Valori
Last activity: 9 Dec 2021 10:28 EST
PEGA API pxresults to pyworkpage how to populate
Situation :
I need data from /D_pxCaseRelatedContent to commit/execute a certain task in the application.
Most of the time i just do a PUT /Cases/ID and than run the assigments/id too commit the task
IF i click save in the front end D_pxCaseRelatedContent values are written too the pyworkpage or if i commit in the frontend
Issue:
I cant insert the data because new rows are create in the list if i do
I cant just press commit because i need to make a selection based on the results from D_pxCaseRelatedContent
If i click save in the frond end everything goes correctly
If i do through the API i doesnt work. Either new data is added or get an error i need to make a selection
Question :
How can i get the data from D_pxCaseRelatedContent in the main case under pyworkpage without create duplicate entries ?
