished item 5160 INDEX pr_sys_queue_autotest1 [exec] pg_restore: launching item 5187 CONSTRAINT pr_sys_queue_col_pop pr_sys_queue_col_pop_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_col_pop pr_sys_queue_col_pop_pk" [exec] pg_restore: finished item 5161 INDEX pr_sys_queue_autotest2 [exec] pg_restore: launching item 5189 CONSTRAINT pr_sys_queue_count pr_sys_queue_count_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_count pr_sys_queue_count_pk" [exec] pg_restore: finished item 5187 CONSTRAINT pr_sys_queue_col_pop pr_sys_queue_col_pop_pk [exec] pg_restore: launching item 5184 INDEX pr_sys_queue_col_pop_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_col_pop_idx1" [exec] pg_restore: finished item 5189 CONSTRAINT pr_sys_queue_count pr_sys_queue_count_pk [exec] pg_restore: launching item 5185 INDEX pr_sys_queue_col_pop_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_col_pop_idx2" [exec] pg_restore: finished item 5184 INDEX pr_sys_queue_col_pop_idx1 [exec] pg_restore: launching item 5179 CONSTRAINT pr_sys_queue_execreq_conn pr_sys_queue_execreq_conn_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_execreq_conn pr_sys_queue_execreq_conn_pk" [exec] pg_restore: finished item 5185 INDEX pr_sys_queue_col_pop_idx2 [exec] pg_restore: launching item 5173 CONSTRAINT pr_sys_queue_execreq_svc pr_sys_queue_execreq_svc_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_execreq_svc pr_sys_queue_execreq_svc_pk" [exec] pg_restore: finished item 5179 CONSTRAINT pr_sys_queue_execreq_conn pr_sys_queue_execreq_conn_pk [exec] pg_restore: launching item 5176 INDEX pr_sys_queue_conn_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_conn_idx1" [exec] pg_restore: finished item 5176 INDEX pr_sys_queue_conn_idx1 [exec] pg_restore: launching item 5177 INDEX pr_sys_queue_conn_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_conn_idx2" [exec] pg_restore: finished item 5173 CONSTRAINT pr_sys_queue_execreq_svc pr_sys_queue_execreq_svc_pk [exec] pg_restore: launching item 5174 INDEX pr_sys_queue_svc_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_svc_idx1" [exec] pg_restore: finished item 5177 INDEX pr_sys_queue_conn_idx2 [exec] pg_restore: launching item 5175 INDEX pr_sys_queue_svc_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_svc_idx2" [exec] pg_restore: finished item 5174 INDEX pr_sys_queue_svc_idx1 [exec] pg_restore: launching item 5502 CONSTRAINT pr_sys_queue_ftsconflict pr_sys_queue_ftsconflict_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_ftsconflict pr_sys_queue_ftsconflict_pk" [exec] pg_restore: finished item 5175 INDEX pr_sys_queue_svc_idx2 [exec] pg_restore: launching item 5327 CONSTRAINT pr_sys_queue_ftsindexer pr_sys_queue_ftsindexer_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_ftsindexer pr_sys_queue_ftsindexer_pk" [exec] pg_restore: finished item 5502 CONSTRAINT pr_sys_queue_ftsconflict pr_sys_queue_ftsconflict_pk [exec] pg_restore: launching item 5499 INDEX pr_sys_queue_ftsconflict_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_ftsconflict_idx1" [exec] pg_restore: finished item 5327 CONSTRAINT pr_sys_queue_ftsindexer pr_sys_queue_ftsindexer_pk [exec] pg_restore: launching item 5500 INDEX pr_sys_queue_ftsconflict_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_ftsconflict_idx2" [exec] pg_restore: finished item 5499 INDEX pr_sys_queue_ftsconflict_idx1 [exec] pg_restore: launching item 5324 INDEX pr_sys_queue_ftsindexer_index1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_ftsindexer_index1" [exec] pg_restore: finished item 5500 INDEX pr_sys_queue_ftsconflict_idx2 [exec] pg_restore: launching item 5325 INDEX pr_sys_queue_ftsindexer_index2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_ftsindexer_index2" [exec] pg_restore: finished item 5324 INDEX pr_sys_queue_ftsindexer_index1 [exec] pg_restore: launching item 5171 CONSTRAINT pr_sys_queue_sla pr_sys_queue_sla_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_sla pr_sys_queue_sla_pk" [exec] pg_restore: finished item 5171 CONSTRAINT pr_sys_queue_sla pr_sys_queue_sla_pk [exec] pg_restore: launching item 5168 INDEX pr_sys_queue_sla_index1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_sla_index1" [exec] pg_restore: finished item 5168 INDEX pr_sys_queue_sla_index1 [exec] pg_restore: launching item 5169 INDEX pr_sys_queue_sla_index2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_sla_index2" [exec] pg_restore: finished item 5169 INDEX pr_sys_queue_sla_index2 [exec] pg_restore: launching item 5390 CONSTRAINT pr_index_pref_notify pr_index_pref_notify_pk [exec] pg_restore: creating CONSTRAINT "data.pr_index_pref_notify pr_index_pref_notify_pk" [exec] pg_restore: finished item 5325 INDEX pr_sys_queue_ftsindexer_index2 [exec] pg_restore: launching item 5183 CONSTRAINT pr_sys_queue_startflows pr_sys_queue_startflows_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queue_startflows pr_sys_queue_startflows_pk" [exec] pg_restore: finished item 5390 CONSTRAINT pr_index_pref_notify pr_index_pref_notify_pk [exec] pg_restore: launching item 5387 INDEX pr_index_pref_notify_idx1 [exec] pg_restore: creating INDEX "data.pr_index_pref_notify_idx1" [exec] pg_restore: finished item 5183 CONSTRAINT pr_sys_queue_startflows pr_sys_queue_startflows_pk [exec] pg_restore: launching item 5388 INDEX pr_index_pref_notify_idx2 [exec] pg_restore: creating INDEX "data.pr_index_pref_notify_idx2" [exec] pg_restore: finished item 5387 INDEX pr_index_pref_notify_idx1 [exec] pg_restore: launching item 5180 INDEX pr_sys_queue_startflows_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_queue_startflows_idx1" [exec] pg_restore: finished item 5388 INDEX pr_index_pref_notify_idx2 [exec] pg_restore: launching item 5181 INDEX pr_sys_queue_startflows_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_queue_startflows_idx2" [exec] pg_restore: finished item 5180 INDEX pr_sys_queue_startflows_idx1 [exec] pg_restore: launching item 5159 CONSTRAINT pr_sys_queues pr_sys_queues_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_queues pr_sys_queues_pk" [exec] pg_restore: finished item 5181 INDEX pr_sys_queue_startflows_idx2 [exec] pg_restore: launching item 5323 CONSTRAINT pr_sys_statusdetails pr_sys_statusdetails_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_statusdetails pr_sys_statusdetails_pk" [exec] pg_restore: finished item 5159 CONSTRAINT pr_sys_queues pr_sys_queues_pk [exec] pg_restore: launching item 5156 INDEX pr_sys_queues_index1 [exec] pg_restore: creating INDEX "data.pr_sys_queues_index1" [exec] pg_restore: finished item 5323 CONSTRAINT pr_sys_statusdetails pr_sys_statusdetails_pk [exec] pg_restore: launching item 5157 INDEX pr_sys_queues_index2 [exec] pg_restore: creating INDEX "data.pr_sys_queues_index2" [exec] pg_restore: finished item 5156 INDEX pr_sys_queues_index1 [exec] pg_restore: launching item 5321 INDEX pr_sys_statusdetails_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_statusdetails_idx1" [exec] pg_restore: finished item 5157 INDEX pr_sys_queues_index2 [exec] pg_restore: launching item 5144 CONSTRAINT pr_sys_serviceregistry pr_sys_serviceregistry_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_serviceregistry pr_sys_serviceregistry_pk" [exec] pg_restore: finished item 5321 INDEX pr_sys_statusdetails_idx1 [exec] pg_restore: launching item 5251 CONSTRAINT pr_log_batchstats pr_log_batchstats_pk [exec] pg_restore: creating CONSTRAINT "data.pr_log_batchstats pr_log_batchstats_pk" [exec] pg_restore: finished item 5144 CONSTRAINT pr_sys_serviceregistry pr_sys_serviceregistry_pk [exec] pg_restore: launching item 5141 INDEX pr_sys_serviceregistry_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_serviceregistry_idx1" [exec] pg_restore: finished item 5251 CONSTRAINT pr_log_batchstats pr_log_batchstats_pk [exec] pg_restore: launching item 5142 INDEX pr_sys_serviceregistry_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_serviceregistry_idx2" [exec] pg_restore: finished item 5141 INDEX pr_sys_serviceregistry_idx1 [exec] pg_restore: launching item 5151 INDEX updatecachenode [exec] pg_restore: creating INDEX "data.updatecachenode" [exec] pg_restore: finished item 5142 INDEX pr_sys_serviceregistry_idx2 [exec] pg_restore: launching item 5150 CONSTRAINT pr_sys_statusnodes pr_sys_statusnodes_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_statusnodes pr_sys_statusnodes_pk" [exec] pg_restore: finished item 5151 INDEX updatecachenode [exec] pg_restore: launching item 5155 CONSTRAINT pr_sys_user pr_sys_user_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_user pr_sys_user_pk" [exec] pg_restore: finished item 5150 CONSTRAINT pr_sys_statusnodes pr_sys_statusnodes_pk [exec] pg_restore: launching item 5738 CONSTRAINT pr_sys_user_grid pr_sys_user_grid_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_user_grid pr_sys_user_grid_pk" [exec] pg_restore: finished item 5155 CONSTRAINT pr_sys_user pr_sys_user_pk [exec] pg_restore: launching item 5152 INDEX pr_sys_user_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_user_idx1" [exec] pg_restore: finished item 5738 CONSTRAINT pr_sys_user_grid pr_sys_user_grid_pk [exec] pg_restore: launching item 5153 INDEX pr_sys_user_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_user_idx2" [exec] pg_restore: finished item 5152 INDEX pr_sys_user_idx1 [exec] pg_restore: launching item 5736 INDEX pr_sys_user_grid_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_user_grid_idx1" [exec] pg_restore: finished item 5736 INDEX pr_sys_user_grid_idx1 [exec] pg_restore: launching item 5232 CONSTRAINT pr_usage_summary pr_usage_sum_pk [exec] pg_restore: creating CONSTRAINT "data.pr_usage_summary pr_usage_sum_pk" [exec] pg_restore: finished item 5153 INDEX pr_sys_user_idx2 [exec] pg_restore: launching item 4919 CONSTRAINT prpc_ignite_server_addr prpc_ignite_server_addr_pk [exec] pg_restore: creating CONSTRAINT "data.prpc_ignite_server_addr prpc_ignite_server_addr_pk" [exec] pg_restore: finished item 4919 CONSTRAINT prpc_ignite_server_addr prpc_ignite_server_addr_pk [exec] pg_restore: launching item 5899 CONSTRAINT pc_index_flowref pc_index_flowref_pk [exec] pg_restore: creating CONSTRAINT "rules.pc_index_flowref pc_index_flowref_pk" [exec] pg_restore: finished item 5232 CONSTRAINT pr_usage_summary pr_usage_sum_pk [exec] pg_restore: launching item 5148 CONSTRAINT pr_sys_serviceregistry_kvs pr_sys_serviceregistry_kvs_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_serviceregistry_kvs pr_sys_serviceregistry_kvs_pk" [exec] pg_restore: finished item 5899 CONSTRAINT pc_index_flowref pc_index_flowref_pk [exec] pg_restore: launching item 5167 CONSTRAINT pr_sys_workindexer_queue pr_sys_workindexer_queue_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sys_workindexer_queue pr_sys_workindexer_queue_pk" [exec] pg_restore: finished item 5148 CONSTRAINT pr_sys_serviceregistry_kvs pr_sys_serviceregistry_kvs_pk [exec] pg_restore: launching item 5145 INDEX pr_sys_servicereg_kvs_idx1 [exec] pg_restore: creating INDEX "data.pr_sys_servicereg_kvs_idx1" [exec] pg_restore: finished item 5145 INDEX pr_sys_servicereg_kvs_idx1 [exec] pg_restore: launching item 5146 INDEX pr_sys_servicereg_kvs_idx2 [exec] pg_restore: creating INDEX "data.pr_sys_servicereg_kvs_idx2" [exec] pg_restore: finished item 5167 CONSTRAINT pr_sys_workindexer_queue pr_sys_workindexer_queue_pk [exec] pg_restore: launching item 5164 INDEX pr_sys_workindexer_index1 [exec] pg_restore: creating INDEX "data.pr_sys_workindexer_index1" [exec] pg_restore: finished item 5146 INDEX pr_sys_servicereg_kvs_idx2 [exec] pg_restore: launching item 5165 INDEX pr_sys_workindexer_index2 [exec] pg_restore: creating INDEX "data.pr_sys_workindexer_index2" [exec] pg_restore: finished item 5164 INDEX pr_sys_workindexer_index1 [exec] pg_restore: launching item 4975 CONSTRAINT pr_sysjobs pr_sysjobs_pk [exec] pg_restore: creating CONSTRAINT "data.pr_sysjobs pr_sysjobs_pk" [exec] pg_restore: finished item 5165 INDEX pr_sys_workindexer_index2 [exec] pg_restore: launching item 6183 CONSTRAINT pr4_rule_appconfiguration pr4_rule_appconfiguration_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_appconfiguration pr4_rule_appconfiguration_pk" [exec] pg_restore: finished item 4975 CONSTRAINT pr_sysjobs pr_sysjobs_pk [exec] pg_restore: launching item 5870 CONSTRAINT pr4_rule_application pr4_rule_application_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_application pr4_rule_application_pk" [exec] pg_restore: finished item 6183 CONSTRAINT pr4_rule_appconfiguration pr4_rule_appconfiguration_pk [exec] pg_restore: launching item 5963 CONSTRAINT pr4_rule_autotest pr4_rule_autotest_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_autotest pr4_rule_autotest_pk" [exec] pg_restore: finished item 5870 CONSTRAINT pr4_rule_application pr4_rule_application_pk [exec] pg_restore: launching item 5867 INDEX pr4_rule_app_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_app_idx1" [exec] pg_restore: finished item 5963 CONSTRAINT pr4_rule_autotest pr4_rule_autotest_pk [exec] pg_restore: launching item 5868 INDEX pr4_rule_app_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_app_idx2" [exec] pg_restore: finished item 5867 INDEX pr4_rule_app_idx1 [exec] pg_restore: launching item 5961 INDEX autotstres_1 [exec] pg_restore: creating INDEX "rules.autotstres_1" [exec] pg_restore: finished item 5868 INDEX pr4_rule_app_idx2 [exec] pg_restore: launching item 6217 CONSTRAINT pr4_rule_bi_dashboard pr4_rule_bi_dashboard_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_dashboard pr4_rule_bi_dashboard_pk" [exec] pg_restore: finished item 5961 INDEX autotstres_1 [exec] pg_restore: launching item 6232 CONSTRAINT pr4_rule_bi_insight pr4_rule_bi_insight_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_insight pr4_rule_bi_insight_pk" [exec] pg_restore: finished item 6217 CONSTRAINT pr4_rule_bi_dashboard pr4_rule_bi_dashboard_pk [exec] pg_restore: launching item 6214 INDEX pr4_rule_bi_dashboard_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_dashboard_idx1" [exec] pg_restore: finished item 6232 CONSTRAINT pr4_rule_bi_insight pr4_rule_bi_insight_pk [exec] pg_restore: launching item 6215 INDEX pr4_rule_bi_dashboard_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_dashboard_idx2" [exec] pg_restore: finished item 6214 INDEX pr4_rule_bi_dashboard_idx1 [exec] pg_restore: launching item 6229 INDEX pr4_rule_bi_insight_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_insight_idx1" [exec] pg_restore: finished item 6215 INDEX pr4_rule_bi_dashboard_idx2 [exec] pg_restore: launching item 6230 INDEX pr4_rule_bi_insight_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_insight_idx2" [exec] pg_restore: finished item 6229 INDEX pr4_rule_bi_insight_idx1 [exec] pg_restore: launching item 6213 CONSTRAINT pr4_rule_bi_queryphrase pr4_rule_bi_queryphrase_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_queryphrase pr4_rule_bi_queryphrase_pk" [exec] pg_restore: finished item 6230 INDEX pr4_rule_bi_insight_idx2 [exec] pg_restore: launching item 6209 CONSTRAINT pr4_rule_bi_theme pr4_rule_bi_theme_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_bi_theme pr4_rule_bi_theme_pk" [exec] pg_restore: finished item 6213 CONSTRAINT pr4_rule_bi_queryphrase pr4_rule_bi_queryphrase_pk [exec] pg_restore: launching item 6210 INDEX pr4_rule_bi_queryphrase_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_queryphrase_idx1" [exec] pg_restore: finished item 6209 CONSTRAINT pr4_rule_bi_theme pr4_rule_bi_theme_pk [exec] pg_restore: launching item 6211 INDEX pr4_rule_bi_queryphrase_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_queryphrase_idx2" [exec] pg_restore: finished item 6210 INDEX pr4_rule_bi_queryphrase_idx1 [exec] pg_restore: launching item 6206 INDEX pr4_rule_bi_theme_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_theme_idx1" [exec] pg_restore: finished item 6206 INDEX pr4_rule_bi_theme_idx1 [exec] pg_restore: launching item 6207 INDEX pr4_rule_bi_theme_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_bi_theme_idx2" [exec] pg_restore: finished item 6207 INDEX pr4_rule_bi_theme_idx2 [exec] pg_restore: launching item 6195 CONSTRAINT pr4_rule_clientdata pr4_rule_clientdata_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_clientdata pr4_rule_clientdata_pk" [exec] pg_restore: finished item 6195 CONSTRAINT pr4_rule_clientdata pr4_rule_clientdata_pk [exec] pg_restore: launching item 6193 INDEX pr4_rule_clientdata_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_clientdata_idx1" [exec] pg_restore: finished item 6193 INDEX pr4_rule_clientdata_idx1 [exec] pg_restore: launching item 6192 CONSTRAINT pr4_rule_connect pr4_rule_connect_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_connect pr4_rule_connect_pk" [exec] pg_restore: finished item 6192 CONSTRAINT pr4_rule_connect pr4_rule_connect_pk [exec] pg_restore: launching item 6190 INDEX pr4_rule_connect_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_connect_idx1" [exec] pg_restore: finished item 6211 INDEX pr4_rule_bi_queryphrase_idx2 [exec] pg_restore: launching item 6200 CONSTRAINT pr4_rule_connect_robot pr4_rule_connect_robot_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_connect_robot pr4_rule_connect_robot_pk" [exec] pg_restore: finished item 6190 INDEX pr4_rule_connect_idx1 [exec] pg_restore: launching item 6242 CONSTRAINT pr4_rule_dataobject pr4_rule_dataobject_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_dataobject pr4_rule_dataobject_pk" [exec] pg_restore: finished item 6200 CONSTRAINT pr4_rule_connect_robot pr4_rule_connect_robot_pk [exec] pg_restore: launching item 6198 INDEX pr4_rule_connect_robot_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_connect_robot_idx1" [exec] pg_restore: finished item 6242 CONSTRAINT pr4_rule_dataobject pr4_rule_dataobject_pk [exec] pg_restore: launching item 6238 INDEX pr4_rule_dataobject_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_dataobject_idx1" [exec] pg_restore: finished item 6198 INDEX pr4_rule_connect_robot_idx1 [exec] pg_restore: launching item 6239 INDEX pr4_rule_dataobject_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_dataobject_idx2" [exec] pg_restore: finished item 6238 INDEX pr4_rule_dataobject_idx1 [exec] pg_restore: launching item 6240 INDEX pr4_rule_dataobject_idx3 [exec] pg_restore: creating INDEX "rules.pr4_rule_dataobject_idx3" [exec] pg_restore: finished item 6239 INDEX pr4_rule_dataobject_idx2 [exec] pg_restore: launching item 6222 CONSTRAINT pr4_rule_declare_expression pr4_rule_declare_exp_3194_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_declare_expression pr4_rule_declare_exp_3194_pk" [exec] pg_restore: finished item 6240 INDEX pr4_rule_dataobject_idx3 [exec] pg_restore: launching item 6019 CONSTRAINT pr4_rule_declarepages pr4_rule_declarepages_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_declarepages pr4_rule_declarepages_pk" [exec] pg_restore: finished item 6222 CONSTRAINT pr4_rule_declare_expression pr4_rule_declare_exp_3194_pk [exec] pg_restore: launching item 6223 INDEX pr4_rule_declare_exp_insid [exec] pg_restore: creating INDEX "rules.pr4_rule_declare_exp_insid" [exec] pg_restore: finished item 6223 INDEX pr4_rule_declare_exp_insid [exec] pg_restore: launching item 6224 INDEX pr4_rule_declare_exp_insname [exec] pg_restore: creating INDEX "rules.pr4_rule_declare_exp_insname" [exec] pg_restore: finished item 6224 INDEX pr4_rule_declare_exp_insname [exec] pg_restore: launching item 6153 CONSTRAINT pr4_rule_delegationconfig pr4_rule_dc_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_delegationconfig pr4_rule_dc_pk" [exec] pg_restore: finished item 6153 CONSTRAINT