OCR methods not working in Pega robotics runtime
I am trying to automate an Windows application which main UI only exposed as a control. For the same I tried using OCR methods (ClickByOCR / HighlightByOcr / SetValueByOCR) which are working through test target method. But the same when I keep in automation flow and run in the runtime where it is not able to detect and perform. Please advise in case of any setting changes are required.
(Note: The same automation/Methods running and working even with Pega robot Inspector.)
