Kaiser
Last activity: 6 Apr 2022 9:25 EDT
Need to run Scenario Test Case rule from our application link
Want to leverage scenario testing feature in our application. To do that we need to run the scenario test case rule from a "pxLink" control in our application screen. We don't want to use PEGA OOTB scenario testing right pane but want to use PEGA OOTB scenario testing rule invocation API.
1. Add a "pxLink" in any flow action under any flow. 2. Create a scenario test case rule for the particular screen. 3. Add a "pxLink" control for that screen. 4. Run the PEGA OOTB scenario test case execution API in the on click of that link (Run Script --> "pega.ui.automation.utils.invokeApi" --> Parameter Name : [apiName:"pega.ui.automation.executor.runTestCasesWithSetup"]). e.g. Follow the Run button on click events of PEGA OOTB pyFunctionalTestCaseRow & pxTestCaseDetails section. 5. Open that screen and click the link. 6. The test case is executing but giving failed result.
