GCP Remediation - Function Alias - SQL Expression
Convert unsupported DB vendor specific syntax in Connect SQL to use a PostgreSQL supported function or use application logic to update the query needed; convert schema name.table name to use Pega class references; eliminate unsupported custom DB objects (views, procedures, functions, sequences and triggers) and custom schema names (except OOTB Rules, Data, CustomerData and MKTData)
***Edited by Moderator Marije to change Product details from S.I to Pega 8.8****
