Incessant Technologies Pvt Ltd
Last activity: 19 Jan 2023 0:34 EST
Commitwitherrorhandling failing in higher env but working as expected in dev
In Dev, the work is getting save even though there are errors on pages, but in higher env the values are rolled back, and the work is not getting saved properly.
I have an error due to declare trigger on pages which can be ignored and only the change I made need to be committed for that we used commit with error handling, and it worked as expected in dev but not in higher environments.
The activity which I have written used in job scheduler for data correction purpose.
Suggest a way to this problem to save the modified work by ignoring the errors.
