OCR runtime exception on abbyyTextExtractor
Hi all,
i am trying the OCR package on a PRPC 8.5 sandbox environment to test the functionalities. While runtime i am getting following exception in tracer:
Failed to compile generated Java com.pegarules.generated.activity.ra_action_abbyytextextractor_f4e3334cd68d6a0f946a9e19b3aff492: ----------
1. ERROR in /com/pegarules/generated/activity/ra_action_abbyytextextractor_f4e3334cd68d6a0f946a9e19b3aff492.java (at line 234)
class FileReader implements com.abbyy.FREngine.IReadStream {
com.abbyy cannot be resolved to a type
2. ERROR in /com/pegarules/generated/activity/ra_action_abbyytextextractor_f4e3334cd68d6a0f946a9e19b3aff492.java (at line 244)
public int Read(com.abbyy.FREngine.Ref<byte[]> ref, int count) {
I am calling an activity performOCR where i am preparing the data and forward the data to the reader while using Call Data-AbbyyFineReader.ExtractTextViaOCR! So there is the java code which worked before on another machine. But now i am getting 63 errors from that code snipet.
Might there be a problem with the JVM?
Thanks a lot
