LTIMindtree Limited
Last activity: 21 Sep 2022 6:22 EDT
Decryption not working when moved cases from one environment to another
We have used the Package work and migration wizard to move work from one environment to another.
We have a set of PropEncrypt type Access Policies which refer a HashiCorp Vault keystore and encrypts the property value.
When we created the cases in the source environment and verified the encryption and decryption both works fine. But when we import the same cases into another environment where we have used the same keystore for data encryption, the decryption of data is not working.
We are getting the following error in logs
Failed to decrypt org.bouncycastle.crypto.InvalidCipherTextException: pad block corrupted
Any insight into this problem will be of great help.
Thanks, Tanay
