CBA
Last activity: 31 Jan 2023 1:10 EST
Warning messages in pega log while Posting messages to external Kafka topic
We are getting lot of warning messages in pega logs when we write messages to external Kafka topic(avro message) . we analysed and found its due to field's definition in avro schema as it has data type as "null and string"(sample given below). but Kafka team clarified, its the standard to define non-mandatory fields. but in pega we are getting warning messages for those non mandatory fields and its flooding pega log with warnings.
to avoid writing these warning messages from pega logs we have created the log category with "Error" for below class com.pega.dsm.kafka.api.serde.avro.AvroSerdeException to write error and above on the pega logs for this class but it didnt help. we are still seeing the messages in pega logs.
Has anyone faced this issue. please help
Pega Version : 8.7.0
sample definition for non mandatory field
"name": "Version",
"type": [
"null",
"type": "string",
"avro.java.string": "String"
sample definition for mandatory field
"name": "Version",
"type": [
"null",
"type": "string",
"name": "toDate",
"type": {
"type": "string",
Warning message in Pega logs
Property couldn't be matched with the potential schema.
com.pega.dsm.kafka.api.serde.avro.AvroSerdeException: Unsupported data type! NULL
at com.pega.dsm.kafka.api.serde.avro.ClipboardPageToGenericRecordConverter.resolveObjectByFieldType(ClipboardPageToGenericRecordConverter.java:97) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.avro.ClipboardPageToGenericRecordConverter.handleUnionType(ClipboardPageToGenericRecordConverter.java:108) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.avro.ClipboardPageToGenericRecordConverter.resolveObjectByFieldType(ClipboardPageToGenericRecordConverter.java:70) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.avro.ClipboardPageToGenericRecordConverter.convertClipboardPageToGenericRecord(ClipboardPageToGenericRecordConverter.java:51) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.avro.ClipboardPageToGenericRecordConverter.resolveObjectByFieldType(ClipboardPageToGenericRecordConverter.java:67) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.avro.AvroValuesSchemaRegistrySerde.serialize(AvroValuesSchemaRegistrySerde.java:99) ~[d-node.jar:?]
at com.pega.dsm.kafka.api.serde.LazyExceptionHandlingSerDe.serialize(LazyExceptionHandlingSerDe.java:66) ~[d-node.jar:?]
***Edited by Moderator Marije to add Support Case Details***
***Edited by Moderator Marissa to add Product Version***