pr4_rule_delegationconfig pr4_rule_dc_pk [exec] pg_restore: launching item 6150 INDEX pr4_rule_dc_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_dc_idx1" [exec] pg_restore: finished item 6019 CONSTRAINT pr4_rule_declarepages pr4_rule_declarepages_pk [exec] pg_restore: launching item 6020 INDEX pr4_rule_dp_objclass [exec] pg_restore: creating INDEX "rules.pr4_rule_dp_objclass" [exec] pg_restore: finished item 6150 INDEX pr4_rule_dc_idx1 [exec] pg_restore: launching item 6021 INDEX pr4_rule_dp_oc_cn [exec] pg_restore: creating INDEX "rules.pr4_rule_dp_oc_cn" [exec] pg_restore: finished item 6020 INDEX pr4_rule_dp_objclass [exec] pg_restore: launching item 6022 INDEX pr4_rule_dp_oc_in [exec] pg_restore: creating INDEX "rules.pr4_rule_dp_oc_in" [exec] pg_restore: finished item 6021 INDEX pr4_rule_dp_oc_cn [exec] pg_restore: launching item 6023 INDEX pr4_rule_dp_ruleres_1 [exec] pg_restore: creating INDEX "rules.pr4_rule_dp_ruleres_1" [exec] pg_restore: finished item 6022 INDEX pr4_rule_dp_oc_in [exec] pg_restore: launching item 6024 INDEX pr4_rule_dp_ruleset [exec] pg_restore: creating INDEX "rules.pr4_rule_dp_ruleset" [exec] pg_restore: finished item 6024 INDEX pr4_rule_dp_ruleset [exec] pg_restore: launching item 6151 INDEX pr4_rule_dc_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_dc_idx2" [exec] pg_restore: finished item 6023 INDEX pr4_rule_dp_ruleres_1 [exec] pg_restore: launching item 5916 CONSTRAINT pr4_base pr4_base_pk [exec] pg_restore: pg_restore: creating CONSTRAINT "rules.pr4_base pr4_base_pk" [exec] finished item 6151 INDEX pr4_rule_dc_idx2 [exec] pg_restore: launching item 5924 CONSTRAINT pr4_fieldvalue pr4_fieldvalue_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_fieldvalue pr4_fieldvalue_pk" [exec] pg_restore: finished item 5916 CONSTRAINT pr4_base pr4_base_pk [exec] pg_restore: launching item 5908 INDEX base_cat [exec] pg_restore: creating INDEX "rules.base_cat" [exec] pg_restore: finished item 5908 INDEX base_cat [exec] pg_restore: launching item 5909 INDEX base_classname [exec] pg_restore: creating INDEX "rules.base_classname" [exec] pg_restore: finished item 5909 INDEX base_classname [exec] pg_restore: launching item 5910 INDEX base_objclass [exec] pg_restore: creating INDEX "rules.base_objclass" [exec] pg_restore: finished item 5910 INDEX base_objclass [exec] pg_restore: launching item 5911 INDEX pr4_base_idx1 [exec] pg_restore: creating INDEX "rules.pr4_base_idx1" [exec] pg_restore: finished item 5911 INDEX pr4_base_idx1 [exec] pg_restore: launching item 5912 INDEX pr4_base_idx2 [exec] pg_restore: creating INDEX "rules.pr4_base_idx2" [exec] pg_restore: finished item 5912 INDEX pr4_base_idx2 [exec] pg_restore: launching item 5913 INDEX pr4_base_idx3 [exec] pg_restore: creating INDEX "rules.pr4_base_idx3" [exec] pg_restore: finished item 5913 INDEX pr4_base_idx3 [exec] pg_restore: launching item 5914 INDEX pr4_base_idx4 [exec] pg_restore: creating INDEX "rules.pr4_base_idx4" [exec] pg_restore: finished item 5914 INDEX pr4_base_idx4 [exec] pg_restore: launching item 5917 INDEX rule_baseres_1 [exec] pg_restore: creating INDEX "rules.rule_baseres_1" [exec] pg_restore: finished item 5924 CONSTRAINT pr4_fieldvalue pr4_fieldvalue_pk [exec] pg_restore: launching item 5920 INDEX pr4_fieldvalue_idx1 [exec] pg_restore: creating INDEX "rules.pr4_fieldvalue_idx1" [exec] pg_restore: finished item 5917 INDEX rule_baseres_1 [exec] pg_restore: launching item 5921 INDEX pr4_fieldvalue_idx2 [exec] pg_restore: creating INDEX "rules.pr4_fieldvalue_idx2" [exec] pg_restore: finished item 5920 INDEX pr4_fieldvalue_idx1 [exec] pg_restore: launching item 5922 INDEX pr4_fieldvalue_idx3 [exec] pg_restore: creating INDEX "rules.pr4_fieldvalue_idx3" [exec] pg_restore: finished item 5921 INDEX pr4_fieldvalue_idx2 [exec] pg_restore: launching item 5925 INDEX rule_fieldvres_1 [exec] pg_restore: creating INDEX "rules.rule_fieldvres_1" [exec] pg_restore: finished item 5922 INDEX pr4_fieldvalue_idx3 [exec] pg_restore: launching item 6015 CONSTRAINT pr4_rule_file pr4_rule_file_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_file pr4_rule_file_pk" [exec] pg_restore: finished item 6015 CONSTRAINT pr4_rule_file pr4_rule_file_pk [exec] pg_restore: launching item 6013 INDEX pr4_rule_file_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_file_idx1" [exec] pg_restore: finished item 6013 INDEX pr4_rule_file_idx1 [exec] pg_restore: launching item 6016 INDEX rf_insnclass [exec] pg_restore: creating INDEX "rules.rf_insnclass" [exec] pg_restore: finished item 6016 INDEX rf_insnclass [exec] pg_restore: launching item 6017 INDEX rule_rulefileres_1 [exec] pg_restore: creating INDEX "rules.rule_rulefileres_1" [exec] pg_restore: finished item 6017 INDEX rule_rulefileres_1 [exec] pg_restore: launching item 5864 CONSTRAINT pr4_rule_guide pr4_rule_guide_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_guide pr4_rule_guide_pk" [exec] pg_restore: finished item 5864 CONSTRAINT pr4_rule_guide pr4_rule_guide_pk [exec] pg_restore: launching item 5862 INDEX pr4_rule_guide_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_guide_idx1" [exec] pg_restore: finished item 5862 INDEX pr4_rule_guide_idx1 [exec] pg_restore: launching item 5987 CONSTRAINT pr4_rule_flow pr4_rule_flow_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_flow pr4_rule_flow_pk" [exec] pg_restore: finished item 5925 INDEX rule_fieldvres_1 [exec] pg_restore: launching item 5866 CONSTRAINT pr4_rule_html_property pr4_rule_html_property_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_html_property pr4_rule_html_property_pk" [exec] pg_restore: finished item 5987 CONSTRAINT pr4_rule_flow pr4_rule_flow_pk [exec] pg_restore: launching item 5983 INDEX flow_objclass [exec] pg_restore: creating INDEX "rules.flow_objclass" [exec] pg_restore: finished item 5983 INDEX flow_objclass [exec] pg_restore: launching item 5984 INDEX flow_pyclassname [exec] pg_restore: creating INDEX "rules.flow_pyclassname" [exec] pg_restore: finished item 5984 INDEX flow_pyclassname [exec] pg_restore: launching item 5985 INDEX flow_resolution [exec] pg_restore: creating INDEX "rules.flow_resolution" [exec] pg_restore: finished item 5985 INDEX flow_resolution [exec] pg_restore: launching item 5988 INDEX rule_flow_insname [exec] pg_restore: creating INDEX "rules.rule_flow_insname" [exec] pg_restore: finished item 5988 INDEX rule_flow_insname [exec] pg_restore: launching item 5989 INDEX rule_flow_ruleset [exec] pg_restore: creating INDEX "rules.rule_flow_ruleset" [exec] pg_restore: finished item 5989 INDEX rule_flow_ruleset [exec] pg_restore: launching item 5990 INDEX rule_ruleflowres_1 [exec] pg_restore: creating INDEX "rules.rule_ruleflowres_1" [exec] pg_restore: finished item 5866 CONSTRAINT pr4_rule_html_property pr4_rule_html_property_pk [exec] pg_restore: launching item 6249 CONSTRAINT pr4_rule_localization pr4_rule_localization_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_localization pr4_rule_localization_pk" [exec] pg_restore: finished item 5990 INDEX rule_ruleflowres_1 [exec] pg_restore: launching item 6139 CONSTRAINT pr4_rule_message pr4_rule_message_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_message pr4_rule_message_pk" [exec] pg_restore: finished item 6249 CONSTRAINT pr4_rule_localization pr4_rule_localization_pk [exec] pg_restore: launching item 6243 INDEX pr4_rule_localization_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_localization_idx1" [exec] pg_restore: finished item 6243 INDEX pr4_rule_localization_idx1 [exec] pg_restore: launching item 6244 INDEX pr4_rule_localization_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_localization_idx2" [exec] pg_restore: finished item 6244 INDEX pr4_rule_localization_idx2 [exec] pg_restore: launching item 6245 INDEX pr4_rule_localization_idx3 [exec] pg_restore: creating INDEX "rules.pr4_rule_localization_idx3" [exec] pg_restore: finished item 6245 INDEX pr4_rule_localization_idx3 [exec] pg_restore: launching item 6246 INDEX pr4_rule_localization_idx4 [exec] pg_restore: creating INDEX "rules.pr4_rule_localization_idx4" [exec] pg_restore: finished item 6246 INDEX pr4_rule_localization_idx4 [exec] pg_restore: launching item 6247 INDEX pr4_rule_localization_idx6 [exec] pg_restore: creating INDEX "rules.pr4_rule_localization_idx6" [exec] pg_restore: finished item 6247 INDEX pr4_rule_localization_idx6 [exec] pg_restore: launching item 6237 CONSTRAINT pr4_rule_persona pr4_rule_persona_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_persona pr4_rule_persona_pk" [exec] pg_restore: finished item 6237 CONSTRAINT pr4_rule_persona pr4_rule_persona_pk [exec] pg_restore: launching item 6233 INDEX pr4_rule_persona_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_persona_idx1" [exec] pg_restore: finished item 6233 INDEX pr4_rule_persona_idx1 [exec] pg_restore: launching item 6234 INDEX pr4_rule_persona_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_persona_idx2" [exec] pg_restore: finished item 6234 INDEX pr4_rule_persona_idx2 [exec] pg_restore: launching item 6235 INDEX pr4_rule_persona_idx3 [exec] pg_restore: creating INDEX "rules.pr4_rule_persona_idx3" [exec] pg_restore: finished item 6235 INDEX pr4_rule_persona_idx3 [exec] pg_restore: launching item 6186 CONSTRAINT pr4_rule_presentation pr4_rule_presentation_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_presentation pr4_rule_presentation_pk" [exec] pg_restore: finished item 6186 CONSTRAINT pr4_rule_presentation pr4_rule_presentation_pk [exec] pg_restore: launching item 6184 INDEX pr4_rule_presentation_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_presentation_idx1" [exec] pg_restore: finished item 6184 INDEX pr4_rule_presentation_idx1 [exec] pg_restore: launching item 6149 CONSTRAINT pr4_rule_library pr4_rule_library_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_library