WellsFargo
Last activity: 28 Feb 2023 13:13 EST
Issue with pega deploying in more than one pod in AKS HCI
cloud:AKS HCI
pega version image :8.8.1
we deployed one pod in AKS HCI and its works fine and facing issue when we create more than one pod .The issue is the application becomes unresponsive and i could see the error from pega rules logs :
SEVERE [http-nio-8080-exec-9] com.pega.pegarules.internal.bootstrap.PRBootstrap. Problem during method invocation (doPostInner)
com.pega.pegarules.pub.PRRuntimeException: FUACache-FailAssembly [this:is:not:a:classname] produced no java source:
cloud:AKS HCI
2023-02-28 17:13:57,692 [http-nio-8080-exec-9] [ STANDARD] [ ] [ ] (ernal.cache.AssemblerFunctions) ERROR - com.pega.pegarules.pub.generator.FirstUseAssemblerException: FUAInstance-AssembleFailed null
2023-02-28 17:13:57,692 [http-nio-8080-exec-9] [ STANDARD] [ ] [ ] (pcentric.RACacheAppCentricImpl) ERROR - Failed assembly of [this:is:not:a:classname] produced no java source
2023-02-28 17:13:57,693 [http-nio-8080-exec-9] [ STANDARD] [ ] [ ] ( internal.mgmt.Executable) ERROR - Exception:
java.lang.NullPointerException: null
Cluster logs:
The pods are unable to communicate each other :
2023-02-28 01:11:05,069 [web-6b696fd744-p4x27] [ ] [ ] (azelcast.core.LifecycleService) INFO - [ Proprietary information hidden]:5701 [67798a082be3bae124f89b4bfd3f4d3f] [3.12.10] [ Proprietary information hidden]:5701 is STARTED
2023-02-28 01:11:05,106 [web-6b696fd744-p4x27] [ ] [ ] (ion.impl.PartitionStateManager) INFO - [ Proprietary information hidden]:5701 [67798a082be3bae124f89b4bfd3f4d3f] [3.12.10] Initializing cluster partition table arrangement...
2023-02-28 01:14:44,829 [http-nio-8080-exec-2] [ shared] [ ILM:04.02.01] (he.impl.EnterpriseCacheService) INFO prmt-pega-cloud-web.prxxxx-aks-poc-tm.xxxxxxxxxxxaks-s1.XXXXXXXxx.net| Proprietary information hidden HYAFYN1G39DV4D2SQ3FGR1EKWCGANYBSYA RUxxxxxx - [ Proprietary information hidden]:5701 [67798a082be3bae124f89b4bfd3f4d3f] [3.12.10] Added cache config: CacheConfig{name='INTERNAL_cachename', managerPrefix='/hz/', inMemoryFormat=BINARY, backupCount=1, hotRestart=HotRestartConfig{enabled=false, fsync=false}, wanReplicationRef=null}
2023-02-28 01:14:44,847 [http-nio-8080-exec-2] [ shared] [ ILM:04.02.01] (he.impl.EnterpriseCacheService) INFO prmt-pega-cloud-web.prxxxx-aks-poc-tm.xxxxxxxxxxxaks-s1.XXXXXXXxx.net| Proprietary information hidden HYAFYN1G39DV4D2SQ3FGR1EKWCGANYBSYA RUxxxxxx - [ Proprietary information hidden]:5701 [67798a082be3bae124f89b4bfd3f4d3f] [3.12.10] Added cache config: CacheConfig{name='StaticContentAGCache', managerPrefix='/hz/', inMemoryFormat=BINARY, backupCount=1, hotRestart=HotRestartConfig{enabled=false, fsync=false}, wanReplicationRef=null}
2023-02-28 13:35:41,564 [f4d3f.IO.thread-in-0] [ ] [ ] ( nio.tcp.TcpIpConnection) INFO - [ Proprietary information hidden]:5701 [67798a082be3bae124f89b4bfd3f4d3f] [3.12.10] Connection[id=1, / Proprietary information hidden:5701->/ Proprietary information hidden:53915, qualifier=null, endpoint=null, alive=false, type=NONE] closed. Reason: Connection closed by the other side
pegauser@prmt-pega-cloud-web-XXXXXXXXXx:/usr/local/tomcat/logs/prmt-pega-cloud-web-XXXXXXXXXx$
