Import zip file giving error- A problem encountered.
While importing the jar encountered with below error- A problem encountered while it shows below error in logs. If anyone faced the same issue can guide on this.
-Import started - Operation Status: Preparing archive Import Parameters... + Fail On Error: true + Only Insert: false + Perform Fast Install: false + Disable Inference Engine: false - Created new restore point: RP_20210805T030025.640_zypv - Operation Status: Importing Instances - Processed 121 of 161 (75.16%): 1 committed, 120 skipped, ? seconds remaining - Encountered an error when saving instance "HISTORY-RULE RULE-OBJ-HTML @BASECLASS EXPORTARCHIVEDDATATOEXCELCIG #20210702T105326.997 GMT!20210805T070030.902 GMT" of class History-Rule
