Santander F1rst
BR
Last activity: 13 Sep 2021 14:14 EDT
BIX Extracts running multiple times on different nodes
We have a set of 100+ extracts to run in 5 servers in production.
We have set up an Agent that will run these extracts on blocks of 10 each 10 minutes (so 10 starting at 0400am, 10 starting at 0410am, 10 starting at 0420am, etc) daily.
These 5 servers in production are only for BIX extracting and are categorized under a BIX node type and all instances of pxExtractDataWithArgs running each extract are mapped to be run on this node type and in Advance mode with the option "Run this agent on only one node at a time" set as true.
We are expecting that each extract runs only once in one of the servers.
The issue here is that we are experiencing most if not all extracts to be running more than once in different servers.
PEGA version: Pega 7.3.0
BIX version: 07-10-31
Attached is an example of the Agent rule and a pivot table from the log showing more than one execution for each extract rule.