pr4_rule_library_pk" [exec] pg_restore: finished item 6139 CONSTRAINT pr4_rule_message pr4_rule_message_pk [exec] pg_restore: launching item 6136 INDEX pr4_rule_message_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_message_idx1" [exec] pg_restore: finished item 6149 CONSTRAINT pr4_rule_library pr4_rule_library_pk [exec] pg_restore: launching item 6137 INDEX pr4_rule_message_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_message_idx2" [exec] pg_restore: finished item 6136 INDEX pr4_rule_message_idx1 [exec] pg_restore: launching item 6143 INDEX pr4_rule_library_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx1" [exec] pg_restore: finished item 6137 INDEX pr4_rule_message_idx2 [exec] pg_restore: launching item 6144 INDEX pr4_rule_library_idx3 [exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx3" [exec] pg_restore: finished item 6143 INDEX pr4_rule_library_idx1 [exec] pg_restore: launching item 6145 INDEX pr4_rule_library_idx4 [exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx4" [exec] pg_restore: finished item 6144 INDEX pr4_rule_library_idx3 [exec] pg_restore: launching item 6146 INDEX pr4_rule_library_idx5 [exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx5" [exec] pg_restore: finished item 6145 INDEX pr4_rule_library_idx4 [exec] pg_restore: launching item 6147 INDEX pr4_rule_library_idx6 [exec] pg_restore: creating INDEX "rules.pr4_rule_library_idx6" [exec] pg_restore: finished item 6146 INDEX pr4_rule_library_idx5 [exec] pg_restore: launching item 6189 CONSTRAINT pr4_rule_reports pr4_rule_reports_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_reports pr4_rule_reports_pk" [exec] pg_restore: finished item 6189 CONSTRAINT pr4_rule_reports pr4_rule_reports_pk [exec] pg_restore: launching item 6187 INDEX pr4_rule_reports_idex1 [exec] pg_restore: creating INDEX "rules.pr4_rule_reports_idex1" [exec] pg_restore: finished item 6187 INDEX pr4_rule_reports_idex1 [exec] pg_restore: launching item 6065 CONSTRAINT pr4_rule_requirement pr4_rule_requirement_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_requirement pr4_rule_requirement_pk" [exec] pg_restore: finished item 6065 CONSTRAINT pr4_rule_requirement pr4_rule_requirement_pk [exec] pg_restore: launching item 6062 INDEX pr4_rule_req_ruleset [exec] pg_restore: creating INDEX "rules.pr4_rule_req_ruleset" [exec] pg_restore: finished item 6062 INDEX pr4_rule_req_ruleset [exec] pg_restore: launching item 6063 INDEX pr4_rule_requirement_oc_in [exec] pg_restore: creating INDEX "rules.pr4_rule_requirement_oc_in" [exec] pg_restore: finished item 6063 INDEX pr4_rule_requirement_oc_in [exec] pg_restore: launching item 6066 INDEX pr4_rule_requirementoc_cn [exec] pg_restore: creating INDEX "rules.pr4_rule_requirementoc_cn" [exec] pg_restore: finished item 6147 INDEX pr4_rule_library_idx6 [exec] pg_restore: launching item 6067 INDEX rule_requirement_objclass [exec] pg_restore: creating INDEX "rules.rule_requirement_objclass" [exec] pg_restore: finished item 6066 INDEX pr4_rule_requirementoc_cn [exec] pg_restore: launching item 6068 INDEX rule_requirement_ruleres_1 [exec] pg_restore: creating INDEX "rules.rule_requirement_ruleres_1" [exec] pg_restore: finished item 6067 INDEX rule_requirement_objclass [exec] pg_restore: launching item 6002 CONSTRAINT pr4_rule_ruleset pr4_rule_ruleset_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_ruleset pr4_rule_ruleset_pk" [exec] pg_restore: finished item 6068 INDEX rule_requirement_ruleres_1 [exec] pg_restore: launching item 5992 CONSTRAINT pr4_rule_property pr4_rule_property_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_property pr4_rule_property_pk" [exec] pg_restore: finished item 6002 CONSTRAINT pr4_rule_ruleset pr4_rule_ruleset_pk [exec] pg_restore: launching item 5999 INDEX pr4_rule_ruleset_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_ruleset_idx1" [exec] pg_restore: finished item 5999 INDEX pr4_rule_ruleset_idx1 [exec] pg_restore: launching item 6000 INDEX pr4_rule_ruleset_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_ruleset_idx2" [exec] pg_restore: finished item 6000 INDEX pr4_rule_ruleset_idx2 [exec] pg_restore: launching item 6003 INDEX rule_resolution_rrs [exec] pg_restore: creating INDEX "rules.rule_resolution_rrs" [exec] pg_restore: finished item 6003 INDEX rule_resolution_rrs [exec] pg_restore: launching item 6171 CONSTRAINT pr4_rule_securitypolicies pr4_rule_securitypolicies_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_securitypolicies pr4_rule_securitypolicies_pk" [exec] pg_restore: finished item 6171 CONSTRAINT pr4_rule_securitypolicies pr4_rule_securitypolicies_pk [exec] pg_restore: launching item 6165 INDEX pr4_rule_secpol_oc_cn [exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_oc_cn" [exec] pg_restore: finished item 6165 INDEX pr4_rule_secpol_oc_cn [exec] pg_restore: launching item 6166 INDEX pr4_rule_secpol_oc_in [exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_oc_in" [exec] pg_restore: finished item 6166 INDEX pr4_rule_secpol_oc_in [exec] pg_restore: launching item 6167 INDEX pr4_rule_secpol_ruleres_1 [exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_ruleres_1" [exec] pg_restore: finished item 6167 INDEX pr4_rule_secpol_ruleres_1 [exec] pg_restore: launching item 6168 INDEX pr4_rule_secpol_ruleset [exec] pg_restore: creating INDEX "rules.pr4_rule_secpol_ruleset" [exec] pg_restore: finished item 6168 INDEX pr4_rule_secpol_ruleset [exec] pg_restore: launching item 6169 INDEX pr4_rule_securitypolicies_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_securitypolicies_idx1" [exec] pg_restore: finished item 6169 INDEX pr4_rule_securitypolicies_idx1 [exec] pg_restore: launching item 5861 CONSTRAINT pr4_rule_service_rest pr4_rule_service_rest_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_service_rest pr4_rule_service_rest_pk" [exec] pg_restore: finished item 5861 CONSTRAINT pr4_rule_service_rest pr4_rule_service_rest_pk [exec] pg_restore: launching item 5859 INDEX pr4_rule_service_rest_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_service_rest_idx1" [exec] pg_restore: finished item 5859 INDEX pr4_rule_service_rest_idx1 [exec] pg_restore: launching item 5966 CONSTRAINT pr4_rule_shortcut pr4_rule_shortcut_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_shortcut pr4_rule_shortcut_pk" [exec] pg_restore: finished item 5966 CONSTRAINT pr4_rule_shortcut pr4_rule_shortcut_pk [exec] pg_restore: launching item 5964 INDEX pr4_rule_shorctcut_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_shorctcut_idx1" [exec] pg_restore: finished item 5964 INDEX pr4_rule_shorctcut_idx1 [exec] pg_restore: launching item 5967 INDEX rule_shortcres_1 [exec] pg_restore: creating INDEX "rules.rule_shortcres_1" [exec] pg_restore: finished item 5967 INDEX rule_shortcres_1 [exec] pg_restore: launching item 5968 INDEX shortcut_owner_idx [exec] pg_restore: creating INDEX "rules.shortcut_owner_idx" [exec] pg_restore: finished item 5968 INDEX shortcut_owner_idx [exec] pg_restore: launching item 6006 CONSTRAINT pr4_rule_sysgen pr4_rule_sysgen_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_sysgen pr4_rule_sysgen_pk" [exec] pg_restore: finished item 6006 CONSTRAINT pr4_rule_sysgen pr4_rule_sysgen_pk [exec] pg_restore: launching item 6004 INDEX pr4_rule_sysgen_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_sysgen_idx1" [exec] pg_restore: finished item 6004 INDEX pr4_rule_sysgen_idx1 [exec] pg_restore: launching item 6007 INDEX rule_sysgres_1 [exec] pg_restore: creating INDEX "rules.rule_sysgres_1" [exec] pg_restore: finished item 6007 INDEX rule_sysgres_1 [exec] pg_restore: launching item 6008 INDEX sysgen_objclass [exec] pg_restore: creating INDEX "rules.sysgen_objclass" [exec] pg_restore: finished item 6008 INDEX sysgen_objclass [exec] pg_restore: launching item 6009 INDEX sysgen_oc_cn [exec] pg_restore: creating INDEX "rules.sysgen_oc_cn" [exec] pg_restore: finished item 6009 INDEX sysgen_oc_cn [exec] pg_restore: launching item 6010 INDEX sysgen_oc_in [exec] pg_restore: creating INDEX "rules.sysgen_oc_in" [exec] pg_restore: finished item 6010 INDEX sysgen_oc_in [exec] pg_restore: launching item 6011 INDEX sysgen_resolution [exec] pg_restore: creating INDEX "rules.sysgen_resolution" [exec] pg_restore: finished item 6011 INDEX sysgen_resolution [exec] pg_restore: launching item 6012 INDEX sysgen_ruleset [exec] pg_restore: creating INDEX "rules.sysgen_ruleset" [exec] pg_restore: finished item 6012 INDEX sysgen_ruleset [exec] pg_restore: launching item 6157 CONSTRAINT pr4_rule_testcase pr4_rule_tc_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_testcase pr4_rule_tc_pk" [exec] pg_restore: finished item 6157 CONSTRAINT pr4_rule_testcase pr4_rule_tc_pk [exec] pg_restore: launching item 6154 INDEX pr4_rule_tc_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_tc_idx1" [exec] pg_restore: finished item 6154 INDEX pr4_rule_tc_idx1 [exec] pg_restore: launching item 6155 INDEX pr4_rule_tc_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_tc_idx2" [exec] pg_restore: finished item 6155 INDEX pr4_rule_tc_idx2 [exec] pg_restore: launching item 6178 CONSTRAINT pr4_rule_testsuite pr4_rule_testsuite_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_testsuite pr4_rule_testsuite_pk" [exec] pg_restore: finished item 6178 CONSTRAINT pr4_rule_testsuite pr4_rule_testsuite_pk [exec] pg_restore: launching item 6071 CONSTRAINT pr4_rule_usecase pr4_rule_usecase_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_usecase pr4_rule_usecase_pk" [exec] pg_restore: finished item 6071 CONSTRAINT pr4_rule_usecase pr4_rule_usecase_pk [exec] pg_restore: launching item 6069 INDEX pr4_rule_usecase_oc_in [exec] pg_restore: creating INDEX "rules.pr4_rule_usecase_oc_in" [exec] pg_restore: finished item 6069 INDEX pr4_rule_usecase_oc_in [exec] pg_restore: launching item 6072 INDEX pr4_rule_usecaseoc_cn [exec] pg_restore: creating INDEX "rules.pr4_rule_usecaseoc_cn" [exec] pg_restore: finished item 6072 INDEX pr4_rule_usecaseoc_cn [exec] pg_restore: launching item 6073 INDEX pr4_ruleucruleset [exec] pg_restore: creating INDEX "rules.pr4_ruleucruleset" [exec] pg_restore: finished item 6073 INDEX pr4_ruleucruleset [exec] pg_restore: launching item 6074 INDEX rule_usecase_objclass [exec] pg_restore: creating INDEX "rules.rule_usecase_objclass" [exec] pg_restore: finished item 6074 INDEX rule_usecase_objclass [exec] pg_restore: launching item 6075 INDEX rule_usecase_ruleres_1 [exec] pg_restore: creating INDEX "rules.rule_usecase_ruleres_1" [exec] pg_restore: finished item 6075 INDEX rule_usecase_ruleres_1 [exec] pg_restore: launching item 6228 CONSTRAINT pr4_rule_view pr4_rule_view_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_view pr4_rule_view_pk" [exec] pg_restore: finished item 6228 CONSTRAINT pr4_rule_view pr4_rule_view_pk [exec] pg_restore: launching item 6225 INDEX pr4_rule_view_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_view_idx2" [exec] pg_restore: finished item 6225 INDEX pr4_rule_view_idx2 [exec] pg_restore: launching item 6226 INDEX pr4_rule_view_idx4 [exec] pg_restore: creating INDEX "rules.pr4_rule_view_idx4" [exec] pg_restore: finished item 6226 INDEX pr4_rule_view_idx4 [exec] pg_restore: launching item 6028 CONSTRAINT pr4_rule_file_binary pr4_rule_file_binary_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_file_binary pr4_rule_file_binary_pk" [exec] pg_restore: finished item 6028 CONSTRAINT pr4_rule_file_binary pr4_rule_file_binary_pk [exec] pg_restore: launching item 6025 INDEX pr4_rule_file_binary_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_file_binary_idx1" [exec] pg_restore: finished item 6025 INDEX pr4_rule_file_binary_idx1 [exec] pg_restore: launching item 6026 INDEX pr4_rule_file_binary_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_file_binary_idx2" [exec] pg_restore: finished item 6026 INDEX pr4_rule_file_binary_idx2 [exec] pg_restore: launching item 6029 INDEX rfb_insnclass [exec] pg_restore: creating INDEX "rules.rfb_insnclass" [exec] pg_restore: finished item 6029 INDEX rfb_insnclass [exec] pg_restore: launching item 6030 INDEX rule_rulefilebinaryres_1 [exec] pg_restore: creating INDEX "rules.rule_rulefilebinaryres_1" [exec] pg_restore: finished item 6030 INDEX rule_rulefilebinaryres_1 [exec] pg_restore: launching item 6058 CONSTRAINT pr_app_branch_idx pr_app_branch_idx_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_app_branch_idx pr_app_branch_idx_pk" [exec] pg_restore: finished item 6058 CONSTRAINT pr_app_branch_idx pr_app_branch_idx_pk [exec] pg_restore: launching item 6055 INDEX app_branch_idx_key [exec] pg_restore: creating INDEX "rules.app_branch_idx_key" [exec] pg_restore: finished item 6055 INDEX app_branch_idx_key [exec] pg_restore: launching item 6056 INDEX branch_id_idx_key [exec] pg_restore: creating INDEX "rules.branch_id_idx_key" [exec] pg_restore: finished item 6056 INDEX branch_id_idx_key [exec] pg_restore: launching item 5976 CONSTRAINT pr4_rule_vw pr4_rule_vw_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_vw pr4_rule_vw_pk" [exec] pg_restore: finished item 5992 CONSTRAINT pr4_rule_property pr4_rule_property_pk [exec] pg_restore: launching item 5993 INDEX prop_resolution [exec] pg_restore: creating INDEX "rules.prop_resolution" [exec] pg_restore: finished item 5993 INDEX prop_resolution [exec] pg_restore: launching item 5994 INDEX property_objclass [exec] pg_restore: creating INDEX "rules.property_objclass" [exec] pg_restore: finished item 5994 INDEX property_objclass [exec] pg_restore: launching item 5995 INDEX property_oc_cn [exec] pg_restore: creating INDEX "rules.property_oc_cn" [exec] pg_restore: finished item 5995 INDEX property_oc_cn [exec] pg_restore: launching item 5996 INDEX property_oc_in [exec] pg_restore: creating INDEX "rules.property_oc_in" [exec] pg_restore: finished item 5996 INDEX property_oc_in [exec] pg_restore: launching item 5997 INDEX property_ruleset [exec] pg_restore: creating INDEX "rules.property_ruleset" [exec] pg_restore: finished item 5997 INDEX property_ruleset [exec] pg_restore: launching item 5998 INDEX rule_propres_1 [exec] pg_restore: creating INDEX "rules.rule_propres_1" [exec] pg_restore: finished item 5976 CONSTRAINT pr4_rule_vw pr4_rule_vw_pk [exec] pg_restore: launching item 5969 INDEX pr4_rule_vw_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx1" [exec] pg_restore: finished item 5998 INDEX rule_propres_1 [exec] pg_restore: launching item 5970 INDEX pr4_rule_vw_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx2" [exec] pg_restore: finished item 5969 INDEX pr4_rule_vw_idx1 [exec] pg_restore: launching item 5971 INDEX pr4_rule_vw_idx3 [exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx3" [exec] pg_restore: finished item 5970 INDEX pr4_rule_vw_idx2 [exec] pg_restore: launching item 5972 INDEX pr4_rule_vw_idx4 [exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx4" [exec] pg_restore: finished item 5971 INDEX pr4_rule_vw_idx3 [exec] pg_restore: launching item 5973 INDEX pr4_rule_vw_idx5 [exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx5" [exec] pg_restore: finished item 5972 INDEX pr4_rule_vw_idx4 [exec] pg_restore: launching item 5974 INDEX pr4_rule_vw_idx6 [exec] pg_restore: creating INDEX "rules.pr4_rule_vw_idx6" [exec] pg_restore: finished item 6706 TABLE DATA pr_engineclasses [exec] pg_restore: launching item 5977 INDEX pr4_view_op [exec] pg_restore: creating INDEX "rules.pr4_view_op" [exec] pg_restore: finished item 5973 INDEX pr4_rule_vw_idx5 [exec] pg_restore: launching item 5978 INDEX pr4_vw_oc_in [exec] pg_restore: creating INDEX "rules.pr4_vw_oc_in" [exec] pg_restore: finished item 5977 INDEX pr4_view_op [exec] pg_restore: launching item 5979 INDEX pr4_vwoc_cn [exec] pg_restore: creating INDEX "rules.pr4_vwoc_cn" [exec] pg_restore: finished item 5974 INDEX pr4_rule_vw_idx6 [exec] pg_restore: launching item 5980 INDEX pr4_vwruleset [exec] pg_restore: creating INDEX "rules.pr4_vwruleset" [exec] pg_restore: finished item 5978 INDEX pr4_vw_oc_in [exec] pg_restore: launching item 5981 INDEX vw_objclass [exec] pg_restore: creating INDEX "rules.vw_objclass" [exec] pg_restore: finished item 5980 INDEX pr4_vwruleset [exec] pg_restore: launching item 5982 INDEX vw_resolution [exec] pg_restore: creating INDEX "rules.vw_resolution" [exec] pg_restore: finished item 5979 INDEX pr4_vwoc_cn [exec] pg_restore: launching item 5893 CONSTRAINT pr_changelog pr_changelog_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_changelog pr_changelog_pk" [exec] pg_restore: finished item 5981 INDEX vw_objclass [exec] pg_restore: launching item 6120 CONSTRAINT pr_data_admin_product pr_data_admin_product_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_admin_product pr_data_admin_product_pk" [exec] pg_restore: finished item 6120 CONSTRAINT pr_data_admin_product pr_data_admin_product_pk [exec] pg_restore: launching item 5919 CONSTRAINT pr_data_admin_restore pr_data_admin_restore_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_admin_restore pr_data_admin_restore_pk" [exec] pg_restore: finished item 5919 CONSTRAINT pr_data_admin_restore pr_data_admin_restore_pk [exec] pg_restore: launching item 6160 CONSTRAINT pr_data_customproperties pr_data_customproperties_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_customproperties pr_data_customproperties_pk" [exec] pg_restore: finished item 6160 CONSTRAINT pr_data_customproperties pr_data_customproperties_pk [exec] pg_restore: launching item 6158 INDEX pr_data_customproperties_idx1 [exec] pg_restore: creating INDEX "rules.pr_data_customproperties_idx1" [exec] pg_restore: finished item 6158 INDEX pr_data_customproperties_idx1 [exec] pg_restore: launching item 6106 CONSTRAINT pr_data_map_entries pr_data_map_entries_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_map_entries pr_data_map_entries_pk" [exec] pg_restore: finished item 6106 CONSTRAINT pr_data_map_entries pr_data_map_entries_pk [exec] pg_restore: launching item 6104 INDEX pr_data_map_entries_idx [exec] pg_restore: creating INDEX "rules.pr_data_map_entries_idx" [exec] pg_restore: finished item 6104 INDEX pr_data_map_entries_idx [exec] pg_restore: launching item 6077 CONSTRAINT pr_data_products pr_data_products_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_products pr_data_products_pk" [exec] pg_restore: finished item 6077 CONSTRAINT pr_data_products pr_data_products_pk [exec] pg_restore: launching item 6079 CONSTRAINT pr_data_restore pr_data_restore_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_restore pr_data_restore_pk" [exec] pg_restore: finished item 6079 CONSTRAINT pr_data_restore pr_data_restore_pk [exec] pg_restore: launching item 6112 CONSTRAINT pr_data_rule_appmetadata pr_data_rule_appmetadata_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_rule_appmetadata pr_data_rule_appmetadata_pk" [exec] pg_restore: finished item 6112 CONSTRAINT pr_data_rule_appmetadata pr_data_rule_appmetadata_pk [exec] pg_restore: launching item 6132 CONSTRAINT pr_data_scanner pr_data_scanner_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_data_scanner pr_data_scanner_pk" [exec] pg_restore: finished item 6132 CONSTRAINT pr_data_scanner pr_data_scanner_pk [exec] pg_restore: launching item 6130 INDEX pr_data_scanner_idx1 [exec] pg_restore: creating INDEX "rules.pr_data_scanner_idx1" [exec] pg_restore: finished item 6130 INDEX pr_data_scanner_idx1 [exec] pg_restore: launching item 5951 CONSTRAINT pr4_rule pr4_rule_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule pr4_rule_pk" [exec] pg_restore: finished item 5893 CONSTRAINT pr_changelog pr_changelog_pk [exec] pg_restore: launching item 5891 INDEX