Optum
Last activity: 10 Jun 2021 3:52 EDT
Declare rule to trigger custom activity
Hello everyone
My requirement is to create a declare trigger on Assign-.pxUrgencyAssign where I need a custom activity to run whenever there is a saved change to pxUrgencyAssign. But I don't need the custom activity to run when only the instance is saved and the urgency is same as earlier. How do I acheive this ? Please help
Best Regards
@SouravD6325
You can use the Saved and .. option in the declare trigger rule. You can add the pxUrgencyAssign as the property which you want to watch . Check the StatusElapsedCalculation declare trigger which is available OOTB for reference.
