ING
Last activity: 16 Feb 2021 7:27 EST
Unable to execute shell script from activity or function from Pega 8.4.3
Hi Team,
We have some requirement where zip file needs to be moved from pega server location to external application location by using XFB automation. As part of this requirement, we are trying to execute shell script by using an activity or function. But its not allowing and throwing below the error message.
"Java code injection pattern identified in the java source code. Vulnerable code detected: Runtime.getRuntime()"
Kindly suggest if there is any alternate approach for the same.
Anjaneyulu
