Capgemini
BR
Last activity: 7 Jul 2022 9:00 EDT
The First Deploy using Deployment Manager
I have a big doubt regarding the use of Pipeline Deployment. When we generate the Development environment artifact and go to the next stage of the Pipeline, which is the QA environment, the first step is to perform the Deploy application step.
In my scenario, I am implementing my first Deploy, that is, the application does not yet exist in the quality environment and the package generated in the development environment contains the application that I want to implement.
I verified that, the pipeline executes the step, to apply the Deploy, however, when it goes to the next step, which is to execute the guardrail, it receives a failure, because it indicates that the Access Group to run this verification, was not found .
{ "pxObjClass":"Pega-Int-Pipeline" ,"pyAccessGroup":"BVTI:Authors" ,"pyApplicationName":"BVTI" ,"pyApplicationVersion":"01.01.01" ,"pyBuildName":"Dep-1TYVK1YWSR1VRH5" ,"pyExecutorActivityClass":"Pega-API-ApplicationManagement" ,"pyExecutorActivityName":"pzGetApplicationsGuardrailMetrics" ,"pyID":"Task-RI1445YS9MER5YG" ,"pyIsTaskSync":"true" ,"pyStatusMessage":"Invalid access group BVTI:Authors" ,"pyStatusValue":"FAIL" ,"pySystemNodeID":"pega-web-75479db5cd-bnl4l" ,"taskType":"CheckGuardrailCompliance" ,"thresholdGuardrailScore":"90" ,"response":{ "executorActivityClass":"Pega-API-ApplicationManagement" ,"executorActivityName":"pzGetApplicationsGuardrailMetrics" ,"ID":"RULE-APPLICATION BVTI 01.01.01" ,"pxObjClass":"Pega-Int-Pipeline" ,"stepPage":null } }
We verified that the application was not implemented, as the action should have been in the previous step, and therefore it does not identify the access group.
My main question is: Is the Deployment Manager prepared to execute the first deploy of an application, through the pipeline that is suggested for configuration? Or is it necessary to manually deploy your first Deploy, so that the application exists in the above environment as QA and Production, so that the CI|CD configuration can make sense.
I say this, because after we put the package manually and then went to apply a new package, the pipeline worked correctly.
