Not able to open any rule in Pega
We are not able to open any rule in designer studio.
We tried the below steps:
- Tried re-validate & saving the rules
- Tried to create a new rule but not able to
- Checked using an operator with OOTB Pega AccessGroup – same behavior
We could see the below errors in the log while trying to open the rules.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:217) ~[?:?] Line 3511: 2021-12-03 02:24:06,204 [ PegaRULES-Batch-5] [ STANDARD] [ ] [BatchRerate:01.01.01] (rnal.access.RulesetContextImpl) ERROR rajesh.elumai - There was a problem opening a database instance (class: Rule-Obj-Property): Attempting to access a rule with a bad defined-on class: ESTES-CUST-DISPUTES-WORK-DISPUTE. Line 3549: 2021-12-03 02:24:06,216 [ PegaRULES-Batch-5] [ STANDARD] [ ] [BatchRerate:01.01.01] (rnal.access.RulesetContextImpl) ERROR rajesh.elumai - There was a problem opening a database instance (class: Rule-Obj-Property): Attempting to access a rule with a bad defined-on class: ESTES-CUST-DISPUTES-WORK-DISPUTE. Line 3587: 2021-12-03 02:24:06,218 [ PegaRULES-Batch-5] [ STANDARD] [ ] [BatchRerate:01.01.01] (rnal.access.RulesetContextImpl) ERROR rajesh.elumai - There was a problem opening a database instance (class: Rule-Obj-Property): Attempting to access a rule with a bad defined-on class: ESTES-CUST-DISPUTES-WORK-DISPUTE. Line 3625: 2021-12-03 02:24:06,225 [ PegaRULES-Batch-5] [ STANDARD] [ ] [BatchRerate:01.01.01] (rnal.access.RulesetContextImpl) ERROR rajesh.elumai - There was a problem opening a database instance (class: Rule-Obj-Property): Attempting to access a rule with a bad defined-on class: ESTES-CUST-DISPUTES-WORK-DISPUTE. Line 3663: 2021-12-03 02:24:06,227 [ PegaRULES-Batch-5] [ STANDARD] [ ] [BatchRerate:01.01.01] (rnal.access.RulesetContextImpl) ERROR rajesh.elumai - There was a problem opening a database instance (class: Rule-Obj-Property): Attempting to access a rule with a bad defined-on class: ESTES-CUST-DISPUTES-WORK-DISPUTE. Line 3701: 2021-12-03 02:24:06,237 [ PegaRULES-Batch-5] [ STANDARD] [ ] [BatchRerate:01.01.01] ( internal.mgmt.Executable) ERROR rajesh.elumai - Exception Line 3737: 2021-12-03 02:24:06,238 [ PegaRULES-Batch-5] [ STANDARD] [ ] [BatchRerate:01.01.01] ( internal.mgmt.Executable) ERROR rajesh.elumai - Exception Line 3782: 2021-12-03 02:24:13,870 [ PegaRULES-Batch-4] [ STANDARD] [ ] [BatchRerate:01.01.01] ( internal.mgmt.Executable) ERROR rajesh.elumai - Exception Line 3823: 2021-12-03 02:24:18,335 [ default task-35] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-Application'. Line 3823: 2021-12-03 02:24:18,335 [ default task-35] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-Application'. Line 3824: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 3944: 2021-12-03 02:24:40,235 [ default task-19] [TABTHREAD0] [ ] [sAppFactory:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 3944: 2021-12-03 02:24:40,235 [ default task-19] [TABTHREAD0] [ ] [sAppFactory:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 3945: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4065: 2021-12-03 02:25:03,712 [ default task-11] [TABTHREAD0] [ ] [ DMSample:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 4065: 2021-12-03 02:25:03,712 [ default task-11] [TABTHREAD0] [ ] [ DMSample:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 4066: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4186: 2021-12-03 02:25:34,541 [ default task-5] [TABTHREAD0] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 4186: 2021-12-03 02:25:34,541 [ default task-5] [TABTHREAD0] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 4187: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4307: 2021-12-03 02:25:40,925 [ default task-48] [TABTHREAD1] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-AccessGroup'. Line 4307: 2021-12-03 02:25:40,925 [ default task-48] [TABTHREAD1] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-AccessGroup'. Line 4308: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4428: 2021-12-03 02:25:59,383 [ default task-18] [TABTHREAD2] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-Async-JobScheduler'. Line 4428: 2021-12-03 02:25:59,383 [ default task-18] [TABTHREAD2] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-Async-JobScheduler'. Line 4429: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4550: 2021-12-03 02:27:11,335 [ default task-52] [TABTHREAD1] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-Obj-FlowAction'. Line 4550: 2021-12-03 02:27:11,335 [ default task-52] [TABTHREAD1] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-Obj-FlowAction'. Line 4551: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4671: 