Hong Kong Exchanges and Clearing Limited
HK
Last activity: 31 Oct 2022 21:49 EDT
pxInsName (using pyGUID key) is null in Data class table during Create, but it populated after Update
Can someone help with this issue? https://community.pega.com/support/support-articles/pxinsname-not-inserted-pega-data
I noticed that if the Data record is newly created both pyGUID, pzInsKey are populated but the pxInsName is null
But when i update and save the same Data record, the pxInsName is then populated
I see no issues with my records when i try to process or display it.
Should we be concerned that is it empty at create and can do something to fix?
NOTE: Everything is same in the mentioned article: Data class, ticked the pyGUID option
