NullPointerException on accessing the case narrative on Audit tab in V7.3
When we open case and navigate to Audit--> Case Narrative tab the below error is encounter for random cases.
"The Flow Action pre-processing activity pzFetchSubcaseAttachments failed: java.lang.NullPointerException"
In tracer I found that this pzGetAttachmentData activity 2nd step is failing to open the Object.
please suggest any approach how to fix this issue.
| FAIL | |
| Step Status Info |
Unable to open an instance using the given inputs: DATA-CORR-EMAIL XX-XX-XX ABC-01!20110414T202340.943 GMT |
***Edited by Moderator: Pooja Gadige to change content format from Discussion to Question, add platform capability tag***
