Bank Of America
Last activity: 20 Aug 2021 5:33 EDT
Difference in Results Data returned by Report Definition
Hello All,
There was this different behavior observed when report definition was executed in work- class with pyID as column vs pzinskey as column in Data- class.
For work- pega is able to show results where as for data- it is throwing a runtime error as follows.
Error:
The report has an abstract class ['Data-'] with no data as a source, and cannot be resolved to a concrete class containing data
Rules observed in Trace:
pxretrivereportdata step 36 is failing
version pega 8
Verified class definition of both and both are similar where as DB mapping rules also been in system with pc_work,pr_data ,not able to identify root cause.
can any one kindly through some light on this.
Dileep.N
Hi @Nerella Dileep
Could you please provide us screen shots of the class definitions of both classes so we could check whether your Data- class in not an abstract class as pointed out in the error message?
Thank you,
