Last activity: 2 May 2022 10:37 EDT
Angular SDK update – SDK-A.87.0 now available!
A new release of the Angular SDK is now available – SDK-A.87.0
Marketplace download: https://community.pega.com/marketplace/components/angular-sdk
Github code repository: https://github.com/pegasystems/angular-sdk
Updates include:
- This is the first release of the Angular SDK for Infinity 8.7.
- Use the corresponding ConstellationJS files found in the SDK-A.87.0 download from Pega Marketplace: https://community.pega.com/marketplace/components/angular-sdk
- The Angular SDK does not include every component that a Constellation application supports. At this time, we provide the most commonly used components to get you started with your application.
Background:
The Angular SDK includes a bridge and DX components that connect the ConstellationJS Engine to an Angular-based design system. The SDK provides a front-end developer friendly NodeJS environment for building an application’s UI using a different design system than Cosmos React. The alternative design system used in the Angular SDK is Angular Material.
