Centene
Last activity: 23 Mar 2022 2:10 EDT
Business Calendar - Closed Days
Why Pega is not able provide a better user interface for the business calendar? One of our App has 50 different calendars(hundreds of LOB's) per year & we were NOT able to delegate this data instance to business as the user can provide in-valid data and save it.
1) A Date Picker for Closed Day selection Calendar (User can enter Jan1, 2124)
2) Drop downs for the time frame(start & end dates)
3) Property validations while saving the instance
UI experts can give better UI options but this could be a possible UI enhancement
T-Systems ICT India Pvt Ltd Pune
@RajaniKanth Yes, i did selected the calendar which i have created. Also added the same calendar in my Operator ID including Standard Time Zone are same for calendar and my operator id.
Please let me know if you could help me on this to Grade out these closed days on UI portal.
Centene
@Sagar Chavan Please look at the below articles provided by the Marije which will helpful to build your custom control.
Please note that there is already an open Enhancement Request for this: FDBK-26658
It was logged off the back of this Idea.
Regarding the UI side of your question, please see this post.
Can you please confirm that the Idea/FDBK-26658 matches your requirement as well?
Marije
Senior Technical Documentation Specialist
@RajaniKanth Thanks for your valuable inputs.
@RajaniKanth is your issue answered?
Centene
@MarijeSchillern Both the enhancement & the article will be helpful for Sagar's implementation question.
My issue is with the data instance of the business calendar where I were are having issues while delegating the rule to business users. Any typo's & manual errors are causing the Calendar to fail its functionality. We have more than 30 calendars in the application (various business units) and developers/prod support always need to keep monitoring the business calendar for typos. If a UI with validation exists that will be helpful for the business users to do edit.
@RajaniKanth thanks for clarifying your requirement.
This sounds like a valid new product enhancement request.
Could I please ask that you log this as an Idea here? Our SME should be able to comment further and users can upvote your idea to show popularity.
Centene
@MarijeSchillern I thought that is what I did but anyway have posted it again.
https://collaborate.pega.com/idea/business-calendar-data-instance-validations
@RajaniKanth
Even if i update the Closed Days in the requested format it is not getting grade out from UI.
Can someone please help me on how can i update Holidays/Closed Days in Calendar?
Sagar Chavan
