Shawbrook Bank
Last activity: 25 Nov 2021 10:43 EST
Application deployment along with Robot manager into higher environments
We have 3 environments - Dev, UAT and Prod.
Case management application also has Robot Manager (RM) as build on application in DEV.
RM connectivity to robot runtime is working and also I can see the above three environments in the RM portal. Now the question is, when I move the Case management application from Dev to UAT and eventually into Production, should I also move RM application? If yes then how does this work in any environment apart from Dev?
Thanks.
Gayathri
