Report Definition asking to optimize .pzInsKey
Hello to everyone, I have a report on a Work class, with sub reports in Work-A and Work-B so I use .pzInsKey to join in Data Access, but pega gives me this warning:
"These properties are not optimized, and using them to join a sub report will result in very poor performance: .pzInsKey. Consult your system administrator about optimizing properties for reporting."
I understand that the property pzInsKey doesn't need to optimize but when I run the report y returns me this fail:
| FAIL | |
| Step Status Info |
There was a problem getting a list: code: 0 SQLState: 42883 Message: ERROR: function pegadata.pr_read_from_stream(unknown, character varying, bytea) does not exist Hint: No function matches the given name and argument types. You might need to add explicit type casts. Position: 30023 |
Has anyone had the same problem? Greetings, Manuel
***Edited by Moderator Marije to change type from General to Product***
