Explore Data- Limited Field with WB Association- ThemeCosmos Hyb
Explore Data has limited fields to join with Assign-Workbasket table in Theme Cosmos application. However, when same thing is done in a Cosmos React application it has more fields.
Solution was to make following changes, post marking the property as Mark as Relevant they are apperaing in Explore Data.
However a few of them are not coming still. .Customer.OrganizationName and .ProcessDefinition.ProcessName are not appearing however rest of the properties listed below appears.
Any clue, is it because of _1 in the column name? Can we create another column as OrganisationName and ProcessName? Will it resolve the issue.
Another thing is all work pools do not appear in Explore Data, even though there are several case type classes. How to make other case type appear in Explore Data?
