Tata Consultancy Services
Last activity: 23 May 2023 3:21 EDT
Sending Report as Excel Using Activity
Hi, I am doing one poc for sending report definition data in excel format through activity. 1) Call pxCallRetrieveReportData {for calling report in activity}
2) Call pxGenerateExcelFile ExceStepage {for generating excel}
3) Page-New AttachmentsPG {Steppage [class = Data-EmailAttachments ] }
4) Page-Copy AttachmentsPG {Stepage}
CopyFrom = ExceStepage
CopyInto = .pyAttachments(<APPEND>)
5) Call sendemailnotification. I am receiving only email message, not receiving attachment in the form of excel. Can anyone help me with any solution, or what mistake I am doing here?
Updated: 23 May 2023 2:20 EDT
TATA Consultancy Services
@Nadimuthu T pxGenerateExcelFile activity generate the excel file and place into service export directory. Please refer pyActionSendMail activity step 14 and get the file and Local.strFileData holds the attachment stream data.
@AbhishekC1725 Please use OOTB option for the scheduled report option. Go to report browser and select the report and click edit option and configure the schedule option. you will get the report definition as a excel attachment via email.
@Nadimuthu TI know this. But here the requirement is different.
Bits in Glass
@AbhishekC1725 you can refer to sendemailwithattachments OOTB activity.
@AbhishekC1725 Please follow below mentioned steps.
Property-Set
AttachmentPage.pyAttachments(<APPEND>).pyName = Attachment Name
AttachmentPage.pyAttachments(<LAST>).pyData = Attachment Stream 64 byte
AttachmentPage.pyAttachments(<LAST>)..pyDecode = true
Call sendEmailNotificationWithAttachments or SendEmailNotification baseclass activity and pass Param.AttachmentPage =AttachmentPage and other required parameters.
Anoop Krishna
@Nadimuthu TAttachmentPage.pyAttachments(<LAST>).pyData = Attachment Stream 64 byte Can you explain this step. Currently the excel file is in Page = ExceStepage
Abhishek Choubey Anoop Krishna
@Nadimuthu T Thanks for explanation.
Bits in Glass
@AbhishekC1725 If you have achieved this, please post the screenshots of the same. Will be helpful for the others. Also wanted to confirm one thing, you are trying to generate an excel and directly send that over email right? That file is not attached to case right?
@Anoop Krishna Yes, The file is not attached to the case. I am generating excel using Call pxGenerateExcelFile method. Job scheduler in Pega: Generate Excel and as an attachment in email, tracing job scheduler - YouTube This video will be help full for you. Java code is present in the description of this Video. Sorry I can;t share activity screenshot here, due to privacy policy. Pages & Classes {That are used} Atts[Pagename] Data-EmailAttachments {Class} Att[Pagename] Embed-EmailAttachment {Class} Major Steps In activity {I used} 1) Call pxRetrieveReportData 2) Call pxGenerateExcelFile 3) Property-Set 4) Java 5) Page-New Att 6) Property-Set Att 7) Page-New Atts 8) Page-Copy From = Att CopyInto = Atts.pyAttachments(1) 9) Call SendEmailNotification 10) Page-Remove Hope this will helpfull
Anoop Krishna
