IBM
CN
Last activity: 9 Sep 2022 23:46 EDT
SOR of data object who has same name as case type
Appreciate for below "simple" questions (however I can not find explicit answer in whole SA course)
What SOR (system of record) is source of a data object who has same name as a case type?
E.g. I create a case type "Car Rental", then the fields I defined in views of this case type (common fields, not data ref ), such as an Integer, a string, are defined in data object with same name of case type, that is, "Car Rental".
However I can not see "Car Rental" data object in the data object list (Under App studio 'Data' function) in which each data object's SOR is shown. So I do not know "Car Rental" data object's SOR.
So what SOR data object "Car Rental" is sourced from?
Local (i.e. Pega) SOR, or, no SOR?
And, if "no SOR", it should mean the fields values are lost after case completed, right?
Many thanks!
