Rules Cube Inc.
Last activity: 28 Apr 2021 11:28 EDT
Error working with local path: Connect-FTP method failing
Connect-FTP method is failing when we tried to access the file from the local server folder and move to an external root client ftp location. Everything is working fine but ftp method is failing in the tracer.
For our business usecase if ftp transmission fails we need to send an email to our support team. So, the method should not fail if there is no issue.
Please let me know what could be wrong with the configuration?
LocalFile at run time is getting as /usr/local/tomcat/work/sync-data/MemberFiles/Name/PositiveFiles/0T20210426testcsv.pgp
Similar issue: https://community.pega.com/support/support-articles/connect-ftp-error-working-local-path
Fail Error in tracer: Error working with local path: '/usr/local/tomcat/work/sync-data/MemberFiles/Name/PositiveFiles/0T20210426test.csv.pgp',
Venkatesh