pr_changelog_idx1 [exec] pg_restore: creating INDEX "rules.pr_changelog_idx1" [exec] pg_restore: finished item 5891 INDEX pr_changelog_idx1 [exec] pg_restore: launching item 6164 CONSTRAINT pr_index_applicationbuilton pr_index_applicationbuilton_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_applicationbuilton pr_index_applicationbuilton_pk" [exec] pg_restore: finished item 6164 CONSTRAINT pr_index_applicationbuilton pr_index_applicationbuilton_pk [exec] pg_restore: launching item 6161 INDEX getbuiltonapplications [exec] pg_restore: creating INDEX "rules.getbuiltonapplications" [exec] pg_restore: finished item 6161 INDEX getbuiltonapplications [exec] pg_restore: launching item 6162 INDEX keypurposeidx_appbuilton [exec] pg_restore: creating INDEX "rules.keypurposeidx_appbuilton" [exec] pg_restore: finished item 6162 INDEX keypurposeidx_appbuilton [exec] pg_restore: launching item 6220 CONSTRAINT pr_index_bi_permission pr_index_bi_permission_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_bi_permission pr_index_bi_permission_pk" [exec] pg_restore: finished item 6220 CONSTRAINT pr_index_bi_permission pr_index_bi_permission_pk [exec] pg_restore: launching item 6218 INDEX pr_index_bi_permission_idx1 [exec] pg_restore: creating INDEX "rules.pr_index_bi_permission_idx1" [exec] pg_restore: finished item 6218 INDEX pr_index_bi_permission_idx1 [exec] pg_restore: launching item 5907 CONSTRAINT pr_index_circumstance_def pr_index_circumstance_def_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_circumstance_def pr_index_circumstance_def_pk" [exec] pg_restore: finished item 5907 CONSTRAINT pr_index_circumstance_def pr_index_circumstance_def_pk [exec] pg_restore: launching item 5905 INDEX keypurposeidx_cirdef [exec] pg_restore: creating INDEX "rules.keypurposeidx_cirdef" [exec] pg_restore: finished item 5905 INDEX keypurposeidx_cirdef [exec] pg_restore: launching item 5960 CONSTRAINT pr4_rule_section pr4_rule_section_pk [exec] pg_restore: creating CONSTRAINT "rules.pr4_rule_section pr4_rule_section_pk" [exec] pg_restore: finished item 5960 CONSTRAINT pr4_rule_section pr4_rule_section_pk [exec] pg_restore: launching item 5957 INDEX pr4_rule_section_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_section_idx1" [exec] pg_restore: finished item 5951 CONSTRAINT pr4_rule pr4_rule_pk [exec] pg_restore: launching item 5948 INDEX pr4_rule_idx1 [exec] pg_restore: creating INDEX "rules.pr4_rule_idx1" [exec] pg_restore: finished item 5957 INDEX pr4_rule_section_idx1 [exec] pg_restore: launching item 5949 INDEX pr4_rule_oc_in [exec] pg_restore: creating INDEX "rules.pr4_rule_oc_in" [exec] pg_restore: finished item 5982 INDEX vw_resolution [exec] pg_restore: launching item 5952 INDEX pr4_ruleoc_cn [exec] pg_restore: creating INDEX "rules.pr4_ruleoc_cn" [exec] pg_restore: finished item 5948 INDEX pr4_rule_idx1 [exec] pg_restore: launching item 5953 INDEX pr4_ruleruleset [exec] pg_restore: creating INDEX "rules.pr4_ruleruleset" [exec] pg_restore: finished item 5953 INDEX pr4_ruleruleset [exec] pg_restore: launching item 5954 INDEX rule_app_hier [exec] pg_restore: creating INDEX "rules.rule_app_hier" [exec] pg_restore: finished item 5952 INDEX pr4_ruleoc_cn [exec] pg_restore: launching item 5955 INDEX rule_objclass [exec] pg_restore: creating INDEX "rules.rule_objclass" [exec] pg_restore: finished item 5954 INDEX rule_app_hier [exec] pg_restore: launching item 5956 INDEX rule_ruleres_1 [exec] pg_restore: creating INDEX "rules.rule_ruleres_1" [exec] pg_restore: finished item 5949 INDEX pr4_rule_oc_in [exec] pg_restore: launching item 5958 INDEX pr4_rule_section_idx2 [exec] pg_restore: creating INDEX "rules.pr4_rule_section_idx2" [exec] pg_restore: finished item 5955 INDEX rule_objclass [exec] pg_restore: launching item 5933 CONSTRAINT pr_index_customfields pr_index_customfields_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_customfields pr_index_customfields_pk" [exec] pg_restore: finished item 5933 CONSTRAINT pr_index_customfields pr_index_customfields_pk [exec] pg_restore: launching item 5931 INDEX customfields [exec] pg_restore: creating INDEX "rules.customfields" [exec] pg_restore: finished item 5931 INDEX customfields [exec] pg_restore: launching item 6181 CONSTRAINT pr_index_datasaveoptions pr_index_datasavop_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_datasaveoptions pr_index_datasavop_pk" [exec] pg_restore: finished item 6181 CONSTRAINT pr_index_datasaveoptions pr_index_datasavop_pk [exec] pg_restore: launching item 6179 INDEX pr_index_datasaveop_idx1 [exec] pg_restore: creating INDEX "rules.pr_index_datasaveop_idx1" [exec] pg_restore: finished item 6179 INDEX pr_index_datasaveop_idx1 [exec] pg_restore: launching item 6061 CONSTRAINT pr_index_datasources pr_index_datasources_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_datasources pr_index_datasources_pk" [exec] pg_restore: finished item 6061 CONSTRAINT pr_index_datasources pr_index_datasources_pk [exec] pg_restore: launching item 6059 INDEX pr_datasource_type [exec] pg_restore: creating INDEX "rules.pr_datasource_type" [exec] pg_restore: finished item 6059 INDEX pr_datasource_type [exec] pg_restore: launching item 6252 CONSTRAINT pr_index_dpparameter pr_index_dpparameter_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_dpparameter pr_index_dpparameter_pk" [exec] pg_restore: finished item 6252 CONSTRAINT pr_index_dpparameter pr_index_dpparameter_pk [exec] pg_restore: launching item 6250 INDEX pr_index_dpparameter_idx1 [exec] pg_restore: creating INDEX "rules.pr_index_dpparameter_idx1" [exec] pg_restore: finished item 5958 INDEX pr4_rule_section_idx2 [exec] pg_restore: launching item 6174 CONSTRAINT pr_index_policyconditions pr_index_policycond_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_policyconditions pr_index_policycond_pk" [exec] pg_restore: finished item 6174 CONSTRAINT pr_index_policyconditions pr_index_policycond_pk [exec] pg_restore: launching item 6172 INDEX pr_index_policycond_idx1 [exec] pg_restore: creating INDEX "rules.pr_index_policycond_idx1" [exec] pg_restore: finished item 6172 INDEX pr_index_policycond_idx1 [exec] pg_restore: launching item 6129 CONSTRAINT pr_index_privilege pr_index_privilege_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_privilege pr_index_privilege_pk" [exec] pg_restore: finished item 6129 CONSTRAINT pr_index_privilege pr_index_privilege_pk [exec] pg_restore: launching item 6126 INDEX insindexedkeyprivilege [exec] pg_restore: creating INDEX "rules.insindexedkeyprivilege" [exec] pg_restore: finished item 6126 INDEX insindexedkeyprivilege [exec] pg_restore: launching item 6127 INDEX keypurposeidxprivilege [exec] pg_restore: creating INDEX "rules.keypurposeidxprivilege" [exec] pg_restore: finished item 6250 INDEX pr_index_dpparameter_idx1 [exec] pg_restore: launching item 5930 CONSTRAINT pr_index_css pr_index_css_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_css pr_index_css_pk" [exec] pg_restore: finished item 6127 INDEX keypurposeidxprivilege [exec] pg_restore: launching item 6135 CONSTRAINT pr_index_rule_agents pr_index_rule_agents_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_rule_agents pr_index_rule_agents_pk" [exec] pg_restore: finished item 6135 CONSTRAINT pr_index_rule_agents pr_index_rule_agents_pk [exec] pg_restore: launching item 6133 INDEX pr_index_rule_agents_idx1 [exec] pg_restore: creating INDEX "rules.pr_index_rule_agents_idx1" [exec] pg_restore: finished item 6133 INDEX pr_index_rule_agents_idx1 [exec] pg_restore: launching item 5938 CONSTRAINT pr_index_warnings pr_index_warnings_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_warnings pr_index_warnings_pk" [exec] pg_restore: finished item 5956 INDEX rule_ruleres_1 [exec] pg_restore: launching item 6176 CONSTRAINT pr_link_feature pr_link_feature_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_link_feature pr_link_feature_pk" [exec] pg_restore: finished item 6176 CONSTRAINT pr_link_feature pr_link_feature_pk [exec] pg_restore: launching item 5904 CONSTRAINT pr_link_usecase pr_link_usecase_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_link_usecase pr_link_usecase_pk" [exec] pg_restore: finished item 5904 CONSTRAINT pr_link_usecase pr_link_usecase_pk [exec] pg_restore: launching item 5900 INDEX pr_link_usecase_faobj [exec] pg_restore: creating INDEX "rules.pr_link_usecase_faobj" [exec] pg_restore: finished item 5900 INDEX pr_link_usecase_faobj [exec] pg_restore: launching item 5901 INDEX pr_link_usecase_linkref [exec] pg_restore: creating INDEX "rules.pr_link_usecase_linkref" [exec] pg_restore: finished item 5901 INDEX pr_link_usecase_linkref [exec] pg_restore: launching item 5902 INDEX pr_link_usecase_linkreffrom [exec] pg_restore: creating INDEX "rules.pr_link_usecase_linkreffrom" [exec] pg_restore: finished item 5902 INDEX pr_link_usecase_linkreffrom [exec] pg_restore: launching item 6202 CONSTRAINT pr_migration_point pr_migration_point_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_migration_point pr_migration_point_pk" [exec] pg_restore: finished item 6202 CONSTRAINT pr_migration_point pr_migration_point_pk [exec] pg_restore: launching item 6048 CONSTRAINT pr_assembledclasses pr_asmclass_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_assembledclasses pr_asmclass_pk" [exec] pg_restore: finished item 5930 CONSTRAINT pr_index_css pr_index_css_pk [exec] pg_restore: launching item 5926 INDEX css_index1 [exec] pg_restore: creating INDEX "rules.css_index1" [exec] pg_restore: finished item 5938 CONSTRAINT pr_index_warnings pr_index_warnings_pk [exec] pg_restore: launching item 5927 INDEX css_indexed_key [exec] pg_restore: creating INDEX "rules.css_indexed_key" [exec] pg_restore: finished item 5926 INDEX css_index1 [exec] pg_restore: launching item 5928 INDEX keypurposeidx_css [exec] pg_restore: