Centene Corporation
Last activity: 2 Aug 2022 2:56 EDT
Pega Personal Edition 8.7 UI not shown while run flow
I have created flow in my Implementation application personal edition 8.7. The flow action,section are created in Implementation application and the properties which are populated by page property from data class. The process tab of flow I also checked out create a new work object , select work parties as pyCasemanagementdefault.
when I run the flow it is executed back end but the UI not shown. I upload that image here please check out.
and One more point when I do in Framework Application for test purpose it is working and shown UI .
only issue in Implementation application .
so please let me give the solution
