Common Validation Message for all the property
Hello All,
My requirement is in a section there are many properties and have to give validation for all the properties, but the error message should be common for all the properties which will be at extreme end of the section like "Fields highlighted in red cannot be left blank" and the control should be highlighted with red color.
So how this problem can be solved. I have tried by DT method in which I have used one of the function but it's not working, have attached the ss of the DT and the function as well.
Thank You
***Edited by Moderator Marije to change type from General to Product***
