Virtusa Consulting and Services Pty Ltd
Last activity: 6 Feb 2024 3:29 EST
Deployment Manager Connectivity Issue
Using PDM 5.5.4
Orchestrator on on 8.5.2 | Candidate on 8.8 - if this may be a version issue then we will be moving Orchestrator to 8.8 soon.
All checks have been done and everything as per the documentation.
From the logs - clearing the authentication settings before sending the request leading to no Auth in request and client sending a 401:Unathutorized. Does anyone seen this and know how to fix. Thanks.
Using PDM 5.5.4
2023-03-13 13:29:08,361 [fault (self-tuning)'] [ STANDARD] [ ] [aDeploymentManager:5] (.internal.ComponentsHttpClient) DEBUG pdm.boubyan.com|EP-VD013.corp.BBYNUAT.com DMReleaseAdmin - Clearing authentication settings for this client. 2023-03-13 13:29:08,361 [fault (self-tuning)'] [ STANDARD] [ ] [aDeploymentManager:5] (.internal.ComponentsHttpClient) DEBUG pdm.boubyan.com|EP-VD013.corp.BBYNUAT.com DMReleaseAdmin - Proxy configuration is not provided, or it is not applicable for this request. 2023-03-13 13:29:08,361 [fault (self-tuning)'] [ STANDARD] [ ] [aDeploymentManager:5] (.internal.ComponentsHttpClient) DEBUG pdm.boubyan.com|EP-VD013.corp.BBYNUAT.com DMReleaseAdmin - Clearing HTTP(S) proxy settings for this client. 2023-03-13 13:29:08,361 [fault (self-tuning)'] [ STANDARD] [ ] [aDeploymentManager:5] (.internal.ComponentsHttpClient) DEBUG pdm.boubyan.com|EP-VD013.corp.BBYNUAT.com DMReleaseAdmin - No Auth objects found in request 2023-03-13 13:29:08,361 [fault (self-tuning)'] [ STANDARD] [ ] [aDeploymentManager:5] (.internal.ComponentsHttpClient) DEBUG pdm.boubyan.com|EP-VD013.corp.BBYNUAT.com DMReleaseAdmin - HTTP request method=POST, url=https://xxxxxxxx:18011/prweb/PRRestService/cicd/v1/diagnostics 2023-03-13 13:29:08,361 [fault (self-tuning)'] [ STANDARD] [ ] [aDeploymentManager:5] (.internal.ComponentsHttpClient) DEBUG pdm.boubyan.com|EP-VD013.corp.BBYNUAT.com DMReleaseAdmin - HTTP request headers:
2023-03-13 13:29:08,373 [fault (self-tuning)'] [ STANDARD] [ ] [aDeploymentManager:5] (.internal.ComponentsHttpClient) DEBUG pdm.boubyan.com|EP-VD013.corp.BBYNUAT.com DMReleaseAdmin - Response 401 Unauthorized:
