How to use hybrid mode for Theme Cosmos
We're trying to migrate old applications (built with UI kit) to Theme Cosmos hybrid mode.
According to document as below, we have installed the Conslletation service, and enabled the React UI engieen in PEGA platform.
https://docs-previous.pega.com/user-experience/87/hybrid-mode
We have tested an Cosmos React application, it works fine; which means the Conslletation service is working.
Now, we want to enable hybrid mode for existing applications (Theme Cosmos); but it seems the Conslletation service is not used by hybrid mode, and also we cannot fine the way of using React compoments in section base UI.
So, our questions is:
- How can we use Conslletation service for Theme Cosmos hybrid mode?
- How can the React UI compoments be used with in Theme Cosmos section based UI?
Thanks very much.