2021-12-03 02:28:39,270 [ default task-50] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 4671: 2021-12-03 02:28:39,270 [ default task-50] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 4672: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4792: 2021-12-03 02:32:47,160 [ default task-7] [TABTHREAD4] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 4792: 2021-12-03 02:32:47,160 [ default task-7] [TABTHREAD4] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 4793: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 4919: 2021-12-03 02:33:05,347 [ default task-59] [ ] [ ] [ ] (ngineinterface.service.HttpAPI) ERROR citipoclb.estesinternal.com| Proprietary information hidden - Exception occured: Line 4992: 2021-12-03 02:40:13,772 [ default task-34] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 4992: 2021-12-03 02:40:13,772 [ default task-34] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 4993: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 5105: 2021-12-03 02:40:17,149 [ default task-16] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 5105: 2021-12-03 02:40:17,149 [ default task-16] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 5106: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 5218: 2021-12-03 02:40:20,675 [ default task-61] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 5218: 2021-12-03 02:40:20,675 [ default task-61] [TABTHREAD3] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 5219: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 5334: 2021-12-03 03:07:43,980 [ default task-5] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5334: 2021-12-03 03:07:43,980 [ default task-5] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5335: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 5455: 2021-12-03 03:08:38,141 [ default task-26] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5455: 2021-12-03 03:08:38,141 [ default task-26] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5456: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 5570: 2021-12-03 03:09:11,252 [ default task-60] [TABTHREAD1] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5570: 2021-12-03 03:09:11,252 [ default task-60] [TABTHREAD1] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5571: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 5738: 2021-12-03 09:43:03,029 [ default task-5] [ STANDARD] [ ] [ ] (ngineinterface.service.HttpAPI) ERROR citipoclb.estesinternal.com| Proprietary information hidden - Exception occured: Line 5809: 2021-12-03 09:43:53,859 [ default task-14] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'pyNewResults' of class 'Rule-Obj-Activity'. Line 5809: 2021-12-03 09:43:53,859 [ default task-14] [TABTHREAD0] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'pyNewResults' of class 'Rule-Obj-Activity'. Line 5810: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 5931: 2021-12-03 09:48:50,169 [ default task-59] [TABTHREAD2] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5931: 2021-12-03 09:48:50,169 [ default task-59] [TABTHREAD2] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 5932: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 6053: 2021-12-03 09:49:15,448 [ default task-43] [TABTHREAD2] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 6053: 2021-12-03 09:49:15,448 [ default task-43] [TABTHREAD2] [ ] [BatchRerate:01.01.01] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden rajesh.elumai - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Rule-HTML-Section'. Line 6054: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 6176: 2021-12-03 09:57:55,005 [ default task-53] [TABTHREAD0] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden ajith.kumar - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 6176: 2021-12-03 09:57:55,005 [ default task-53] [TABTHREAD0] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden ajith.kumar - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-Operator-ID'. Line 6177: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' . Line 6297: 2021-12-03 09:59:09,844 [ default task-1] [ STANDARD] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden ajith.kumar - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-ServicePackage'. Line 6297: 2021-12-03 09:59:09,844 [ default task-1] [ STANDARD] [ ] [ PegaRULES:8] (eFormMain.Rule_Obj_Flow.Stream) ERROR citipoclb.estesinternal.com| Proprietary information hidden ajith.kumar - Section 'RuleFormMain' execution error on page 'RH_1' of class 'Data-Admin-ServicePackage'. Line 6298: com.pega.pegarules.pub.PRRuntimeException: Error evaluating visible when ' wxpzShowDelegation' .