creating INDEX "rules.keypurposeidx_css" [exec] pg_restore: finished item 6048 CONSTRAINT pr_assembledclasses pr_asmclass_pk [exec] pg_restore: launching item 5934 INDEX idxwarnings [exec] pg_restore: creating INDEX "rules.idxwarnings" [exec] pg_restore: finished item 5927 INDEX css_indexed_key [exec] pg_restore: launching item 5935 INDEX keypurposeidx_warn [exec] pg_restore: creating INDEX "rules.keypurposeidx_warn" [exec] pg_restore: finished item 5928 INDEX keypurposeidx_css [exec] pg_restore: launching item 5936 INDEX pr_index_warnings_idx1 [exec] pg_restore: creating INDEX "rules.pr_index_warnings_idx1" [exec] pg_restore: finished item 5934 INDEX idxwarnings [exec] pg_restore: launching item 6049 INDEX pr_assembledclasses_package [exec] pg_restore: creating INDEX "rules.pr_assembledclasses_package" [exec] pg_restore: finished item 5935 INDEX keypurposeidx_warn [exec] pg_restore: launching item 5897 CONSTRAINT pr_selectquerylog pr_selectquerylog_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_selectquerylog pr_selectquerylog_pk" [exec] pg_restore: finished item 5897 CONSTRAINT pr_selectquerylog pr_selectquerylog_pk [exec] pg_restore: launching item 5894 INDEX pr_selectquerylog_idx1 [exec] pg_restore: creating INDEX "rules.pr_selectquerylog_idx1" [exec] pg_restore: finished item 5894 INDEX pr_selectquerylog_idx1 [exec] pg_restore: launching item 5895 INDEX pr_selectquerylog_idx2 [exec] pg_restore: creating INDEX "rules.pr_selectquerylog_idx2" [exec] pg_restore: finished item 5895 INDEX pr_selectquerylog_idx2 [exec] pg_restore: launching item 6093 CONSTRAINT pr_sys_app_hierarchy_flat pr_sys_app_hierarchy_flat_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_app_hierarchy_flat pr_sys_app_hierarchy_flat_pk" [exec] pg_restore: finished item 6093 CONSTRAINT pr_sys_app_hierarchy_flat pr_sys_app_hierarchy_flat_pk [exec] pg_restore: launching item 6087 INDEX apphierarchyflat_report [exec] pg_restore: creating INDEX "rules.apphierarchyflat_report" [exec] pg_restore: finished item 6087 INDEX apphierarchyflat_report [exec] pg_restore: launching item 6088 INDEX pr_sys_app_hierarchy_flat_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx1" [exec] pg_restore: finished item 6088 INDEX pr_sys_app_hierarchy_flat_idx1 [exec] pg_restore: launching item 6089 INDEX pr_sys_app_hierarchy_flat_idx2 [exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx2" [exec] pg_restore: finished item 6089 INDEX pr_sys_app_hierarchy_flat_idx2 [exec] pg_restore: launching item 6090 INDEX pr_sys_app_hierarchy_flat_idx3 [exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx3" [exec] pg_restore: finished item 6090 INDEX pr_sys_app_hierarchy_flat_idx3 [exec] pg_restore: launching item 6091 INDEX pr_sys_app_hierarchy_flat_idx4 [exec] pg_restore: creating INDEX "rules.pr_sys_app_hierarchy_flat_idx4" [exec] pg_restore: finished item 6091 INDEX pr_sys_app_hierarchy_flat_idx4 [exec] pg_restore: launching item 6054 CONSTRAINT pr_sys_app_ruleset_index pr_sys_app_ruleset_index_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_app_ruleset_index pr_sys_app_ruleset_index_pk" [exec] pg_restore: finished item 6054 CONSTRAINT pr_sys_app_ruleset_index pr_sys_app_ruleset_index_pk [exec] pg_restore: launching item 6050 INDEX pr_sari_appverrs [exec] pg_restore: creating INDEX "rules.pr_sari_appverrs" [exec] pg_restore: finished item 6050 INDEX pr_sari_appverrs [exec] pg_restore: launching item 6051 INDEX pr_sys_app_ruleset_index_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_app_ruleset_index_idx1" [exec] pg_restore: finished item 6051 INDEX pr_sys_app_ruleset_index_idx1 [exec] pg_restore: launching item 6052 INDEX pr_sys_app_ruleset_index_idx4 [exec] pg_restore: creating INDEX "rules.pr_sys_app_ruleset_index_idx4" [exec] pg_restore: finished item 6052 INDEX pr_sys_app_ruleset_index_idx4 [exec] pg_restore: launching item 6098 CONSTRAINT pr_sys_appcache_dep pr_sys_appcache_dep_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_appcache_dep pr_sys_appcache_dep_pk" [exec] pg_restore: finished item 6098 CONSTRAINT pr_sys_appcache_dep pr_sys_appcache_dep_pk [exec] pg_restore: launching item 6094 INDEX pr_sys_appcache_dep_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_appcache_dep_idx1" [exec] pg_restore: finished item 6094 INDEX pr_sys_appcache_dep_idx1 [exec] pg_restore: launching item 6095 INDEX pr_sys_appcache_dep_idx2 [exec] pg_restore: creating INDEX "rules.pr_sys_appcache_dep_idx2" [exec] pg_restore: finished item 6095 INDEX pr_sys_appcache_dep_idx2 [exec] pg_restore: launching item 6096 INDEX pr_sys_appcache_dep_idx4 [exec] pg_restore: creating INDEX "rules.pr_sys_appcache_dep_idx4" [exec] pg_restore: finished item 6096 INDEX pr_sys_appcache_dep_idx4 [exec] pg_restore: launching item 6086 CONSTRAINT pr_sys_appcache_entry pr_sys_appcache_entry_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_appcache_entry pr_sys_appcache_entry_pk" [exec] pg_restore: finished item 6086 CONSTRAINT pr_sys_appcache_entry pr_sys_appcache_entry_pk [exec] pg_restore: launching item 6080 INDEX appentry_apphash [exec] pg_restore: creating INDEX "rules.appentry_apphash" [exec] pg_restore: finished item 6080 INDEX appentry_apphash [exec] pg_restore: launching item 6081 INDEX appentry_impl [exec] pg_restore: creating INDEX "rules.appentry_impl" [exec] pg_restore: finished item 6081 INDEX appentry_impl [exec] pg_restore: launching item 6082 INDEX appentry_rule [exec] pg_restore: creating INDEX "rules.appentry_rule" [exec] pg_restore: finished item 6082 INDEX appentry_rule [exec] pg_restore: launching item 6083 INDEX pr_sys_appcache_entry_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_appcache_entry_idx1" [exec] pg_restore: finished item 6083 INDEX pr_sys_appcache_entry_idx1 [exec] pg_restore: launching item 6084 INDEX pr_sys_appcache_entry_idx2 [exec] pg_restore: creating INDEX "rules.pr_sys_appcache_entry_idx2" [exec] pg_restore: finished item 6084 INDEX pr_sys_appcache_entry_idx2 [exec] pg_restore: launching item 6103 CONSTRAINT pr_sys_appcache_shortcut pr_sys_appcache_shortcut_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_appcache_shortcut pr_sys_appcache_shortcut_pk" [exec] pg_restore: finished item 6103 CONSTRAINT pr_sys_appcache_shortcut pr_sys_appcache_shortcut_pk [exec] pg_restore: launching item 6099 INDEX appshortcut_entrykey [exec] pg_restore: creating INDEX "rules.appshortcut_entrykey" [exec] pg_restore: finished item 6099 INDEX appshortcut_entrykey [exec] pg_restore: launching item 6100 INDEX pr_sys_appcache_shortcut_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_appcache_shortcut_idx1" [exec] pg_restore: finished item 6100 INDEX pr_sys_appcache_shortcut_idx1 [exec] pg_restore: launching item 6101 INDEX pr_sys_appcache_shortcut_idx2 [exec] pg_restore: creating INDEX "rules.pr_sys_appcache_shortcut_idx2" [exec] pg_restore: finished item 6101 INDEX pr_sys_appcache_shortcut_idx2 [exec] pg_restore: launching item 5881 CONSTRAINT pr_sys_cache_dep pr_sys_cache_dep_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_cache_dep pr_sys_cache_dep_pk" [exec] pg_restore: finished item 5881 CONSTRAINT pr_sys_cache_dep pr_sys_cache_dep_pk [exec] pg_restore: launching item 5877 INDEX cache_dep_dep [exec] pg_restore: creating INDEX "rules.cache_dep_dep" [exec] pg_restore: finished item 5877 INDEX cache_dep_dep [exec] pg_restore: launching item 5878 INDEX cache_dep_impl [exec] pg_restore: creating INDEX "rules.cache_dep_impl" [exec] pg_restore: finished item 5878 INDEX cache_dep_impl [exec] pg_restore: launching item 5879 INDEX dep_ruleinsid [exec] pg_restore: creating INDEX "rules.dep_ruleinsid" [exec] pg_restore: finished item 5879 INDEX dep_ruleinsid [exec] pg_restore: launching item 5876 CONSTRAINT pr_sys_cache_entry pr_sys_cache_entry_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_cache_entry pr_sys_cache_entry_pk" [exec] pg_restore: finished item 5876 CONSTRAINT pr_sys_cache_entry pr_sys_cache_entry_pk [exec] pg_restore: launching item 5871 INDEX cache_entry_hash [exec] pg_restore: creating INDEX "rules.cache_entry_hash" [exec] pg_restore: finished item 5871 INDEX cache_entry_hash [exec] pg_restore: launching item 5872 INDEX cache_entry_impl [exec] pg_restore: creating INDEX "rules.cache_entry_impl" [exec] pg_restore: finished item 5872 INDEX cache_entry_impl [exec] pg_restore: launching item 5873 INDEX cache_entry_rule [exec] pg_restore: creating INDEX "rules.cache_entry_rule" [exec] pg_restore: finished item 5873 INDEX cache_entry_rule [exec] pg_restore: launching item 5874 INDEX pr_sys_cache_entry_idx2 [exec] pg_restore: creating INDEX "rules.pr_sys_cache_entry_idx2" [exec] pg_restore: finished item 5874 INDEX pr_sys_cache_entry_idx2 [exec] pg_restore: launching item 5885 CONSTRAINT pr_sys_cache_impl pr_sys_cache_impl_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_cache_impl pr_sys_cache_impl_pk" [exec] pg_restore: finished item 5885 CONSTRAINT pr_sys_cache_impl pr_sys_cache_impl_pk [exec] pg_restore: launching item 5882 INDEX cache_impl_impl [exec] pg_restore: creating INDEX "rules.cache_impl_impl" [exec] pg_restore: finished item 5882 INDEX cache_impl_impl [exec] pg_restore: launching item 5883 INDEX cache_impl_rulename [exec] pg_restore: creating INDEX "rules.cache_impl_rulename" [exec] pg_restore: finished item 5883 INDEX cache_impl_rulename [exec] pg_restore: launching item 6118 CONSTRAINT pr_reference_page pr_reference_page_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_reference_page pr_reference_page_pk" [exec] pg_restore: finished item 6049 INDEX pr_assembledclasses_package [exec] pg_restore: launching item 6038 CONSTRAINT pr_sys_decchg pr_sys_decchg_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_decchg pr_sys_decchg_pk" [exec] pg_restore: finished item 6038 CONSTRAINT pr_sys_decchg pr_sys_decchg_pk [exec] pg_restore: launching item 6036 INDEX pr_sys_decchg_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_decchg_idx1" [exec] pg_restore: finished item 5936 INDEX pr_index_warnings_idx1 [exec] pg_restore: launching item 6039 INDEX sdc_class [exec] pg_restore: creating INDEX "rules.sdc_class" [exec] pg_restore: finished item 6036 INDEX pr_sys_decchg_idx1 [exec] pg_restore: launching item 6040 INDEX sdc_key [exec] pg_restore: creating INDEX "rules.sdc_key" [exec] pg_restore: finished item 6039 INDEX sdc_class [exec] pg_restore: launching item 6041 INDEX sdc_prop [exec] pg_restore: creating INDEX "rules.sdc_prop" [exec] pg_restore: finished item 6041 INDEX sdc_prop [exec] pg_restore: launching item 6142 CONSTRAINT pr_sys_hotfix_events pr_sys_hotfix_events_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_hotfix_events pr_sys_hotfix_events_pk" [exec] pg_restore: finished item 6142 CONSTRAINT pr_sys_hotfix_events pr_sys_hotfix_events_pk [exec] pg_restore: launching item 6140 INDEX pr_sys_hotfix_events_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_hotfix_events_idx1" [exec] pg_restore: finished item 6140 INDEX pr_sys_hotfix_events_idx1 [exec] pg_restore: launching item 6197 CONSTRAINT pr_sys_import_queue pr_sys_import_queue_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_import_queue pr_sys_import_queue_pk" [exec] pg_restore: finished item 6197 CONSTRAINT pr_sys_import_queue pr_sys_import_queue_pk [exec] pg_restore: launching item 5890 CONSTRAINT pr_sys_class_ancestors pr_sys_class_ancestors_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_class_ancestors pr_sys_class_ancestors_pk" [exec] pg_restore: finished item 6040 INDEX sdc_key [exec] pg_restore: launching item 6033 CONSTRAINT pr_sys_ruleset_index pr_sys_ruleset_index_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_ruleset_index pr_sys_ruleset_index_pk" [exec] pg_restore: finished item 6033 CONSTRAINT pr_sys_ruleset_index pr_sys_ruleset_index_pk [exec] pg_restore: launching item 6031 INDEX pr_sys_ruleset_index_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_ruleset_index_idx1" [exec] pg_restore: finished item 6031 INDEX pr_sys_ruleset_index_idx1 [exec] pg_restore: launching item 6034 INDEX rule_res_rule_join [exec] pg_restore: creating INDEX "rules.rule_res_rule_join" [exec] pg_restore: finished item 6034 INDEX rule_res_rule_join [exec] pg_restore: launching item 6035 INDEX rulesetname [exec] pg_restore: creating INDEX "rules.rulesetname" [exec] pg_restore: finished item 6035 INDEX rulesetname [exec] pg_restore: launching item 6205 CONSTRAINT pr_sys_runtime_context pr_sys_runtime_context_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_runtime_context pr_sys_runtime_context_pk" [exec] pg_restore: finished item 6205 CONSTRAINT pr_sys_runtime_context pr_sys_runtime_context_pk [exec] pg_restore: launching item 6203 INDEX pr_sys_runtime_context_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_runtime_context_idx1" [exec] pg_restore: finished item 6203 INDEX pr_sys_runtime_context_idx1 [exec] pg_restore: launching item 6125 CONSTRAINT pr_sysgen_static_content pr_sysgen_static_content_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sysgen_static_content pr_sysgen_static_content_pk" [exec] pg_restore: finished item 6125 CONSTRAINT pr_sysgen_static_content pr_sysgen_static_content_pk [exec] pg_restore: launching item 6121 INDEX pr_sysgen_static_content_idx2 [exec] pg_restore: creating INDEX "rules.pr_sysgen_static_content_idx2" [exec] pg_restore: finished item 6121 INDEX pr_sysgen_static_content_idx2 [exec] pg_restore: launching item 6122 INDEX pr_sysgen_static_content_idx3 [exec] pg_restore: creating INDEX "rules.pr_sysgen_static_content_idx3" [exec] pg_restore: finished item 6122 INDEX pr_sysgen_static_content_idx3 [exec] pg_restore: launching item 6123 INDEX pr_sysgen_static_content_idx4 [exec] pg_restore: creating INDEX "rules.pr_sysgen_static_content_idx4" [exec] pg_restore: finished item 6123 INDEX pr_sysgen_static_content_idx4 [exec] pg_restore: launching item 6110 CONSTRAINT pr_sys_rule_impl pr_sysrulim_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_sys_rule_impl pr_sysrulim_pk" [exec] pg_restore: finished item 6110 CONSTRAINT pr_sys_rule_impl pr_sysrulim_pk [exec] pg_restore: launching item 6107 INDEX pr_sys_rule_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_rule_idx1" [exec] pg_restore: finished item 5890 CONSTRAINT pr_sys_class_ancestors pr_sys_class_ancestors_pk [exec] pg_restore: launching item 5886 INDEX pr_sys_class_ancest_rr [exec] pg_restore: creating INDEX "rules.pr_sys_class_ancest_rr" [exec] pg_restore: finished item 6118 CONSTRAINT pr_reference_page pr_reference_page_pk [exec] pg_restore: launching item 6113 INDEX pr_ref_page_pageclass [exec] pg_restore: creating INDEX "rules.pr_ref_page_pageclass" [exec] pg_restore: finished item 6107 INDEX pr_sys_rule_idx1 [exec] pg_restore: launching item 6114 INDEX pr_reference_page_idx1 [exec] pg_restore: creating INDEX "rules.pr_reference_page_idx1" [exec] pg_restore: finished item 5886 INDEX pr_sys_class_ancest_rr [exec] pg_restore: launching item 6115 INDEX pr_reference_page_idx2 [exec] pg_restore: creating INDEX "rules.pr_reference_page_idx2" [exec] pg_restore: finished item 6113 INDEX pr_ref_page_pageclass [exec] pg_restore: launching item 6116 INDEX pr_reference_page_idx3 [exec] pg_restore: creating INDEX "rules.pr_reference_page_idx3" [exec] pg_restore: finished item 6114 INDEX pr_reference_page_idx1 [exec] pg_restore: launching item 5887 INDEX pr_sys_class_ancest_rr2 [exec] pg_restore: creating INDEX "rules.pr_sys_class_ancest_rr2" [exec] pg_restore: finished item 6115 INDEX pr_reference_page_idx2 [exec] pg_restore: launching item 5888 INDEX pr_sys_class_ancestors_cc [exec] pg_restore: creating INDEX "rules.pr_sys_class_ancestors_cc" [exec] pg_restore: finished item 5887 INDEX pr_sys_class_ancest_rr2 [exec] pg_restore: launching item 6108 INDEX pr_sys_rule_impl_idx1 [exec] pg_restore: creating INDEX "rules.pr_sys_rule_impl_idx1" [exec] pg_restore: finished item 6116 INDEX pr_reference_page_idx3 [exec] pg_restore: launching item 6044 CONSTRAINT pr_engineclasses pr_engclass_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_engineclasses pr_engclass_pk" [exec] pg_restore: finished item 6108 INDEX pr_sys_rule_impl_idx1 [exec] pg_restore: finished item 5888 INDEX pr_sys_class_ancestors_cc [exec] pg_restore: finished item 6044 CONSTRAINT pr_engineclasses pr_engclass_pk [exec] pg_restore: launching item 6042 INDEX pr_engclass_code [exec] pg_restore: pg_restore: launching item 6045 INDEX pr_engclass_pkg [exec] creating INDEX "rules.pr_engclass_code" [exec] pg_restore: pg_restore: launching item 6046 INDEX pr_engclass_querykey [exec] creating INDEX "rules.pr_engclass_pkg" [exec] pg_restore: creating INDEX "rules.pr_engclass_querykey" [exec] pg_restore: finished item 6691 TABLE DATA pr_index_reference [exec] pg_restore: launching item 5944 CONSTRAINT pr_index_reference pr_index_reference_pk [exec] pg_restore: creating CONSTRAINT "rules.pr_index_reference pr_index_reference_pk" [exec] pg_restore: finished item 6042 INDEX pr_engclass_code [exec] pg_restore: finished item 6045 INDEX pr_engclass_pkg [exec] pg_restore: finished item 6046 INDEX pr_engclass_querykey [exec] pg_restore: finished item 5944 CONSTRAINT pr_index_reference pr_index_reference_pk [exec] pg_restore: launching item 5939 INDEX index_ref [exec] pg_restore: pg_restore: creating INDEX "rules.index_ref" [exec] launching item 5940 INDEX index_refport [exec] pg_restore: pg_restore: launching item 5941 INDEX pr_index_reference_index1 [exec] creating INDEX "rules.index_refport" [exec] pg_restore: pg_restore: launching item 5942 INDEX pr_index_reference_index2 [exec] creating INDEX "rules.pr_index_reference_index1" [exec] pg_restore: creating INDEX "rules.pr_index_reference_index2" [exec] pg_restore: finished item 5941 INDEX pr_index_reference_index1 [exec] pg_restore: launching item 5945 INDEX ref_index [exec] pg_restore: creating INDEX "rules.ref_index" [exec] pg_restore: finished item 5942 INDEX pr_index_reference_index2 [exec] pg_restore: launching item 5946 INDEX ref_objclass [exec] pg_restore: creating INDEX "rules.ref_objclass" [exec] pg_restore: finished item 5940 INDEX index_refport [exec] pg_restore: launching item 5947 INDEX ref_rules [exec] pg_restore: creating INDEX "rules.ref_rules" [exec] pg_restore: finished item 5939 INDEX index_ref [exec] pg_restore: finished item 5946 INDEX ref_objclass [exec] pg_restore: finished item 5945 INDEX ref_index [exec] pg_restore: finished item 5947 INDEX ref_rules [exec] pg_restore: finished main parallel loop [echo] Reindexing postgres database... [exec] REINDEX
Assign Ports: [replace] Replaced 1 occurrences in 1 files. [replace] Replaced 1 occurrences in 1 files. [replace] Replaced 4 occurrences in 1 files. [replace] Replaced 1 occurrences in 1 files.
Configuration: [exec] Microsoft (R) Windows Script Host Version 5.812 [exec] Copyright (C) Microsoft Corporation. All rights reserved. [exec] [delete] Deleting: C:\Users\thepr\OneDrive\Desktop\117149_PEga_8.7(2)\pegaGuiInstallerTemp\CreatePegaShortCut.vbs [exec] Microsoft (R) Windows Script Host Version 5.812 [exec] Copyright (C) Microsoft Corporation. All rights reserved. [exec] [delete] Deleting: C:\Users\thepr\OneDrive\Desktop\117149_PEga_8.7(2)\pegaGuiInstallerTemp\CreatePegaShortCut.vbs [exec] Microsoft (R) Windows Script Host Version 5.812 [exec] Copyright (C) Microsoft Corporation. All rights reserved. [exec] [delete] Deleting: C:\Users\thepr\OneDrive\Desktop\117149_PEga_8.7(2)\pegaGuiInstallerTemp\CreatePegaShortCut.vbs
PRPC Launching: [echo] Starting tomcat .... [exec] 'C:\Users\thepr\OneDrive\Desktop\117149_PEga_8.7' is not recognized as an internal or external command, [exec] operable program or batch file.
