De Volksbank
Last activity: 13 Feb 2023 12:58 EST
Low-Code App Builder mission scenario 2 verification fails
In scenario 2, , I score 75 out of 100. First validation fails with message: The Create view has a data reference field Balance transfer account that refers to the Account data object field.
This however is incorrect, I have the create view, I have the Balance transfer account field, and it is a data reference field referring to Account.
What goes or do I do wrong and how can I fix it?
Likes (1)
Thamizhpon Dhanapal -
@HielkeS16699952 Hi Hielke, I think I know what is wrong. I will investigate.
Hielke Schut
Coforge INC
@ThamizhponD Hi Thamizhpon,
I apologize for the delayed response. I see you were able to complete the mission exercise - and the mission.
Let me know if this is still an issue.
We apologize for the inconvenience. We introduced a regression in the 8.8 mission exercise whereby we are checking for hard-coded names. This hard-coded check means we are not accommodating users correcting their mistakes.
I updated your solution build so your corrections are acceptable.
I also noticed your Pega instance was about to expire, so I reset the Pega instance you were using and uploaded your previous work. Now you have another 7 days from today to complete the mission exercise.
@ZahidC16753830 Hi Zahid,
eddie
Zahid Ceopa
@HielkeS16699952 Hi everyone,
I do not have an update yet. The issue is not with the Balance Transfer Account field - it has to do with a mistake y'all are making with the Create view. We are working on a work-around to accommodate this. I will check w/ the content team on Monday (13 Feb) to see how things are progressing.
If you are pressed for time, I recommend resetting the Pega instance and trying the mission exercise from the beginning.
