CYBG
Last activity: 31 Jul 2022 11:44 EDT
Why does 8.7 always open PRPC base application on logon
We are experiencing an issue with 8.7 (this is our first attempt at using an 8.x version, previously we used 7.x). Our operator record has two access gorups defined: ABC:Administrators (ABC being our new application) and PRPC:Administrators. ABC:Administrators is set as default. We are seeing two unwanted behaviours:
1. Despite ABC:Administrators being set as default, the user is always logged into PRPC:Administrators. The user then has to switch applications for ABC application, which works fine from this point onwards.
2. A separate user that only has ABC:Administrators access group is unable to logon due to "not having an alias" to a valid access group (system is preventing me from launching the application at the moment so I can't give exact wording or screenshot, apologies)
Has anyone seen this behaviour before? I suspect it is an issue in the application definition but I am unable to see where.
