[Idea] Add other functions in ABAC to compare characteristics of the object to attributes
Hello Team, We suggest to add other functions in ABAC such as: "contains", "start with" or others to compare characteristics of the object to attributes.
- Use case:
We have a table of operators (added manually in the case) and the main idea is to restrict the access to this case for operators whose not mentioned in the table. Since we cannot add pagelist in value in the ABAC configuration, we have the idea to concatenate operators identifier and why not using a new function "contains" to check if the operator identifier from the column source exist in the concatenated value of all operators identifier.
SPW
***Edited by Moderator Marije to change add tag Idea***
