Pega 8.3 will use native Amazon Connect widget or Pega UI
Can someone please answer to the question below?
Pega 8.3 will use native Amazon Connect widget or Pega UI.
- Amazon Connect Widget is used only for UI ?
- Can Pega make use of Amazon Connect API and render the UI ?
- Amazon Connect CCP will be loaded in Iframe ?
- Stream API will be loaded in order to initialize Amazon Conect CCP ?
- Can we use API to send back data to AWS Connect (UpdateContactAttributes API)?
