Capgemini
Last activity: 21 Feb 2022 13:07 EST
Installation issue with Pega CRM 8.6
We are facing the following error while installing Pega CRM 8.6 in Pega Labs environment from the self-service portal.
The environment has CDH 8.6 installed.
Any pointer on any known issue/workaround is greatly appreciated.
(nal.util.SystemManagementUtils) ERROR - The following SQL Statement contains a change to a column type. Type Change Not allowed [ STANDARD] [ ] [ ] (nal.util.SystemManagementUtils) ERROR - ALTER TABLE pegadata.pa_account ALTER COLUMN "accountclosedate" TYPE VARCHAR (8) USING "accountclosedate"::VARCHAR (8) [ STANDARD] [ ] [ ] ( internal.util.MoveLog) INFO - FATAL ERROR: Found exception running import: com.pega.pegarules.priv.deploy.DeploymentException: Import failed due to an unallowed type change [java] ALTER TABLE pegadata.pa_account ALTER COLUMN "accountclosedate" TYPE VARCHAR (8) USING "accountclosedate"::VARCHAR (8) [java] Caused by: com.pega.pegarules.pub.PRException: Import failed due to an unallowed type change [java] ALTER TABLE pegadata.pa_account ALTER COLUMN "accountclosedate" TYPE VARCHAR (8) USING "accountclosedate"::VARCHAR (8)
