GFT
BR
Last activity: 22 Sep 2021 10:01 EDT
Not able to use java lamba in Pega 8.5
I'm trying to run some Java 8 lambda expressions in a function in Pega 8.6, Personal Edition for a PoC, but am getting the following error message:
Method references are allowed only at source level 1.8 or above
The code I am running trying is:
Files.walk(Paths.get(destDirPath)) .filter(Files::isRegularFile) .map(Path::toFile) .forEach(File::delete);
Do I need to change any configuration to be able to run this?
