Stella
Last activity: 27 Aug 2021 6:10 EDT
Declarative Expression not firing
I have a declarative expression on a property that is dependent upon another property.
The expression is set whenever inputs change regardless of the page
I perform an Obj-Open-By-Handle to open a work object and lock it. I then set the property that the expression is dependent upon to a hard coded value. Why does the expression not fire?
If instead I perform a page new on the work class and set the property the expression is dependent on the expression then fires.
