TATA Consultancy Services
Last activity: 8 Nov 2022 0:44 EST
multiple access grup and appliation allow parallel testing
Hi ,
We are using pega verion 7.1.9 . In the application requirement is that , as we have two environment dev and staging. we are using the branches for development among 6 team using multiple access group and application. In staging we have single access group and application to test the code.
As we can not use branches in staging. So do we have any solution if we have multiple access group and applications and allow parallel testing. if it is possible what will be the pros and cons.
@Bandna Gupta It is always better to have a single application in higher environments or you would come across issues directly in production once all the code is merged and deployed as the testing was done individually.
